Staro 30.03.2007., 14:14   #331
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,753
Evo ipak se nesto dogadalo na cebitu
We are talking about a 9.5 inch board that ATI already demonstrated behind closed doors at Cebit. The DDR3 memory works at 1600 MHz while the GDDR4 board will end up with memory speeds in excess of 2000 MHz.
http://www.fudzilla.com/index.php?op...d=354&Itemid=1
Bono je online   Reply With Quote
Staro 12.04.2007., 23:11   #332
Donkass
Postovi: 26
Donkass je offline   Reply With Quote
Staro 12.04.2007., 23:14   #333
Big Guy
RPG player
Postovi: 1,574
built in sound card???
I hate to see you leave, but I love to watch you go
Big Guy je offline   Reply With Quote
Staro 12.04.2007., 23:51   #334
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Na kraju kad su skinuli svu tu masu hladnjaka i ne izgleda tako velika, možda bi mi i ušla u mog Chiefteka
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 13.04.2007., 01:47   #335
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,753
ATI won't be using X in its Rx6xx brand names. The new Radeon generation will be branded Radeon HD 2000 series.
The R600XT or Radeon HD 2900XT is actually a 512 MB GDDR 3 card and the XTX will come later.
All the Radeon Rx6xx chips will be known as ATI Radeon HD 2000 Series.
Slike:
http://www.fudzilla.com/index.php?op...d=483&Itemid=1
http://forums.vr-zone.com/showthread.php?t=143108
Staro 13.04.2007., 01:53   #336
domy_os
domy_os's Avatar
Postovi: 18,975
0.9 ns memorija??? Bolesno...
Staro 13.04.2007., 02:05   #337
Mazohista
Lokacija: VT
Postovi: 333
imate sve na fudovim domacim stranicama,na bosanskom, sve o r600 od a-ž:
http://www.itx.ba/
Mazohista je offline   Reply With Quote
Staro 13.04.2007., 11:42   #338
Postovi: 7,568
AMD has named the rest of its upcoming ATi Radeon DirectX 10 product lineup. The new DirectX 10 product family received the ATi Radeon HD 2000-series moniker. For the new product generation, AMD has tagged HD to the product name to designate the entire lineup’s Avivo HD technology. AMD has also removed the X-prefix on its product models. The AMD ATi Radeon HD 2900-series features 320 stream processors, over twice as many as NVIDIA’s GeForce 8800 GTX. AMD couples the 320 stream processors with a 512-bit memory interface with eight channels. ATi Radeon HD 2900-series products also support 128-bit HDR rendering and up to 24x anti-aliasing.
  • AMD’s RV630-based products will carry the ATi Radeon HD 2600 moniker with Pro and XT models.
  • The value-targeted RV610-based products will carry the ATi Radeon HD 2400 name with Pro and XT models as well.
Izvor: Daily Tech
Staro 13.04.2007., 12:02   #339
Mazohista
Lokacija: VT
Postovi: 333
320 stream procesora, to bi moralo bit bar 2x jace od 8800gtx
Staro 13.04.2007., 12:03   #340
domy_os
domy_os's Avatar
Postovi: 18,975
Govori se i o nekom "besplatnom" FSAA-u odnosno o FSAA-u bez gubitaka u performansama. Zanimljivo...
Staro 13.04.2007., 12:56   #341
malba
schwere panzerspitze
malba's Avatar
Postovi: 313
Autor domy_os Pregled postova
da, pogotovo ako se prisjetim mojih dosadašnjih iskustava i iz njih izvučenih zaključaka da ništa nije besplatno, tj. ono što je besplatno najskuplje te dođe...
možda su mislili na besplatni fsaa na 1024*768 i nižim rezama?
nekako sumnjam da na 1680 i većim rezama fsaa može biti "besplatan" bez obzira na mrcinu od grafičke...
u svakom slučaju, zanimljivo.. odoh svirati harmoniku na bwin da skupim lovu za jednu makinu
malba je offline   Reply With Quote
Staro 13.04.2007., 16:41   #342
Mazohista
Lokacija: VT
Postovi: 333
Radeon HD 2900xt postize oko 12000bodova u 3dm06:
http://www.vr-zone.com/?i=4898
Staro 13.04.2007., 17:32   #343
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
R600XT scored 12K in 3DMark06, slightly better than a GeForce 8800 GTX.
Izgleda da će neki plakat
žmnpp
Staro 13.04.2007., 18:06   #344
malba
malba's Avatar
Postovi: 313
Autor buljo Pregled postova
da, a mnogima neće biti drago
nastranu sprdnja i bodovi, sve je to bezveze bez prave dx10 igre...
tek kad bude dx10 naslova vidjet će se tko je tko...
Staro 13.04.2007., 18:17   #345
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,474
i onda ce opet pola igrica rasturat nvidia, drugu polovicu ati... niš novo...
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 14.04.2007., 16:33   #346
peroW1
peroW1's Avatar
Lokacija: Croatia Čk
Postovi: 551
Mene nije briga, ja imam 12,5k+ u cmarku.
Zivio 3dmark!
i5 2550K 4.1GHz *Gigabyte Z77-D3H, 32 GB RAM KINGSTON HYPER X FURY, ASUS GTX 1060Ti , SSD 1TB, CoolerMaster 850W, ASUS 32'' 4K
peroW1 je offline   Reply With Quote
Staro 16.04.2007., 15:48   #347
Bono
Uptime 99.99%
Bono's Avatar
Postovi: 2,753
Evo vise o free FSA:
But of course there is a catch. The "free" FSAA comes only in low resolutions and it is possible as the 512 Mbit bus has a lot of bandwidth. At 16x12, 20x15 or higher resolutions you should still see the big difference once you turn the FSAA and Aniso on versus the score without it.
http://www.fudzilla.com/index.php?op...d=552&Itemid=1
Staro 16.04.2007., 16:47   #348
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
512Mbit bus? Mislim da ćemo na to pričekati bar jedno 80 godina
Staro 18.04.2007., 18:47   #349
AGP
Postovi: 10
Kolko ce to kostat???
