Datum registracije: Sep 2011
Postovi: 18
BSOD se pojavljuje svako toliko, „WhoCrashed“ krivi ntfs.sys i ntsokrnl.exe
Dakle, ovo traje već neko vrijeme. U početku se rušio sistem svako malo, nije mi prikazivao dodatni hard disk ,onda ipak je, pa je mjesec dana radio najnormalnije itd. Više nisam ni sam siguran koje su se sve kombinacije izdešavale. Na kraju je došlo do toga da se windowsi uopće nisu niti mogli dić, i to bez blue screena, jednostavno se ništa ne bi loudalo. Instalirao sam prije par dana nove windowse. Jedan dan je sve radilo normalno, kad ono odjednom blue screen. Program „WhoCrashed mi izbacuje slijedeće: On Mon 25.6.2012. 12:33:01 GMT your computer crashed crash dump file: C:\Windows\Minidump\062512-24031-01.dmp This was probably caused by the following module: ntfs.sys (Ntfs+0x5B68) Bugcheck code: 0x24 (0x1904FB, 0xFFFFF88003549608, 0xFFFFF88003548E70, 0xFFFFF800028A8AF7) Error: NTFS_FILE_SYSTEM file path: C:\Windows\system32\drivers\ntfs.sys product: Microsoft® Windows® Operating System company: Microsoft Corporation description: NT File System Driver Bug check description: This indicates a problem occurred in the NTFS file system. The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time. On Sun 24.6.2012. 15:21:48 GMT your computer crashed crash dump file: C:\Windows\Minidump\062412-23500-01.dmp This was probably caused by the following module: ntoskrnl.exe (nt+0x70040) Bugcheck code: 0x1E (0xFFFFFFFFC0000005, 0xFFFFF80001CAE893, 0x0, 0xFFFFFFFFFFFFFFFF) Error: KMODE_EXCEPTION_NOT_HANDLED file path: C:\Windows\system32\ntoskrnl.exe product: Microsoft® Windows® Operating System company: Microsoft Corporation description: NT Kernel & System Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch. This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time. On Sun 24.6.2012. 15:20:20 GMT your computer crashed crash dump file: C:\Windows\Minidump\062412-28125-01.dmp This was probably caused by the following module: ntfs.sys (Ntfs+0x213D8) Bugcheck code: 0x24 (0x1904FB, 0xFFFFF8800448C5C8, 0xFFFFF8800448BE30, 0xFFFFF800029AB90D) Error: NTFS_FILE_SYSTEM file path: C:\Windows\system32\drivers\ntfs.sys product: Microsoft® Windows® Operating System company: Microsoft Corporation description: NT File System Driver Bug check description: This indicates a problem occurred in the NTFS file system. The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time. Minidump fileovi su ovdje: http://www.mediafire.com/?1hub9zfedldm5dz Everest kompletno izvješće: http://www.mediafire.com/?f47a3ei307prxwl Windowsov memory test ništa nije pronašao, chkdsk ni scannow također ništa. Promjenio sam tri hard diska koja su provjerena na drugim kompovima, dakle nije ni to. Avast je skenirao komp više puta i ništa nije našao. Jel ima itko ikakve ideje što da dalje radim? |
Postovi: 23,680
- provjeri / promjeni sata kabele, pazi da su dobro uštekani na oba kraja - Hiren's > testiraj hdd na greške i speed transfer |
Postovi: 18
HDD mi nije na sata kablu nego ga slejvam, a na onom prije toga sam mjenjao kablove i nije pomoglo. Svi hardovi su čekirani na drugim kompovima i rade najnormalnije, tako da mislim da nije u tom stvar. |
Datum registracije: Jun 2012
Postovi: 133
kao što ti dump file kaže imaš instaliran neki drajver što ti stvara probleme.napravi ponovo reinstal windowsa sa format diskom,tako da ti taj drajver prebriše i install novih drajvera sa ovlaštenih stranica ne nekih divljih.Možda se varam ali većinom drajveri za grafičku rade ovakve probleme. |
Jack of all, master of none
Lokacija: Matulji - Rijeka
Postovi: 6,214
Čak se i ne mora udarit friška instalacija OS-a odmah na prvu, ako je do grafičkih drivera biti će dovoljno i brisanje istih u safe modeu sa Driver Cleanerom pa nakon toga instalacija drivera nanovo.
red drum
Datum registracije: Aug 2008
Postovi: 144
naravno ako je do drivera,nekako sam skeptičan da baš driver udara toliki BSOD.
Postovi: 133
Čak se i ne mora udarit friška instalacija OS-a odmah na prvu, ako je do grafičkih drivera biti će dovoljno i brisanje istih u safe modeu sa Driver Cleanerom pa nakon toga instalacija drivera nanovo. Da može i to napravit,ako može doći do safe moda i provjeri te windowse koje instaliraš možda u njima imaš neki bug.Dvije glave su uvijek pametnije od jedne!!! |
Postovi: 6,214
#10 | |
red drum
Postovi: 144
Možda je najbolje da proba maknut drivere i sa cleanerom počisti to sve pa vidi šta će se dešavat i onda bacit ponovno oko na hw.
Postovi: 34,118
Neka uzme tvorničke alate za čekiranje diskova. Naći će ih na Hiren'su. I to neka udari onu dugačku/detaljnu kontrolu (full scan). Potraje, ali bar saznaš na čemu si.
red drum
Postovi: 144
kako misliš neznaš od kud ih poskidat? Pa sa stranice proizvođača ![]() http://support.amd.com/us/gpudownload/Pages/index.aspx ATI http://www.nvidia.com/Download/index.aspx?lang=en-us NVIDIA
red drum
Postovi: 144
Sad kad si naveo driverscannerom - eto gdje je problem Nikad,ali baš nikad nemoj koristit takve gluposti za instaliravanje drivera već skidaj sa stranica proizvođača pa ručno sve...imat ćeš puno manje problema
#16 |
Postovi: 18
Teško da ću ikako uć u safe mode jer sad više ne mogu ni dić windowse nit ništ. Past će install novi. Dakle onda skidam drajvere za grafu i matičnu? Drugo ne treba ništ od ovih bitnijih stvari? (ne znam baš previše o tome, pa bolje da pitam) |
#17 |
Postovi: 6,214
Driveri za chipset od matične, valjda imaš CD koji si dobio s pločom, tamo su ti driveri.
#18 |
Postovi: 133
ostalo nađeš na stranici proizvođača i mora ti biti sve pet! |
#20 |
Postovi: 6,214
#21 | |
Postovi: 133
Ako su xp skini sve za njih natoj stranici,ako je win7 onda moraš tražiti još za grafiku za lan,wireless ako imaš sound card itd..sve posebno na stranici proizvođača i ne stavljaj neke drivers scanere i ostale slične gluposti. ![]() |
