Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Radeon Omega Drivers 3.8.330 (Cat 7.1)
What's New in Omega Drivers? v3.8.330[*] Based on the Catalyst 7.1 Official drivers. [+] Added support for some new chipsets.[*] Clarified some options in the installer. What's new for ATI Tray Tools? 1.2.6.964 [F] Fixed procedure to display memory clocks as DDR in Overclocking Window.[*] Updated tray icon [+] Added hotkeys to switch monitor rotation between 0/90 and 0/270 [+] Added Romanian translation[*] Updated existing translation files [+] Added Memory IO voltage control for X1xxx video boards. [+] Updated GUI interface for some dialog boxes[*] Updated more names database [+] Added 500ms delay before restoring previous 3D settings after exiting from game. If this included in game profile.[*] Updated text rendering procedure in FlashOSD module[*] Updated overclocking support for RV570 and RV560 boards. Thanks Unwinder for help and information. www.omegadrivers.net
Postovi: 1,606
Super Moderators
Postovi: 17,485
Headbangig Grunf!
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Nevjerujem da je izdao nove drivere, zadnji su mu bili 6.9. idem odmah skinut.. ![]()
Porsche 6cyl.boxer se hladi zrakom komp se hladi vodom! Chairman of G.M.S. , Heavy Metal Thunder!Former member of PCE 100+kg demolition squad Grunf je moj idol! Moji Grunf type modovi NB:Mini Monster NB,VGA:Ye Monster C!, Ye Monster D!,Abit NB:Abit mini Monster,PSU:Ultra Monster! ![]() Alfisti site, Alfisti forum |
Postovi: 1,606
Govorim o release notama u kojima bi bili navedeni njegovi tvikovi, optimizacije, etc... Recimo: - optimizirao xy, hl2ep1 se sad na nekim mjestima vrti 5% brže nego sa orig. driverima ili: - promijenio xy, dobio bolji IQ u odnosu na official drivere uz iste performanse |
Super Moderators
Postovi: 17,485
Update: The original release had a "flag" problem on 3 files and if you didn't selected to install ATT, 3 files will be reported as missing when installing the drivers, this has been fixed and the name of the name of the new file is "rad_w2kxp_omega_38330_7z_fixed.exe", please re-download if you experienced the problem in the first release. Sorry for any inconveniences this may have caused. Ja ću pričekati još dan-dva da pofiksa sve kaj je u žurbi zaboravio Jednostavno je nevjerovatno kaj taj WoW radi od normalnih ljudi.... ![]()
#8 | |
Headbangig Grunf!
Postovi: 4,373
Super Moderators
Postovi: 17,485
Headbangig Grunf!
Postovi: 4,373
Istina no simbol WoWomanije je ipak Prigorski Židof, pojavi se na forumu sam kad treba nekaj prodat ![]()
Postovi: 1,711
jel postoji kakva verzija omege za vistu? ili ce izaci kad catalaysti dodu u final release,jer su u beti jos ili sam zazujao ![]()
http://eu.prepsafe.com |
Lokacija: Solin
Postovi: 1,753
Ne postoje takvi trenutno. Ja sam probao ove i mogu rec da nisu loši... dapače. Usporedivao sam ih sa službenim 7.1 i warcatsima 6.12 (koji su mi dali čak nekih 100-ak bodova + u 3dMarku 06) ,ali omega je i dalje bolja jer su nedostatak FPS-ova kompenzirali sa boljim IQ-om...uspoređujem sa XG Warcatsima 6.12... tako da... thumbs up : goood : Malo sam prošarao FC, NFS karbon i CO2 i mogu to potvrdit. ![]() |
Lokacija: Solin
Postovi: 1,753
#17 |
Headbangig Grunf!
Postovi: 4,373
nabijem ga!
Neznam u čem je problem al meni instalacija ne valja, navodno bud einstalation succesfull, al štanga, nakon reboota, nema drivera, pokušam uninstall i javi mi run dll error c:\windows\system32\atiiiexx.dll module could not be found. SKinuo sam fixed verziju. ovo isto mi se dešavalo i s 6.9 omegom, al tada sam msilio da je zto zbog toga jer tad ajš nije bilo X1950Xt. ideje? Sad imam opet catalyst 6.12. : bonker2 : giljotin : Machineg : boxers :
#18 |
Super Moderators
Postovi: 17,485
Pretpostavljam da si probao reinstal drivera? Mislim nevjerovatno-tebe non-stop driveri zezaju:confused:
#19 |
Postovi: 1,606
#20 | |
Headbangig Grunf!
Postovi: 4,373
Jelc! Kvargu! Da jednom, 10 puta! neznam zakaj al nekaj se desi da se kod mene driveri "ne prime". Pitao sam na DH-u al vidi čuda nitko mi još nije odgvorio. Jedino kaj nisam probao je instalacija u Safe modu.
#21 | |
Super Moderators
Postovi: 17,485
Moram ti priznat da mi ništa ne pada na pamet....
#22 |
Headbangig Grunf!
Postovi: 4,373
Razmišljam jel možda ima veze s mojim nLite windowsima, al onda opeti na x800gto2 i berenovoj x1300 su omege delale normalno. Striček omega je ko i paske smao u WoW u i neznam kak dojti do njega. Nevjerujem da se radi o lošem dowloadu jer ipak sve je to jedno te isti fajl. pas mater....
#23 |
Super Moderators
Postovi: 17,485
To kaj ti fali je .INF file installer Probaj ga naći tamo gdje si otpakirao drivere pa ga prikelji gdje treba.
#24 |
Lokacija: Senj
Postovi: 636
Bit će to najprije...al nemoš više bit siguran ni u full verziju windowsa: nono : Ja npr. imam "normalan" pro zakrpan dokraja pa mi se 7.1 od Atija ne instaliraju dobro kao i omega.: hitthewa Zbrljanac u registrima totalan Jedino mi rade kako treba NGO ATI OD 1.6.12 s CP-om http://www.ngohq.com/home.php?page=F...t&dwn_cat_id=9
Suck Satan's cock |
#25 |
Headbangig Grunf!
Postovi: 4,373
al pazi na istim windowsima su mi omege 6.7 radile ko urica na x1300, kad sam ih pokušao staviti na x1950xt se nisu instalirali kak treba.
#26 |
Headbangig Grunf!
Postovi: 4,373
#27 |
Lokacija: Senj
Postovi: 636
Meni se njesra dogodilo(bar tako mislim) kad sam izvadio X1800XL i stavio x1900XTX,a nisam deinstalirao drivere :P Najbolje bi bilo ponovo stavit windowse,hebiga.Sad radi kako treba s ovim NGO drajverima,al još imam problema s 2d/3d mod šaltanjem,jer ATI Overdrive neradi kako spada : hitthewa
Suck Satan's cock |
#28 |
Headbangig Grunf!
Postovi: 4,373
vjerojatno si ubio Ati hotkeypoller.
#30 |
Headbangig Grunf!
Postovi: 4,373
Prokl dirveri prokleta grafa prokleti windowsi, malo sma mozgao i ja sam grafu prebacio iz donjeg u gornji slot ( da prebacio sam jumpere na LP Ultra D) i sad kretonidni komad softwarea sere skupa s kretenoidnim komadom hardwarea razpizđuje nadrkanog koriniska ergo mene te mi javlja divnu grešu : zero display service error. : Machineg : axeman : : bonker2 Ideje????
