#3601 | |
Postovi: 779
ak si na ULL-u onda ide najcesce enkom a1521 i zyxel VMG5313, ak se korisnik zali na slabiji wifi onda se obicno stavlja sx763. Thomson ST780i ide ako su parametri linije losiji jer ima vecu toleranciju na greske od gore spomenutih. zxyel p2601 ak nema ovih gore na skladistu |
#3602 |
Datum registracije: Feb 2015
Lokacija: Sisak
Postovi: 827
Meni na Mozilli kaže: "www.google.com uses an invalid security certificate." zanimljivo. EDIT: Riješenje. Morao sam prvo nadograditi Firefox a onda Chrome i sad leti sve. ![]() Zadnje izmijenjeno od: Froxie24. 02.07.2016. u 18:13. |
#3603 | |
Lokacija: Sisak
Postovi: 827
#3604 |
Postovi: 706
Eto vrnuli mene na 10, kažu nemore više, čudno da prije je max bio 23 sada je 15 Greškice postojane ko moja čelava glava sa 3vremenskim taftom. ============================================================================ VDSL Training Status: Showtime Mode: VDSL2 Annex B VDSL Profile: Profile 8b Traffic Type: PTM Mode Link Uptime: 1 day: 14 hours: 0 minute ============================================================================ VDSL Port Details Upstream Downstream Line Rate: 1.195 Mbps 12.363 Mbps Actual Net Data Rate: 1.172 Mbps 12.287 Mbps Trellis Coding: ON ON SNR Margin: 5.2 dB 6.1 dB Actual Delay: 2 ms 4 ms Transmit Power: 11.5 dBm 18.6 dBm Receive Power: 0.8 dBm 0.1 dBm Actual INP: 0.5 symbols 1.0 symbols Total Attenuation: 11.0 dB 18.5 dB Attainable Net Data Rate: 1.201 Mbps 15.142 Mbps ============================================================================ VDSL Band Status U0 U1 U2 U3 D1 D2 D3 Line Attenuation(dB): 18.4 N/A N/A N/A 35.0 102.3 N/A Signal Attenuation(dB): 18.4 N/A N/A N/A 33.0 N/A N/A SNR Margin(dB): 5.2 N/A N/A N/A 6.1 N/A N/A Transmit Power(dBm): 11.6 N/A N/A N/A 18.6 N/A N/A ============================================================================ VDSL Counters Downstream Upstream Since Link time = 37 sec FEC: 1282336 1526 CRC: 653 253 ES: 388 187 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 15 minutes time = 1 min 1 sec FEC: 604 0 CRC: 1 0 ES: 1 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 15 minutes time = 15 min 0 sec FEC: 7403 0 CRC: 4 0 ES: 4 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 1 day time = 14 hours 1 min 1 sec FEC: 412458 340 CRC: 204 46 ES: 141 40 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 1 day time = 24 hours 0 sec FEC: 869878 1186 CRC: 449 207 ES: 247 147 SES: 0 0 UAS: 22 22 LOS: 0 0 LOF: 0 0 LOM: 0 0 Total time = 1 days 14 hours 1 min 1 sec FEC: 1282336 1526 CRC: 653 253 ES: 388 187 SES: 0 0 UAS: 22 22 LOS: 0 0 LOF: 0 0 LOM: 0 0 ============================================================================
Sig-5 redova normalne veličine max
#3605 |
RESPECT MY AUTHORITAH
Postovi: 7,506
Loše. Spoji se kao supervisor, uključi telnet pa u puttyiju daj; Code:
xdslctl configure --bitswap on --sra on --trellis on --i24k on --maxDataRate 10500 900 20000 Meni na Chromeu Google i Youtube i dalje štekaju. Ne znam zašto ni kako riješiti.
#3607 |
Datum registracije: Oct 2010
Lokacija: Kaštel Lukšić
Postovi: 1,617
#3609 | |
Džabe si krečio!
