#4381 | |
Postovi: 455
A onaj dinamov grb u srcu Rijeke necu niti komentirati... : baad :
RABBITS CLAN |
#4382 |
Džabe si krečio!
Postovi: 5,191
#4383 | |
1oo1 NooB
Postovi: 1,306
1. NITKO NEMA PRAVO KICKANJA I BANOVA OSIM ADMINISTRATORA - SAMIM TIM "ŠALE" TIPA KICK ADMIN ILI KICK "FREND" POVLAČE BAN PRVO NA MJESEC DANA A KOD PONOVLJENOG PREKRŠAJA DOK GOD OVAJ SERVER POSTOJI. 2. NITKO ALI APSOLUTNO NITKO VIŠE NEČE IGNORIRATI ADMINISTRATORE NAŠEG SERVERA - UBUDUČE KADA ADMIN NEKOGA NEŠTO PITA OSTALI NE KOMENTIRAJU A PROZVANI SE ODMAH JAVLJA PA MAKAR NOSIO ZASTAVU ZA POBJEDNIČKI BOD. 3. VOTANJE ZA NOVU IGRU/MAPU NE MOŽE SE PROVESTI NITI ĆE SE TRPJETI NA POLOVICI IGRE. SAČEKAJTE KRAJ TE IGRE PA ONDA NA POČETKU NOVE DAJTE PRIJEDLOG - POČETAK IGRE JE JEDINO VRIJEME ZA PROMJENU IGRE/MAPE. MOLIMO IGRAČE DA AKO SVI PRIJEĐU NA JEDNU STRANU DA SE SAMI BALANSIRAJU JER DO AUTOBALANSA TREBA NEKO VRIJEME - U TOM SLUČAJU JE OPRAVDAN RESTART MAPE. 4.OVO JE SAMO KONSTANTNO PONAVLJANJE ISTOG - NEMA VRIJEĐANJA SUIGRAČA. PSOVKE I SLIČNO MOGU SE SVAKOM DOGODITI ALI NE SMIJU BITI OSOBNE. MISLIM DA SU SVI DO SADA SHVATILI ŠTO PROLAZI A ŠTO NE 5. VEČ PRIJE NAVEDANA PRAVILA VRIJEDE ISTO TAKO I POTRUDITE IH SE PROČITATI. OVDJE ĆU SAMO NAVESTI - ČITATI PRAVILA PRIJE ULASKA U IGRU I OBAVEZNO POZDRAVITI KOD DOLASKA NA SERVER GORE NAVEDENO SE VIŠE NIKOME NEĆE PONAVLJATI NITI OBJAŠNJAVATI - DOSTA JE BILO UBOJICA IGRE/GUŠTA Ulazak i igranje na serveru podliježu istim pravilima kao do sada samo sada će se kazne sprovoditi bez uopozorenja - znači ako neko ne pročita pravila ponašanja i igranja to je njegov problem ali leti sa servera.
IT IS EASY TO KILL FIVE HUNDRED NOOBS. BUT THERE IS STILL FIVE HUNDRED AND ONE AND YOU ARE OUT OF AMMO! 1oo1 NOOB - POWER IN NUMBERS! Good judgment comes from bad experience and a lot of that comes from bad judgment. |
#4385 |
Lokacija: Grad Varazdin
Postovi: 3
I što će sad biti .Ja sam gledao ljudi su jako puno psovali i nisu izbačeni .Stvarno mi je žao ako sam nekog povrijedio. Ali nisam ništa ignorirao i psovao ,samo sam maxa nagovarao nek mi da sniper. |
#4387 | |
1oo1 NooB
Postovi: 1,306
@Tyreal - nemoj se vise pravit - hmm - da neznas o čemu se radi - niko nikome neče prijetiti pogotovo ne adminu - o psovkama i neću govoriti.
