Staro 13.02.2008., 23:34   #1
Danijel1803
Danijel1803's Avatar
Lokacija: Tenja
Postovi: 164
Catalyst 8.2
http://ati.amd.com/support/driver.html
Resolved Issues for the Windows Vista Operating System
This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows Vista. These include:
Enemy Territory: Quake Wars: Corruption is no longer noticed when editing levels. Further details can be found in topic number 737-32141
World of Warcraft: Flickering and missing objects are no longer noticed when playing the game in OpenGL mode. Further details can be found in topic number 737-32140
.NET Framework an Unhandled Exception error no longer occurs when upon booting or re-booting the system. Further details can be found in topic number 737-32115
A white dot no longer appears on the windows desktop when launching the Catalyst Control Center. However, this issue may still be experienced under the Windows XP operating system. Further details can be found in topic number 737-31715
Audio stutter is no longer noticed when using the HDMI connector. Further details can be found in topic number 737-32118
Running the Spanish version of the Windows operating system no longer results in the Catalyst Control Center option failing to be available when right-clicking the Windows desktop menu bar. Further details can be found in topic number 737-32125
The Catalyst Control Center options are no longer missing for the secondary extended display when hot unplugging and hot plugging the display device. Further details can be found in topic number 737-32126
Native CrossFire™ can now be enabled when the primary display device is connected to the master card using a CV or TV. Further details can be found in topic number 737-32131
Enabling clone mode on a system containing an ATI Radeon™ X1200/1250/1270 series of product no longer results in the resolution and color depth changing to 640x480 8bpp. Further details can be found in topic number 737-32132
Playing DVD content using the Windows Media Player no longer results in the playback being choppy. Further details can be found in topic number 737-32136
Hot plugging and hot-unplugging an HDMI display device multiple times during one windows session may result in the display device failing to be detected. Further details can be found in topic number 737-32137
Enabling CrossFire™ on a system containing an ATI Radeon™ X1950 series of product no longer results in the Windows Vista operating system intermittently failing to respond. Further details can be found in topic number 737-32138
The lower portion of the Catalyst Control Center is no longer cropped when changing the display resolution from 640x480 to 1920x1200. Further details can be found in topic number 737-32139
An error message is no longer displayed when attempting to set both the primary (HDMI) display device and secondary (DVI) display device to a display resolution of 1280x1024. Further details can be found in topic number 737-32142
The Windows XP Professional x64 Edition operating system no longer reboots when installing the T200 driver. Further details can be found in topic number 737-32143
Setting the DPI to 120 in the Display Properties no longer results in the combo box being cut-off. Further details can be found in topic number 737-32144
The antenna signal strength is no longer reported by Vista Media Center as low. Further details can be found in topic number 737-32145
A black line is no longer noticed when using VIVO for capturing and using Radeon™ HD 2900. Further details can be found in topic number 737-32146
The PAL-N video captured from the ATI Radeon™ HD2900 no longer displays colors and with vertical bars. Further details can be found in topic number 737-32147
The T200 NTSC capture card no longer fails to capture the Closed Captioning signal. Further details can be found in topic number 737-32148
A Reduce DVI frequency on high-resolution displays option no longer appears when an HDMI display device is connected using an HDMI-DVI cable. Further details can be found in topic number 737-32149
Resolved Issues for the Windows XP Operating System
This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows XP. These include:
Doom3: Running an OpenGL application with CrossFire™ enabled and AA set to 16x no longer results in corruption being noticed when the display resolution is set to 2048x1536 or higher. Further details can be found in topic number 737-32150
TianXia2: Launching the game no longer results in the Windows XP operating system rebooting. Further details can be found in topic number 737-32152
Playing an H.264/VC1 title on a system with a display resolution higher than 1440x900 no longer results in the content failing to play in hardware mode. Further details can be found in topic number 737-32154
Changing the display resolution when CrossFire™ is enabled no longer results in the running 3D application failing to respond. Further details can be found in topic number 737-32155
Zadnje izmijenjeno od: Jelc. 14.02.2008. u 02:34.
