Staro 19.03.2019., 22:13   #1
Blue Spirit
Blue Spirit's Avatar
Datum registracije: Apr 2004
Lokacija: ZG - Dubrava
Postovi: 2,227
Monitor 144 Hz skipa frejmove u igrama - Imam li pravo na drugi monitor ?
Prijatelj ima problema sa monitorom koji je spojen preko DISPLAY porta.
nisam znao gdje bi postao problem tu ili u temi nVidia FreeSync/Adaptive-Sync podrška: Pitanja, informacije, mišljenja i savjeti
ako treba neka admin premjesti ...
Lenovo Legion Y25-F 10 144hz free snyc
Slika šteka - nije fluidna prilikom igranja COD 2 i RING of Elysium , Assassin's Creed i LOL-a.
Nosio je monitor u trgovinu u kojoj ga je kupio i rekli su mu da distributer lenova zna za taj problem.
Te da mu sigurno neče zamijenit taj monitor.
Zar nebi on trebao dobiti novi monitor ili povrat novca ako monitor ne radi onako kao što je napisano - deklariran po specifikacijama ?!
PC:
GTX 1060 6 gb ( naveo sam dolje u postu da drugi i sa RX 580 imaju isti problem)
Ryzen 5 1400
8 GB RAM
https://forums.lenovo.com/t5/Y-Gamin...ng/m-p/4021320
I have the exact same issue. When running the monitor at 144hz, everything is choppy, when I switch to 120hz, everything runs smooth. I am on an Nvidia card, so I don't have freesync, but I don't want it. I simply want 144hz stable refresh rate
https://forums.lenovo.com/t5/Y-Gamin...Hz/m-p/4283526
Hello! I've got this monitor recently and everything is fine. No frame skipping, HDR working fine... but freesync does not work at 144Hz or below. I test it on League of Legends as its config make it easy to test and it works fine at 120Hz, and i think its okey at 130Hz, but i'm not sure as i think i saw tearing in some ocasion.
Isn't suppose to support freesync up to 144Hz? I've got an RX 580.
Slike frejm testiranja
Lenovo Legion y25-f 10 144hz frame skiping https://forums.lenovo.com/t5/Y-Gamin...4021320/page/5
https://imgur.com/a/JdH1a
/connect 185.107.96.125:28990
server rcon: oldschool
Zadnje izmijenjeno od: Blue Spirit. 20.03.2019. u 00:35.
Staro 19.03.2019., 22:42   #2
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,630
Trebalo bi probati kako se ponaša na nekoj AMD kartici na 144Hz i uključenim Freesyncom
Postoji mogućnost da se radi o 120Hz panelu koji je tvornički overclockan na 144Hz, ali nemože raditi kako spada na tih 144Hz
Kolega imao slučaj tako sa jednim Asusom pa ga je vratio i dobio povrat novaca jer je bio kupljen u manje od 6 mjeseci pa je prošlo kao tvornički nedostatak
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 19.03.2019., 22:45   #3
Blue Spirit
Postovi: 2,227
Monitor je star 5 mjeseci.
Vec sam naveo da tip sa RX 580 ima isti problem.
Mogu mu ja posudit svoju RX 580 da proba s njom, ali sumnjam da ce i s njom nešto postić...
Staro 19.03.2019., 22:54   #4
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,630
Nisu svi monitori isti
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 19.03.2019., 22:58   #5
Blue Spirit
Postovi: 2,227
Što dalje ako i sa RX 580 bude ista stvar ?
Dal onda ima pravo na novi monitor ili povrat love ako monitor ne radi unutar propisanih specifikacija ?
Staro 19.03.2019., 23:02   #6
Revolver3844
Datum registracije: Apr 2017
Lokacija: SB
Postovi: 719
Ako ga ima već 5 mjeseci pretpostavka je da je problem uočio već davno ?
Treba stisnut taj dućan malo ako misli dobit drugi ili povrat love pa da uzme neki skroz drugi monitor.
kakva im je to fora da odjeb kupca koji ima problm sa izjavom znaju oni za problem al to vam neće proći ? LOL
Revolver3844 je offline   Reply With Quote
Staro 19.03.2019., 23:14   #7
Blue Spirit
Postovi: 2,227
Vraga misli je da ga .ebu windowzi i u zadnjih 3 mjeseca usnimio ih je preko 15 što 7 icu što 10 tku puta.
