Povratak   PC Ekspert Forum > Računala > DIY i Tinkering
Staro 21.07.2025., 11:17   #121
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,593
Autor Sinac Pregled postova
Mislim da će i AMD i Intel morat držat gaće kad se Nividijin ARM laptop pojavi na tržištu. Za sada su rezultati bencheva dosta dobri, još ovisi kako će se grafička kartica ponašati:
https://www.club386.com/nvidia-arm-c...zen-7-9800x3d/
Nije sve u Benchevima i brojkama. Ako nemas punu softwersku podrsku mos ga fuckat.
Staro 21.07.2025., 11:22   #122
Postovi: 8,658
nVidia je već jedno dulje vrijeme u poziciji da nametne i isforsira kaj god ih volja, još samo da poslože hardver do kraja i to je to.
nVidia's long-awaited entry into Arm-based laptop CPUs has hit yet another obstacle. Despite publicly declaring the N1 and its sibling N1x is in full production, the company now faces fresh engineering challenges that threaten to push shipping dates as far back as late 2026. This setback follows an earlier hiccup, reported in early 2025, when some subtle flaws emerged during initial validation. nVidia engineers managed to correct those without a respin, restoring confidence and nudging the timetable back to early next year. Late 2026 now appears set to become the new milestone for when the first N1‑powered notebooks might finally reach store shelves.
Istinabog do kraja 2026. lako moguće da Intel prestane postojati u ovom sastavu, a šrot AMD bude se već snašel.
AMD Ryzen 9 9950X | Noctua NH-U12A chromax.black | MSI MAG B650 Tomahawk Wi-Fi | 128GB Kingston FURY Beast DDR5-5200 | 256GB AData SX8200 Pro NVMe | 22TB WD Red Plus | Fractal Define 7 Compact | Seasonic GX-750
Staro 21.07.2025., 13:28   #123
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,838
Linux distribucije? Windows on ARM? Misliš da Nvidia neće imati pokriveno sve s drajverima? Mislim da će se Microsoft itekako potruditi da ubaci sve drajvere u WoA...
Staro 21.07.2025., 13:41   #124
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,593
Joj kak mi se neda objasnjavat. Driveri su dio price - drugi dio je dostupan softwer...i optimizacija istog za novu platformu. Googlaj kaj da ti velim, nebi bilo prvi put, a jedini faktor koji to moze ovaj put promjeniti je zbilja nvidia ako bude pokazala dovoljno interesa i tvrdoglavosti.
Staro 21.07.2025., 13:51   #125
Postovi: 8,658
Imaju već sve spremno otkad su još za potrebe Grace Hopper platforme iskombinirali ARM CPU i pripadajući GPU, a u ovom slučaju nude provjerenu i podržanu platformu samo u manjem i mobilnom izdanju za mase. Linux podrška sigurno ne bude predmet spoticanja, jer to su već zapravo riješili, a za Windows OS, u slučaju da se Microsoft ne angažira, nVidia ima dovoljno novaca da ih na to prisili ili jednostavno odjebe u korist Linuxa, ako im ne paše, pa nek se kasnije pitaju "kako to".
Zadnje izmijenjeno od: The Exiled. 21.07.2025. u 13:57.
Staro 21.07.2025., 16:16   #126
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,809
Zapravo, pitanje mu je sasvim na mjestu.
Samo o tome kako ce nVidia sloziti firmware stack ce ovisiti koliko ce platforma biti dostupna regularnim i manje regularnim korisnicima.
(Userspace) Softver ko softver, nemas sto posebno - zaista je manji dio problema eventualno napraviti patch za kompajler i Bog da im prosti grijehe.
No hoces li trivijalno moci podici nekakav *nix ili ce biti Qualcomm-Windows seks, to je vec pitanje.
E sad, ako je kult kozne jakne odlucio da ce zakucati x86, onda im je ovo sjajna prilika.
