#871 |
driver
Postovi: 1,083
Veseli me što sam po CPU time ušao u top ten pa još da uđem i po obrađenim rezultatima, onda mogu na masters... ![]()
SPECTRUM ZX 48 K, Grundig Cassette player, RIZ Color TV - 16 kanala UHF, sobna antena Čajavec SA-3 s lampicom, software : River Raid & Jet set Willie |
#874 | |
matroxfanatic
Lokacija: Zagreb, na zapadu
Postovi: 2,444
![]() Zadnje dvije vijesti sa http://forum.grid.org : Grid.org scheduled outage Dear Members, This is a reminder that Grid.org will be physically moving to a new facility this weekend. This will provide better reliability and is part of the Grid.org migration. Grid.org must be completely powered down in order to move. This will include the forum, member web, and the grid itself. Since this is not a trivial outage, we cannot give an exact time that Grid.org will be down. The outage will take as long as it takes and it may be a day or two before everything is back online. _________________ Robby Brewer Senior Support Engineer United Devices Grid.org back up Dear Members, It looks like Grid.org is back up now. I have seen posts that workunits are being downloaded so I think everything is working correctly. If you do encounter any strange behavior please post to Member to Member Support so that we can investigate. Our entire facility move has not completed yet, so there may be another interruption at some point although I am not expecting one. As soon as I have more information from our IT department regarding the move, I will share it. Thank you for your contribution. _________________ Robby Brewer Senior Support Engineer United Devices
Holly: "Appreciate what vou've got, because basically, I'm fantastic!"
#875 |
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Gle gpremec, kontam ja sve to, al stvarno se u zadnje vrijeme malo previse izvlace... Ovo pa ono, pa sad mjenjamo ovo...bla bla, bla... Znam da nije lako organizirati takvu jednu stvar, al nije samo jedan tamo zaduzen za sve to... ![]() Al ajde, ako se dogodi da, nakon sto se presele, i nebuse 3 mjeseca nikakvih problema, castim te ![]()
#876 | |
matroxfanatic
Postovi: 2,444
Svi samo vidimo krajnji rezultat takvog posla (radi ili ne radi), ali malo tko je zaista imao prilike i sudjelovati u necem toliko kompleksnom, a kamoli zaista i raditi takav posao. Kolicina vremena koja se potrosi na same pripreme je ogromna, a sav posao se uvijek radi vikendom (kada kazem vikendom, onda mislim od subote u podne do ponedjeljka do 6 ujutro, i to bez pauze). Nejedamput sam morao dizati/upgradeati sustave zivih servera vikendom, tako da su mi izjave tipa "izmotavanje" i "prckanje" samo pokazatelj neshvacanja problematike vezane uz rad na server u zivoj okolini. Problemi i ispadanja sustava? Na zalost, i do toga dolazi, a kada pocnu, onda se nizu jedan za drugim, a uzrokovani su necim sto je netko napravio ili nije napravio davno/nedavno prije. Uostalom, grid.org je bez znacajnih problema radio dvije-tri godine, a tek je zadnjih 6 mjeseci bilo ispada sustava. Premjestanje sustava na drugu lokaciju je odluka kako bi se razrijesili problemi u koje upadaju zadnjih pola godine, a vrijeme ce pokazati koliko su to dobro odradili. I uza sve te ceste ispade zadnjih pola godine necu odluciti prestati s donacijom procesorskog vremena u svrhe potrage za lijekom protiv raka. Naravno, svatko odlucuje za sebe, i svatko ima druge razloge zasto sudjeluje u grid.org ili nekom drugom projektu takvoga tipa.
#877 |
Postovi: 9,505
Ja se ispricavam, nisam imao namjeru se svadjati ili izazvati svadju...jer nemam nimalo pojma o samoj problematici kod vodjenja takvog projekta...al znam da kod kompjutera, cim nesto prvo podje krivo, sve ostalo ode u k... ![]() Ali kazem, njima je u interesu da poboljsaju sustav, ja cu i dalje isto pomogati oko raka dok mi ne pukne... Al mislim da i oni snose dio krivice (makar minimalan jer kompjuteri su najcudnije stvari na svijetu, u jednom trenu rade savrseno, a onda poludi u sekundi) Ajde da zavrsimo ovu diskusiju, u kojoj sam ja mozda malo pretjerano reagirao, i to priznajem... slazemo se da je najbolje da srede stvari na odusevljenje i njih i nas... ![]()
#878 |
AutoCad & Allplan expert
Postovi: 2,159
ljudevi najte se živcirat. ja sam peglam po gridu i gledam scor, a da idem jos i na njifov forum, to mi se bas i neda nit me ne zanima....
none |
#881 |
E Pluribus UNIX
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,807
Sredjeno bezobrazno zauzece memorije u Windblowsima? Moze li se vrtiti na necem drugom osim Wintelu?
#882 |
Postovi: 9,505
@bubba neznam kako je bilo sa zauzecem prije godinu dana, al evo meni danas UD uzima 10-11MB memorije...ni vise ni manje... Sad neznam jel zdere vise kad dela rozetu, jer ja do jucer sam delao samo cancer... Za ostale OS-ove neznam jer, evo stoji mi Knoppix pred nosom i nemam DVD u kompu da ga pokrenem (onaj kad se sve boota sa CD-a)...
#884 | |
E Pluribus UNIX
Lokacija: M82
Postovi: 6,807
Steta. ![]()
#887 |
Postovi: 9,505
Sinuo rozetu prije par sati, trenutno je na 15% a proslo je 9h i zauzima mi 5,4MB?? Jos do sada mi se nije dogodilo da uzima preko 50MB...:confused:
#889 |
matroxfanatic
Postovi: 2,444
Vidim da je komunikacija na ovom threadu malo zamrla. Srecom, nije zamro sam team: bodovi, procesorsko vrijeme i kolicina obradjenih paketa se gomilaju.
#890 |
driver
Postovi: 1,083
stotka!
Ponosno javljam da sam dobacio do 100.000 !
#892 | |
Datum registracije: Aug 2003
Postovi: 3,193
Re: stotka!
![]() Jos malo pa sam preko 50k.
#893 | |
driver
Postovi: 1,083
Re: Re: stotka!
#894 |
Lokacija: Zagreb, Trešnjevka
Postovi: 5,778
Počeo sam i ja opet vrtiti grid...al imam problem...ne želi mi poslati rezultate, nikako da se spoji na server, jel treba neki port ili tak neš poštelati? |
#895 |
Postovi: 19,014
Evo da vam se i ja priključim. Što je sve potrebno za to? Kak se na kraju zove team? PC Ekspert Forum? EDIT: Zašto se neće regat?
#896 |
driver
Postovi: 1,083
Točno, PC Ekspert forum je team a na početku ovog topica imaš sva uputstva za priključenje, doborodošao u team!
#897 | |
Postovi: 3,193
#898 |
Lokacija: Agram
Postovi: 2,983
Sve ponovo radi ... dva dana server neš nije radio. Stanje PC Expert krančerske nacije ![]() Current Members 100 Retired Members 4 Total CPU Time(y:d:h:m:s) 23:010:16:01:36 Points Generated 5,016,720 (# 693) Results Returned 16,073 Eto odvališmo i milestone od 5.000.000 i bližimo se 24 godini doniranog procesorskog vremena ... |
#899 |
Postovi: 3,193
Presao 50k ![]()
#900 |
Postovi: 19,014
Jel može neko ukratko objasnik kako treba popunit podatke, kako se ubacit u team i ostalo. Hvala. ![]()
