Staro 28.10.2025., 18:56   #20851
OuttaControl
OuttaControl's Avatar
Lokacija: Dalmacija
Postovi: 5,953
To sve ovisi od covika do covika, ja imam astigmatizam sa 2 metra ne vidim na 55" razliku izmedju 4k i 1080p, super za grafe
Staro 28.10.2025., 18:59   #20852
Postovi: 17,143
Autor pogi Pregled postova
https://pcchip.hr/hardver/tv-i-monit...8k-rezolucije/
Saljem sa mobitela nemogu kalo link
Isto kažu da oko ne može vidjeti znad tipa 60FPS-a, što je nortorna glupost.
Staro 28.10.2025., 19:06   #20853
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,142
Neki kazu i da 100% razlikuju 192kbps MP3 vs FLAC/WAV
Verifikacija poštenog trgovca #1, #2, #3, #4, #5, #6, #7, #8, #9
Staro 28.10.2025., 19:16   #20854
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,675
Kako tko, ali definitivno je istina da je taj 8k najobičnija budalaština. Nemam neki super vid, meni je sa 2m na 55" vrlo vrlo teško razlučiti 4k i 1440p.
Ako je audio oprema prava, tu razliku bi valjda i gluh čuo. Na PC speakerima od 10 eura nema razlike, to je istina.
Staro 29.10.2025., 15:47   #20855
biohazard
Datum registracije: Jun 2025
Postovi: 58
Autor Exy Pregled postova
pravi maheri audiofili skuže kak se veli i koji kukac leti u zraku, moraš imati nekakvu adekvatnu opremu
biohazard je offline   Reply With Quote
Staro 30.10.2025., 07:28   #20856
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,361
Manufacturers continue to release new TV models featuring Ultra HD and even higher-resolution panels. However, according to a recent UK study, much of this effort may be largely unnecessary, as the human eye has a natural "resolution limit."
A team of researchers at the University of Cambridge set out to determine the true number of pixels the human eye can actually perceive. Using a sliding 4K monitor that could be moved closer or farther from the viewer, they found that the eye can detect far more pixels than previously thought, but that larger TVs often have a pixel density far beyond what most viewers can appreciate.
The experiment led to the identification of what the researchers call "retinal resolution" – the pixel threshold beyond which adding more pixels does not improve the perceived image quality. This limit depends on several factors, including screen size, room lighting, and the distance between the viewer and the display.
> Techspot
Ja znam da ja nemogu razlikovati kad je monitor na 166Hz a kad na 60Hz :P
Staro 30.10.2025., 08:34   #20857
medo
#erase startup-config
medo's Avatar
Postovi: 3,733
Iskoristio sam ove akcije i upiknuo si LG C5. Baš zbog toga sam išao na 55” umjesto na 65”
Odlučio sam zayebati “immersion” efekt. Ekran 65” bi mi previše naprezalo oči na tih 2.1m koliko je ekran udaljen pogotovo na zapečenim titlovima na zemaljskoj TV a koštao bi me 350-400€ više. I trošio bi više struje.
Ovako je slika nešto manja ali prirodnija. Kao da manje izgleda “digitalno”.
Staro 30.10.2025., 10:09   #20858
Exy
Exy's Avatar
Postovi: 2,675
Struja je ključna
Slažem se, za daljinu cca 2m 55" je idealna veličina. 65" dođe kao kad sjediš u kinu u prvom redu
Sad kad imaš C5, RTL Kockica će izgledat bolje nego ikad
Staro 30.10.2025., 10:16   #20859
nub
PREMIUM
nub's Avatar
Datum registracije: Dec 2014
Postovi: 2,165
50 inča s tri metra, pff... amateri. S tri metra su trebali staviti barem 65", optimalno 75-77", da bi imalo smisla istraživanje.
https://www.rtings.com/tv/reviews/by...e-relationship
Zadnje izmijenjeno od: nub. 30.10.2025. u 10:32.
Staro 30.10.2025., 11:09   #20860
Postovi: 17,143
85" idealno. Govorim iz osobnog iskustva.
