Staro 29.06.2012., 16:27   #1
Deyo238
Grazie Michael
Deyo238's Avatar
Lokacija: Ogulin
Postovi: 360
ATI Catalyst 12.6 WHQL + 12.7 Beta (25.6.2012)
12.6 WHQL Win Vista/7 32-bit
12.6 WHQL Win Vista/7 64-bit
12.6 WHQL Win XP 32-bit
12.6 WHQL Win XP 64-bit
12.7 Beta Win Vista/7 32-bit & 64-bit
12.7 Beta Win XP 32-bit & 64-bit
A list of changes follows - Resolved Issues:
  • AMD Radeon HD 7900, AMD Radeon HD 7800 Tri-CrossFire configurations + Eyefinity no longer results in a BSOD when launching a DirectX application
  • AMD Radeon HD 7900, AMD Radeon HD 7800 Eyefinity/Multiple Display configurations no longer results in a BSOD when using desktop applications
  • AMD Catalyst 12.6 includes some additional fixes(not found in the AMD Catalyst 12.6 Beta) for the AMD Radeon HD 7900, AMD Radeon HD 7800, and AMD Radeon HD 7700 graphics cards for issues related to the GPU hanging when the system goes to sleep. Please ensure that your System BIOS is up to date. Some occurrences of this issue may be related to outdated System BIOS.
  • Resolves CrossFire scaling issues seen in AMD Catalyst 12.4 with Elder Scrolls: Skyrim CrossFire
  • AMD Catalyst Control Center – Overdrive page is no longer intermittently missing
  • AMD Catalyst Control Center – GPU Activity gauge is no longer missing
  • AMD Radeon HD 7900 CrossFire Configuration – no longer results in system hang after cinematic in Call Of Duty: Black Ops
  • Heroes and Generals: Blocky corruption in scenes with smoke effects when run in DirectX 11 mode are no longer experienced.
  • Dirt Showdown: Improves scaling for CrossFire configurations using the AMD Radeon HD 6000 Series
  • HDMI audio is no longer disabled if the connected HDTV is powered Off/On.
Performance Highlights of 12.7 BETA:
This release of AMD Catalyst™ 12.7 Beta includes a number of performance optimizations for the AMD Radeon ™ HD 7900, AMD Radeon HD 7800, and AMD Radeon HD 7700 Series.
  • Up to 25% in Elder Scrolls: Skyrim
  • Up to 3% in Battlefield 3
  • Up to 6% in Batman: Arkham City
  • Up to 3% in Dues Ex: Human Revolution
  • Up to 6% in Crysis 2
  • Up to 15% in Total War: Shogun
  • Up to 8% in Crysis Warhead
  • Up to 5% in Just Cause 2
  • Up to 10% in Dirt 3
Feature highlights of AMD Catalyst 12.7 Beta
Diablo 3: Anti-Aliasing support:
  • Users can now enable Multi-Sample Anti-Aliasing and Super Sample Anti-Aliasing for Diablo 3 through the AMD Catalyst Control Center.
Resolved Issues for the Windows® 7, Windows Vista® and Windows XP Operating System
  • Elder Scrolls: Skyrim- screen flickering when in AMD CrossFire™ mode
    Note: This issue was first observed with version 1.6 of Skyrim.
Full Release Notes (12.6 WHQL)
CPU: Intel Core i7 3930k C2 Sandy Bridge E 3200MHz @ 4500MHz (100x45 @ 1.288V) HT enabled
CLR: Corsair H100x
MBO: ASUS RAMPAGE IV FORMULA
RAM: Crucial DDR3-1600 2x8GB + 2x4GB (24GB) @ 1600MHz - 10-11-10-24-1T @ 1.535V
VGA: KFA2 GeForce GTX1070 8GB EXOC
HDD: ADATA SUV800 256GB ++ WD BLUE WD30EZRZ 3TB ++ WD Blue WD6400AAKS 640GB
PSU: Corsair CS550M 550W 80+ Gold Modular
BOX: Jonsbo W2
LCD: DELL P2417H 24" LED @ 1920x1080
OS1: MICROSOFT Windows 10 Pro N x64
GSM: iPhone 11 black 4/64GB
ROM: latest iOS
Deyo238 je offline   Reply With Quote
Staro 30.06.2012., 16:54   #2
Romano.Cule
Outer Space
Romano.Cule's Avatar
Lokacija: Vinkovci
Postovi: 833
Ne radi overscan opcija.Nakon svakog restarta ne rasiri sliku od ruba do ruba nego moram rucno namjestati.Koji su to debili.