Postovi: 5,191
Slucajno naletih na ovaj post, ali ja isto pizdim vec posteno! Bas to, googleove aplikacije (gmail, drive, etc + youtube), vuku se ko posrane. Imam Iskonov Duo, 20mbita... Stvarno ne znam do cega je... Kopao sam malo po dns cacheu, stavio googleov DNS (internet tips 101), ali nista... Sent from my iPhone using Tapatalk |
#3610 |
Postovi: 779
I kod mene steka, al ocito je do googla jer steka i kad se zakvacim na susjedov wifi (tcom) |
#3612 |
Postovi: 100
Jel ima tko na Iskonu problema s netom kad intenzivno radi upload? Imam VDSL 20/5 i ako radim backup na iCloud, Google Photos ili slicno, zagusi se veza i nitko doma ne moze normalno surfati. Naravno, ne mogu nikako limitirati bandwidth jer takvih opcija nema ni u iCloudu ni u Google Photos, a na Zyxelu kojeg imam je QoS naravno disablean. Vec smo jednom prijavljivali problem Iskonu pa su prvo hintali da ne bi smjeli toliko uploadati na sto je odgovor bio da ne mozemo to kontrolirati (a zapravo niti ne zelim, neka oni to hendlaju) i problem su rijesili, ali mi se ne da svakih par mjeseci natezati s njihovom korisnickom sluzbom. |
#3613 |
Postovi: 7,506
Spoji se kao supervisor, pass (ovisno o fw-u) W33'&Lf*G!45]Dbq)"RL )gR9&cGn3(}ce{et}s[* k{!fF&gK=*Hjx58[8?Yb ![]() Omogući qos ili u wirellesu ograniči propusnost uploada. Došao mi račun, sljedećih 10 mjeseci imam ovo ![]() ![]() Savedesk has respected my authoritah ![]()
#3615 |
Lokacija: Metković
Postovi: 16
#3618 |
Lokacija: Metković
Postovi: 16
Ha, false alarm. Ista stvar i bez njega. Ne znam jel mi laknulo ili ne. ![]() |
#3619 |
Džabe si krečio!
Postovi: 5,191
Baš, same shit ![]() EDIT: Errrrm, weird shit, probao u Internet Exploreru (TM) i youtube leti... Bit će da ću se morat poigrat sa Chrome-om i postavkama, extensionima, etc... Zadnje izmijenjeno od: Sam Fischer. 06.07.2016. u 20:45. |
#3621 |
Lokacija: Metković
Postovi: 16
Da, na edge-u nema problema. Svasta. |
#3622 | |
Postovi: 100
![]() Usput, s obzirom da su mi svi uređaji na Wifiju, limit na wifi upload ne bi pomogao, zar ne? |
#3624 |
Postovi: 2,230
#3625 |
Datum registracije: Jul 2016
Lokacija: Belišće
Postovi: 4
Trebam savjet, zapravo želim negdje napisati ovaj rant, a vi slobodno dodijelite pokoju mudrost. Kome se ne da čitati rant, može preskočiti na pitanja, mislim da su dovoljno self-explanatorna bez puno uvoda. Bio sam u Zagrebu na optici i sve je bilo super, pogotovo zbog uploada jer često moram slati poveće datoteke i solidni upload mi je apsolutno neophodan. Doma u Belišću smo imali neku prastaru ADSL optimu tipa 5/256 i naleti čiko iz iskona i obeća brda i doline, uglavnom 50/10 i to za manju cijenu od Optime, što je zvučalo super. Ja pitam čovjeka jel to sigurno, mislim znam kakve su veze u Belišću, al tvrdi on da je to sve super i ja rekoh okej mama, potpiši. Uvedu oni to, od 50/10 ja se spajam na 28/6. I dobro, meni bi to bilo skroz dovoljno da veza nije stalno, ali STALNO pucala. Youtube puca, upload puca, tv zapinje, restart 5-20 puta dnevno.Modemu treba po 5 minuta da se spoji. Užasno. Zovemo, dođe tehničar, otpiše nas i kaže da je to sigurno do naše infrastrukture i da zamijenimo sve žice. U nalog napiše da ga "nismo pustili na tavan". Zovemo privatnika koji obiđe sve tavane i žice i kaže da je sve okej, osim jednog kabela kojeg nam zamijeni. I kaže da nam preporuča da spustimo paket na 30/5. Mi tako napravimo, veza se smiri nekih 2 tjedna. I onda opet kreće pucanje. Nakon što je puklo 5 puta u pola sata, nazovemo službu, oni kažu doći će sutra opet majstor. Čovjek