#3571 |
Postovi: 1,542
nema, Zakaj još nema update za 620?? Treba bi Glance 2,0!!! |
#3573 |
Postovi: 2,438
Debela lista novosti s WP 8.1: http://www.wpcentral.com/developers-...s-phone-81-sdk -NEW Audio/video transcoding, Hardware accelerated -NEW Media editing: audio and video; Audio effects, video effects; Slow motion video -NEW Apps can capture audio/video from themselves -NEW Stereoscopic 3d support -NEW Wi-Fi Direct, a Wi-Fi standard allowing direct peer-to-peer connections over Wi-Fi without an access point -NEW Windows Phone 8.1 apps won't run on 8.0 devices until they upgrade -NEW Documentation confirms ALL current Windows Phone 8 hardware to get 8.1 -NEW Dev tools: SemanticZoom, DatePicker, TimePicker -NEW PlayTo support -NEW Single sign-in for apps (like on Windows 8) with Microsoft Account; sign in will persist across devices + apps with permissions prompt -NEW YouTube Player (see lede image) including HTML5 video support (video playback doesn't have to be full screen) And you get custom UI, so YouTube Closed Captions are in -NEW File picker (see above image) -NEW Geofencing API for location-based reminders -NEW Background tasks: Bluetooth signal strength, Chat message notification, -Device connection change, Device use trigger, Gatt characteristic notification, Location, Push notification, Rfcomm connection, System event, Timer -NEW Slide down to close apps -NEW Navigation bar color selection -NEW USB choices -NEW Updated camera layout, similar to Windows 8.1 (see lede photo above) -VPN (Virtual Private Network) -OneDrive (previously SkyDrive) with integrated file browser (just like Windows 8.1) -Filter through installed apps by usage/install date -Select multiple tiles when customising the Start screen -More efficient multitasking -Ability to install apps on inserted SD Cards -Internet Explorer 11 improved with WebGL and Normal mapping support -Separate volume controls for ringer, media, etc. -Bing smart search (similar search system as Windows 8.1) -Xbox Music and Xbox Video as standalone apps instead of the Music + Video -Hub (allowing more updates to be pushed) -Redesigned Xbox Game Hub -Twitter integrated more deeply into the contacts Hub -Facebook account option REMOVED (updated) -Quick settings access (Wi-Fi, Bluetooth) by doing a quick swipe from the top of the screen -Action Center accessed by doing a full swipe from up to the bottom (separate from the Notification Center) -Silent notifications which go directly to the Action center -Possibility to mark a Live Tile as read by swiping from the left of said tile -'Cortana' smart agent performs the same tasks as Siri and Google Now and even more, including data from Foursquare (MS INVEST) -Auto-updates for apps (just like Windows 8.1) -Better backup functionality -Improved keyboard -Bluetooth 4.0 LE (to non-Lumia Windows Phones) -Feature to mirror Windows Phone screens to TVs and/or monitors -A final interesting note is how Windows Phone is referred to as WinPRT. Zadnje izmijenjeno od: gin.tonic. 11.02.2014. u 21:17. |
#3574 |
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Jel vam sad jasno da ste kakili one smeđe kobaje cijelo vrijeme dok ste mi govorili kako je usluga pusha pouzdana. Pouzdana je bila ko poklopac torpedo cijevi na podmornici Kursk. Ovo nije trollanje,flejm nego činjenično stanje. Nisam često na ovom topicu(a i sam koristim HTC 8X ko službeni) jer su tu obično ljudi pametniji i od samog MS....a bojim se iako je i MS sam priznao da im je sistem pusha u banani,ne sumnjam da će se nać neki genijalac iz Babine Grede koji će me pokušat uvjeriti da Microsoft to ne misli onako kako prikazuje u changelogu... |
#3575 |
Postovi: 2,438
Ne znam, meni notifikacije na Whatsupp normalno dolaze, imam WP8 skoro godinu dana, da ne radi kako treba već bi prodao mobitel jer ga koristim svaki dan. Nekad zna kasniti ali jako rijetko, isto kako i curi na Androidu zna kasniti. |
#3576 |
Omicron Alpha resident
Lokacija: Bistra
Postovi: 5,111
Istina, Viber i Facebook su kasnili ali sa updejtovima je to riješeno. A koliko ja znam update aplikacije ne dira sistem tako da sam siguran da je do aplikacija, ne do OS-a.
#3577 |
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Meni je bilo momenata kad su dolazile kako spada....a nekad sam moram u samu app ući i tek onda je pisalo delivered na frendovom telefonu. MIslim,WP central forum je bio prepun takvih žalbi. Naravno da sam sve isprobao i šanse su bile 50-50. A da nije do OSa...nebi ispravljali osim ako im je baš jako dosadno pa iz dosade izbacuju novi push deamon spec. za Viber i Whatsapp(po mob.hr forumu). ![]() |
#3579 |
Lokacija: Bistra
Postovi: 5,111
#3580 |
Postovi: 8,235
Sent from AS/400. |
#3581 |
Postovi: 2,438
#3585 |
Lokacija: n/a
Postovi: 1,258
kom se daju pratit WP8.1 leak-ovi.. https://twitter.com/AngelWZR leak-a screenshot-ove, doslovce, svekih par minuta ![]() |
#3586 |
Postovi: 1,542
popis je jako zanimljiv ima dosta novina koje nisu očekivane al mi se sviđaju |
#3588 | |
Lokacija: Bistra
Postovi: 5,111
2. travanj, tijekom BUILD konferencije. Mada, čitam po netu da bi WP8.1 image mogao leakati prije ![]() EDIT: Citiraj:
95% of the world is retarded, I'm glad I am the 10%. Zadnje izmijenjeno od: Mario92. 12.02.2014. u 00:31. |
#3590 |
Lokacija: Bistra
Postovi: 5,111
Video demo: http://www.youtube.com/watch?v=r0K5eoSMsQY
#3591 |
Lokacija: Sv.Nedelja
Postovi: 5,830
Posto 925 i 1020 imaju isti kapacitet baterija, potonja ima veci napon, al kolko sam videl na gsm areni bogme ima i duze trajanje od 925.. Nije neka ogromna razlika, al po testovima je vidljiva.. |
#3592 |
Postovi: 1,542
#3599 |
Datum registracije: Jan 2014
Postovi: 94
cekajmo MWC da dobijemo nove lumie, garant cemo dobiti nesto dobro nokia je danas poslala jos jedan teaser koji je malo cudan a nextleak govori o puno uredaja na MWC-u http://mynokiablog.com/2014/02/12/no...-treasure-tag/ https://twitter.com/NextLeaks/status/433584859051618305 |