#4388 |
Archangel Of Light
Lokacija: Kraljevica
Postovi: 326
@MisterM Nemam razloga se pravit da neznam o čemu se radi, da si mi ljepo rekao kao što sam te zamolio da mi kažeš o čemu se radi, onda bih znao, ovako sam moram gnjavit RAKa da mi razjasni situaciju, moj okršaj s Athom je star 2 tjedna, iz kojeg bih ja razloga trebao pomisliti da me je pravda sustigla nakon 2 tjedna?? Ali da skoro sam zaboravio pa Vaše visočanstvo je admin. zašto bi se uostalom morao obraćati nama jadnim smrtnicima. @Atha Mogo si imat makar toliko obraza pa mi odgovorit na ICQ kad sam ti postavio pitanje, dali sam banan zbog naseg okrsaja. -- Naravno nakon ovog posta ce mi se ili prijetiti banom ili cu biti banan, jer ce se ovo ocjeniti kao omalovazavanje administratora, a kad se mene omalovazava na nacin da me se javno proziva da se pravim glup, i da neznam o cemu se radi onda nikome nista, a mislim da smo svi ovdje dovoljno informatički pismeni da znaju da se mailovi od Inboxa do inboxa ne gube bas tako lako, ali za svaki slucaj MM ako nisi shvati poanta MAKNIvdevcic@OVOgmail.com je da zapravo maknes slova koja su napisana TISKANO.. Hvala na vašem vremenu i pozdrav ekipi od koje se očito rastajem.. MaD i Ren falit cete mi ![]()
"Old programers never die. They GOSUB and never RETURN." |
#4390 |
Postovi: 9,068
tyrael, a shta mislish da ja spavam uz rachunalo pa pratim icq cijeli dan. prije 20min sam vidio tvoju poruku. druga stvar. 2tjedna. vrijeme ipak ne ide toliko brzo. treca stvar. nechesh dobiti ban. kakav ban, ovo je pce, a ne server. chetvrta. ti si se uvrijedio na prozivku glup, i onda se josh chudish. zz
___________ Just atha x |
#4392 |
Lokacija: Solin
Postovi: 1,753
Di su njemci?! ![]() |
#4393 |
Ex-Gastarbajter
Lokacija: Zagreb / Rijeka
Postovi: 5,472
Vidi se da sam vam falio... a sada nema nikoga očito su presitni (ili preveliki) sati.... ajd pucamo se sutra, tj. danas ![]() |
#4394 |
Postovi: 3
Dajte me izbrišite sa liste članova ne mislim se tu s vama natezati . Ja sam retardiran pa imajte milosti za mene i ohladite me na dva tjedna sa foruma. Ionako tu nemam sta traziti! Zadnje izmijenjeno od: E.T.. 09.04.2006. u 15:53. |
#4397 |
1oo1 NooB
Postovi: 1,306
U stikyju imate obnovljene pravila igranja i ponašanja na PCE COD 2 SERVERU. THX, MM
#4398 | |
1oo1 NooB
Postovi: 1,306
Još sinoč sam htio napisati par "10000 znakova postova" ali sjetim se da normalnim ljudima nisam ništa trebao ponavljati svaki put ponovno i ponovno i ponovno....... @Tyrael - to kaj tu sada glumiš da ti niko nije ništa objasnio - to sada i najsporiji shvačaju kao laž. Ako to tebi podiže moral slobodno piši ovdje o malim zelenim, svijetskim urotama protiv jadnog i nevinog, pokušavaj kod sporijih dobivati bodove sa jeftinom demagogijom tipa "Vi Povlašteni"...... Ako misliš da si informatički pismen - to ti ja ne osporavam - da li misliš da si pismen opčenito - naime ili to ili nisi pročitao pravila.... Na kraju shvati slijedeče - PRIJETIO SI FIZIČKIM OBRAČUNOM - za ovo bi te ja banao doživotno. Ima i previše objesnih manijaka oko nas da bi se ovo shvatilo olako. To je sve. Prijetio si fizičkim obračunom. I zamisli da ovo ponavljam ovdje 100 puta da shvatiš. U stvari možda Athi ne bi bilo zgorega prijaviti ovo nadležnim službama...... Mislim da ovdje imamo par stručnjaka iz toga područja pa neka oni kažu da li je to potebno. EDIT: PS - ako si ti bio uvrijeđen od strane bilo koga ili u ovom slučaju od Athe - mogao si tražiti javnu ispriku ovdje - i vjeruj mi ako je zahtijev opravdan - dobio bi je - bez prijetnji.
