Staro 28.10.2025., 18:56   #20851
OuttaControl
OuttaControl's Avatar
Lokacija: Dalmacija
Postovi: 5,870
To sve ovisi od covika do covika, ja imam astigmatizam sa 2 metra ne vidim na 55" razliku izmedju 4k i 1080p, super za grafe
Staro 28.10.2025., 18:59   #20852
Postovi: 16,965
Autor pogi Pregled postova
https://pcchip.hr/hardver/tv-i-monit...8k-rezolucije/
Saljem sa mobitela nemogu kalo link
Isto kažu da oko ne može vidjeti znad tipa 60FPS-a, što je nortorna glupost.
Staro 28.10.2025., 19:06   #20853
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,113
Neki kazu i da 100% razlikuju 192kbps MP3 vs FLAC/WAV
Verifikacija poštenog trgovca #1, #2, #3, #4, #5, #6, #7, #8, #9
Staro 28.10.2025., 19:16   #20854
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,579
Kako tko, ali definitivno je istina da je taj 8k najobičnija budalaština. Nemam neki super vid, meni je sa 2m na 55" vrlo vrlo teško razlučiti 4k i 1440p.
Ako je audio oprema prava, tu razliku bi valjda i gluh čuo. Na PC speakerima od 10 eura nema razlike, to je istina.
Staro 29.10.2025., 15:47   #20855
biohazard
biohazard's Avatar
Datum registracije: Jun 2025
Postovi: 47
Autor Exy Pregled postova
pravi maheri audiofili skuže kak se veli i koji kukac leti u zraku, moraš imati nekakvu adekvatnu opremu
biohazard je offline   Reply With Quote
Staro Jučer, 07:28   #20856
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,043
Manufacturers continue to release new TV models featuring Ultra HD and even higher-resolution panels. However, according to a recent UK study, much of this effort may be largely unnecessary, as the human eye has a natural "resolution limit."
A team of researchers at the University of Cambridge set out to determine the true number of pixels the human eye can actually perceive. Using a sliding 4K monitor that could be moved closer or farther from the viewer, they found that the eye can detect far more pixels than previously thought, but that larger TVs often have a pixel density far beyond what most viewers can appreciate.
The experiment led to the identification of what the researchers call "retinal resolution" – the pixel threshold beyond which adding more pixels does not improve the perceived image quality. This limit depends on several factors, including screen size, room lighting, and the distance between the viewer and the display.
> Techspot
Ja znam da ja nemogu razlikovati kad je monitor na 166Hz a kad na 60Hz :P
Staro Jučer, 08:34   #20857
medo
#erase startup-config
medo's Avatar
Postovi: 3,729
Iskoristio sam ove akcije i upiknuo si LG C5. Baš zbog toga sam išao na 55” umjesto na 65”
Odlučio sam zayebati “immersion” efekt. Ekran 65” bi mi previše naprezalo oči na tih 2.1m koliko je ekran udaljen pogotovo na zapečenim titlovima na zemaljskoj TV a koštao bi me 350-400€ više. I trošio bi više struje.
Ovako je slika nešto manja ali prirodnija. Kao da manje izgleda “digitalno”.
Staro Jučer, 10:09   #20858
Exy
Exy's Avatar
Postovi: 2,579
Struja je ključna
Slažem se, za daljinu cca 2m 55" je idealna veličina. 65" dođe kao kad sjediš u kinu u prvom redu
Sad kad imaš C5, RTL Kockica će izgledat bolje nego ikad
Staro Jučer, 10:16   #20859
nub
PREMIUM
nub's Avatar
Datum registracije: Dec 2014
Postovi: 2,163
50 inča s tri metra, pff... amateri. S tri metra su trebali staviti barem 65", optimalno 75-77", da bi imalo smisla istraživanje.
https://www.rtings.com/tv/reviews/by...e-relationship
Zadnje izmijenjeno od: nub. Jučer u 10:32.
Staro Jučer, 11:09   #20860
Postovi: 16,965
85" idealno. Govorim iz osobnog iskustva.
