Staro 05.12.2006., 00:01   #31
9800pro
aka Edo, aka Syncros
9800pro's Avatar
Postovi: 1,795
Sad cekam da mi se enlajta sata driver u xp instalaciju pa cemo vidjet kaj to je.
Staro 06.12.2006., 00:39   #32
ikocuba
dedicide
ikocuba's Avatar
Lokacija: Slav.Brod
Postovi: 686
Evo što sam pročitao na xtremesystem forumu u vezi ove meme, planiram ju kupiti ali ako nema d9gkx možda da neku drugu uzmem.
Tko ima memu dali mu ide na 1066mhz 4-4-4-12 sa 2.4V?
You're right and I don't think anyone is going to be able to deny the fact that T1000UX2G4 has been quite impossible to come by. About 2 weeks ago, in response to my email, I was told pretty much what I have expected. From what I was informed a while ago, this kit is built with Micron's DDR2-800 parts (D9GKX) and these have been in extremely low supply for the past 2 months. Therefore shortage of T1000UX2G4. On the other hand, Super Talent's T800UX2GC4 (which used to be D9GKX) is quite available and that leads me to believe they switched to D9GMH (I believe it has been confirmed somewhere), which supply situation is a bit better, although not as great as many vendors would like it to be.
I was told, that as soon as they are able to buillt more of T1000UX2G4, it will be available at Newegg right away. As you noticed, other memory manufacturers are also having same problems with their fastest rated DDR2 lines (8000 or 8500 ), so this is an industry-wide shortage. Some manufacturers seem to switch to D9GMH for their high bins and maybe this is some sort of workaround at this moment...
http://mmgn.com/Lib/Images/Blogs/Normal/PWNAGE-Basics-1057811.jpg
ikocuba je offline   Reply With Quote
Staro 06.12.2006., 15:48   #33
gorluk
Čovjek
gorluk's Avatar
Postovi: 1,166
Pitanje - za iste novce mogu dobiti Super Talent 800Mhz CL5 i Kingmax 800Mhz - koja je bolja? Pretpostavljam Super Talent, ali bih htio provjeriti prije kupnje...
gorluk je offline   Reply With Quote
Staro 06.12.2006., 15:50   #34
bobe
teta Mraz
Lokacija: hr
Postovi: 1,596
Autor gorluk Pregled postova
supertalent, je bolji, nego...di to možeš dobit za iste novce ak nije tajna?
edit: mislio sam da je cl4, nisam dobro gledao, u tom slućaju razlika nije tolika no ja bi prednost ipak dao super talentu
bobe je offline   Reply With Quote
Staro 06.12.2006., 21:14   #35
9800pro
9800pro's Avatar
Postovi: 1,795
Trenutno je: proc 271.5x10 = 2715mhz
memorija: 1090mhz 5-5-5-15 2.3v
to je sve nabrzinu, nisam jos detaljno istestirao
