Staro 01.11.2007., 13:17   #1
tema
tema's Avatar
Postovi: 169
Dodavanje još jednog AP-a u mrežu
Trenutno imam jedan AP
i htio bio proširiti mrežu s još jednim AP-om
U kojem načinu rada treba biti ovaj drugi i dali se to uopće može?
Hvala
PC E4400@3GHZ,ASUS|P5K-E(WiFi),Gainward 9800GT,2gb|800MHz,3x320GB,250GB,160GB,1TB,Samsung|DVD-rw,ChieftecBIG|Sharkoon(450W)
HTPC A64X2|BE-2300+,AsusM2A-VM(HDMI),1gb|800MHz,2x500GB,1x640GB,Asus|DVD-RW,Frontier Prime 15M
tema je offline   Reply With Quote
Staro 01.11.2007., 16:05   #2
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Gledaj možeš ga staviti. I pitanje misliš tog drugog spojit na AP ili direktno na ruter/modem?
Ja imam svoje AP direktno kabelom spojene na adsl modem/ruter jer ruting mod dosta loše radi na AP-ovima od d-linka
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 01.11.2007., 17:33   #3
tema
tema's Avatar
Postovi: 169
Evo točno kakva je situacija
Imam trenutno Canyon WF-514, na kojeg mislim staviti 9dbi omnicu, da bi se povezao s frendom koji živi preko puta. Signala ima i sada sa, ovom standardnom 2dbi antenom, ali je slab. E sada, znam da bi najjednostavnije rješenje bilo kupit običnu Wlan karticu, ali pošto on ima još par PC.a pa bi AP bilo bolje rješenje.
Dakle, dali se to može ?
Staro 01.11.2007., 22:24   #4
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Canyon wf-514 ima odličan signal, gledaj ne moraš kupit omnicu cijelu, već samo produžni kabal od rutera i potegneš ga van i na njega našarafiš onu malu antenicu. Jeftinije rješenje. A susjedu se misliš spojit na njegov ruter ili na njegov komp?
Ryzen 7 2700X
2x 8gb Crucial
B450 Aurus Elite
GTX 1060
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
Harman Kardon
MX revolution
Battery grip
Sony: 18-70, 55-200
Staro 02.11.2007., 00:13   #5
tema
tema's Avatar
Postovi: 169
Ako antenu izvadim van i da se on uspije spojit , opet nebi bilo dobro, jer ja po stanu nebi imao signala, a treba mi za jedan PC, za laptop i za mobitel(koji ionako ima nikakvu antenu).
evo po slici možeš vidit kako sam ja to zamislio.
Dakle moj AP (canyon) je "glavni" ,
e sad dali se on sa svojim APom , može spojiti na moj, tako da samo proširuje moju mrežu, ne kao klijent
mislim da bi to trebao biti "Bridge mode" ,al nisam siguran , pa pitan
Staro 02.11.2007., 00:22   #6
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Ruting mod je proširivanje postojeće mreže, dakle AP pronalazi po mac i ip adresi ruter i na njega se spaja te proširuje domet.
Samo moraš pazit pri kupnji nemaju ti to svi uređaji.
Ryzen 7 2700X
2x 8gb Crucial
B450 Aurus Elite
GTX 1060
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
Harman Kardon
MX revolution
Battery grip
Sony: 18-70, 55-200
Staro 02.11.2007., 00:33   #7
Postovi: 23,551
Zavisi koji uređaj ima frend i koje modove rada podržava njegov uređaj.
U principu, njegov uređaj treba raditi ili u WDS ili Bridge ili Universal Repeter modu.
Npr. Neki AirLive AP - ovi podržavaju sve navedeno
Staro 02.11.2007., 01:23   #8
tema
tema's Avatar
Postovi: 169
Ok , frend još nije uzeo AP, tako da znam što treba uzeti
Hvala na pomoći
edit:
samo još nešto, dali ja svoj trebam prebacit u neki mode , ili treba ostat u AP modu ?
Staro 06.11.2007., 02:03   #9
Mihael
Mihael's Avatar
Lokacija: Home
Postovi: 2,186
Imam sličan problem.
Treba AirLive router spojit sa se555
Oba imaju wds.
Na kojemu što uključiti, kako podesiti ip adrese, treba li još šotogod?
DHCP? portove? routing?
Hvala puno
