Staro 07.01.2019., 10:05   #1
T}{OR
DBS
T}{OR's Avatar
Datum registracije: Nov 2010
Postovi: 1,855
Nvidia FreeSync/Adaptive-Sync podrška: Pitanja, informacije, mišljenja i savjeti
nVidia FreeSync/Adaptive-Sync podrška: Pitanja, informacije, mišljenja i savjeti
nVidia To Officially Support VESA Adaptive Sync (FreeSync) Under “G-Sync Compatible” Branding
nVidia has internally supported VESA Adaptive Sync for a couple of years now; rather than putting G-Sync modules in laptops, they’ve used what’s essentially a form of Adaptive Sync to enable “G-Sync” on laptops. As a result we’ve known for some time now that nVdiia could support VESA Adaptive Sync if they wanted to, however until now they haven’t done this. Coming next week, this is changing. On January 15th, nVidia will be releasing a new driver that enables VESA Adaptive Sync support on GeForce GTX 10 and GeForce RTX 20 series (i.e. Pascal and newer) cards. There will be a bit of gatekeeping involved on nVdiia’s part – it won’t be enabled automatically for most monitors – but the option will be there to enable variable refresh (or at least try to enable it) for all VESA Adaptive Sync monitors. If a monitor supports the technology – be it labeled VESA Adaptive Sync or AMD FreeSync – then nVidia’s cards can finally take advantage of their variable refresh features. Full stop.
Using FreeSync with nVidia GPUs Examined: How Well Does It Work?
Izvor: AnandTech i TechSpot
Sa sljedećim driverima nVidia će podržavati i FreeSync:
https://www.techpowerup.com/251237/n...ync-technology
Zanimljivo kako izbjegavaju naziv "FreeSync" u službenoj objavi:
https://blogs.nvidia.com/blog/2019/0...-displays-ces/
Zadnje izmijenjeno od: Brko. 20.01.2019. u 21:03. Razlog: spelling
Staro 07.01.2019., 10:45   #2
sti
Lokacija: Lawl
Postovi: 1,380
Kako se stvari brzo mijenjaju kad je dionica u slobodnom padu, majmun u kožnoj jakni kao pokisli miš priznaje da je Gsync apsolutni nonsens.
Staro 07.01.2019., 10:53   #3
warlock25
warlock25's Avatar
Postovi: 2,327
To te ja pitam.Konacno freesync na 1080ti.Sad Ati fakat nema vise sanse.LOL.
Samo ljudi koji su kupili G-sync monitore vjerojatno sada pizde jer su mogli proc puuuuuuuuuuuuuuuuuno jeftinije.
Zadnje izmijenjeno od: warlock25. 07.01.2019. u 10:59.
Staro 07.01.2019., 11:04   #4
maXonja
bu
maXonja's Avatar
Datum registracije: Jan 2017
Lokacija: VŽ
Postovi: 2,627
Uuuuuuuuu vrhunski, odmah u nabavku freesync monitora, ooodmah
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 07.01.2019., 15:23   #5
tole_
Casual Racist
tole_'s Avatar
Lokacija: Sneed's feed and seed (formerly Chuck's)
Postovi: 422
Autor T}{OR Pregled postova
Ne izbjegavaju oni ništa jer Fresync ne podržavaju niti ga mogu podržati. Freesync je AMD-ova implementacija VESA Adaptive Sync tehnologije koja zahtjeva AMD driver da bi radila.
Autor sti Pregled postova
Pad cijena dionice apsolutno nikakve veze nema s ovim potezom, niti s RTX serijom kad smo već kod toga.
Why did the console peasant cross the road?
To render the buildings on the other side!
tole_ je offline   Reply With Quote
Staro 07.01.2019., 17:42   #6
nickross
Budget gamer
Datum registracije: Nov 2017
Postovi: 909
Autor tole_ Pregled postova
Ali Freesync je open source i kada ukućaš neki od monitora koji su ''gsync compatible'' onda dobiješ samo "AMD FREESYNC Technology" recimo na amazonu. Tak da će gtx/rtx grafe podržavati freesync monitore.
nickross je offline   Reply With Quote
Staro 13.01.2019., 17:57   #7
warlock25
warlock25's Avatar
Postovi: 2,327
Ljudi jos 2 dana i Freesync na Nvidia grafama.
