Staro 04.10.2005., 13:07   #61
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
WinUAE 1.1
Izašao je novi WinUAE 1.1
Major bugs introduced in 1.0 fixed:
- Picasso96 graphics corruption after ALT-TAB
- Zipped Amiga Forever Kickstart ROM image decryption problem
- JIT FPU ACOS bug (incorrect result if argument was negative)
Older bugs fixed:
- More stable on the fly configuration loading
- In windowed mode Amiga window height was sometimes slightly
larger than requested size
- "the desktop is too small for the specified window size"-check
was not completely correct
- AHI recording mode memory leak
- Some Amiga monitor drivers work now properly (for example Euro36)
- Incorrect paths if WinUAE was run from networked drive
- Some custom chipset emulation bugs (Obliterator intro, Elfmania
scoreboard, Warp and others)
- Directory filesystem directory modification date bug if comment
or protection flags were modified
- Improved directory filesystem compatibility
- Rare disk emulation bug introduced in 0.9.90
- Action Replay statefile restore bug introduced in 0.9.90
- OCS/ECS color translation to native colors fixed. (this was bug
since the beginning of UAE..) Colors are now slightly brighter.
No effect on AGA-mode colors.
New features:
- Configurable Catweasel joystick support, MK4 mouse support added
(NOTE: Right and middle mouse button may not work with all mice,
requires Catweasel driver/firmware update)
- MMKeyboard support added
- Transparent "drive led status bar"
- SPTI (Windows 2K/XP) SCSI emulation includes non-CDROM SCSI devices
- Improved uaescsi.device SCSI interface selection
- Custom emulation updates (Death Trap, Loons Docs, Spanish Rose by
Creed, Filled Perspective by Zero Defects, Himalaya by Avalanche..)
- Improved default path setting, Amiga Forever 2005 paths supported
- More missing keycodes added to input-panel
- Copper debugger: tracing, single step and breakpoint
- Disk swapper: right button doubleclick in "Disk image"-column:
removes disk in disk swapper panel. right button singleclick in
"Drive"-column: remove disk in drive
- New-style ROM config entries
- Compressed hardfiles supported (limitations: max 100MB, all written
data will be lost after reset or exit, hardfile file name extension
must be either hdz, zip, rar or 7z)
- Hardfile drag&drop to harddisk-panel
http://www.winuae.net/files/InstallWinUAE1100.exe
1.3 MB.
Staro 21.03.2006., 02:24   #62
Visage
8-bit Gen.
Visage's Avatar
Lokacija: Giethoorn - ZG
Postovi: 3,164
Umjesto da PM-am samo Jelc-u.... stavljam ovdje...
Neki dan mi jedan poznanik Rodolpho koji zivi u FR i radi lude egozte za ATARI i sikne mi na mail jedan mali programcic :
http://www.shlock.co.uk/Utils/OmniFlop/OmniFlop.htm
Nema sto taj ne prebacuje i tako mi svih bubnjeva Darkvuda ni manje ni vise nego bas nema Amige
Pa koje perverzije sve cita ali bas ne Amigu.
I onda me slucajno jedna BBB spodoba sjeti na ovo
http://everything2.com/index.pl?node_id=870970
http://www.jschoenfeld.com/products/catweasel_e.htm
Nije novina, al'bi se nikako ovog sjetio... ni pod razno.
Uh, al je ovo anti HTML-oidna ruznoca za linkanje
>>>> PCE kante 2012 <<
>>>>>>>>> PCE & ostalo <<<<<
>>>>>>> Što sam Slušao? <<<<<<
>>>>> Gimnastika za Okulare & LCD Addendum<<<<
>>>>> P o s t ... M j e s e c a <<<<
______________________________
Zadnje izmijenjeno od: Visage. 21.03.2006. u 16:51.
Staro 21.03.2006., 02:56   #63
Costa
Costa's Avatar
Datum registracije: Aug 2003
Postovi: 3,193
Emulac shalje pozdrave Jelcu s porukom da je prognoza za tvoj desktop sunchana do kraja godine. Visage inspirirao, ja pogledao i eto tvojoj brizi je kraj
Staro 21.03.2006., 16:51   #64
Jelc
Super Moderators
Postovi: 17,485
Fino, fino-Visage si je dao truda a Costa me je razveselio
Staro 22.03.2006., 18:15   #65
piNheaD
piNheaD's Avatar
Lokacija: Senj
Postovi: 636
WinUAE 1.2
WinUAE 1.2 (20.02.2006)
New features:
- New "lores filter" in GUI, fixes incorrect colors in programs that
use superhires trick (eg. Virtual Karting, demo Rest-2).
