Staro 25.12.2005., 11:57   #1
Costa
Costa's Avatar
Datum registracije: Aug 2003
Postovi: 3,193
Nova verzija programa
Pomislih da bi bilo dobro imati jednu temu u kojoj ce se upisivati novoizasle verzije raznih programa. Kad izadje nesto novo napravimo odgovor s linkom, popisom promjena i eventualno kratkim opisom.
Staro 25.12.2005., 12:04   #2
Costa
Costa's Avatar
Postovi: 3,193
IrfanView v3.98
http://irfanview.com/
Promjene:
  • Option to support IrfanView by installing Google Toolbar and/or Google Desktop Search (OPTIONAL !)
    New Thumbnail window option: Load thumbs from all subfolders (CTRL+F)
    Alpha blending effect added for slideshow/fullscreen (Properties->Fullscreen)
    New options for fullscreen/slideshow: Set text position/alignment
    PlugIn for AFPL Ghostscript: PS, EPS, PDF formats (see Properties->PlugIns)
    Support for CGM/SVG formats : CADImage.DLL (Shareware, see i_plugins.txt)
    Support for HDR format (Formats PlugIn, thanks Kevin)
    New option for DigiCam RAW formats: Load half size image (Properties->PlugIns)
    New effects added: Sepia, Raindrops, Fragment etc. (Thanks to GENiEBEN :-)
    Option to set the start corner for crop and text-layout in batch mode
    New placeholders for Date/Time: %Y, %m, %d (see help file for examples)
    New placeholders: $M (multipage index), $d (directory name)
    Most of normal placeholders can be used for "/convert=" too
    Option to hide main window in Thumbnails mode (Properties->Misc 1)
    New lossless JPG dialog option: Set DPI value
    Set loading options for Ghostscript, MrSID, JPM: Properties->PlugIns
    New JPG save option: Reset EXIF orientation tag
    New advanced slideshow dialog option: Play in window mode
    Command line option for EXE Slideshow: /monitor=X (start on monitor X)
    Command line option: /dpi works now for /scan, /scanhidden and /batchscan
    New special INI options to hide caption/menu bar permanently (see FAQs)
    Support for 3GP format (Quicktime PlugIn)
    New hotkeys: Red eye, Fullscreen text, Direct print, Lossless JPG (see help file)
    Several PlugIns are changed/updated, please install the newest versions
    http://www.irfanview.com/plugins.htm
    Some minor bugs/features fixed/added (slideshow, print)
Zadnje izmijenjeno od: Costa. 12.01.2006. u 19:48.
Staro 12.01.2006., 19:51   #3
Costa
Costa's Avatar
Postovi: 3,193
Mozilla Thunderbird 1.5
http://getthunderbird.com
Promjene:
  • # Automated update to streamline product upgrades. Notification of an update is more prominent, and updates to Thunderbird may now be half a megabyte or smaller. Updating extensions has also improved.
    # Sort address autocomplete results by how often you send e-mail to each recipient.
    # Spell check as you type.
    # Saved Search Folders can now search across multiple accounts.
    # Built in phishing detector to help protect users against email scams.
    # Podcasting and other RSS Improvements.
    # Deleting attachments from messages.
    # Integration with server side spam filtering.
    # Reply and forward actions for message filters.
    # Kerberos Authentication.
    # Auto save as draft for mail composition.
    # Message aging.
    # Filters for Global Inbox.
    # Improvements to product usability including redesigned options interface, and SMTP server management.
    # Many security enhancements
Staro 13.01.2006., 02:19   #4
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
ja za to koristim
MajorGeeks
DeadMan+ je offline   Reply With Quote
Staro 13.01.2006., 15:31   #5
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,859
može MR.Costa ali neka se otvori još jedan podforum i neka se on podjeli ne znam na AV program, tweak utiites,dvd programi itd.
Staro 13.01.2006., 23:51   #6
Postovi: 7,568
Ovo bi moglo biti od koristi.
Staro 06.03.2006., 11:29   #7
Costa
Costa's Avatar
Postovi: 3,193
Media Player Classic 6.4.8.8
https://sourceforge.net/project/show...ease_id=398635
Promjene:
  • - two pass bicubic shader, bilinear more optimized
    - dropped subtitles are loaded instead of opening them as a media file
    - thumbnail image generator
    - dsm demuxer can output individual streams into files (context menu -> demux...), the raw data is corrected if possible, like subtitles are output
    to srt/ssa/vobsub, frame header added to aac, wave header to pcm, etc.
    - better support for quicktime files by the mp4 splitter, more track types are recognized and also reads zlib compressed headers
    - dvd navigator's software dvd region check is disabled using the detours lib, there is still a hw region check built in the firmware of the drives, unless it
    was flushed with a region free firmware it will still not work and may cause strange problems like freezing the player
    - the mpeg ts splitter can repack h264 streams in "mp4 style" packets for decoders so they won't crash (ffdshow, coreavc)
    - "next aspect ratio preset" command
    - yv12/i420 is no longer a disallowed format when using "vmr9 (renderless)" as the renderer, holding the ctrl key when loading a file will still disable it, the current display drivers should not have that color conversion bug anymore but just in case...