Danijel1803 je offline   Reply With Quote
Staro 13.02.2008., 23:40   #2
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,508
Ajmo pokusni kunići!
Staro 13.02.2008., 23:53   #3
Thommy
Thommy's Avatar
Postovi: 469
hm da, ja sam bio pokusni za 8.1 pa sam vracao na stare drivere sad neka netko drugi testira
Thommy je offline   Reply With Quote
Staro 13.02.2008., 23:54   #4
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,508
Ja sam na 7.11 i čekam... :-)
Staro 13.02.2008., 23:59   #5
d0X
Kostolomac
d0X's Avatar
Postovi: 1,570
ja čekam omegu da izbaci nove drajvere, zasad na njegovim 7.12
PSN Steam
Staro 14.02.2008., 00:04   #6
Fleks
JDM
Fleks's Avatar
Datum registracije: Sep 2004
Postovi: 6,137
Skidam
javim kroz pol sata kakvi su
Staro 14.02.2008., 00:14   #7
ShebY
ShebY's Avatar
Lokacija: Velika / Osijek
Postovi: 1,442
Evo skino, instaliro i..
Sve radi noramalno, probo witchera čini mi se da ima malo više frejmova ili je to možda palcebo efekat XD, nema nikakvih kvadratića il tak nešto, vrati sa Clear Type na Standard i sve OK sa bojama u firefoxu, 3d čmark javim skoro...
Evo i 3DČmark 21 bod manje nego sa 7.11
Zadnje izmijenjeno od: ShebY. 14.02.2008. u 00:35.
Staro 14.02.2008., 00:26   #8
Danijel1803
Lokacija: Tenja
Postovi: 164
Autor ShebY Pregled postova
Isto primjetio nema više kvadratića,sad Gpu-z grafe vidi kao HD 3800 series a prije je bilo HD 3870. Još da im se obistini ono 30% boljitka za CrossFire i ja zadovoljan ...
Staro 14.02.2008., 00:35   #9
jimi
Postovi: 80
Danijel1803
Stari moj, koji komp! Koliko te došel?
Sorry na offtopic, al komp je ti bogca, brz!
jimi je offline   Reply With Quote
Staro 14.02.2008., 00:37   #10
Danijel1803
Lokacija: Tenja
Postovi: 164
Autor jimi Pregled postova
Danijel1803
nisam sve još stavio na papir al je puuunno vjeruj !
Staro 14.02.2008., 00:38   #11
AuX
AuX's Avatar
Postovi: 367
na nije lose mora da ga je doso jedno 15k sa svime sta pise ali nije bitno mogao si ga pitati preko PM-a a ne da tu OT pokreces
AuX je offline   Reply With Quote
Staro 14.02.2008., 00:44   #12
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Ajde, ajde, vi sa flatovima skidajte. Ja siromah sa 3GB limita moram cekat iskustva drugih.
Staro 14.02.2008., 00:48   #13
Facelessone
Facelessone's Avatar
Postovi: 4,205
skidam skidam, za pol sata post
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 14.02.2008., 00:51   #14
ShebY
ShebY's Avatar
Postovi: 1,442
Autor SRV Pregled postova
Rofl ja imam 1Gb pa sam skinio iste sekunde...
Staro 14.02.2008., 00:53   #15
Fleks
JDM
Fleks's Avatar
Postovi: 6,137
Mah. Isto shranje ko i prije kolko vidim. 3dmark 21 bod manje il tako nesto
@SRV: Budi sretan da si ti na ono brdo i dovukli kabel, a ti bi jos i flat
Staro 14.02.2008., 00:54   #16
Thommy
Thommy's Avatar
Postovi: 469
instaliro sam nije vrag dal mira i radi sve kak treba nema nikakvih kockica i firefoxu su sve boje kako trebaju biti ... kad stignem budem 3dmark odvrtio ... meni gpu z pokazuje uredno HD3870
edit: ja sam dobio 46 bodova vise u 3D Mark-u
slike stavljam u top 10 3DM poboljsao sam rezultat
Zadnje izmijenjeno od: Thommy. 14.02.2008. u 01:29.