Staro 13.01.2019., 18:46   #8
axo
Datum registracije: Sep 2017
Postovi: 1,434
Autor warlock25 Pregled postova
Yup, yt ce pucat od testiranja monitora...
Ak to bude sljakalo ide moj monitor na prodaju pa lagano po drugi dell...
Staro 13.01.2019., 18:47   #9
Newbie Pro
Zule
Newbie Pro's Avatar
Postovi: 1,993
Nisam stigao procesljat cijelu temu, da li ovo znaci da cu moc upogonit 1070Ti sa svojim LG Freesync monitorom?
Sent from my SM-J600FN using Tapatalk
Newbie Pro je offline   Reply With Quote
Staro 13.01.2019., 19:02   #10
BlackDwarf
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,437
Da li ce nvidia namjerno sabotirati da ne radi najbolje s monitorima koji nisu prosli njihov "test"?
Sent from my WAS-LX1A using Tapatalk
Staro 13.01.2019., 21:58   #11
dmr
dmr's Avatar
Lokacija: Tuzla
Postovi: 1,267
Pa ima onaj video da na nekim monitorima ima blinkanja, ne bih reko da ce nvidia to namjerno.
dmr je offline   Reply With Quote
Staro 14.01.2019., 01:17   #12
warlock25
warlock25's Avatar
Postovi: 2,327
Autor Newbie Pro Pregled postova
Tocno to.
Staro 14.01.2019., 01:38   #13
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,627
Autor dmr Pregled postova
Meni to nekako djeluje da ima veze sa panelima, TN nebi trebao imati problema, a VA i IPS su upitni
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 14.01.2019., 09:34   #14
warlock25
warlock25's Avatar
Postovi: 2,327
Ako je to istina onda su retardi. Pa Ips i Va matrice prevladavaju u zadnje vrijeme.
Sent from my H8266 using Tapatalk
Staro 14.01.2019., 09:38   #15
maXonja
bu
maXonja's Avatar
Lokacija: VŽ
Postovi: 2,627
A neznam, ja to tako vidim, možda sam u krivu
Jer od svih ovih testiranih/certified monitora samo je 1 sa IPS, a svi ostali su TN
Po čemu prevladavaju IPS i VA paneli? Pa i dalje su baš pravi gaming monitori sa TN panelima jer su najbrži
Nvidia u očima
Intel u duši
Alfa Romeo u srcu
Staro 14.01.2019., 10:05   #16
warlock25
warlock25's Avatar
Postovi: 2,327
Autor maXonja Pregled postova
mislio sam na to da ljudi vise kupuju ips i va monitore nego tn.
Staro 14.01.2019., 17:11   #17
dmr
dmr's Avatar
Lokacija: Tuzla
Postovi: 1,267
U koliko sati nvidia izbacuje drivere
Staro 14.01.2019., 17:17   #18
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,537
joj nadam se da vam je hype opravdan
gsync im ne radi kak spada u većini slučajeva, tak da bi bilo čudo da freesync proradi odmah
ljudi po nvidia forumima su masu igara testirali, gsync uključen sve radi, al zapravo ne radi, ili uzme brdo FPSa bez razloga, ili nešto treće..i tako već otkad imam gsync i pratim to, preko pola godine, iz drivera u driver ništa bolje, samo gore
Staro 14.01.2019., 17:35   #19
U biti ono što kažeš je "ja sam bacio 5000 kn za sync koji ne radi dobro, a vi za ćete imati isto sranje samo za dosta novaca manje"
Jebat ga druže, trebao si ti to istražiti detaljnije prije kupovine monitora. Okinuo si za monitor fest para da za 6 mjeseci kažeš da to generalno ne valja. Kako se manifestira taj "ne-rad" Gsynca uopće? I da nije od igre do igre ili baš u svakom scenariju sere?
