Staro 23.03.2006., 22:09   #31
domy_os
domy_os's Avatar
Postovi: 19,022
To je najbliža točka GPU-u. Možeš i malo ljepila stavit na vrh sonde, al nek bude stvarno malo...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 23.03.2006., 22:50   #32
SniperWolf
SniperWolf's Avatar
Postovi: 4,193
rocks: Machineg
Pošteni Trgovci: 1,2
Staro 24.03.2006., 22:05   #33
kiki89
kiki89's Avatar
Lokacija: n/a
Postovi: 228
bas ljepo
kiki89 je offline   Reply With Quote
Staro 25.03.2006., 00:13   #34
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
Autor domy_os
nadam se da se šališ
Staro 25.03.2006., 03:15   #35
domy_os
domy_os's Avatar
Postovi: 19,022
Ne, ja sam tako lijepio na 9700, a i sad isto pomoću ljepila. Samo malo dotakneš, stisneš i to je to, mora stajat, nećeš se vješat po njoj.
Staro 25.03.2006., 03:21   #36
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Opako je kuciste, ljepo si to sredio... A i dobra konfa je u njemu...
Nego, daj mi reci kolko se gubi na hladenju ak su ventovi na 5V, a ne na 12? Jer cu poludit od buke, a dosta mi je bitna temperatura (temperature freek, jeb. ga)
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 25.03.2006., 03:54   #37
domy_os
domy_os's Avatar
Postovi: 19,022
Sad sam pogodio najbolji omjer buke i hlađenja. U tijeku je izrada "potenciometra" pa ću onda malo istestirat. Zašto pod navodnicima? Zato jer neće bit klasični potenciometri koji se okreću nego ću preko dva prekidača sa slike izvest prebacivanje napona na 5, 7 i 12 V.
http://www.luthimate.fr/images/SWI-XXX.jpg
Pored toga će bit LE diode koje će signalizirat koji je napon postavljen. Stavit ću još po jednu LED-icu za aktivnost diskova i optike te prekidač za clear CMOS. Sve ću to nekako uglavit na 3.5" poklopac floppyja.
Staro 25.03.2006., 10:11   #38
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
Autor domy_os
pa necu...ali....ponekad i nešto mjenjam po kompu pa nebi svaki put htio odljepljivati i zaljepljivati senzor..to nebi bilo zdravo
tj.stavit cu gore nekog zalmana i rijesiti problem
Staro 25.03.2006., 20:50   #39
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
domy - aj meni pošalji postavke za taj temp senzor u windozama, te koji je to uopće?
koji BIOS koristiš na ploči kad goniš 313 htt?
Staro 25.03.2006., 21:38   #40
domy_os
domy_os's Avatar
Postovi: 19,022
Evo postavke su u prilogu. Raspakiraj to u folder "C:\Program Files\Motherboard Monitor 5\Data".
Koristim OCWBeta2 BIOS.
Zadnje izmijenjeno od: domy_os. 02.05.2010. u 23:15.
Staro 28.03.2006., 17:13   #41
domy_os
domy_os's Avatar
Postovi: 19,022
Evo još jedne igračke.
Lijevo su LED-ice za aktivnost diskova i optike, u sredini dva prekidača za napon na ventovima (5, 7 i 12 V) sa statusnim LED-icama i sasvim desno prekidač za clear CMOS.
Zadnje izmijenjeno od: domy_os. 28.03.2006. u 18:03.
Staro 28.03.2006., 20:45   #42
hjerkic
hjerkic's Avatar
Lokacija: .
Postovi: 328
Domy svaka ti čast
hjerkic je offline   Reply With Quote
Staro 28.03.2006., 20:52   #43
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
Autor domy_os
haha domy ti si fula nic..ti si se trebao zvati clear CMOS
hahaha legendo...nemrem vjerovati da imas prekidac za to
Staro 28.03.2006., 20:56   #44
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
Autor domy_os
Pleksi, LED ventovi i te điđe miđe su mi bezveze. Par put sam došo u napast da počupam te LED-ice iz potenciometra. Platio sam ga oko 140 kn u Linksu.
eee bi bio dobar pa mi dao link na taj potenciometar...tj.imam i pitanje..cek jel tak fino stane..jerbo meni se neda cupati..trgati..rezati..lijepiti itd...
jel to mozda ovaj?
http://www.links.hr/index.php?option...kl=050.912.045
ubo bi si takvog..cool mi izgleda
Staro 28.03.2006., 21:13   #45
domy_os
domy_os's Avatar
Postovi: 19,022
Nemoj to uzimat, ništa ne valja, ventove ne spusti ispod 8-9 V tak da nema pretjerane koristi od toga, bolje mi je ovo što sam sâm napravio nego taj Nexus Vantec...
