Staro 27.12.2007., 13:25   #1681
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
Ja nove win stavljao pa se nesto shebalo i sada sve isto od nule tako da mislim nista od cetvorke sljedecih mjesec dana....
Nekak i nisam nabrijan da idem ponovo skupljati levele ispocetka...
Master: E7200, 3MB L2, M0 {TT Big Typhoon VX @3500mhz}/Gigabyte P35-DS3P/2x1GB SuperTalent CL4 Overclock DDR2 800Mhz + 2GB Kingmax/Coolermaster Extreme Power 430W/XFX 8800GTX {Arctic Cooling Accelero Extreme} /Seagate Barracuda 250GB/Pioneer DVD-RW/
Periferija: LG W2242T 22"/Logitech X-230/Razer - Death Adder/LCD TV Toshiba WL66Z Regza 32"/Thrust Keyboard+Mouse Wifi/Logitech ChillStream/Sharkoon Rebel12
Gjurovski je offline   Reply With Quote
Staro 27.12.2007., 13:38   #1682
Amdejac
Amdejac's Avatar
Datum registracije: Jun 2003
Lokacija: Kuća
Postovi: 5,417
Stavio sam za download PunkBuster Setup v.3.0.
Meni radi savršeno.
Asus N750JK (Upgrade)
MBO: Asus N750JK
RAM: 2x8 Gb PC3-12800 DDR3
PSU: Asus Li-ion 69486 mWh
OS: Windows 8.1
Monitor: 17,3 LCD (FHD)
Net: Intel AX210 NGW
Net: TP-Link Archer TX55E
PSU: Xilence, Bronze 550W
Monitor: Samsung
VGA: ATI RX570, 4 Gb
HDD: NVMe 1 Tb, Patriot
PSU: Inter-Tech SP750
Monitor: Samsung
Amdejac je online   Reply With Quote
Staro 27.12.2007., 18:17   #1683
PhnX
PhnX's Avatar
Lokacija: lepoglava
Postovi: 182
meni ne radi uopce.
puna poruka glasi:
PhnX PunkBuster kicked player "PhnX" (for 0 minutes)... RESTRICTION:
Service communication failure: PnkBstrB:exe initialization failed
pb je apdejtan.
PhnX je offline   Reply With Quote
Staro 27.12.2007., 20:11   #1684
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
Autor PhnX Pregled postova
meni ne radi uopce.
puna poruka glasi:
pb je apdejtan.
Odi ovdje:
http://www.evenbalance.com/index.php?page=pbsvcfaq.php
U prvom dijelu
What is all this about new PunkBuster services?
tamo gdje piše here downloadaj pbsvc.exe - to je servis koji vozi PnkBstrA i PnkBstrB - i instaliraj ga.
Imaš tamo i test services - sve ti mora biti zeleno da je u redu.
Iako ti nekad napiše da je test uspješan u stvari je neuspješan ako je išta u crvenome.
IT IS EASY TO KILL FIVE HUNDRED NOOBS. BUT THERE IS STILL FIVE HUNDRED AND ONE AND YOU ARE OUT OF AMMO!
1oo1
NOOB - POWER IN NUMBERS!
Good judgment comes from bad experience and a lot of that comes from bad judgment.
MisterM je offline   Reply With Quote
Staro 28.12.2007., 00:12   #1685
PhnX
PhnX's Avatar
Lokacija: lepoglava
Postovi: 182
fala,tu je bil problem.
Staro 29.12.2007., 02:42   #1686
alengrosevic
alengrosevic's Avatar
Postovi: 3,794
COD4 savegame
Ovak, igral sam doticnu igru na multyu i dosao do levela 29 te sam bio prisiljen reinstalirati sistem. prije toga sam direktorij players sazipao i spremio na drugi disk. nakon reinstalacije sam instalirao igru, stavio zakrpu 1.4 (prije je bila 1.3) i u direktorij players otpakirao sadrzaj. Kad sam nakon toga usao u igru i pisao je neki error, bla bla bla i kao mora se profil resetirati i vratiti na 0, znaci bez XP-a. Probao sam i stvoriti jedan lijevi profil i ovoga raspakirati kraj njega pa odabrati u igri drugi profil (zeljeni) da ga loadam ali bez uspjeha, uvijek ista poruka.