Staro Jučer, 11:43   #20861
Exy
Exy's Avatar
Postovi: 2,579
Gledaš u 85" TV sa daljine od 2m?
Staro Jučer, 11:52   #20862
Postovi: 16,965
3m.
Staro Jučer, 15:03   #20863
okarm
Postovi: 773
meni je s 3- 3.5m 50" taman. imao jedno vrijeme 60", pokusao se uvjeriti da je bolje i pratiti trendove ali sam se nakon mjesec dana vratio na 50tku. ugodnije mi je gledat, a i sam prostor mi je ljepsi.
Staro Jučer, 15:10   #20864
nick praskaton
Asshole
nick praskaton's Avatar
Lokacija: RH
Postovi: 2,360
Autor okarm Pregled postova
hmm, s tri ipo metra udaljenosti, meni bi idealno bilo 75", ne znam kako ista vidis na 50" tvu na toj udaljenosti
Staro Jučer, 16:17   #20865
Postovi: 16,965
Ja u sobi imam nekih 3m do TV-a i gore sam stavio 50" jer više nije išlo. Nemam naočale ni dioptriju, ali ja taj tv ne gledam baš iz razloga jer mi je sve premalo i vidim da se oči naprežu. Žena ima neku minimalnu dioptriju, kaže da joj je sve mutno, ne treba nosit naočale.
Svaka čast, no meni je to negledljivo.
Zadnje izmijenjeno od: Mommistake. Jučer u 16:27.
Staro Jučer, 21:12   #20866
nub
PREMIUM
nub's Avatar
Postovi: 2,163
Dobro sad, negledljivo je malo pregruba riječ. Nije optimalno po izračunu, ali svakako gledljivo. Nekoć su se gledale televizije s 50-65cm i to je bilo kao dobro, a danas se kakti hurca ne vidi i oči se naprežu na 50 inča .
Ja sam prilagodil prostor 65" telki i stavio kauč na nekih 2.70 što je po izračunu idealno i meni isto paše. Mogao bih malo veću dijagonalu za filmove za kino doživljaj, al za igre i tv program, koji je ipak puno lošije kvalitete, je ovako super.
Staro Jučer, 21:24   #20867
Postovi: 16,965
Autor nub Pregled postova
Ja ti kažem, negledljivo je meni. Titlovi mi se mute, borim se.
Išao sam na pregled vida, mali astigmatizam, ali dioptrija 0.25 i jednostavno ne vidim koliko bi htio.
Išao izmjeriti sobu, 3.5m je negdje duga. TV je 50". Ne znam, baš sam izgubio volju gledati gore tv.
Staro Jučer, 21:42   #20868
9800pro
aka Edo, aka Syncros
9800pro's Avatar
Postovi: 1,776
Dobro sad, negledljivo je malo pregruba riječ. Nije optimalno po izračunu, ali svakako gledljivo. Nekoć su se gledale televizije s 50-65cm i to je bilo kao dobro, a danas se kakti hurca ne vidi i oči se naprežu na 50 inča :D.
Upravo to. Ja kad sam kupio Panasonic crt 80cm koji je to šou bio doma. Sa 3.5m udaljenosti na kojima danas gledam 65" tada je tih 32" bilo ogromno. Nisu svi isti. Meni je tih 65" super, mogao bi možda na 77" da je neka super cijena ali više od toga ne. Ali projektor sa druge strane mogu gledati 120" sliku sa iste udaljenosti. Nije isto buljiti u platno i neku telku sa 2-3000 nita hdr-a koji ti izbija zjenice...
Staro Jučer, 21:50   #20869
nub
PREMIUM
nub's Avatar
Postovi: 2,163
Slažem se. Ta svjetlina stvarno počne ubijat kad se gleda kako spada - u zamračenoj prostoriji. SDR materijal stvarno ne treba previše dizat (standard industrije je 100 nita!), jedino HDR zahtjeva 1000.
To mi je malo neobično. Ovaj 65" kaj imam mogu gledati i s druge strane prostorije s tipa 6-7 metara i niš mi se ne mute titlovi.