Programer
Staro 21.07.2025., 16:57   #127
medo
#erase startup-config
medo's Avatar
Postovi: 3,733
OK. Dići će se Windowsi na ARMu. I što onda? Hoćeš li moći na tome podići svu silu softwarea koju trenutno imaš na PCu? Ne baš. Netko će to morati modificirati i prekompajlirati da to tamo radi. I tako za svaki komad softwarea koji koristiš.
Nešto će spremno raditi samo ćeš morati instalirati ARM verziju. Nešto ćeš pričekati da to možeš, kraće, dulje ili jedva. Nešto nikada nećeš dočekati.
I to ako nVidia odluči tako i ne krene kao Apple.
Staro 21.07.2025., 17:09   #128
Postovi: 8,658
Tu onda u igru ulazi količina novaca koju su spremni zdrobiti da Microsoft zajedno s nVidijom dovede podršku kak spada uz ono kaj je dosad već službeno podržano za Windows ARM izdanje. Na Linux polju već sad imaju na raspolaganju ARM verzije Ubuntu, Debian, Fedora, Arch, Manjaro, RHEL i (Open)SUSE distribucija zajedno s njihovim pripadajućim softverskim repozitorijima, tak da je dosta toga u samom startu pokriveno, a i onaj Geekbench test se odvrtjel na Ubuntu 24.04.1 LTS ARM izdanju.
Staro 21.07.2025., 18:39   #129
Mladenxy
Mladenxy's Avatar
Postovi: 4,511
Staro 21.07.2025., 19:02   #130
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,593
Autor Bubba Pregled postova
Ma s obzirom kako se sve to dosad odvijalo sam skeptičan. Ok ovaj put je to nvidija pa možda i bude bolje - ali vjerovat ću tek kad vidim par mjeseci nakon izlaska platforme kako stvari stoje....
@Mladenxy > baš to se dogodi kad proizvođač softwera podržava hardwer kak spada ali Apple je tu posebna kategorija.
Staro 21.07.2025., 20:46   #131
Mladenxy
Mladenxy's Avatar
Postovi: 4,511
Djeluje impresivno za hardver u tako tankom kućištu sa takvim performansama.
Staro 22.07.2025., 00:41   #132
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,809
Autor medo Pregled postova
Ne lupetaj. Vec par godina gotovo sav softver radi bez problema out of the box.
https://imgur.com/a/yTeIKeh
S obzirom na to kako su trenutno ozbiljno jaki - mozda nije tako nevjerojatno da se dogodi neka distrupcija. Realno, vec je bilo i vrijeme.
Programer
Staro 22.07.2025., 09:28   #133
Sinac
Sinac's Avatar
Postovi: 2,838
Vidim da je dobar dio vas zaboravio ili prečuo informaciju da je još 2016./2017. Qualcomm vrtio Windowse i softver na platformama s ARM procesorima i da se Intel malo "uzrujao".
Već sam u jednom postu stavio napomenu da se radilo o "punokrvnoj" desktop verziji Windowsa 10 koja je kroz emulaciju vrtila x86 Win32 aplikacije, čak i mrvicu (hardverski/softverski) zahtjevnije poput Adobe Photoshopa i Office aplikacija. Nisam našao podatak je li ta verzija Windowsa bila rana WoA 32 bitna varijanta ili derivat Windowsa RT, ponegdje se na webu tvrdi da je u pitanju klasična desktop verzija s pridodanoj mogućnosti emulacije.
https://www.forbes.com/sites/tiriasr...x86-emulation/
https://www.anandtech.com/show/11477...snapdragon-835
https://redmondmag.com/articles/2016...ragon-arm.aspx
Bili su se pojavili i neki benchmark rezultati koji su pokazali da ARM ima već tada itekakav potencijal da ugrozi i veće igrače. Ne znam koliko je ovo Intelovo rogoborenje usporilo WoA, ali mi je drago da se ARM probija na tržištu, barem zbog manje potrošnje el. energije i manjeg zagrijavanja.