Staro 30.10.2025., 11:43   #20861
Exy
Exy's Avatar
Postovi: 2,675
Gledaš u 85" TV sa daljine od 2m?
Staro 30.10.2025., 11:52   #20862
Postovi: 17,143
3m.
Staro 30.10.2025., 15:03   #20863
okarm
Postovi: 776
meni je s 3- 3.5m 50" taman. imao jedno vrijeme 60", pokusao se uvjeriti da je bolje i pratiti trendove ali sam se nakon mjesec dana vratio na 50tku. ugodnije mi je gledat, a i sam prostor mi je ljepsi.
Staro 30.10.2025., 15:10   #20864
nick praskaton
Asshole
nick praskaton's Avatar
Lokacija: RH
Postovi: 2,361
Autor okarm Pregled postova
hmm, s tri ipo metra udaljenosti, meni bi idealno bilo 75", ne znam kako ista vidis na 50" tvu na toj udaljenosti
Staro 30.10.2025., 16:17   #20865
Postovi: 17,143
Ja u sobi imam nekih 3m do TV-a i gore sam stavio 50" jer više nije išlo. Nemam naočale ni dioptriju, ali ja taj tv ne gledam baš iz razloga jer mi je sve premalo i vidim da se oči naprežu. Žena ima neku minimalnu dioptriju, kaže da joj je sve mutno, ne treba nosit naočale.
Svaka čast, no meni je to negledljivo.
Zadnje izmijenjeno od: Mommistake. 30.10.2025. u 16:27.
Staro 30.10.2025., 21:12   #20866
nub
PREMIUM
nub's Avatar
Postovi: 2,165
Dobro sad, negledljivo je malo pregruba riječ. Nije optimalno po izračunu, ali svakako gledljivo. Nekoć su se gledale televizije s 50-65cm i to je bilo kao dobro, a danas se kakti hurca ne vidi i oči se naprežu na 50 inča .
Ja sam prilagodil prostor 65" telki i stavio kauč na nekih 2.70 što je po izračunu idealno i meni isto paše. Mogao bih malo veću dijagonalu za filmove za kino doživljaj, al za igre i tv program, koji je ipak puno lošije kvalitete, je ovako super.
Staro 30.10.2025., 21:24   #20867
Postovi: 17,143
Autor nub Pregled postova
Ja ti kažem, negledljivo je meni. Titlovi mi se mute, borim se.
Išao sam na pregled vida, mali astigmatizam, ali dioptrija 0.25 i jednostavno ne vidim koliko bi htio.
Išao izmjeriti sobu, 3.5m je negdje duga. TV je 50". Ne znam, baš sam izgubio volju gledati gore tv.
Staro 30.10.2025., 21:42   #20868
9800pro
aka Edo, aka Syncros
9800pro's Avatar
Postovi: 1,781
Upravo to. Ja kad sam kupio Panasonic crt 80cm koji je to šou bio doma. Sa 3.5m udaljenosti na kojima danas gledam 65" tada je tih 32" bilo ogromno. Nisu svi isti. Meni je tih 65" super, mogao bi možda na 77" da je neka super cijena ali više od toga ne. Ali projektor sa druge strane mogu gledati 120" sliku sa iste udaljenosti. Nije isto buljiti u platno i neku telku sa 2-3000 nita hdr-a koji ti izbija zjenice...
Staro 30.10.2025., 21:50   #20869
nub
PREMIUM
nub's Avatar
Postovi: 2,165
Slažem se. Ta svjetlina stvarno počne ubijat kad se gleda kako spada - u zamračenoj prostoriji. SDR materijal stvarno ne treba previše dizat (standard industrije je 100 nita!), jedino HDR zahtjeva 1000.
To mi je malo neobično. Ovaj 65" kaj imam mogu gledati i s druge strane prostorije s tipa 6-7 metara i niš mi se ne mute titlovi.
Staro 31.10.2025., 10:08   #20870
Postovi: 17,143
A nemam pojma.
Ne radi se o nekom vrhunskom TV-u, stavio sam po jednoga u svaku sobu. Ali opet...