- Logitech G15 keyboard LCD support.
- FPU emulation updates and fixes.
- Ability to create 1:1 HDF from Amiga formatted harddisk.
- ProWizard module ripper updated to latest version.
- Display Filter panel updates, added 1x,2x,4x,6x,8x multipliers.
- PNG screenshots.
- Light pen hardware emulated. (but no trigger or cursor emulation yet)
- Manual language selection.
Bug fixes:
- Right border color problems finally fixed.
(Leander, T-Racer, Unreal etc..)
- Misc custom chipset emulation updates.
(Bubba'n'Stix second level, Cover Girl Strip Poker title screen,
Detonator, Thai Boxing, Wicked etc..)
- CIA TOD counter fix. (demo Harmony by Haujobb)
- Display was shifted by one pixel in lores-mode and horiz centering enabled.
- Overlay windowed mode one pixel position error.
- Swapped parallel port joystick adapter firebuttons.
- Toggling disk image's read-write status don't leave locked files anymore.
- Amiga Forever 2005 path detection should really work 100% now.
- Corrupted wav-files in 4-channel audio mode
http://www.winuae.net/files/InstallWinUAE1200.exe
Suck Satan's cock
piNheaD je offline   Reply With Quote
Staro 22.03.2006., 22:39   #66
Jelc
Super Moderators
Postovi: 17,485
Ja sam ga skinuo čim je izašao
Staro 23.03.2006., 00:15   #67
Ziiky
Ziiky's Avatar
Postovi: 2,882
Amiga je u to vrijeme bila strojcina, nisam ju nikada imo...............ali zato dan danas imam Spectruma, kasnije commodorca
Mislim da sam jedini u gradu imao adapter za joistic koji se kacio odozada i na sebi je imao 2 porta ko comodorac...(bio sam faca u komsiluku)
To je bila negdje 85 ak se nevaram....
Ebem ti ta vremena.......sarafciger i kazetas i udri dok ne ucitas igru: wtf :
Staro 23.03.2006., 04:32   #68
piNheaD
piNheaD's Avatar
Lokacija: Senj
Postovi: 636
Da,Amiga je bila zakon,sad mi je žao što san je proda btw , ima san Amiga 500+ (ovo plus znači da je imala 1MB Chip RAM i koristila AmigaOS 2.04) i igrica na bacanje : goood :
Suck Satan's cock
Staro 23.03.2006., 05:15   #69
Amdejac
Amdejac's Avatar
Datum registracije: Jun 2003
Lokacija: Kuća
Postovi: 5,409
Autor ziky
Sad mi je žao šta sam dao ZX Spectruma 48+ sa 30-setak kazeta na kojima je bilo po 10 igrica.
Procesor 3,5MHz ZilogZ80, 16 ili 48KB RAM-a, 16KB ROM-a (Read Only Memory), gumena tipkovnica, grafika se prikazivala u rezoluciji 256x192 piksela u 15 boja na TV Ekranu, dok je za zvuk bio zadužen ugrađeni, kako da to nazovemo, 'beeper' jednoga kanala u pet oktava.
To u biti izgleda kao da igricu igrate na mobitelu, a gledate na TV-u.
Asus N750JK (Upgrade)
MBO: Asus N750JK
RAM: 2x8 Gb PC3-12800 DDR3
PSU: Asus Li-ion 69486 mWh
OS: Windows 8.1
Monitor: 17,3 LCD (FHD)
Net: Intel AX210 NGW
Net: TP-Link Archer TX55E
PSU: Xilence, Bronze 550W
Monitor: Samsung
VGA: ATI RX570, 4 Gb
HDD: NVMe 1 Tb, Patriot
PSU: Inter-Tech SP750
Monitor: Samsung
Amdejac je online   Reply With Quote
Staro 23.03.2006., 15:12   #70
ghoul
ghoul's Avatar
Postovi: 63
Jel' ima tko od vas WorkBench instalaciju.... ovu novu verziju..treba mi za instaliranje Virtual AmigaHDD-a???
Odigrao sam nedavno Milenium i Deuteros; Pri kraju sam s Antarticom i sad bih prašao na BAT, .... a za BAT2 i Hired Guns mi treba virtual HDD.
ghoul je offline   Reply With Quote
Staro 23.03.2006., 17:35   #71
Jelc
Super Moderators
Postovi: 17,485
Autor ghoul
Za WinUAE?