Zadnje izmijenjeno od: Sinac. 22.07.2025. u 09:52.
Staro 22.07.2025., 10:25   #134
Postovi: 8,658
Da, u pravu si, komentirali smo i to u sklopu Intelovih bajnih poteza i odluka, a za ARM su se već u samom startu zajebali, posebice kad im se pružila prilika kakvu nisu mogli ni sanjati, ali su ju kao i sve ostalo, okarakterizirali kao nedovoljnu i nebitnu.
Under CEO Paul Otellini, Intel turned down a deal to make iPhone processors because it did not stand to profit enough from the arrangement.
Instead, Apple used chips based on designs from Arm Holdings, whose tech now dominates the mobile market.
Staro 22.07.2025., 14:05   #135
medo
medo's Avatar
Postovi: 3,733
Presvetli, držim te za tvoju as usual nekulturnu riječ.
Staro 22.07.2025., 14:24   #136
Ivo_Strojnica
PRO
Ivo_Strojnica's Avatar
Postovi: 4,928
čisto da vam kažem: Windows Fax ne radi na ARMu.
meni dealbrejker.
Staro 22.07.2025., 14:31   #137
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,809
Ne pamtim tu pricu za uzrujavanje bilo koga, ali Windowsi su se od svojih pocetaka vrtili na kojecemu neintelovom, od Alphe APX serije, PowerPC 600 serije, MIPS R4000 serije, Hitachijeve SuperH-3 i SuperH-4 serije pa do ARM Thumb-2 kompatibilnih procesora i onda konacno AArch64.
Windows RT je bio poluiskoristiv a koliko me pamcenje sluzi, W10 je imao neku donekle krnju emulaciju koja je radila samo s 32bitnim softverom ili tako nesto.
Ono sto je zapravo zanimljivo jest kako su Windowsi koristili sve te arhitekture na neke vrlo neobicne nacine, od ASM-a do pozivnih konvencija.
U tim bizarnostima je svakako, tradicionalno i poslovicno, prednjacio IBM.
https://classiccmp.org/pipermail/cct...ly/020304.html
Jos nisi shvatio da su tvoje tlapnje problem, a ne moje "nekulturne rijeci"?
Bilo kako bilo, nisam naletio na userspace softver (osim DirectX baziranih igara, to nisam isprobavao) koji ne radi na Windows 11 ARM varijanti kroz emulaciju. Eto, ukljucivo i PCI-Z, za kojeg igrom slucaja znam kako je pisan, pa sam ostao ugodno iznenadjen kako je zapravo cijeli ABI ispravno emuliran, a ne samo da sam koristio razne prljave trikove, nego se radi o core Windows libu.
meni dealbrejker.
Mozda je vrijeme da migriras na neku cloud faks uslugu?
Programer
Staro 22.07.2025., 16:06   #138
Chuby
Chuby's Avatar
Datum registracije: Feb 2004
Postovi: 1,311
Baš me zanima reakcija prosječnog korisnika kad kupi nVidia (dakle gamerski laptop) na ARMu i onda se krene ozbiljno igrat. A baš si nekak mislim kak bu jeftin by nVidia.
Al ok, ionako imaju svu lovu svijeta pa se mogu zajebavat
Chuby je offline   Reply With Quote
Staro 22.07.2025., 17:34   #139
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,593
> Update
TLDR:
MacBook Air M1 barely plays the game at 12 fps
Staro 22.07.2025., 19:07   #140
medo
medo's Avatar
Postovi: 3,733
Još ćemo mi plakati za PCjima
Staro 22.07.2025., 22:56   #141
Sinac
Sinac's Avatar
Postovi: 2,838
Malo optimizma za gejmere na ARM-u, novi Nividijin ARM CPU bit će dobro potkovan mogućnostima grafičke kartice:
https://www.tomsguide.com/computing/...we-know-so-far
Either way, it's looking to leverage the power of an RTX GPU, with these Blackwell-based GPUs being used in RTX 5060 Ti or RTX 5060 graphics cards.