Staro 31.10.2025., 14:22   #20871
gogoklepci
Datum registracije: Sep 2019
Lokacija: Mostar
Postovi: 364
HRT daje sliku 1080i i tv od 65" i neki max blizine je 2.5m! 4K je 1.2 metra! Osobna mišljenja nemaju veze s znanošću!
gogoklepci je offline   Reply With Quote
Staro 31.10.2025., 14:40   #20872
Postovi: 17,143
A nema ni vjera veze s znanošću pa ljudi u svakakve gluposti vjeruju...
Znanonost ne gleda tv, ja ga gledam.
Možemo mi dan i noć pričati o brojkama, mjerama i udaljenostima.
Zadnje izmijenjeno od: Mommistake. 31.10.2025. u 14:46.
Staro 03.11.2025., 14:40   #20873
gunther
Postovi: 1,369
Dečki, što bi bilo bolje, Philips 65OLED820/12 ili LG C5 65?
Hvala!
AMD Ryzen 5900X; Gigabyte Aorus X570 Elite; Corsair Vengeance RGB Pro SL DDR4 2X16 Gb 3600 Mhz; AMD Radeon Gigabyte 7900 XTX; SSD Patriot Viper VP4300 PCIe m.2 GEN4 2 Tb;Lian Li 011 Dynamic EVO; LG C2
gunther je offline   Reply With Quote
Staro 03.11.2025., 14:46   #20874
Postovi: 17,143
C5.
Staro 03.11.2025., 16:17   #20875
adaksinjo
adaksinjo's Avatar
Datum registracije: Dec 2011
Lokacija: Virje
Postovi: 601
Hisense 65A7GQ s godinu i pol garancije u mint stanju otišao za 250e nakon 3 tjedna natezanja s njuškalo jazavcima koji nude sve i svašta u zamjenu.
Autor Keano16 Pregled postova
TCL C7K?
Ja gledam taj 65". Koliko ga koristis? Kako si zadovoljan?
prvo i osnovno, slika je neusporedivo bolja. crna boja je crna, nema probijanja svjetline kao na starom tvu. nisam imao oled tako da uzmi to s dozom rezerve, ali prezadovoljan sam.
zvuk je također odličan, softver je brz, nisam primjetio da šteka ili da ga čekam po xx sekundi ko na starom tvu.
moram se priviknuti na daljinski, što ne znači nužno da je loš, ali neke stvari su na Hisense daljincu bile smislenije, ali možda je jednostavno do navike.
adaksinjo je online   Reply With Quote
Staro 05.11.2025., 17:34   #20876
RedSky
RedSky's Avatar
Datum registracije: Apr 2017
Postovi: 425
https://www.hgspot.hr/qled-tv-xiaomi...le-tv-o39ph-eu
Ima li netko iskustva sa ovim TV-om, ima li što bolje za 300 €?
RedSky je offline   Reply With Quote
Staro 05.11.2025., 23:21   #20877
Postovi: 17,143
Biti će to spori android, ali za pogledat tv ili film ili seriju, bude ok.
Nemaš baš izbor te veličine za te novce.
Staro 05.11.2025., 23:38   #20878
RedSky
RedSky's Avatar
Postovi: 425
Imam Xiaomi Stick 4K koji je po specifikacijama slabiji od procesora ovog TV-a i sasvim je ok za ono što koristim: MAXtv, Tivimate, Netflix...
Tako da mislim da je po tom pitanju ok.
Ranije sam koristio Philipsov Android TV, to je tek bio užas...
Zanima me kvaliteta slike i slično...
Staro 06.11.2025., 10:23   #20879
Postovi: 17,143
Pa nećeš puno dobiti. LED ekran u 4k rezoluciji s relativno niskom razinom osvjetljenja.
Android koji je gore će ti loše raditi, gore od ovoga na sticku, bez obzira što je jači od njega.
Pričamo o TV-u od 300EUR, ne možeš očekivati spektakl, ali da nije dobar, nije istina.
Staro 06.11.2025., 11:23   #20880
tiki66
tiki
tiki66's Avatar
Postovi: 2,765
Kako znaš da će loše raditi?
