Staro 04.08.2006., 19:48   #1
Anthrax a.k.a. Priest
Postovi: 621
Linux>slackware>friski install ali ne dize se X
Dakle frisko sam instalirao winse i slack 10.2, sve radi osim sto mi slack nakon logiranja ne zeli podignut GUI. Imam LCD Samsung SyncMaster 930 BF i sapphire X300 SEIzbaci mi ovaj error :
Mouse 1: Cannot open input device
preinit failed for input device "Mouse1"
No core pointer
Fatal server error:
failed to initialaze core devices
XIO: fatal IO error 104 on x server ":0.0" after 0 requests (0 known processed) with 0 events remaining
Mouse je opticki usb sa 2 tipke i kotacicem. vjerojatno treba neke gluposti editirat u xorg.conf samo ne znam koje pa ako neko moze pejstat svoj xorg ili reci sta da editiram bio bi zahvalan
Anthrax a.k.a. Priest je offline   Reply With Quote
Staro 04.08.2006., 20:11   #2
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
# (Type "man /etc/X11/xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
FontPath "/usr/share/X11/fonts/misc"
FontPath "/usr/share/X11/fonts/cyrillic"
FontPath "/usr/share/X11/fonts/100dpi/:unscaled"
FontPath "/usr/share/X11/fonts/75dpi/:unscaled"
FontPath "/usr/share/X11/fonts/Type1"
FontPath "/usr/share/X11/fonts/100dpi"
FontPath "/usr/share/X11/fonts/75dpi"
# path to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
Load "i2c"
Load "bitmap"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "type1"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc104"
Option "XkbLayout" "cro"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ExplorerPS/2"
Option "ZAxisMapping" "4 5"
Option "Emulate3Buttons" "true"
EndSection
Driver "wacom"
Identifier "stylus"
Option "Device" "/dev/wacom" # Change to
# /dev/input/event
# for USB
Option "Type" "stylus"
Option "ForceDevice" "ISDV4" # Tablet PC ONLY
EndSection
Driver "wacom"
Identifier "eraser"
# /dev/input/event
# for USB
Option "Type" "eraser"
EndSection
Driver "wacom"
Identifier "cursor"
# /dev/input/event
# for USB
Option "Type" "cursor"
EndSection
Section "Device"
Identifier "NVIDIA Corporation NV34 [GeForce FX 5200]"
Driver "nvidia"
Option "nologo""1"
BusID "PCI:1:0:0"
VideoRam 131072
EndSection
Section "Monitor"
Identifier "Generic Monitor"
Option "DPMS"
HorizSync 76.16
VertRefresh 56
EndSection
Section "Screen"
Identifier "Default Screen"
Device "NVIDIA Corporation NV34 [GeForce FX 5200]"
Monitor "Generic Monitor"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1024x768" "800x600" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
InputDevice "stylus" "SendCoreEvents"
InputDevice "cursor" "SendCoreEvents"
InputDevice "eraser" "SendCoreEvents"
EndSection
Section "DRI"
Mode 0666
EndSection
Ovo je sa Ubuntu-a 6.06 LTS
Tomo je offline   Reply With Quote
Staro 04.08.2006., 20:36   #3
Postovi: 621
hvala na brzom odgovoru. Sada mi jos jedini problrm ostaje sto kaze no screens found
Staro 04.08.2006., 21:00   #4
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,364
Dakle, Slackware je po defoltu namješten na runlevel 3 i ne diže X-e osim ako mu ti ne kažeš. Postoji utility koji radi konfiguraciju X-a, zove se "Xorgconfig" koji ti postavlja razna pitanja u vezi konfiguracije i na kraju to sve sejava u /etc/X11/xorg.conf fajl. Nakon toga još ručno editiraš po potrebi.
Ovaj config što ti ga je Snake poslao sadrži "nvidia" driver pod "Section Device". Ako nisi instalirao nvidia drivere, trebao bi staviti "nv" umjesto toga da diže driver od X-a. Također, vjerojatno treba zakomentirati,staviti # ispred "option No Logo" koja je isto od Nvidia drivera. Imaš li uopće Nv grafičku?
stef je online   Reply With Quote
Staro 04.08.2006., 21:04   #5
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
@ stef: E da, zaboravio sam to napomenut... THNX kaj si se sjetio...
@ Anthrax: Koju grafu imas....
Staro 04.08.2006., 21:14   #6
Postovi: 621
procitajte malo moj post :d imam ATI-ja
Problem je sto ne prepoznaje monitor mislim i tu nesto treba podesit oko njega
Staro 04.08.2006., 21:29   #7
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,364
Normalno da ga ne kuži kad su u konfiguraciji nvidia driveri. Ja sam zaboravio kako se zove Ati driver od X-a ... pa ako tko zna neka napiše.
