Rezultati ankete: Grid.org Team
Osnujmo Team 111 70.25%
Ne zanima nas 8 5.06%
Ma boli me briga 39 24.68%
Glasači: 158. Ne možete glasati na ovoj anketi
Staro 18.11.2005., 15:43   #871
panoramix
driver
panoramix's Avatar
Postovi: 1,083
Wink
Veseli me što sam po CPU time ušao u top ten pa još da uđem i po obrađenim rezultatima, onda mogu na masters...
Staro 21.11.2005., 21:37   #872
FERRYS
AutoCad & Allplan expert
FERRYS's Avatar
Postovi: 2,159
meni se posljednja 2 dana nemoze spojit na server....
jos kome?
none
Staro 21.11.2005., 22:41   #873
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
isti problem al mi se spojio danas u 9 ujutro nakon 2o minuta...
Vec me malo zivciraju takve stvari...
Staro 21.11.2005., 23:59   #874
gpremec
matroxfanatic
gpremec's Avatar
Lokacija: Zagreb, na zapadu
Postovi: 2,444
Originally posted by gpremec
Takodjer, ovo je svima nama interesantna vijest:
"Grid.org upgrade: Grid.org will be physically moving to a new facility in the next week. This will provide better reliability and is part of the Grid.org migration. There was a small outage this weekend due to some hardware maintenance that was performed in preparation for the facility move. Please note that next weekend there will be some additional outages. Grid.org must be completely powered down in order to move. This will include the forum, member web, and the grid itself. Since this is not a trivial outage, we cannot give an exact time that Grid.org will be down. The outage will take as long as it takes. "
Cini se da nekima od vas zaista treba crtati, kada vec ne citate postove.
Zadnje dvije vijesti sa http://forum.grid.org :
Grid.org scheduled outage
Dear Members,
This is a reminder that Grid.org will be physically moving to a new facility this weekend. This will provide better reliability and is part of the Grid.org migration. Grid.org must be completely powered down in order to move. This will include the forum, member web, and the grid itself.
Since this is not a trivial outage, we cannot give an exact time that Grid.org will be down. The outage will take as long as it takes and it may be a day or two before everything is back online.
_________________
Robby Brewer
Senior Support Engineer
United Devices
Grid.org back up
Dear Members,
It looks like Grid.org is back up now. I have seen posts that workunits are being downloaded so I think everything is working correctly. If you do encounter any strange behavior please post to Member to Member Support so that we can investigate.
Our entire facility move has not completed yet, so there may be another interruption at some point although I am not expecting one. As soon as I have more information from our IT department regarding the move, I will share it.
Thank you for your contribution.
_________________
Robby Brewer
United Devices
Holly: "Appreciate what vou've got, because basically, I'm fantastic!"
my UD stats
gpremec je offline   Reply With Quote
Staro 22.11.2005., 01:48   #875
Vuco
Vuco's Avatar
Postovi: 9,505
Gle gpremec, kontam ja sve to, al stvarno se u zadnje vrijeme malo previse izvlace...
Ovo pa ono, pa sad mjenjamo ovo...bla bla, bla...
Znam da nije lako organizirati takvu jednu stvar, al nije samo jedan tamo zaduzen za sve to...
Al ajde, ako se dogodi da, nakon sto se presele, i nebuse 3 mjeseca nikakvih problema, castim te
Staro 23.11.2005., 01:07   #876
gpremec
matroxfanatic
gpremec's Avatar
Postovi: 2,444
Mnogi ce cesto reci/napisati kako znaju/razumiju da takav tip posla nije jednostavan, jada-jada-jada, bla-bla-bla, truch-truch-truch, ali na zalost to su izrazi ljudi koji se nikada nisu susreli s kompleksnoscu problematike takvog posla. Nije sad da ih branim, ali i sam radim takav posao i razumijem sto znaci imati problem u tako velikom zivom sustavu.
