Staro 26.06.2012., 00:54   #1
krolovača
Datum registracije: Sep 2011
Postovi: 18
BSOD se pojavljuje svako toliko, „WhoCrashed“ krivi ntfs.sys i ntsokrnl.exe
Dakle, ovo traje već neko vrijeme. U početku se rušio sistem svako malo, nije mi prikazivao dodatni hard disk ,onda ipak je, pa je mjesec dana radio najnormalnije itd. Više nisam ni sam siguran koje su se sve kombinacije izdešavale. Na kraju je došlo do toga da se windowsi uopće nisu niti mogli dić, i to bez blue screena, jednostavno se ništa ne bi loudalo. Instalirao sam prije par dana nove windowse. Jedan dan je sve radilo normalno, kad ono odjednom blue screen. Program „WhoCrashed mi izbacuje slijedeće:
On Mon 25.6.2012. 12:33:01 GMT your computer crashed
crash dump file: C:\Windows\Minidump\062512-24031-01.dmp
This was probably caused by the following module: ntfs.sys (Ntfs+0x5B68)
Bugcheck code: 0x24 (0x1904FB, 0xFFFFF88003549608, 0xFFFFF88003548E70, 0xFFFFF800028A8AF7)
Error: NTFS_FILE_SYSTEM
file path: C:\Windows\system32\drivers\ntfs.sys
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT File System Driver
Bug check description: This indicates a problem occurred in the NTFS file system.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
On Sun 24.6.2012. 15:21:48 GMT your computer crashed
crash dump file: C:\Windows\Minidump\062412-23500-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x70040)
Bugcheck code: 0x1E (0xFFFFFFFFC0000005, 0xFFFFF80001CAE893, 0x0, 0xFFFFFFFFFFFFFFFF)
Error: KMODE_EXCEPTION_NOT_HANDLED
file path: C:\Windows\system32\ntoskrnl.exe
description: NT Kernel & System
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
On Sun 24.6.2012. 15:20:20 GMT your computer crashed
crash dump file: C:\Windows\Minidump\062412-28125-01.dmp
This was probably caused by the following module: ntfs.sys (Ntfs+0x213D8)
Bugcheck code: 0x24 (0x1904FB, 0xFFFFF8800448C5C8, 0xFFFFF8800448BE30, 0xFFFFF800029AB90D)
Minidump fileovi su ovdje:
http://www.mediafire.com/?1hub9zfedldm5dz
Everest kompletno izvješće:
http://www.mediafire.com/?f47a3ei307prxwl
Windowsov memory test ništa nije pronašao, chkdsk ni scannow također ništa. Promjenio sam tri hard diska koja su provjerena na drugim kompovima, dakle nije ni to. Avast je skenirao komp više puta i ništa nije našao. Jel ima itko ikakve ideje što da dalje radim?
krolovača je offline   Reply With Quote
Staro 26.06.2012., 09:15   #2
Postovi: 23,684
- provjeri / promjeni sata kabele, pazi da su dobro uštekani na oba kraja
- Hiren's > testiraj hdd na greške i speed transfer
Staro 26.06.2012., 14:24   #3
krolovača
Postovi: 18
HDD mi nije na sata kablu nego ga slejvam, a na onom prije toga sam mjenjao kablove i nije pomoglo. Svi hardovi su čekirani na drugim kompovima i rade najnormalnije, tako da mislim da nije u tom stvar.
Staro 26.06.2012., 14:38   #4
~Trt~
red drum
~Trt~'s Avatar
Datum registracije: Aug 2008
Postovi: 144
pod nove windowse misliš - uzeo si neke druge koje nisi imao već instalirane ili si instalirao iste kao i prošli put?
~Trt~ je offline   Reply With Quote
Staro 26.06.2012., 15:00   #5
nitrooxid
Datum registracije: Jun 2012
Postovi: 133
kao što ti dump file kaže imaš instaliran neki drajver što ti stvara probleme.napravi ponovo reinstal windowsa sa format diskom,tako da ti taj drajver prebriše i install novih drajvera sa ovlaštenih stranica ne nekih divljih.Možda se varam ali većinom drajveri za grafičku rade ovakve probleme.
nitrooxid je offline   Reply With Quote
Staro 26.06.2012., 15:36   #6
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Čak se i ne mora udarit friška instalacija OS-a odmah na prvu, ako je do grafičkih drivera biti će dovoljno i brisanje istih u safe modeu sa Driver Cleanerom pa nakon toga instalacija drivera nanovo.