Staro 23.07.2025., 06:57   #142
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,593
Iskreno mislim da trenutno Gaming nije ni tolko bitan, samo da sve ostalo radi kak spada i da je omjer performanse/potrošnja na mjestu. Igre optimizirane za tu platformu će onda već doć s vremenom.
Staro 23.07.2025., 08:53   #143
Dr. Strange
Datum registracije: Aug 2020
Postovi: 900
Ako Nvidia ne može značajnije pokrenuti gaming na ARM-u, tko onda može?
Staro 23.07.2025., 09:37   #144
Postovi: 8,658
Nitko, jer hardver bude kao i u Qualcomm slučaju sasvim solidan, odnosno bolji uz dodatak Linux podrške, ali za Microsoft dio priče, nVidia bude morala odlučiti koliko im taj izlet vrijedi.
On the Microsoft front, nVidia is apparently waiting for the company’s ‘next-generation operating system’. This is presumably Windows 12, which rumours suggest will launch later than expected resulting in Windows 11 25H2. Of course, N1X needs the ARM version of the OS up and running rather than the more commonplace x86 variant.
Staro 23.07.2025., 11:15   #145
strikoo
strikoo's Avatar
Postovi: 1,057
ILI
ako naprave sa Valveom Steam box na ARM platformi koji ce se brutalno prodavati
strikoo je offline   Reply With Quote
Staro 23.07.2025., 11:19   #146
Postovi: 8,658
Da, tim više, jer Valve još od početka ove godine priprema teren za ARM.
Recent SteamOS code commit indicates that Valve is in fact testing ARM support for SteamOS.
Staro 24.07.2025., 15:22   #147
Exy
Exy's Avatar
Lokacija: Zagreb, Črnomerec
Postovi: 2,713
Dobro i što sad ja kao jedan (ispod)prosječni korisnik koji ne zna razliku između Cisca i cisc-a dobijem sa tim ARM laptopom? Dulje trajanje baterije?
Jel i dalje mogu skinut nekakav program sa opskurne i nimalo sumnjive web stranice i zavrtit ga? Ili sam u Microsoft store only modu? Zadnji Intel Core i dalje pokreće programe pisane u vrijeme 486 a što je sa tim čudom? Jel mogu igrat Age of Empires 2
Staro 24.07.2025., 15:31   #148
Postovi: 8,658
Intel Lunar Lake i AMD Strix Point/Halo danas nude sličnu autonomiju kao i ARM laptopi, ali trajanje baterije je svakak najveći plus uz taj nivo ponuđenih performansi. Kaj se aplikacija tiče ono kaj već sad radi na Linux ili Windows ARM izdanjima bude pokrilo većinu korisnika, dok su igre upitne i ovisne o tome koliko im se uopće isplati određene naslove posložiti, a tu onda dolazi nVidia sa svojim interesima.
Staro 12.09.2025., 15:53   #149
Sinac
Sinac's Avatar
Postovi: 2,838
Gužva na terenu, ali u pozitivnom smislu:
https://www.gsmarena.com/arm_introdu...news-69450.php
Staro 27.09.2025., 11:32   #150
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,593
Da malo dignemo temu:
The industry may never embrace PCs shaped like drink coasters or modular monitor bases. However, if even part of these concepts reaches market, Qualcomm's push to expand Snapdragon computing beyond tablets and notebooks could redefine what a desktop looks like.
At Snapdragon Summit 2025, Qualcomm highlighted the performance of its new Snapdragon X2 Elite and Elite Extreme processors. Alongside laptops and detachable tablets, the company unveiled two small-form-factor desktop concepts that pushed PC design boundaries. One was a disc-like mini desktop, and the other a modular all-in-one, with the computer designed to slot into a compatible monitor base.
> Techspot