Tek prije 7 dana skužio da je do monitora
Staro 19.03.2019., 23:16   #8
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,630
Može tražiti po zakonu povrat novaca ako hoće samo neka to rješava odmah dok mu nije prošlo 6 mjeseci
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 19.03.2019., 23:22   #9
Blue Spirit
Postovi: 2,227
Na šta da se pozove , na koji zakon ?
Nedostatak da proizvod ne radi unutar tvorničkih specifikacija ili ?
EDIT: sad mi je javio da je ipak star 6 mjeseci - kupljen 19.9.2018
Ima li nade da dobije drugi ili povrat novcas obzirom na starost 6 mjeseci ?
Zar nebi to i po garanciji bilo tvornički nedostatak ili ?!
Zadnje izmijenjeno od: Blue Spirit. 19.03.2019. u 23:39.
Staro 19.03.2019., 23:46   #10
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,630
Ja bih ga nosio opet u dućan i tražio reklamaciju jer je monitor neispravan s obzirom na to da ne radi po specifikaciji kako bi trebao
Naravno, pod uvjetom da ne radi dobro i na AMD kartici sa uključenim Freesyncom
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 19.03.2019., 23:58   #11
fishkal
fishkal's Avatar
Datum registracije: Dec 2009
Postovi: 1,116
Reklamiraj, a od dućana traži da te svoje fore o "zna proizvođač ali ne prizna garu" daju napismeno da se možeš obratiti tržišnoj inspekciji i ministarstvu gospodarstva.
Mislim da će te malo ozbiljnije odmah shvatiti.
Gledam, čitam, kad ne znam pitam!
fishkal je offline   Reply With Quote
Staro 20.03.2019., 00:11   #12
dadoremix
dadoremix's Avatar
Postovi: 4,769
a probaj sročit neki mail samom LG-u
možda netko nekaj pametno odgovori
poslikaš, serijske brojeve im dostaviš
ko zna
Staro 20.03.2019., 02:16   #13
Blue Spirit
Postovi: 2,227
Našao sam da bi novi firmware trebao rješit problem ...( prijatelj je kao "sve procitao i pregledao" i kao "nema rješenja" ; prisjeo mu je monitor i PC zadnjih 3 mj )
Cini se da su fixali problem 2-3 mjeseca nakon što je on kupio monitor ( 19.9.2018 )
PITANJE: Monitor se predaje u trgovinu tamo gdje ga je kupio (u Požegi) i ona ga šalje u ovlašteni servis (na jam. listu piše: Microline u ZG) jelda ?
Pretpostavljam da ce bit bez monitora min 10 - 15 dana.
https://forums.lenovo.com/t5/Y-Gamin...4021320/page/6
datum postova: 23.01.2019
Juraj_Lenovo (Lenovo forum ADMIN) :
It has been tested, the new firmware is confirmed to work and to completely fix the issue. If you're buying a new monitor, it depends on from where you buy it and what batch it is.
The latest monitors which are getting out of factory do have this new firmware already, but older pieces sitting in some storage will surely come with the old one.
Lenovo forum user:
Ok i bought monitor 2 days ago and tested it and i dont have frame skipping with this one on Nvidia gtx 1070 and really old drivers 385.41.
i was searching for the monitor with newer production date and found this one, production date was 09/18/2018.
i guessed that frame skipping was solved with newer models so i risked and this one is good, i guess thats the firmware problem and there should be some kind of tool for people to update it at home.
Zadnje izmijenjeno od: Blue Spirit. 20.03.2019. u 02:59.
Staro 20.03.2019., 09:07   #14
Postovi: 17,143
Ma 6 mjeseci je prošlo, ne možeš ništa ja mislim.
Što je prvih 6 mjeseci radio? Koliko su oni takvih reklamacija već čuli (nakon par mjeseci, ne radi), misliš da im se zajebava s ovim slučajem?
Jedino da ga reklamira, pa da ide na servis, povrat novca ili novi monitor nakon 6 mjeseci, teško...
Staro 20.03.2019., 09:31   #15
trex
trex's Avatar
Lokacija: Bjelovar
Postovi: 649
U čemu je problem?
Neka ga reklamira ako ima garanciju, i proizvođač to mora sredit.
Ako odbijaju primiti, samo neka traži pismenu odbijenicu, kako je već kolega gore napisao.
Za čas će promijeniti priču...
trex je offline   Reply With Quote