Staro 28.03.2006., 21:17   #46
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
a cuj...meni jebeno izgleda...zelim malkice usminkati kuciste...
e da on ima svoje led lampe ili ja moram nekaj gore posebno stavljati...
a cuj 8-9V..khm..tu bi se trebala vec osjetiti razlika
Staro 28.03.2006., 21:27   #47
domy_os
domy_os's Avatar
Postovi: 19,022
Ima u sebi LED-ice koje NE možeš isključit, a dosta su jake. Razlika se osjeti, al jako malo. Evo kak je bilo sa GT 92 mm ventom: na 12 V (iako to nije bilo 12 nego manje) je bilo oko 1600 rpm, a kad skroz smanjiš onda 1400 rpm, bijedno. Žao mi je novaca koje sam dao za njega... Pokušaj naći negdje (makar polovan) CoolerMaster Aerogate 1, to mi je bio najbolji potenciometar koji sam imao. Naponi mirni, regulacija linearna, LE diodice u tri boje, a mogu se i isključit,...
http://www.watercooling.fr/catalog/i.../aerogate1.jpg
Staro 28.03.2006., 21:30   #48
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
i taj kojeg si mi preporucio stane u prostor predviden za floppy disk?
Staro 28.03.2006., 21:40   #49
domy_os
domy_os's Avatar
Postovi: 19,022
Ne stane, to je jedini nedostatak. Šta imaš neki mini tower ili sve popunjene utore?
Staro 28.03.2006., 21:43   #50
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
imam isto kuciste ko i ti
ali mislio sam ga uvaljati u mejsto floppy diska..ali nejde tamo onda ide ispod dvd roma ili dvd kurilice
Staro 03.04.2006., 00:54   #51
Chome
TK
Chome's Avatar
Postovi: 1,092
Autor domy_os
gdje si kupio te ledice sa tim srebrnim obrubom ili si taj obrub posebno nabavio?
Ledice za aktivnost diskova si spojio paralelno sa konektorom od displaya kučišta pa na ploču??
Chome je offline   Reply With Quote
Staro 03.04.2006., 01:10   #52
domy_os
domy_os's Avatar
Postovi: 19,022
U Chipoteci je sve kupljeno, uzeo sam odvojeno LED-ice i okvir za njih pa samo ubacio unutra.
Da, paralelno ide.
Staro 16.12.2007., 04:00   #53
domy_os
domy_os's Avatar
Postovi: 19,022
Došao je red na još jedan update, ovaj puta malo veći. Započeo sam ga prije cca pola godine kupovinom novog kućišta Sharkoon Rebel 9 Economy Edition i završio danas tijekom dana. To "završio" nemojte shvatiti ozbiljno, bit će još modova, ali manjih.
Sharkoon Rebel 9 Economy Edition cijenom od malo preko 300 kn spada u jeftinija kućišta bez napajanja, ali ako ga usporedimo sa starim Novatronom S8, Rebel 9 je čvršće, malo veće i prozračnije. Mana je što je teško sakriti kablove bez bušilice/dremela, ali to mi ionako nije previše bitno.
http://www.sharkoon.com/html/produkt.../index_en.html
Cilj ovog moda je snižavanje buke na minimum minimuma što sam i ostvario. Ljudi boljeg sluha ga neće čuti na udaljenosti većoj od ~1 m. Uz sve to, kućište se vrlo dobro hladi, ako uzmemo u obzir da su unutra ukupno tri ventilatora (u napajanju, ispod napajanja i na procesoru). Šećer na kraju je overclock CPU-a od solidnih 50%. Neki će reći da te tri stvari ne idu zajedno, ali...
Trenutne u kućištu imam slijedeće komponente:
MBO: Gigabyte GA-965P-DS4 rev. 3.3
CPU: Intel Core 2 Duo E4300 + Arctic Cooling Freezer 7 Pro
RAM: 4 x 512 MB Kingmax DDR2 667 MHz
VGA: PowerColor ATi Radeon X1900 AIW + Arctic Cooling Accelero S1
HDD: Seagate Barracuda 7200.10 250 GB single plate
DVDRW: LG GSA-H62N
WLAN: Canyon CN-WF511
PSU: Corsair VX450W
Na kućištu se još nalazi jedan Sharkoon System Fan S od 120 mm, otpornikom spušten na ~9 V pa tako radi na ~800 rpm.