Postupak za instalaciju ATI fglrx drivera:
Download the proper drivers for your X-Free version off of ATI.com
Then login as root
su
Then cd into the directory containing the drivers and run the following:
rpm2tgz filename.rpm
installpkg filename.tgz
cd /lib/modules/fglrx/build_mod
sh make.sh
cd ..
sh make_install.sh
Make sure in your Kernel that you have the DO NOT have DRI compiled or Moduled in and that for agpgart you have it Moduled in with your correct AGP Chipset compiled in. From there type in the ATI X config command that is giving at the last command to go through there auto XF86Config maker. Then load the modules for your AGP Chipset and fglrx like so
modprobe agp-gart
modprobe intel-agp
modprobe fglrx
Then run ATI's xf-config utility
fglrxconfig
Staro 04.08.2006., 21:40   #8
Postovi: 621
nisu nvidia driveri nego vesa driveri i prije mi je super uvijek radilo sa CRT-om ali sad kad sam presao na LCD ga ne prepoznaje dakle samo trebam ustimat postavke monitora....morat cu to malo prokopat
Staro 04.08.2006., 22:06   #9
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
da ti nije mozda do HorizSync i VertRefresh... probaj ovo...
sudo gtf 1280 1024 65
dobit ces nesto u ovom stilu
# 1280x1024 @ 85.00 Hz (GTF) hsync: 91.38 kHz; pclk: 159.36 MHz
Modeline "1280x1024_85.00" 159.36 1280 1376 1512 1744 1024 1025 1028 1075 -HSync +Vsync
Upisi doticne vrijednosti (u xorg.conf) HorizSync i VertRefresh, restartaj X pa vidi oce se pokrenut.
Staro 04.08.2006., 22:15   #10
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,364
Da, koje frekvencije imaš u xorg.conf-u?
Staro 05.08.2006., 15:03   #11
Postovi: 621
instalirao sam ubuntu 6.06 nakon sto sam izgubio zivce...sve sam bio isprobao...
koje pakete moram skinut za slusat mp3 i gledat avi i mpeg?
Staro 05.08.2006., 15:13   #12
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
Autor Anthrax
gstreamer (mp3,lame,mpeg,ffmeg,w32codecs) (plugins-bad/ugly/god) ....
Staro 05.08.2006., 15:25   #13
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,364
xmms (mp3), Xine/Ogle (DVD), Mplayer/w32codecs (Divx)
Staro 05.08.2006., 16:22   #14
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
samo u synapticu skini ove libove...
System -- Administration -- Synaptic
Search: libxine-extracodecs
Search: totem-xine
Staro 05.08.2006., 16:51   #15
Postovi: 621
Autor $n@k€
Search: totem-xine
e stari ovo mi je puno pomoglo jer sam oci izgubio od trazenja...
Jedino ovaj prvi ne mogu naci a drugi kad ubacim u search nadje mi samo totem
Staro 05.08.2006., 17:38   #16
Zond
Rabotnik
Datum registracije: Feb 2003
Postovi: 779
Odi na Ubuntu Wiki, imas sve fino napisano, samo kopiras komande u terminal
Zond je offline   Reply With Quote
Staro 05.08.2006., 17:44   #17
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
@ "crni prist": ako ti je ovako onda skines to.... http://www.slibe.com/slibe/d807fe2e-Screenshot-png.png
@ Zond: http://ubuntuforums.org/ ima i tu dosta stvarcica .... svaka minuta 10 postova Topica (cisti primjer kako ljudi neznaju korisititi search dugmic)
Staro 05.08.2006., 17:56   #18
Zond
Rabotnik
Postovi: 779
Staro 05.08.2006., 18:09   #19
Postovi: 621
isao po wikiu i howto i sve isprobano mi nije htjelo radit...ali uspio sam naci alternativu..skinuo sam VLC player preko apta i sad sve radio ko podmazano...hvala na trudu ljudi
Staro 05.08.2006., 18:12   #20
Zond
Rabotnik
Postovi: 779
Trebao si mplayer skompajlirati iz CVS
Staro 06.08.2006., 12:24   #21
Postovi: 621
nikako na zelenu granu. Imam T-comov adsl modem koji se spaja na ethernet i namjestio sam konekciju sa pppoeconf i sve radi krasno do prvog restarta nakon cega vise nece da se poveze.... znali neko u cemu je problem?
Staro 06.08.2006., 12:30   #22
tutix
tutix's Avatar
Postovi: 4,068
Taj problem i ja imam, nakon što mi restarta komp nakon prvog postavljanja, internet malo radi pa malo ne, uglavnom ne. Zato sam i prestal koristit Ubuntu. Možda je zbog modema, imam onaj crni od Elcona koji radi i na usb i na mrežnoj.
Staro 06.08.2006., 12:43   #23
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
hm... nemam problema s tim jer nemam DSL... jeste probali ovaj link?
Staro 06.08.2006., 12:56   #24
Postovi: 621
Autor tutix
ne imam siemens onaj bijeli koji ide samo na ethernet
Staro 06.08.2006., 12:56   #25
Postovi: 621
Autor $n@k€
to je za suse
Staro 06.08.2006., 12:57   #26
Zond
Rabotnik
Postovi: 779
Meni je na ubuntu pppoeconf delao bez beda. Svaki restart je prosao bez problema, link se digne, apsolutno 0 problema. Siemens modem inace. Bez problema do jucer, jucer je krepao disk pa se mogu khm..
Staro 06.08.2006., 13:00   #27
Postovi: 621
Autor Zond
i meni je stariji ubuntu radio ali ovaj novi mi nece da se cocnnecta nakon prvog restarta