Staro 01.07.2012., 17:46   #3
Strong
Strong's Avatar
Lokacija: Našice
Postovi: 186
instalirao sam 12.6 i sa pripadajućim CCC i odmah je naredio overscan slike kakav je bio i prije..resetirao računalo nekoliko puta i ništa se nije pobrkalo
Zadnje izmijenjeno od: Strong. 01.07.2012. u 22:41.
Strong je offline   Reply With Quote
Staro 01.07.2012., 19:56   #4
doky
doky's Avatar
Datum registracije: Nov 2010
Postovi: 1,942
Prvi driveri na kojima ZeroCore radi baš kako treba u potpunosti bez ikakvih problema.
Dugo im je trebalo.
doky je offline   Reply With Quote
Staro 02.07.2012., 12:33   #5
2 die 4
2 die 4's Avatar
Postovi: 2,276
Autor Romano.Cule Pregled postova
Radi, radi, samo ne odmah, već nakon nekih par minuta se samo podesi.
To je i mene brinulo, i onda sam jednom upalio komp, otišao na WC i kad sam se vratio bilo je sve u redu. Nakon toga svaki put pustim i svaki put se slika raširi, ali ne odmah po paljenju kompa, već nakon par minuta!
RedGreenBlue
Staro 03.07.2012., 12:41   #6
Romano.Cule
Outer Space
Lokacija: Vinkovci
Postovi: 833
Lol,vidi stvarno. Nakon restarta mu treba jedno par minuta da sam podesi xD.Problem je samo sto se meni ne ceka par minuta da se slika rasiri od ruba do ruba.
Staro 06.07.2012., 12:43   #7
Starsylph
Datum registracije: Oct 2010
Lokacija: Sfera
Postovi: 408
Evo i nove Legacy drivere(HD 2000/3000/4000):
Win 7/Vista 32BiT
Win 7/Vista 64BiT
Win XP 32BiT
Win XP 64BiT
Linux 32-64BiT
Starsylph je offline   Reply With Quote
Staro 07.07.2012., 14:59   #8
Burko
Osobni opis - pitaj me
Burko's Avatar
Postovi: 2,317
ok, jesam ja lud ili mi je komp lud ili WTF, zasto mi FF ne otvara niti jednu stranicu, niti jedan ovaj link? ono, help?
kako skinuti ove drivere? naravno, za HD4000 seriju?
Zadnje izmijenjeno od: Burko. 07.07.2012. u 15:29.
Staro 07.07.2012., 15:28   #9
Burko
Burko's Avatar
Postovi: 2,317
DELETE, dupli post
Staro 07.07.2012., 15:30   #10
Starsylph
Lokacija: Sfera
Postovi: 408
Autor Burko Pregled postova
Server je pao. Probaj za 5h. Ako nece, onda sutra.
http://support.amd.com/us/kbarticles...yproducts.aspx
Staro 10.07.2012., 10:32   #11
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
Zanimljivo da su kao jedan od razloga za razdvajanje novih i starih serija naveli i veličinu drivera, ali ja ne vidim da se smanjila veličina bilo drivera za stare, bilo za nove kartice...ispada kao da je i dalje isti driver u pitanju
Staro 27.07.2012., 20:40   #12
raven34
raven34's Avatar
Lokacija: HR,ZG
Postovi: 42
Ako može savjet...12.4 i dalje 12.6 i beta 12.7 NE rade na 5870HD - klasika .inf file error. Ma šta mu god radili , kompletno čistu instalaciju , nema šanse. Upravo sam ubio cijelo popodne sa CCleanerom, driver cleaner Pro, i Msicuu2 dok nisam došao do tog zaključka da su nešto gadno zaj.ali u inf tabeli kod novih drivera.
Svaka škola košta, ako nešto radi, ne diraj to bolje radi 2 ili 3 FPS više.
raven34 je offline   Reply With Quote
Staro 28.07.2012., 11:56   #13
alen.s
alen.s's Avatar
Postovi: 1,441
ja i dalje drzim 12.1 za svoju "četvorku" , svi noviji driveri mi rade sranja....
npr najnoviji driver mi je radio nesto slicno ovome u jednoj igri ( nije bf2 )