Jel ima nade da taj sacuvani profil loadam, jer mi se ne da sve ispocetka prolaziti, vec sam si oruzja nastimao i sve...
thnx
Staro 29.12.2007., 02:54   #1687
tutix
tutix's Avatar
Postovi: 4,069
COD4 je postao Igra godine u BUGu. Još na početku časopisa neki lik u pismima čitetelja komentira kako je ta igra mogla dobiti 96% u prošlomjesečnoj recenziji, kako su mogli tak visoku ocjenu dat, Crysis ovo, Crysis ono, Crysis bolji, Crysis roka. Ja pomislio drago al' lik se potpiso sa Hrvoje. I najjači mi komentar BUGovaca na sve to: A tek kad vidiš koja nam je igra godine . LOL porasli su mi očima. To je kvalitetan, pristojan skur.
Staro 29.12.2007., 03:36   #1688
TheEmpress
TheEmpress's Avatar
Lokacija: Sveta Nedelja
Postovi: 24
Pa, kak je ovdje krenulo, i PcPlay će proglasit CoD4 igrom godine.
“I think we can put our differences behind us. For science. You monster.”
TheEmpress je offline   Reply With Quote
Staro 29.12.2007., 13:47   #1689
Tri upitnika
Tri upitnika's Avatar
Lokacija: blizu wc-a
Postovi: 99
pozdrav,
imam jedan problem kaj se tiče multiplayera...
nabavio ja igricu,idem si instalirat,sve super,i reko,ajd idem prvo preć single,neću ni otvarat multi dok ne predjem single,i sve u redu, u jednom danu sam prešao singleplayer,i onda odo ja upalit multi,i dogodilo mi se ono kaj mi se već prije dogadjalo na nekim programima....a to je: kliknem 2 put na ikonicu,i onda se onaj pješćani sat pokaze odma(kao da ide otvarat igru),ali u roku jedne sekunde nestane pješćani sat,i ništa....komp šuti,kao da mu nisam reko da otvori igru,...samo miruje....neće upalit....to mi se dogadjalo na hrpu igrica prije,ali i na programima...ne znam dal se to vama dogadja? i šta to je? kako to riješit
Tri upitnika je offline   Reply With Quote
Staro 29.12.2007., 13:47   #1690
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
thnx
Nisam siguran ali mislim da ne jer si promjenio verziju sa 1.3 na 1.4.
Inače ako se napravi backup config_mp i mpdata trebalo bi raditi.
Autor Tri upitnika Pregled postova
pozdrav,
Možda reinstall windowsa....
1oo1
Staro 29.12.2007., 14:02   #1691
Destructo
Destructo's Avatar
Lokacija: Internet
Postovi: 124
Autor Gjurovski Pregled postova
Zato drugi put sacuvaj mpdata i svoj cd-key i nakon instalacije igre samo vratis mpdata file u folder igre i to je to.
Jucer sam dobio novi cin (sad sam Level 51) i mucim se otkljucati zlatni skin za M60E4 machine gun.
BTW, ako nekome treba original igra, može si naručiti preko moje webstranice za samo 149kn.
U dva dana sam već isporučio 33 originalna cd-keya pa požurite po svoj primjerak dok ne ostanem bez..
Pozdrav!
Destructo je offline   Reply With Quote
Staro 29.12.2007., 14:07   #1692
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
destructo - lakše sa reklamom, i još mi nije jasno kako ti prolazi onaj oglas na tržnici, pošto je reklamiranje zabranjeno...
no, i meni dolazi cdkey, i sad problem, Rank sam napravio na drugom CD keyu, i sad kad metnem original, odoše rankovi, jel? pas mtr...
Staro 29.12.2007., 14:16   #1693
Tri upitnika
Postovi: 99
ma sad sam nedavno tek i instalirao xp,prije tjedan dana (mijenjao sam komp)
Staro 29.12.2007., 14:37   #1694
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,474
meni fali još 12 headshotova do red tigera sa G36C kad to napravim, krecem sa origigi keyem
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 29.12.2007., 14:42   #1695
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
odpočetka opet? ili to u single playeru igraš?
Staro 29.12.2007., 17:41   #1696
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,474
a sada imam ovaj "sređeni" i na njemu stvarno mac toga otkljucano, jos samo da dobijem red tigera za G36C, i onda cu ga umiroviti, i krenuti ispocetka sa origigi
Staro 29.12.2007., 18:26   #1697
mymoon
nautic expert
mymoon's Avatar
Lokacija: Rijeka-Opatija, negdje između
Postovi: 1,386
ne znam. ja sam dva puta mijenjao key i ostao mi je netaknut rank. nisam trebao ništa dirati, samo sam key mijenjao...
mymoon je offline   Reply With Quote
Staro 29.12.2007., 19:19   #1698
Tri upitnika
Postovi: 99
i zaboravio sam reć da sljedeći put kad idem upalit multiplayer onda mi se pojavi prozor u kojem me pita da li želim pokrenuti igru u safe modu,ja kazem da,ne otvori,ja kazem ne,ne otvori....