Svi samo vidimo krajnji rezultat takvog posla (radi ili ne radi), ali malo tko je zaista imao prilike i sudjelovati u necem toliko kompleksnom, a kamoli zaista i raditi takav posao. Kolicina vremena koja se potrosi na same pripreme je ogromna, a sav posao se uvijek radi vikendom (kada kazem vikendom, onda mislim od subote u podne do ponedjeljka do 6 ujutro, i to bez pauze). Nejedamput sam morao dizati/upgradeati sustave zivih servera vikendom, tako da su mi izjave tipa "izmotavanje" i "prckanje" samo pokazatelj neshvacanja problematike vezane uz rad na server u zivoj okolini.
Problemi i ispadanja sustava? Na zalost, i do toga dolazi, a kada pocnu, onda se nizu jedan za drugim, a uzrokovani su necim sto je netko napravio ili nije napravio davno/nedavno prije. Uostalom, grid.org je bez znacajnih problema radio dvije-tri godine, a tek je zadnjih 6 mjeseci bilo ispada sustava. Premjestanje sustava na drugu lokaciju je odluka kako bi se razrijesili problemi u koje upadaju zadnjih pola godine, a vrijeme ce pokazati koliko su to dobro odradili.
I uza sve te ceste ispade zadnjih pola godine necu odluciti prestati s donacijom procesorskog vremena u svrhe potrage za lijekom protiv raka. Naravno, svatko odlucuje za sebe, i svatko ima druge razloge zasto sudjeluje u grid.org ili nekom drugom projektu takvoga tipa.
my UD stats
Staro 23.11.2005., 03:23   #877
Vuco
Vuco's Avatar
Postovi: 9,505
Ja se ispricavam, nisam imao namjeru se svadjati ili izazvati svadju...jer nemam nimalo pojma o samoj problematici kod vodjenja takvog projekta...al znam da kod kompjutera, cim nesto prvo podje krivo, sve ostalo ode u k...
Ali kazem, njima je u interesu da poboljsaju sustav, ja cu i dalje isto pomogati oko raka dok mi ne pukne...
Al mislim da i oni snose dio krivice (makar minimalan jer kompjuteri su najcudnije stvari na svijetu, u jednom trenu rade savrseno, a onda poludi u sekundi)
Ajde da zavrsimo ovu diskusiju, u kojoj sam ja mozda malo pretjerano reagirao, i to priznajem...
slazemo se da je najbolje da srede stvari na odusevljenje i njih i nas...
Staro 05.12.2005., 13:13   #878
FERRYS
FERRYS's Avatar
Postovi: 2,159
ljudevi najte se živcirat.
ja sam peglam po gridu i gledam scor, a da idem jos i na njifov forum, to mi se bas i neda nit me ne zanima....
none
Staro 07.12.2005., 16:46   #879
SniperWolf
SniperWolf's Avatar
Postovi: 4,193
Meni je UT samo tu da nešto radi dok me nema/surfam da mi tih 2600MHz ne čuči beveze
imam 16639 bodova
Pošteni Trgovci: 1,2
Staro 09.12.2005., 21:21   #880
FERRYS
FERRYS's Avatar
Postovi: 2,159
evo ja laga no dosetuckao do 20-og mjesta na listi clanova:clap:
none
Staro 11.12.2005., 12:58   #881
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,809
Question Ista novog u godinu dana?
Sredjeno bezobrazno zauzece memorije u Windblowsima?
Moze li se vrtiti na necem drugom osim Wintelu?
Programer
Staro 15.12.2005., 19:48   #882
Vuco
Vuco's Avatar
Postovi: 9,505
@bubba
neznam kako je bilo sa zauzecem prije godinu dana, al evo meni danas UD uzima 10-11MB memorije...ni vise ni manje...
Sad neznam jel zdere vise kad dela rozetu, jer ja do jucer sam delao samo cancer...
Za ostale OS-ove neznam jer, evo stoji mi Knoppix pred nosom i nemam DVD u kompu da ga pokrenem (onaj kad se sve boota sa CD-a)...
Staro 15.12.2005., 22:19   #883
koletna
koletna's Avatar
Lokacija: Varazdin
Postovi: 121
aha, zato roseta dere prek 200 mega
koletna je offline   Reply With Quote
Staro 16.12.2005., 00:11   #884
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,809
Dakle, same old story. Zaista, mocan projekt... Steta.