Staro 14.02.2008., 00:58   #17
ShebY
ShebY's Avatar
Postovi: 1,442
Autor Fleks Pregled postova
Da.. ma ljudi previše očekujete od ti vozača (drivera) pa nemogu oni sad napravit drivere da imate 2000k više bodova. Sve što mogu, a to i rade je dat podršku za neke nove igre,grafe i ispravit neka sranja iz prijašnjih verzija kao famozni "kvadratić"
Ja sam sretan što su ispravili ovo sa crvenim slovima zato jer mi sa clear type izgledaju slova mutno
Edit: GPU-Z meni isto piše samo 3800 series, ali mi ni brzinu vrtnje venta neočitava točno..
Staro 14.02.2008., 01:11   #18
Facelessone
Postovi: 4,205
nda...... 60bodova manje, nema kockice :lol:
AMD Ryzen 7 5700X
BQ Pure Rock
500GB Crucial MX500
Fractal Define R4
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate SkyHawk 6TB
Staro 14.02.2008., 01:20   #19
Fleks
JDM
Fleks's Avatar
Postovi: 6,137
credits needed to fix bug = 60 points
Staro 14.02.2008., 01:29   #20
ShebY
ShebY's Avatar
Postovi: 1,442
nisi napiso kaj valuta? 3870,3850 ili nešto od 2x00
On toppic el izštla možd koja igra da nudi podršku za DX 10.1 da se to isproba..
Staro 14.02.2008., 01:45   #21
Fug33
Lokacija: OS
Postovi: 412
instalirao drivere
crysis i dalje steka
sve ostalo radi
:P
nema dx10.1 igre na trzistu
nit ce je bit kojih godinu dana
Fug33 je offline   Reply With Quote
Staro 14.02.2008., 02:00   #22
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Ja drivere "rijetko" mijenjam, tek svakih tri mjeseca. Ovi koje imam su 7.12, 8.1 sam preskocio, tako da ciljam na 8.3
Zato cekam feedback ekipe, nije to samo zbog tih 20MB.
Staro 14.02.2008., 10:53   #23
Lud76
Leteći medvjedić
Lud76's Avatar
Postovi: 1,204
OK na 7.11 sam i čekam dalje...
Lud76 je offline   Reply With Quote
Staro 14.02.2008., 10:58   #24
Kapica
Lokacija: Varazdin
Postovi: 108
vidim, nitko nije primijetil...
popravljen prikaz boja koji se javljal u firefoxu...
ak je itko prije imal takav problem, meni je rijesen s 8.2
Kapica je offline   Reply With Quote
Staro 14.02.2008., 11:06   #25
Fleks
JDM
Fleks's Avatar
Postovi: 6,137
Autor Lud76 Pregled postova
A što čekaš?
Staro 14.02.2008., 11:08   #26
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
Da, mnogi su to primjetili, mada ja taj problem nisam imao ni na 7.11 ni na 7.12.
Staro 14.02.2008., 11:24   #27
IGoR_2803
IGoR_2803's Avatar
Lokacija: N/A
Postovi: 771
Autor Kapica Pregled postova
itekako sam primjetil... bilo je i vrijeme da to srede, jer mi je već pomalo kidalo živce...
Staro 14.02.2008., 14:23   #28
Bartuc
The All Seeing Eye
Bartuc's Avatar
Postovi: 1,103
U Release Notes-u nema nikaj zanimljivo za moje potrebe, tak da pratim SRV-ovu šprancu
Na 7.11 sam i čekam 8.3 Možda čak i 8.4
Bartuc je offline   Reply With Quote
Staro 14.02.2008., 14:30   #29
Micko
Peachwize=mudra breskva
Micko's Avatar
Lokacija: Ri
Postovi: 210
Dali se gdje spominju poboljšanja performansi dvoglave aždaje
Micko je offline   Reply With Quote
Staro 14.02.2008., 14:33   #30
Bartuc
The All Seeing Eye
Bartuc's Avatar
Postovi: 1,103
Piše da ima neki boost u Crossfire-u, ali za x2 nisam ziher jel vrijedi isto!?
