Staro 02.12.2006., 11:11   #1
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Koja igra (voznja) da podrzava split screen igranje?
Znaci, koju igru da probam, a da podrzava split screen mode igranja?
Tak da igramo ja i frend na istom kompu?
Trenutno imam CMR 2.0, ok je samo kaj je malo stara.
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 02.12.2006., 11:17   #2
d0X
Kostolomac
d0X's Avatar
Postovi: 1,468
dobro pitanje, i mene to zanima. ja znam isto za cmr 2, još kad uključiš one vatrene kugle...
i još znam za ignition, ali je isto jako stara. možda revolt podržava
PSN Steam
Staro 02.12.2006., 11:25   #3
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,463
revolt podržava, ali isto stara igra, a i nisi baš neki auti nego su autići...
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 02.12.2006., 11:48   #4
zackoj
zackoj's Avatar
Postovi: 887
http://www.scar.blackbeangames.com/
koliko se sjecam ova ima split screen
cak igrica nije ni tako losa.
jedan je GAZDA F1. Michael never give up, never surrender !!!
zackoj je offline   Reply With Quote
Staro 02.12.2006., 12:26   #5
Newbie Pro
Zule
Newbie Pro's Avatar
Postovi: 1,993
CMR 2005 podržava.
Newbie Pro je offline   Reply With Quote
Staro 02.12.2006., 12:43   #6
GrannyKiller
pazi babu!
GrannyKiller's Avatar
Postovi: 269
svi Toca Race Driveri, CMR 3, 04 i 2005...
I noga u guzicu korak je naprijed!
GrannyKiller je offline   Reply With Quote
Staro 02.12.2006., 13:14   #7
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Evo ti jedna za dušu..Ignition! E to možete igrati 2 tjedna bez prestanka...: goood :
Staro 02.12.2006., 13:46   #8
B3mt1
Chipokemon
B3mt1's Avatar
Postovi: 339
NFS 4: high stakes, staro ali zabavno, pogotovo kada ste murjaci ili jedan od vas pa lovis drugog
Piracy helps stop global warming.Insted of driving to get CDs, buying pre-packaged software from megacorporations and wasting energy,you can help fight Global Warming by using P2P.Help save resources,fight pollution and save the enviroment.
-It`s what Jesus would do.
B3mt1 je offline   Reply With Quote
Staro 02.12.2006., 14:01   #9
vga killer
Treba kaj skurit??
vga killer's Avatar
Lokacija: Zgb
Postovi: 4,025
Stari NFS, Toca 2 itd
Staro 02.12.2006., 14:01   #10
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,752
Autor Panzer Pregled postova
NFS, tamo negdje dok nije postao los (4-5-6 ili koji vec broj).
Programer
Staro 03.12.2006., 18:58   #11
Panzer
Panzer's Avatar
Postovi: 1,814
Igrali smo NFS 3, odlicna igra, samo kaj je stara. Nabavit cu NFS 4, i probat tocu.
CMR 3,4,5 je ok, samo kaj je problem u tome kaj se auti vide kao ghost. Znaci nema sudara niti gurkanja. Jel se da to sredit?
Hvala na odgovorima.
UPGRADED...