Programer
Staro 16.12.2005., 03:57   #885
Vuco
Vuco's Avatar
Postovi: 9,505
evo sad skinuo i radim rosettu i uzima mi 25MB meme:confused:
a imam slobodno jos 250MB tako da...
Staro 16.12.2005., 15:34   #886
SniperWolf
SniperWolf's Avatar
Postovi: 4,193
Meni isto 25mb....
Staro 17.12.2005., 22:08   #887
Vuco
Vuco's Avatar
Postovi: 9,505
Sinuo rozetu prije par sati, trenutno je na 15% a proslo je 9h i zauzima mi 5,4MB??
Jos do sada mi se nije dogodilo da uzima preko 50MB...:confused:
Staro 20.12.2005., 11:51   #888
FERRYS
FERRYS's Avatar
Postovi: 2,159
meni na oba kompa trenutno gnjavi rozettu, svaka na nekih 30% i 50h. inace ni jedna mi ne zauzima preko 10mb
none
Staro 29.01.2006., 23:59   #889
gpremec
matroxfanatic
gpremec's Avatar
Postovi: 2,444
Vidim da je komunikacija na ovom threadu malo zamrla.
Srecom, nije zamro sam team: bodovi, procesorsko vrijeme i kolicina obradjenih paketa se gomilaju.
my UD stats
Staro 08.02.2006., 12:39   #890
panoramix
driver
panoramix's Avatar
Postovi: 1,083
stotka!
Ponosno javljam da sam dobacio do 100.000 !
Staro 10.02.2006., 20:09   #891
FERRYS
FERRYS's Avatar
Postovi: 2,159
ja na 100 dana...
none
Staro 11.02.2006., 10:55   #892
Costa
Costa's Avatar
Datum registracije: Aug 2003
Postovi: 3,193
Re: stotka!
Svaka cast
Jos malo pa sam preko 50k.
Staro 11.02.2006., 11:10   #893
panoramix
driver
panoramix's Avatar
Postovi: 1,083
Re: Re: stotka!
Originally posted by Costa
Svaka cast
Ajde, ajde, sad bar obrađeni rezultati putuju par sekundi a ne ko mi bokci na 64/64...
Staro 12.02.2006., 20:46   #894
rendula
Lokacija: Zagreb, Trešnjevka
Postovi: 5,778
Počeo sam i ja opet vrtiti grid...al imam problem...ne želi mi poslati rezultate, nikako da se spoji na server, jel treba neki port ili tak neš poštelati?
Staro 12.02.2006., 20:56   #895
domy_os
domy_os's Avatar
Postovi: 19,022
Evo da vam se i ja priključim. Što je sve potrebno za to? Kak se na kraju zove team? PC Ekspert Forum?
EDIT: Zašto se neće regat?
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 12.02.2006., 21:05   #896
panoramix
driver
panoramix's Avatar
Postovi: 1,083
Točno, PC Ekspert forum je team a na početku ovog topica imaš sva uputstva za priključenje, doborodošao u team!
Staro 12.02.2006., 21:10   #897
Costa
Costa's Avatar
Postovi: 3,193
Nije nesto u redu s njihovim serverom. Ni meni nece poslati.
Staro 15.02.2006., 13:07   #898
Black Dragon
Black Dragon's Avatar
Lokacija: Agram
Postovi: 2,983
Sve ponovo radi ... dva dana server neš nije radio. Stanje PC Expert krančerske nacije
Current Members 100
Retired Members 4
Total CPU Time(y:d:h:m:s) 23:010:16:01:36
Points Generated 5,016,720 (# 693)
Results Returned 16,073
Eto odvališmo i milestone od 5.000.000 i bližimo se 24 godini doniranog procesorskog vremena ...
Staro 15.02.2006., 13:25   #899
Costa
Costa's Avatar
Postovi: 3,193
Presao 50k
Staro 15.02.2006., 14:02   #900
domy_os
domy_os's Avatar
Postovi: 19,022
Jel može neko ukratko objasnik kako treba popunit podatke, kako se ubacit u team i ostalo. Hvala.