    - vmr9 (renderless) mixer mode available, it allows deinterlacing and other vmr9 features, off by default because it is slightly slower
    - Haali's video renderer can be directly selected in the options (subtitling works, shaders don't)
    - mpeg decoder sse2 optimizations (most noticable at hdtv resolution), optional interlaced output, new "field shifter" deinterlacing mode
    - nero's "vobsub" inside mp4 supported
    - clicking another window on a different monitor while mpc is playing in fullscreen will not restore it to normal size anymore, if another application grabs the focus, its name and window title will be displayed on the status bar of mpc
    - graph builder of the filter graph manager was rewritten (again), let's hope nothing is more broken than it was :)
    - new built-in async reader for udf sources, currently only works with the internal mpeg splitter because others aren't prepared for constantly growing files, use the following syntax as the file name: udp://[<multicastgroupip>]:<port>/[<mediasubtypeguid>], where "multicastgroupip" is optional and "mediasubtypeguid" can be used to specify the subtype of the stream, for example udp://:1234/{e06d8023-db46-11cf-b4d1-00805f6cbbea} means transport stream, it will also work fine without the subtype, just selecting the right splitter will take a little longer
    - the checked state of the "enable subtitles" menu item is preserved, this means you can disable subtitling with the vmrs now without having to turn it off for each newly opened file
    - floating toolbars are saved, next time mpc opens they will appear floated and at the same position on the desktop
    - normalizer/booster was moved to the audio switcher, to avoid high spikes lowering the volume too much the normalizer regains 5% per second now
    - "quick open file" menu (similar to vlc's)
    - options/filters section was redone a bit, the internal filters have their own property pages, mpc won't be controlling them directly anymore
    - there is a changelog this time! :)
    other fixes:
    - random crash when seeking files with mp3 audio streams and using the internal decoder
    - compatibility with the oggds/vorbis decoder restored (it is a bug in the ogm vorbis decoder btw)
    - blank checklist elements in options (external filters now, overrides before)
    - run-time error when loading files with certain unicode characters in the filename
    - unicode id3 tags, byte order of le/be utf-16 tags was mixed up
    - repeated languages loading vobsub subtitles
    - dvd angle switching (angle number was off by 1 for many years lol ;)
    - long delay when doing "seek to keyframe" with the avi splitter
    - fading dvd subpics (~ multiple entries in DCSQT)
    bad news:
    - resource ids were cleaned up and renumbered, the old command assignments are lost, sorry.
    Notes:
    v2 update (2006-03-05)
    - matroska splitter fixed
Staro 07.03.2006., 10:19   #8
Rivi
Ovo ispod nisam ja! :)
Rivi's Avatar
Datum registracije: Sep 2002
Postovi: 1,692
Nije problem! Mogu ja otvorit temu, stavit je sticky, a vi u temu stavljajte verzije programa. Ja ću link prebacit u svoj prvi post i uvijek ćemo imati update.
Tako se neće desit da 5 ljudi stavi isti link, jer će u prvom uvijek pisati najnovija vezija.
Ajde, još koji prijedlog, pa da otvorimo...
Potpisujem!
Rivi je offline   Reply With Quote
Staro 07.03.2006., 10:21   #9
Rivi
Rivi's Avatar
Postovi: 1,692
Nego, imamo već jednu jako dobru temu, šta ju je davno otvorio Tor.
http://forum.pcekspert.com/showthread.php?t=16948
Evo je, malko poviše.
Možemo napravit nešto slično tome?!
Potpisujem!
Staro 07.03.2006., 10:26   #10
Costa
Costa's Avatar
Postovi: 3,193
Nemam pojma. Meni se chinilo OK napisati kad izadje nova verzija nekog korisnijeg programa. Ne bih sad za svaki pisao vech samo za one koji mi pashu
Recimo ovaj zadnji MPC donosi puno promjena.
Staro 21.03.2006., 10:13   #11
Costa
Costa's Avatar
Postovi: 3,193
foobar2000 0.9
http://www.foobar2000.org/
Dodatne komponente se mogu naci na:
http://www.foobar2000.org/components/index.html
http://foosion.foobar2000.org/0.9/
http://pelit.koillismaa.fi/plugins/
http://kode54.foobar2000.org/
Promjene:
  • * Reworked UI structure, removed various redundant / rarely used features.
    * New: Media Library, replacing old “database” functionality.
    * Improved playlist management - better handling of multiple playlists, native multilevel undo and more.
    * Changes in title formatting script (field remappings) to make common operations easier.
    * New: Converter, replacing old “Diskwriter” component. Includes album image writing (cuesheet creation, direct encoding to MP4 with chapters), preview generation and multi-CPU optimizations. Most popular encoders are supported out-of-the-box; more encoders can be added using generic commandline encoder setup.
    * Improved support for specific file formats: faster tag updates with MP3 and FLAC, new native ID3v2 support, rewritten MP4 support now including chapters, rewritten cuesheet handling with improved handling of embedded cuesheets, improved AAC streaming support, and more.
    * Various speed optimizations, improved UI responsivity during time-consuming operations; better handling of overkill playlist scripts.
    * New: file type associations page in preferences.
    * New and improved ReplayGain scanner with proper multichannel support and multi-CPU optimizations; now with option to apply RG adjustment directly to audio data in MP3 files.
    * Improved audio CD support, with simple secure ripping functionality.
    * Rewritten network code.
    * Improved security by replacing various third party libraries with own implementations.
    * Various usability improvements.
    * Dropped Windows 95/98/ME/NT4 OS support. Windows 2000, XP or newer is now required.