Na sve stranice je zalijepljen dumping materijal MOQ 982. Uzeo sam dva komada za svaki slučaj. Na kraju sam dobro procijenio.
http://www.dobar-zvuk.hr/auto_ak/REG...na/moq_982.htm
Krenimo sa slikama...
S prednje strane se ne vidi nikakav mod, ali pogledom na bočne i stražnju stranicu vidi se da su sve rupe začepljene zbog toga što sam htio postići da sav zrak ide preko prednje maske. Vidjet ćete kasnije zašto...
Skidanjem bočne stranice se susrećemo s "izolacijom" odnosno dumping materijalom. Budući da je dumping valovit, najtanji dio broji 8 mm, a najdeblji 16 mm zbog čega je zatvaranje stranica malo zahtjevniji posao, pogotovo desne stranice, ali ništa strašno.
Prednja maska je u potpunosti perforirana, učvršćena samo tiplama, bez vijaka. Iza nje se filteri za prašinu koji su se pokazali dosta učinkoviti. Primjetit ćete još jedna "vratašca" koja se protežu preko nekoliko 5.25" utora i imaju dvostruku primjenu - snižavanje buke i usmjeravanje zraka na donji dio kućišta.
U donjem dijelu se nalazi "tunel" za disk(ove), jedino mjesto gdje zrak izvana može ući u kućište. Time se preko diska stvara zračna struja koja ga hladi i potom odlazi dublje u kućište. Disk stoji na elastičnim trakama za ublažavanje vibracija.
Sad možemo pogledati ostatak komponenti. Tu nisam ništa previše radio, samo posloženi kablovi kako bih dobio na što boljem protoku zraka. Nisam htio previše "cjepidlačiti" oko toga, a i mislim da bez bušilice/dremela ne mogu nešto ekstra bolje napraviti.
Grafa s vrlo hvaljenim hladnjakom - AC Accelerom S1 (morao sam staviti nešto da drži to sve jer se opako savilo prema dole... ), AC Freezer 7 Pro i Sharkoon System Fan S 120 mm.
"Opaki trojac" u krupnom planu... To su svi ventovi koje imam u kućištu.
Još jedan pogled na diskove i dio iznad njih...
Vjerujem da vas zanimaju i temperature komponenti... Sistem sam prvo opteretio Orthos Blend testom, ATI Tray Tools Artifact Testerom i HD Tune error scanom, ostavio 1 h da radi, zapisao temperature, zatvorio navedene programe i stavio da se ohladi također 1 h.
Mirovanje - opterećenje:
CPU jezgre: 32°C - 46°C
MBO: 41°C - 42°C
GPU: 39°C - 60°C
HDD: 33°C - 39°C
Soba: 27°C
Budući da su ovo temperature za vjerojatno max opterećen sustav, u "normalnom" radu ih neću nikad imati. U igrama je recimo grafa oko 55°C max, proc 40°C,...
Eto toliko od mene za sada... Ako sam što zaboravio, vi ćete već skužiti, ipak su sitni sati pa se ne mogu svega sjetiti.
Zadnje izmijenjeno od: domy_os. 16.12.2007. u 04:20.
Staro 16.12.2007., 04:13   #54
mislav_os
freak
Postovi: 2,688
Lijepo slozeno,svaka cast
Moram to doci vidjet
Staro 16.12.2007., 04:15   #55
Joke
N00B
Joke's Avatar
Postovi: 3,886
Domy svaka cast odlicno si sve to slozio
Staro 16.12.2007., 10:23   #56
TomG
TomG's Avatar
Lokacija: Munich
Postovi: 2,222
preforastično,odlicno si to poslozio.
taj mi case sve ljepši što ga više gledam...
Staro 16.12.2007., 10:50   #57
Hamm
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
nice
budem i ja tka nekaj slozio sa svojim kuciste...fakat bi trebal
Staro 16.12.2007., 10:56   #58
Buger
Postovi: 4,398
lijepo složeno, svaka čast
neg reci ovi držači diskova, jel dolaze sa kučištem ili je to home made olovka mod?
Staro 16.12.2007., 12:03   #59
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,474
šteta da se accelero ne može postavit gore, tako bi se po meni skinulo par stupnjeva bez problema...
inače, jako lijepo složeno...
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 16.12.2007., 13:10   #60
SniperWolf
SniperWolf's Avatar
Postovi: 4,193
odlicno slozeno