C L O W N I N G A R O U N D
Staro 26.06.2012., 15:39   #7
~Trt~
red drum
~Trt~'s Avatar
Postovi: 144
naravno ako je do drivera,nekako sam skeptičan da baš driver udara toliki BSOD.
Staro 26.06.2012., 15:42   #8
nitrooxid
Postovi: 133
Da može i to napravit,ako može doći do safe moda i provjeri te windowse koje instaliraš možda u njima imaš neki bug.Dvije glave su uvijek pametnije od jedne!!!
Staro 26.06.2012., 15:58   #9
Doink the Clown
Postovi: 6,214
Autor ~Trt~ Pregled postova
Meni na prvu smrdi da je do bad sectora na disku ali kaže čovjek da je čekirao diskove, možda ne bi bilo loše još jedan HD Tune provrtiti za svaki slučaj.
Staro 26.06.2012., 16:04   #10
~Trt~
red drum
~Trt~'s Avatar
Postovi: 144
a i meni smrdi na hard,ja bi to provrtio sa hd tuneom i regeneratorom i pročekirao hw prije software-a.
Možda je najbolje da proba maknut drivere i sa cleanerom počisti to sve pa vidi šta će se dešavat i onda bacit ponovno oko na hw.
Staro 26.06.2012., 16:06   #11
Postovi: 34,120
Neka uzme tvorničke alate za čekiranje diskova. Naći će ih na Hiren'su. I to neka udari onu dugačku/detaljnu kontrolu (full scan). Potraje, ali bar saznaš na čemu si.
Staro 26.06.2012., 16:25   #12
krolovača
Postovi: 18
Probat ću sa brisanjem i dizanjem drivera, samo ne znam odkud da ih poskidam (nisam nikad to radio osim sa driverscannerom).
Staro 26.06.2012., 16:30   #13
~Trt~
red drum
~Trt~'s Avatar
Postovi: 144
kako misliš neznaš od kud ih poskidat? Pa sa stranice proizvođača
http://support.amd.com/us/gpudownload/Pages/index.aspx ATI
http://www.nvidia.com/Download/index.aspx?lang=en-us NVIDIA
Staro 26.06.2012., 16:41   #14
krolovača
Postovi: 18
Viš kak sam prepametan Probam pa javim.
Staro 26.06.2012., 16:43   #15
~Trt~
red drum
~Trt~'s Avatar
Postovi: 144
Sad kad si naveo driverscannerom - eto gdje je problem Nikad,ali baš nikad nemoj koristit takve gluposti za instaliravanje drivera već skidaj sa stranica proizvođača pa ručno sve...imat ćeš puno manje problema
Staro 26.06.2012., 17:03   #16
krolovača
Postovi: 18
Teško da ću ikako uć u safe mode jer sad više ne mogu ni dić windowse nit ništ. Past će install novi. Dakle onda skidam drajvere za grafu i matičnu? Drugo ne treba ništ od ovih bitnijih stvari? (ne znam baš previše o tome, pa bolje da pitam)
Staro 26.06.2012., 17:29   #17
Doink the Clown
Postovi: 6,214
Autor krolovača Pregled postova
Driveri za chipset od matične, valjda imaš CD koji si dobio s pločom, tamo su ti driveri.
Staro 26.06.2012., 17:31   #18
nitrooxid
Postovi: 133
ostalo nađeš na stranici proizvođača i mora ti biti sve pet!
Staro 27.06.2012., 18:23   #19
krolovača
Postovi: 18
Nemam cd, kupio sam kantu od frajera nekog. Gdje mogu nać i kako instaliram te chipset drivere?
Staro 27.06.2012., 18:30   #20
Doink the Clown
Postovi: 6,214
Odi na stranicu proizvođača matične i nađi drivere za ploču, naravno, trebaš znati koji model matične imaš.
Staro 27.06.2012., 18:52   #21
nitrooxid
Postovi: 133
http://www.asus.com/Motherboards/Int...00DX/#download Koje od ovog da skinem i kako se to instalira?
I pod specifikacijama matične pišu dva chipseta, ja sam pronašao drivere za oba (valjda) i to instalirao. Ovaj prvi navedeni je imao samo unzipanje u windowsove foldere, a ovaj drugi setup i restart. Jel to to?
I još sam drivere za grafičku skino. Ne treba ništ više?
Koje windowse imaš?
Ako su xp skini sve za njih natoj stranici,ako je win7 onda moraš tražiti još za grafiku za lan,wireless ako imaš sound card itd..sve posebno na stranici proizvođača i ne stavljaj neke drivers scanere i ostale slične gluposti.