Staro 29.12.2007., 19:30   #1699
Tri upitnika
Postovi: 99
sve uredu,riješio sam problem skidanjem patcha,i sad mi normalno ulazi u multiplayer,ali zato više ne ulazi u singleplayer,,,al jbg,nema veze,singleplayer sam prešao...sam još jedno pitanje zbog kojeg sam ipak mislio otvarat singleplayer....kaj je onaj arcade mod?
šta s onim bodovima mogu postić?
Staro 29.12.2007., 22:10   #1700
croi1
croi1's Avatar
Lokacija: Varazdin
Postovi: 253
Zašto bi vi išli ponovno bildati levele?
Jednostavno ukucajte novi cd-key i preko konzole se spojite na neki server i igrajte malo da skupite neki xp (ja sam odigro 1 cjelu mapu i pričekao drugu) i tad možete izaći iz igre a vaš level če ostati isti a cd-key promjenjen.
Meni tako radi.
Pošteni trgovac: 17/17
croi1 je offline   Reply With Quote
Staro 29.12.2007., 22:40   #1701
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
Autor Renesis Pregled postova
Daj baš za probu spremi mpdata i mp config i probaj primjenit na orginal - ubaci i novi key u registry.
Ništa posebno. Igraš i skupljaš bodove u igri za svaki kill i slično. Još jedan način za proči SP....
1oo1
Staro 29.12.2007., 23:46   #1702
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
U ukucao u registry novi key (org ) i sve se resetiralo, ali nema veze sad ću ič polako isponova, i da već su me proglasili čiterom
žmnpp
Staro 29.12.2007., 23:51   #1703
tech
Postovi: 1,687
Kad mjenjate key, mjenjajte ga u igri....
Staro 30.12.2007., 01:31   #1704
Baja 001
Baja 001's Avatar
Postovi: 7,504
Je li se kako može rješit trokiranje na XP-u?
Staro 30.12.2007., 14:44   #1705
stopalo9
stopalo9's Avatar
Postovi: 763
a kakvo trokiranje imash?
stopalo9 je offline   Reply With Quote
Staro 30.12.2007., 19:09   #1706
kico1
Postovi: 46
Da li ima mreža preko Hamachija za ovu igricu ako je netko od forumaša dignuo? Ako ne, imam ja:
Ime:Carevi
Pass:007
Pa zaigrajmo, pod uvjetom da imate patch 1.4 i Punkbuster update (nisam siguran) sa FAQ stranice Punkbustera
Zadnje izmijenjeno od: kico1. 30.12.2007. u 19:15. Razlog: Dodavanje informacije
kico1 je offline   Reply With Quote
Staro 30.12.2007., 20:27   #1707
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor stopalo9 Pregled postova
Tipa da igra ide na 40 FPS (FPS nikako ne pada za vrijeme trokiranja) a scena kao da zapinjem lagano u nešto. Samo mi se na XP događa. Igra sam kod prike na slabijoj konfi 2puta na Visti i ne trokira ništa!
Staro 31.12.2007., 00:21   #1708
Fleks
JDM
Fleks's Avatar
Datum registracije: Sep 2004
Postovi: 6,137
Autor Fleks Pregled postova
Dodjem na rabbitse igram 2 minute i izbaci me van?
slozio sam onaj pam4 folder, imam zadnji update?
WTF?
i dalje ne uspjevam naci rijesenje. Reinstall sam napravio, otiso na kemenita vrata zapalit svijecu. nakon manje od minute me izbaci uz istu gresku.
Lud sam.
Staro 31.12.2007., 00:30   #1709
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,474
probaj sa \cl_maxpackets 60
Staro 31.12.2007., 00:47   #1710
ti.le
[CTN]Mr.Ti
ti.le's Avatar
Lokacija: Zg, Novi Zg
Postovi: 567
Uf sad sam se i ja navukao na multiplayer....TDM pogotovo...nego pitanje MRUD-ica(claymore) nestane kad poginem?
CPU: Ryzen 7 5700G / Noctua D15S; MBO: MSI B550 Tomahawk; RAM:Corsair Vengeance 2x16 3200MHz; GPU: XFX Merc 319 RX 6900 XT; HDD: 1. Samsung 970EVO 256 GB; 2. Crucial P2 500GB; PSU: EVGA Supernova G2 750; CASE: NZXT H440 White; MONITOR: Asus MG279Q; KEYBOARD: Roccat Vulcan 100; MOUSE: Razer ViperMini @ SteelSeries QCK mass; HEADPHONES: Kingston HyperX Cloud (I) - Superlux HD-681 EVO
ti.le je offline   Reply With Quote