dođe, obiđe opet sve tavane i ustanovi da je sve u redu, samo je "ukinuo jednu paralelku" jer smo uistinu imali jednu otprije. Izmjeri, maksimalno spajanje se podiglo na 37, 7. Rekoh wow, popravio. Još nam kaže mi smo sad sve napravili, ako i dalje ne valja ide nalog HT-u. Kada je otišao, počelo je pucati više nego ikad. Prijavimo, dođe jučer HT-ovac, obiđe tavane i kaže da ovaj iskonov nije ništa napravio i da je ON sad popravio neke spojeve. Odemo do razvodne kutije koja je samo 3 kuće dalje, zamijeni žice i tamo, počisti malo parice bla bla. Izmjerimo, neke neznatne promjene u vezi. Nazove njih, oni ponovno srežu brzinu (već su spuštali na 28, pa na 25, a upload na 4). I kaže mi ak sad i dalje ne valja ROFL nećemo mi ništa popravljat između tebe i razvodne kutije nisi ti naš korisnik, ako je negdje na susjednom tavanu prijeđi na HT pa ćemo ti sredit. KAJ? Danas navečer opet pukne tv. Nazovem službu za korisnike, lik me uvjerava da mi je veza pukla jer sam koristio upload i da nek prestanem koristit upload ili neka si skinem programčiće s kojima ću to ograničit jer sam u zadnjih 6 sati uploadao preko dva gigabajta prometa i da šta ja to radim (ostao mi aktivan ubuntu torrent ograničen na 300kb/s). Rekoh, čovječe plaćamo vam 30/5, odrezali ste me na 4, a sad mi veza puca jer sam uploadao 3? Pa da, ne smijete koristit upload jer zagušite vezu bla bla bla. Uglavnom lik je idiotski ponavljao 5 parola koje zna napamet i na kraju me uputio na reklamacije. Sutra im šaljem mail. Pitanja: 1. Što ja osobno mogu poduzeti da mi veza manje puca, treba mi upload od barem 350-400kb/sec, što mi je sad i pušteno s njihove strane, ali mi sad kažu da ne smijem koristiti ni to? Što onda uopće plaćam? Ako mi ugradiš cijev za vodu i ja ju otvorim na najjače, ak sam platio vodu bolje ti je da voda curi na najjače. Uostalom 3 je manje od pola izmjerene propusnosti (6-7). Od centrale sam supposedly udaljen oko 800m. 2. Je li to što je HT-ovac rekao istina? Mislim Iskon koristi njihovu infrastukturu, valjda mogu nekako inicirati zamjenu par kablova, radi se o svega tri-četiri kuće? Što kada SVI prijeđu na vdsl? 3. Što mogu očekivati kao kompenzaciju? sumnjam da će mi dati raskid ugovora iako bih ih najradije poslao u 349pm i stvarno prešao na HT. Smanjenje računa, odjeb? I kad dobijem odjeb, ponavljam prvo pitanje, što ja mogu napraviti da to popravim. Da ugasim ili tweakam QoS? Da si stvarno dodatno ograničim brzinu? Ovo je trenutno stanje: http://i.imgur.com/qSNCfBj.png Ispričavam se na romanu. Zadnje izmijenjeno od: slsmpl. 09.07.2016. u 01:49. |
#3626 |
Lokacija: doma
Postovi: 2,924
Sto se tice pucanja veze to rjesava ZTE od t-coma, bar kod mene je tako... Zyxel obavezno u tjednu ima 3-4 pucanja dok sa ZTE mislim da je bilo jedno jedino pucanje veze no i vani je bila neka oluja malo tak da mozda je i radi toga... Kako ti imas trio uslugu znaci nista... inace ZTE cesce resinka liniju tj. konstatno mijenja max up i max download kao i Actual rate sto je u sustini i najbitnije, taj Actual rate... a Zyxel mjenja samo max up i download i onda umjesto da promjeni Actual rate on prekine vezu. Koja si ulica ? Jel znas gdje je centrala u Beliscu, kod Kombela ti je... |
#3627 |
Lokacija: Belišće
Postovi: 4
Ma blizu sam Kombela, kad pratim ulice po karti može bit samo manje od 850m koliko su oni izmjerili. |
#3628 |
Lokacija: doma
Postovi: 2,924