Mislim si kupit neki novi komp a i htjeo bi imat neku jaku graficku u njemu da sam miran slijedece 3-4 godine....
AGP je offline   Reply With Quote
Staro 18.04.2007., 20:14   #350
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Autor AGP Pregled postova
Teško da ak sad kupiš novu grafu budeš bezbrižno igrao sljedeće 3-4 god, pogotovo ako misliš vrtit nove naslove..
Čak je i pitanje koliko sadašnji High end bude vremenski dobar.
žmnpp
Staro 23.04.2007., 12:56   #351
frankycro
frankycro's Avatar
Postovi: 65
Evo neke nove vijesti vezane uz R600!
Na kineskom webu su objavljeni prvi benchmark rezultati (kao i slike) novog R600 čipa u 3DMark06. Grafička kartica u kombinaciji s Intel Core 2 Duo E6600 na 2,4 GHz i starijim ATI-driverima pod Windows Vista, „uspijeva nakucati“ 9.685 poena. Pod Windows XP je taj rezultat za skoro hiljadu poena viši, pa grafička dostigne 10.572 3Dmarks. Ako analiziramo sliku pod Windows XP-om, možemo zaključiti da se radi o R600 grafičkoj s 1.024MB memorije, što govori da je to Radeon HD 2900XTX. Da li je pod Windows XP-om korišten isti driver kao što je bio kod Windows Viste, nismo uspjeli doznati.
to sam procitao na: http://www.eni-news.com/Eni-news/ind...336&Itemid=131
ako ce to tako biti, onda 8800GTX sije tu R600 za 2K bodova u 3DMark06
frankycro je offline   Reply With Quote
Staro 23.04.2007., 13:32   #352
tomifish2002
Honda Prelude 2.0i driver
tomifish2002's Avatar
Lokacija: Zagreb Dubrava
Postovi: 1,128
Autor Renesis Pregled postova
klasika... to tak ide već godinama. dosad je nvidia imala najjaču grafu na tržištu, sad će to bit ati, pa za 6 mj. geforce 9800gtx i tako u nedogled.
tomifish2002 je offline   Reply With Quote
Staro 23.04.2007., 14:19   #353
Smartguy
Spiderpig
Smartguy's Avatar
Postovi: 2,043
Autor frankycro Pregled postova
99% fake.
Ja mislim da sada većini nije važno koliko će R600 biti bolja od G80 već kad će izaći i koliko će smanjiti cjene konkurentskih modela. Već je očito da će razlika biti mizerna u korist jedne ili druge.
Smartguy je offline   Reply With Quote
Staro 23.04.2007., 14:46   #354
Mazohista
Lokacija: VT
Postovi: 333
U potpunosti se slazem sa prethodnom izjavom Smartguza. Najvaznije u tomu svemu jeste koliko ce izlazak R600 prizemljiti cijene nvidia kartica. I bilo bi jako dobro da r600 bude jedno 10-20% brzi.
Staro 23.04.2007., 14:55   #355
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
ATI kartice ionako tradicionalno "duže traju" nego Nvidijine, tj nakon izdavanja novog hardwarea u slijedećim mjesecima se dosta dobije na performansama u novim driverima.
Staro 23.04.2007., 15:41   #356
Rigor
In Shadows & Dust
Rigor's Avatar
Lokacija: Beyond The Dream
Postovi: 63
Triba cekati kad izade 8850gts/gtx ili 8950gts/gtx znaci sli ka i kod 7xxx serije.
Rigor je offline   Reply With Quote
Staro 23.04.2007., 15:47   #357
Mazohista
Lokacija: VT
Postovi: 333
Autor Rigor Pregled postova
Toga nece biti. Nvidia je za pocetak sljedece godine najavila novu arhitekturu koja nema blage veze sa ovom sada.
Staro 23.04.2007., 16:19   #358
ZED
a.k.a. LOPOV
ZED's Avatar
Postovi: 2,022
Autor Mazohista Pregled postova
Al opet predugo je vremensko razdoblje da oni nebi upotpunili paletu proizvoda sa nekim derivatom, tak da vjerujem da ce hitit van najesen nekaj tipa gore navedenog
Zabranjene reklama u sigu.
Staro 23.04.2007., 17:34   #359
Mazohista
Lokacija: VT
Postovi: 333
Autor ZED Pregled postova
8800 ultra ce doc u 5 mjesecu, a ostalo ce ovisit o tome sto ce amd napravit sa svojim r650 cipom.
Staro 23.04.2007., 17:55   #360
!v0
NECRIS DARKWALKER
!v0's Avatar
Lokacija: Velika Gorica
Postovi: 175
Jesu objavili kakav datum izlaska?
MBO:Biostar TForce 570 U
CPU:AMD x2 3600+(65nm)@2800Mhz
RAM:1GB TwinMos Twister 800mhz
VGA:ATI x300
ZVUK:AUDIGY 2 PLATINUM EX
PSU:MS 400w
MIŠ:LOGITECH MX518
(\__/)
(O.o )
This is Bunny. Copy Bunny into your signature to help him on his way to world domination!
!v0 je offline   Reply With Quote