Staro 24.03.2006., 15:28   #72
ghoul
ghoul's Avatar
Postovi: 63
DAaaaa!!! IMAŠ?????: roller :
Staro 24.03.2006., 15:44   #73
Jelc
Super Moderators
Postovi: 17,485
Autor ghoul
Imaš npr. kompletni AmigaSYS koji već u sebi ima 200 MB HDF.
Za to trebaš imati WinUAE i barem AmigaOs 3.0 ili 3.1.
AmigaSYS
http://amigasys.fw.hu/
Staro 25.03.2006., 20:12   #74
ghoul
ghoul's Avatar
Postovi: 63
Autor Jelc
Sve super, ali meni nedostaje upravo AmigaOS 3.x
Zadnje što sam imao/imam je Amiga2000 s avojim workbenchom, ali diskete
više nisu uporabljive...hmm ne čudim se ....Bilo je to godine.....
Svejedno, za ovaj link nisam znao!
Staro 25.03.2006., 21:59   #75
Jelc
Super Moderators
Postovi: 17,485
Autor ghoul
Vani ti je 3.1 kakvih 9.90€...
Staro 26.03.2006., 13:34   #76
Clifton
humanoid carbon unit
Clifton's Avatar
Lokacija: tamo
Postovi: 347
mali OT... eto, meni je Amiga još uvijek izvor inspiracije... u drugom mediju
http://www.fotozine.org/index.php?st...1129&pid=12707
Clifton je offline   Reply With Quote
Staro 29.03.2006., 00:05   #77
Jelc
Super Moderators
Postovi: 17,485
Evo i jednog komada periferije za prijateljicu (pripasano sa piceka) koji još uvijek radi.
Staro 04.04.2006., 01:18   #78
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,164
Autor Jelc
Pa nemoj biti tako bescutan.
Daj malo storije, kako, kada, zasto?
Ja imam dva u 2000-ici a zao mi je sto sam davno dao 1080 (mislim da se tako zvao vanjski za Amigu kao monitor) vanjski flopac jer ima igara bas za 3 diskete
Istina da bog zna kad cu to upaliti , ali veseli.
Smeta me sto mi A1200 ima onako bezobrano otvorenu rupetinu za disketu, odvratno se prasi
>>>> PCE kante 2012 <<
>>>>>>>>> PCE & ostalo <<<<<
Zadnje izmijenjeno od: Visage. 04.04.2006. u 13:25.
Staro 04.04.2006., 09:25   #79
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
...a tek kako sam ja bio sretan kad sam 1200-tku spojio preko Parneta na CDTV pa sam mogao koristiti CDTV-ov CD kao da je sa 1200-tke...jednostavno ga mountaš i ponaša se kao lokalni...zbilja zakon OS za to vrijeme
Propast Amige i uspjeh PC-a je pokazatelj da nešto sa ovim svijetom nije kako treba : sniper :
Staro 04.04.2006., 16:10   #80
Jelc
Super Moderators
Postovi: 17,485
Autor Visage
Razmišljam još od jučer-i da se ubijem ne mogu se sjetiti točno...
Ali se zato dobro sjećam guštanja sa dva flopača
Ono prije je bila živa muka...pogotovo kod programa/igri na više disketa.
Malo-malo pa mjenjaj, preporodio sam se kad sam nabavio ovaj externi.
Staro 04.04.2006., 20:39   #81
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,164
Autor Jelc
Razmišljam još od jučer-i da se ubijem ne mogu se sjetiti točno... Ali se zato dobro sjećam guštanja sa dva flopača
Kad smo vec kod flopaca ...
Pogledajte koja ikona krasi moj na PC-u
Staro 05.04.2006., 00:42   #82
Jelc
Super Moderators
Postovi: 17,485
Autor Visage
Kaj to vrtiš i X 10 na piceku?
Staro 06.04.2006., 23:26   #83
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,164
Autor Jelc
Ma jok, dosta mi je Mac-a u fizickom obliku za dva zivota.
Dignuo ga na PC-u radi atrakcije i skinuo odma dole.
Ostao je naziv jer se na njemu znaju naci ponekad Mac programi kad nekome treba nesto prebaciti da se ne navlaci po CD-ima, mada nema bogna sto vise.
Staro 17.07.2006., 23:56   #84
Jelc
Super Moderators
Postovi: 17,485
New WinUAE 1.3
Amiga-zajednica i dalje vrijedno radi, upravo je izašao novi WinUAE 1.3
WinUAE 1.3 (16.07.2006)
New and improved features:
- Input event recording and playback (WIP)
- PC floppy drive drive sound emulation
- Mousehack-"driver" build-in.