IT IS EASY TO KILL FIVE HUNDRED NOOBS. BUT THERE IS STILL FIVE HUNDRED AND ONE AND YOU ARE OUT OF AMMO! 1oo1 NOOB - POWER IN NUMBERS! Good judgment comes from bad experience and a lot of that comes from bad judgment. Zadnje izmijenjeno od: MisterM. 09.04.2006. u 14:39. |
#4400 | |
1oo1 NooB
Postovi: 1,306
Ali trebao sam znati da neko ko se na PCE rega kao Gestapo sa pripadajučim avatarom ( čovjek si je dao truda oko kukastog križa i imena ) i u tome ne vidi ništa loše - da će dotični raditi probleme prije ili kasnije. Dakle sretan ti put. MM
#4401 | |
Zule
Postovi: 1,993
Kaj se ti javljaš, treba i tebi koji šamar udijelit ![]() ![]() |
#4402 |
Ex-Gastarbajter
Postovi: 5,472
našla se dva.... ja barem kempam, pa znaš di me nać... vas ne možeš ni za glavu ni za rep... |
#4404 |
Postovi: 9,068
sfor je prijavljen josh jutros. u svezi tyraela nemam namjeru nishta drugoga poduzimati, razuman sam, mozhda je ono sve bilo recheno u zharu borbe, nisam nikada nishta loshe mislio niti uputio prema IJEDNOME IGRACHU sa servera, ono je bio samo kick upozorenja radi psovke i yebavanje ***** meni, i smatram da reakcija nakon vrachanja na server nije bila primjerena. toliko od mene. mm, molim te instaliraj icq, skype ili msn da mozhemo lakshe i brzhe komunicirati. ![]() pravila prochitana i usvojena. Herr Kommandant Átha. ![]()
___________ Just atha x Zadnje izmijenjeno od: atha. 09.04.2006. u 14:41. |
#4405 |
1oo1 NooB
Postovi: 1,306
Pass će biti promjenjen danas u toku dana ili kasnije večeras. Članovi će dobiti novi na vrijeme. Novi pass će vrijediti tek od trenutka kad ga dobijete. MM
#4407 | |
Postovi: 9,068
![]() kakav edit...hehe
#4408 | |
1oo1 NooB
Postovi: 1,306
#4409 |
driver
Postovi: 1,083
Čitam sve ove prethodne postove i adrenalinske izljeve pojedinih suigrača i sad je i meni, kao najlošijem igraču, dopi....ilo. Admine smo izabrali jer su ljudi od povjerenja, trude se da nam igru olakšaju ( zakaj meni ne kupe novu grafu ??? ) i gube svoje dragocjeno vrijeme da bi svima nama bilo veći gušt igrati. E, sad se nađu dva, tri derana kojima još pikule ispadaju iz džepova i onda popuju, prijete i iskazuju svoj kućni odgoj. Sramotno je, u demokratski oformljenoj grupi igrača, pokušavati istjerati neku svoju "pravdu" i pravila igre na nekulturan način. Grupa smo, i većina određuje kako i na koji način će se igrati. Kome nije po volji, ode na drugi server i kvit. Slobodno im bilo izvadit' pare iz svog džepa, oformiti server i tamo provodit' svoja tzv. pravila. Moja podrška adminima i glas za ban, kad god to treba. Otpast' će 10 % ološa a mi ostali gun u ruke i udri.
SPECTRUM ZX 48 K, Grundig Cassette player, RIZ Color TV - 16 kanala UHF, sobna antena Čajavec SA-3 s lampicom, software : River Raid & Jet set Willie |
#4410 |
Lokacija: Solin
Postovi: 1,753
Joj al je pakleno! : CoolRamb Prasi se u svih šesnaest... cak sam i lak na okidacu pa sam zamalo kolegu sprasio dva puta (koliko se sijecam) ...ovim putem se iskreno ispričavam... Nije bilo namjerno! A njemce je bilo definitivno namjerno! : DualWiel |