Sent from Usreo Mobara
Staro 14.01.2019., 18:17   #20
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,537
varaš se ak misliš da nisam istražio, ne da sam istražio nego pregledao sve ko da kupujem nuklearni reaktor, a to što su počeli fušat drivere negdje u rujnu nije do mene ni monitora kojeg sam kupio dosta prije
ne mislim da sam išta bacio, uzeo sam monitor i ne žalim, i dalje smatram da je slika bolja od svih ostalih koje sam vidio uživo
tearinga nema, 144hz radi normalno
gsync radi, al da radi kak se reklamira ne radi (govorim općenito, na za mene), te probleme koje sam naveo da ljudi imaju ja u igrama koje igram nemam, ali sam iznio iz razloga što na ''svom'' gsyncu nisu uspjeli odradit sve kak spada, di će na freesyncu, nadam se da sam u krivu
uzeli ja i frend taj monitor, još hrpa ljudi ima ACER-ovu predator verziju, jedan frend AOC AG271QG, svi su isti panel svima je slika extra, ALI gsync i driveri nikako nisu sinkronizirano odrađeni kako spada već mjesecima
ima ovdje rejđa https://www.reddit.com/r/nvidia/comm...with_the_next/
ima i na geforce ofišl forumima, samo je za svake drivere naštancano preko 40 stranica pa treba tražit di ljudi baš testiraju s grafovima itd
wow recimo ima dosta problema, safe to go driveri zadnji koji valjaju za gsync su 399.24, što bi bilo super da možeš igrat BF5 s njima, ali nemožeš, upalim igru i kaže da treba 4xx.xx, to me najviše ljuti
Staro 14.01.2019., 18:31   #21
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,537
pazi ovo
kad ne dira miša 50 FPS, kad ga miče 100
itd itd, brdo je tu problema u zadnje vrijeme, mene je samo jedan zakačio, kad imam uštekan HDMI televizor uz monitor, slika blinka na milisekundu svako malo
revertam na 399.24 i toga nema...itd itd itd, sva sreća da me samo to zakačilo, u suprotnom bih prešao na crvene
Staro 14.01.2019., 18:46   #22
dmr
dmr's Avatar
Lokacija: Tuzla
Postovi: 1,267
Pa koliko vidim svi spominju probleme samo kad si u window ili exclusive full screen? Ako je tako stavi igru u fullscreen i deri.
Staro 14.01.2019., 20:58   #23
axo
Postovi: 1,434
a ja mislio kao ono kupit ips ili tn 144hz sa syncom al msm da cu se drzat svog ips della 60hz...
Staro 14.01.2019., 21:54   #24
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Ja nemam ama baš nikakvih problema s G-Syncom. Doduše, isprobao 3 igre i vrtim full screen isključivo tako da...
ACER je brutala od monitora, i izuzev sitnica oko napajanja vrijedi svoje novce.
Staro 14.01.2019., 22:30   #25
emilblomsky
emilblomsky's Avatar
Lokacija: karlovac
Postovi: 2,089
Znači,jel mi po ovom freesync uključen?
Ili trebam još nešto podešavati na monitoru?
I kakva su iskustva sa ovim softverom asus aura?
Rado bi da mi grafička baš ne blinka,već da mi svijetli stalno u istoj boji?
Phil of the future!
Staro 14.01.2019., 23:49   #26
dmr
dmr's Avatar
Lokacija: Tuzla
Postovi: 1,267
pa isprobaj u igrama je li radi, imas li tearinga, imas i onaj freesync demo skini pa provjeri da li radi.
Staro 15.01.2019., 14:27   #27
dmr
dmr's Avatar
Lokacija: Tuzla
Postovi: 1,267
Niko ne spominje da su izasli vec novi driveri. Evo ja testiro i radi gsync na aoc q3279vwfd8 Samo sam gsync demo testiro i izgleda ok, idem sad malo igre testirat
Staro 15.01.2019., 14:34   #28
geronimo_2
geronimo_2's Avatar
Lokacija: Rijeka / Grobnik
Postovi: 4,479
ma cek, pisu decki da nije enabled preko HDMI-a??
pa sta nije bilo govora da ce radait i preko HDMI/DVI i onog novog kak se zove vec, mozak mi je stao.
Staro 15.01.2019., 15:03   #29
dmr
dmr's Avatar
Lokacija: Tuzla
Postovi: 1,267
Kod mene je spojeno preko DPa i radi, sad probo crysis 3 i radi super U meniju monitora pise da je aktiviran freesync.
Staro 15.01.2019., 15:37   #30
markecSMB
Lokacija: Cro
Postovi: 1,042
Ja očigledno nisam u toj većini konfa u profilu. A ni brat 2070 ni bratić s 1080 isti monitor.
I radi mi sve i radi i s prozorom i full scrn, apsolutno svaka igra, i radi mi od kad sam kupio.