Pa zato te i pitam koja si ulica jer nemora biti da parica do tebe ide najkracim putem... sta se krijes ko zmija noge, ja sam domaci U teoriji 30/5 na 800m je skoro pa i ok, unutar prosjeka s obzirom na stanje parica u Beliscu.., mada gledajuci tvoj ss max upload i pripadajuca mu margina je osjetno dobra s obzirom na max download tj. sam max download bi trebao biti zbilja veci od tih 33Mbpsa... on bi se bar oko 40Mbpsa trebao kretati. Kod nas je rasulo malo sto se toga tice. Recimo centar, t-com u Gutmanovoj nudi 60/10, Iskon isto.. zgrada do tj. prekoputa vrtica 1 ulaz potpisano 30/5 spojeno 10... treci ulaz 20/5... "Nove" zgrade oko bazena 30/5 bez pardona. Vatikan isto neznas ko pije ko placa, jedan ulaz jedva 10 a drugi 30/5 i tak... Od Trafostanice kroz Ostri Cosak do doma Kulture ljeva strana ima samo ADSL2+ a onda od Skole do zadnjeg rotora skoro vec u Bistrincima moze VDSL2. Uglavnom zajebano. Sto se tice pitanja sta mos uciniti... nista. VDSL2 se ponasa isto kao i ADSL2+, kada otvoris pipu do kraja bilo upload ili download pati oboje... sa max uploadom da stavis nesto skidati jedva 7-8MBpsa ce ici... ako skidas nesto max brzinom normalno da upload nemoze ici maximalno i jos je tu kod tebe i TV koji stalno po malo zdere. Kada svi predju na VDSL2 bice isto kao i kad su svi bili na ADSL2+ jel.. sve isto samo su brzine vece... da si na t-comu bilo bi isto, umjesto da mjenjaju 10-100m kabla 145% ce ti prije orusiti paket tj. brzinu jer to ne kosta... ako znas gdje je ostecenje rezi zice po mraku, to je najveca sansa da se iste zamjene. Kompezacija ? Koja ? Ako su ti spustili paket na 30/5 a jesu dok ti ne padne ispod 21/3 ni lipe ti nece oprostiti a zakasni jedan dan sa placanjem na iducem racunu ce biti 2-3 lipe vise... U globalu mozes se zaliti na pucanje veze i dalje no to ce dovesti samo do daljnjega smanjenja paketa brzine i evo te za koji dan sa 20/5 paketom s time da onda 12 ti je garantirano... jel... Dok t-com ne skrati lokalnu petlju sve muke po ADSL2+ se samo prenose u sve muke po VDSL2. |
#3629 |
Lokacija: Belišće
Postovi: 4
A već sam sad odrezan na 25/4 iako sam na paketu 30/5. Ako mi spuste upload još malo zakurac sve skupa, ne muči me toliko download. Ako ga moram ograničavati sam, radije bih da mi puste onda svih 5 pa ću ja eksperimentirati, nego ovako da ga još ja moram rezat unutar već smanjene vrijednosti. U Novoj sam tako da spadam u taj škola/rotor dio valjda?, al kažem bio tehničar iz HT-a danas i pratili smo žicu, doslovce imam par kuća do kutije. Znači kad uploadam, najčešće šaljem nešto klijentima, ili streamam nešto na YT, ili eventualno seedam. Ali kad mi kažu "znamo mi da smo vam dali 5 al nemojte vi to baš koristit" onda bih najradije sve zapalio. |
#3630 | |
Lokacija: doma
Postovi: 2,924
A cuj, ja placam 30/5 a imam 24/2.3 i 1300m sam od kolibe no meni nemaju sta spustati i doslovce pat pozicija i njima i meni... ja sam tiskao popravku linije a oni tiskali da se prebacim na DUO uslugu.. kako ja imam solo internet, manjeg paketa nema osim 10 na ADSL2+ a to bi znacilo da ja mogu raskinuti ugovor djabe tako da to nisu ni nudili a natjerat me da uzmem i telefon pa da spuste na 20/5 paket isto ne mogu tako da sute oni a sutim i ja a pucanje sam rijesio promjenom routera i imao popust 12mj radi manjeg uploada... Ti si u raljama sad jer imas trio uslugu i ako ih nastavis cimati spustit ce te na 20/5 dok si reko keks i reci losa infrastrutura. Kazem.. probaj zvati tehnicku podrsku i trazi bas tehnicara a ne ove studente itd... ti mozes imati tih 25 sa cistih 5 ili 6Mbpsa bez problema, tebi je upload odlican sto se tice parametara koje router prikazuje, uopce nema razloga da ga ruse... |
