Staro 13.12.2011., 21:48   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Catalyst 12.1 Preview driver
The AMD Catalyst™ 12.1 Preview includes all of the features found in AMD Catalyst™ 11.12 and also includes all of the latest optimizations found in the AMD Catalyst 11.11c performance drivers (AMD Catalyst 11.12 does not include the latest 11.11c optimizations). It is highly recommended that all gamers use the AMD Catalyst 12.1 Preview driver.
Feature highlights of the AMD Catalyst™ 12.1 Preview driver:
AMD HD3D technology support enhancement
Enables support for AMD HD3D technology in conjunction with AMD CrossFireX configurations
Delivers a new Stereo 3D mode over HDMI 1.4a connections - 1080p at 30Hz is now enabled on supported displays.
AMD Catalyst Control Center / Vision Engine Control Center enhancements – Application Profiles
AMD Catalyst 12.1 Preview driver enables users to create per application profiles to individually control 3D and CrossFireX settings for Direct3D applications
Please be sure to select the “Restore Factory Defaults” option under the Catalyst Control Center Preferences menu before using the new application profiles feature – this ensures there are no compatibility issues between previous drivers and the new AMD Catalyst 12.1 Preview driver with regards to application profiles
AMD Catalyst Control Center / Vision Engine Control Center enhancements – Video UI improvements
AMD Catalyst 12.1 Preview driver includes user interface enhancements to simplify adjustment of video color and video quality control.
Performance highlights of the AMD Catalyst™ 12.1 Preview driver (in addition to the AMD Catalyst 11.11c performance driver)
Improves performance (10-15%) in Elder Scrolls: Skyrim when Multi-Sample Anti-Aliasing is enabled on the AMD Radeon™ HD 6900 Series for single GPU and AMD CrossfireX configurations
http://support.amd.com/us/kbarticles...iewdriver.aspx
http://www.anandtech.com/show/5223/a...crossfire-more
Staro 13.12.2011., 21:55   #2
Sniper
Community Manager
Sniper's Avatar
Postovi: 312
Nadam se da su ispravili neke greske.
Prilikom igranja nekih igrica (malo starijih) neradi dobro s ovim novim driverima.
Recimo kada stavim DX9 imam neke crte u igrici, kao da mi je monitor izgreban
Dok cim prebacim na DX5 ili OpenGL sve radi kako treba.
To se sve desilo cim samo instalirao update 11.11.
Sniper je offline   Reply With Quote
Staro 13.12.2011., 21:58   #3
Jelc
Super Moderators
Postovi: 17,485
Pa lijepo ti piše na linku:
Hardware:
AMD Radeon HD 6000 Series
AMD Radeon HD 5000 Series
To ne znači da nebu radilo i na tvojoj grafi nego da je glavni fokus na 5xxx i 6xxx seriji
Najbolje se držat drivera koji ne rade probleme i bog...
Staro 16.12.2011., 12:59   #4
RiSbO
RiSbO's Avatar
Postovi: 254
I kako rade?dali je vec neko stavio?
BF3?
RiSbO je offline   Reply With Quote
Staro 16.12.2011., 13:52   #5
KixzoR
noob?
KixzoR's Avatar
Datum registracije: Jan 2011
Lokacija: Zaprešić
Postovi: 135
Probat ču ja čim dođem doma večeras!!!
KixzoR je offline   Reply With Quote
Staro 16.12.2011., 14:38   #6
Deyo238
Grazie Michael
Deyo238's Avatar
Lokacija: Ogulin
Postovi: 360
U odnosu na 11.11b popravio mi se Batman - Arkham City za oko 5-10fps-a u DX11, L.A. Noire više ne štuca ni pod razno, tj. netreba mi više onaj fix što sm postao u L.A. Noire temi...druge igre još nisam isprobavao...ukratko sam zadovoljan driverom. Instalirao sam ih samo preko starih drivera...
CPU: Intel Core i7 3930k C2 Sandy Bridge E 3200MHz @ 4500MHz (100x45 @ 1.288V) HT enabled
CLR: Corsair H100x
MBO: ASUS RAMPAGE IV FORMULA
RAM: Crucial DDR3-1600 2x8GB + 2x4GB (24GB) @ 1600MHz - 10-11-10-24-1T @ 1.535V
VGA: KFA2 GeForce GTX1070 8GB EXOC
HDD: ADATA SUV800 256GB ++ WD BLUE WD30EZRZ 3TB ++ WD Blue WD6400AAKS 640GB
PSU: Corsair CS550M 550W 80+ Gold Modular
BOX: Jonsbo W2
LCD: DELL P2417H 24" LED @ 1920x1080
OS1: MICROSOFT Windows 10 Pro N x64
GSM: iPhone 11 black 4/64GB
ROM: latest iOS
Deyo238 je offline   Reply With Quote
Staro 17.12.2011., 18:17   #7
Tuna
Unregistered User
Tuna's Avatar
Lokacija: Našice
Postovi: 426
meni upropastilo font na win7... sve mutno za poludit. probo sam uključit cleartype i još neke fore al ne pomaže. Na kraju se vratio na 11.11b
Tuna je offline   Reply With Quote
Staro 17.12.2011., 21:58   #8
Jelc
Super Moderators
Postovi: 17,485
Stavio na XP, za sad dobro
Na sedmicu ne stavljam još dok ne vidim reakcije nesretnih usera
Staro 17.12.2011., 22:38   #9
Deyo238
Grazie Michael
Deyo238's Avatar
Lokacija: Ogulin
Postovi: 360
Autor Tuna Pregled postova
Probaj isključiti Morphological AA (MLAA)...
CLR: Corsair H100x
BOX: Jonsbo W2
ROM: latest iOS
Staro 18.12.2011., 02:25   #10
Tuna
Unregistered User
Tuna's Avatar
Lokacija: Našice
Postovi: 426
Autor Deyo238 Pregled postova
isključio sam sve što sam mogo i opet ništa... na nekim stranicama je font normalan a na nekim je mutan za poludit. potrošio sam cijeli dan na naređivanju fonta pa sam na kraju odusto
Kad formatiram probat ću opet nove pa ćemo vidit kak će se ponašat
Staro 24.12.2011., 12:13   #11
AtOmIc
AtOmIc's Avatar
Postovi: 324
Koliko vidim driveri se odnose samo na seriju 5 i 6 , dali je netko probao sa 4 serijom i kakva su iskustva ?
AtOmIc je offline   Reply With Quote
Staro 30.12.2011., 12:28   #12
alen.s
alen.s's Avatar
Postovi: 1,441
proba san ja danas i....meni sve "štuca" tj imam padove fps-a u vecini igara . pošto igram samo starije igre vratija san se ( po ko zna koji put ) na 10.3 - po meni najbolji driver za 4850 !
( counter strike source , resident evil 5 , age of empires 3 , left 4 dead 2 , modern warfare 2......sve starije igre mi rade ko sat s 10.3 - nove igre uglavnom probam i izbrišem jer su ništa do copy-paste ali to je vec za neku drugu temu ) .