- PC DD and HD floppy image support.
- Added improved audio filter and interpolation code from uade and other sound setting updates.
- Added build-in HRTMon debugger/monitor. (WIP)
- Action Replay for Amiga 1200 ROM image support.
- Arcadia emulation updates.
- Directory filesystem compatibility updates. (illegal characters in directory names work better now, some protection flag tweaks, more compatible disk capacity check if disk is very big, compatibility issues with \\server\share-directories fixed)
- Debugger updates. (improved trainer search command, fa-command, like in Action Replay, AGA color register dump etc..)
Bug fixes:
- Fix for random state restore freeze.
- AVIOutput crash, incorrect window size.
- Random Picasso96 screen mode switch crash.
- "Create hard disk imagefile"-option in harddisk settings fixed, previously it usually created corrupt hardfiles..
- Fixed garbage lines when program mixed interlace and non-interlace modes.
- D3D filter fullscreen freeze fixed.
- Priority-panel "pause emulation/disable sound output"-checkboxes were not initialized correctly.
And more smaller (and maybe bigger) changes..
Staro 18.07.2006., 00:40   #85
Visage
8-bit Gen.
Visage's Avatar
Postovi: 3,164
Autor Jelc
Pa jesu li ovo dani Amige u zadnja 2-3 dana. Nije dosta sto sam pravio 3k kilometraze za 3000T, sad i ovo
Jos mi javi da neko radi Ami copy party negdje pa da puknem iz realnosti kompletno : roller :
1) http://tinyurl.com/e7jys
2) http://tinyurl.com/geh8e
3) http://tinyurl.com/kl3ur
Staro 18.07.2006., 01:13   #86
Jelc
Super Moderators
Postovi: 17,485
Neki dan si me pitao za grafu-mislim da sam vidio na jednom siteu koji dila Mediator proširenja da je podržana čak i ATI 9200 SE
Budem ovaj tjedan isprobao ovaj novi WinUAE pa javim kako šljaka.
Nekaj sam si mislio (kaj se tiče prebacivanja fajlova)-mislim da bi "prava" Amiga trebala uredno pročitati HDF koji napraviš na emulatoru.
To bi trebalo raditi i u kontra smjeru.
Ili nabaviti ovo:
http://amigakit.leamancomputing.com/...roducts_id=440
Staro 08.08.2006., 12:38   #87
Jelc
Super Moderators
Postovi: 17,485
WinUAE 1.31
WinUAE 1.3 bugs fixed
- Uaescsi.device freeze problem fixed.
- Boot freeze if A4000 ROM was used without AGA.
- Original extended ADF read bug.
- Larger than 1280 wide fullscreen modes work.
- Sound "led" filter configuration data was read incorrectly.
- AVIOutput does not split the AVI anymore when focus was lost.
- D3D filter fullscreen/windowed switching should not freeze anymore.
- Integrated mousehack access fault fixed.
- AVIOutput codec settings stored in registry and other small tweaks.
- HRTMon updated to 2.30, WHDLoad-commands supported.
- Some custom chipset timing tweaks.
Tute:
Staro 10.08.2006., 22:07   #88
Ivan_1
Lokacija: Duga Resa
Postovi: 823
ja na tom novom emulatoru pokusavam vec fest dugo pokrenuti All New World Of Lemmings. vec sam popizdio, nikak nece krenut. prode onaj Hoodlum intro i nakon toga stane na AmigaDOS screenu. pokusavao sam sve moguce kickstart romove...kombinirao cipsetove ali nista...u cemu bi mogao biti problem?? brzo, ocu igrat!
Ivan_1 je offline   Reply With Quote
Staro 10.08.2006., 22:59   #89
Jelc
Super Moderators
Postovi: 17,485
Ta igra je znala raditi problem i na orginalnim Amigama.
Budem probao jedan dan ali mislim da to neće biti tako brzo...
Staro 10.08.2006., 23:27   #90
subtex
subtex's Avatar
Postovi: 329
Pa ***************ate ja imam Amigu doma : lol2 : Sad malo gledam slike i vidim da imam Amigu 500 doma, stoji na tavanu više od 10 god. Točno se sjećam kad sam dobio svoj prvi P166 da sam zapakiro Amigu i puknuo je na tavan, to je bilo u petom osnovne a sad sam prva god faksa. Imam i punu kutiju igara (cca 200 disketa) Sjećam se da sam igrao one utrke autima Lotus, pa mislim da se zove Pong, neka igra gdje gađaš neke lopte koje se djele na sve manje i manje,
subtex je offline   Reply With Quote
