Chipokemon
Postovi: 339
Uplink
Piracy helps stop global warming.Insted of driving to get CDs, buying pre-packaged software from megacorporations and wasting energy,you can help fight Global Warming by using P2P.Help save resources,fight pollution and save the enviroment. -It`s what Jesus would do. |
ono ispred konpjuktora
Datum registracije: Apr 2003
Postovi: 3,659
jaooooo pa neko josh igra uplink!!! genijalna stvar, šteta što je razvoj stao prije nego što je dovršena komponenta za halanje preko neta... ovo je negdje druga ili treća misija u prvom setu ![]() kewl... doh... ne sjećam se više... vjerojatno u college moraš upisati university degree , a u qualifications management. ... javim se s update-om ako iskopam negdje. btw, svaka čast što to igraš ![]()
Postovi: 3,659
Class 3). - Add an Other Qualification. Commit the Update, disconnect. Reply the mission. Mutiple of these mission can be done at once, because of the enormous trace. |
Hack the system. You'll have much time, sometimes about 900 seconds. Search for the name. Now you either have to: - Add a Graduate Qualification with Class (Mechanical Engineering, Class 1). - Change Graduate Class (Class 1 --> Class 3). - Add an Other Qualification. Commit the Update, disconnect. Reply the mission. Mutiple of these mission can be done at once, because of the enormous trace. |
#5 | |
Chipokemon
Postovi: 339
![]() imas mozda neke hintove za mene pocetnika ? i imam jos jedno pitanje, ako kupim novi gateway, da li moram kupovat novi proc, memoriju, modem ... ili mi preseli s starog ?? EDIT: jos jedno pitanje, koliko sam skuzio kada se disconnectam on naparavi log, znaci uvijek ostane neki trag, ima li tome pomoci ?
Piracy helps stop global warming.Insted of driving to get CDs, buying pre-packaged software from megacorporations and wasting energy,you can help fight Global Warming by using P2P.Help save resources,fight pollution and save the enviroment. -It`s what Jesus would do. Zadnje izmijenjeno od: B3mt1. 08.11.2006. u 22:28. |
Ex-Gastarbajter
Lokacija: Zagreb / Rijeka
Postovi: 5,463
mislim da imaš za kupit onaj log eraser... ali ako si preko više jumpova spojen nema zime... mogo bi i ja opet počet to halat... ![]() |
Chipokemon
Postovi: 339
imam log deleter v.4 i izbrisem ja sve logove na target serveru i onda se disconectam, a kada se disconectam on napravi log na target serveru da sam se disconecto (tj. ostavi trag s mojim IP-om)
Ex-Gastarbajter
Postovi: 5,463
hmm, kako onda ono ide... vidi ako nema da se stavi da ostavis neki program na napadnutom kompu koji iza tebe počisti... |
Hurr durr
Lokacija: Stančić
Postovi: 1,449
Mislim da nesmijes nigdje ici vise nakon sta izbrises logove , ja ovako radim izmjenim IP adrese (uzmi od nekog privat lika), izbrisem sve logove i srusim server i nisam imao problema Jedno pitanjce za sve vas dali itko igra ili je igro CRACKER , ja probo i nejde previse mi je tesko za snac se u igri
Chipokemon
Postovi: 339
moram se pohvaliti kupio sam si napokon monitor bypass i htjeo sam ga malo testirat tako da ukradem nesto para, naravno napravio sam backup save (da nebi trebao opet ispocetka ako zaribam) i tako ja idem po acc.-ovima i saljem si pare (sve neka sica) , na trecem acc.-u vidim pod transakcije da je lik nedavno jednom liku poslo 1,3 mil kredita (ja sam osto paf), brzo pisem IP banke i acc. no. na papiric, taman sto sam to napiso trace-ali su me (pasivno) nista za to, stavljam backup, odem u tu banku prebacim si pare, brisem logove, disconnect i taman se spojio na svoj acc. da i tamo izbrisem log, kad ono ulovili me, vec sam pomislio da necu nikako doci do tih para opet dizem backup, samo sada sve puno brze radim, i uspio sam, bogat sam ![]() odmah sam si uzeo najjaci gateway (s 8 proceva) i sav moguci softver : goood : hihi, kako sam happy
Ex-Gastarbajter
Postovi: 5,463
evo i ja opet počeo igrat ![]() ![]() ![]() |
Ex-Gastarbajter
Postovi: 5,463
Da vidimo majstore... kako se ulogirat na LAN server i onda pobrisati fajle sa nekog kompa? imam lan scan, lan force, jel mi treba i spoof? |
#16 |
Lokacija: ???
Postovi: 370
ok moze mi netko objasnit zasto mi kada igram uplink CPU usage stoji na 100% mislim na pravi cpu(athlon 3800+) ne onaj u igrici. EDIT: ma daj bezi imam dojam da me ovo hakersko cudo skenira : paranoid Zadnje izmijenjeno od: hmmm. 12.11.2006. u 03:42. |
#17 |
Ex-Gastarbajter
Postovi: 5,463
nemam pojma, nisam išao za time... ako i piše 100%, nije sigurno, jer meni je temp oko 46, dok je full load oko 51... po tome znam najbolje ![]() |
#18 |
Chipokemon
Postovi: 339
#19 |
Ex-Gastarbajter
Postovi: 5,463
nego bemti, jel znas ti hakirat LAN sustav? |
#20 |
Chipokemon
Postovi: 339
nope, ne radim ja bas one obicne uplinkove misije, cekam mail od Arnomoura da nastavim special, ali nista zasada ![]()
#21 |
Ex-Gastarbajter
Postovi: 5,463
ah, vidiš, mogao bi i ja, koje su specijal misije, ja sam to sve bio odje... ![]() a i šta napravit kad ti moraš prenest novce na drugi acc, a tip nema toliko novaca na accu? |
#23 |
Ex-Gastarbajter
Postovi: 5,463
ulovise me ![]() bio sam drugi agent u firmi, i na jednom serveru, čim sam se spoji, odmah su me ulovili??? ništa, sada isponova, mogao bi probat i onu neku spcije misiju |
#24 |
Lokacija: ???
Postovi: 370
ma meni je to sumnjivo, jos neznam kako ali je. proc mi stalno radi na 100% a za jednu igru koja je najslicnija Ogameu to nije normalno. googlao sam i jos se neki ljudi zale na istu stvar. temp mi je bila na 35 u full hladnoj sobi jer sam taman dosao doma i upalio grijanje. se mmoze u toj igri saveat ili se mora ponovno krenut kad te ulove? |
#25 |
Ex-Gastarbajter
Postovi: 5,463
isponova... |
#26 |
Chipokemon
Postovi: 339
#29 |
Ex-Gastarbajter
Postovi: 5,463
ja se isto nisam uspio skužiti kako... mislim da ti obavezno treba onaj LAN_spoof prije nego što bilo što pokušaš... |
#30 |
Hurr durr
Lokacija: Stančić
Postovi: 1,449
Prvo skeniram i dobijem oko 30-40 novih stvari tipa modem , system security i onda pocnem gasiti 1 po 1 ostane mi oko 30 sec i puf naso me dobro ali ja provaljujem jedan lan kaj sam ja sam napravio tako da je sve high security. I dali je itko otkrio kako nekome unistiti zivot
