Staro 12.03.2005., 11:29   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
ATI cilja na overclockere
Zanimljive specifikacije Sapphire Radeon Xpress 200 ploče, sudeći po njima-overclockeri su ciljana skupina
CPU Power Delivery:
-4 phase CPU power supply with the ability to deliver 170+ Amps
-provision for passive, water block or active air cooled mosfets (heatsink form factor is the same as the northbridge)
-voltage range to 2.7V but artificially clamped to 2.0V
-voltage increments as fine as 20 mV
Memory Power Delivery:
-upto 30 Amps delivery potential
-voltage range to 4.0V
-adjustable VTT (memory termination voltage) to +/- 10% of memory VDD
NB Power Delivery:
-NB core has it's own power rail with 4 discrete steps
HT Power Delivery:
- HT I/O has it's own power rail with 4 discrete steps
PCI-E 1.2V Power Delivery:
- PCI-E 1.2V I/O has it's own power rail with 4 discrete steps
PCI-E 1.8V Power Delivery:
- PCI-E 1.8V I/O has it's own power rail with 2 discrete steps
Board Features:
Onboard Devices:
-twin Silicon Image SI3132 SATA II w/ NCQ chips connected via PCI-E, each chip providing 2 SATA ports. (8 SATA ports total; 4 are SATAI and 4 are SATAII w/NCQ)
-Marvel Gigabit LAN connected via PCI-E
-one general purpose single lane PCI-E slot (provisioned for 1 more single lane general purpose slot if one SI3132 is not populated as a build option)
-Azalia audio support via SB450 using Realtek codec
-POST code LED display
-Firewire support with ViaVT6306
-VGA and DVI outputs via Radeon Xpress 200G (enabling upto 4 monitor outputs using an ATI add in card and ATI Surroundview)
-onboard power and reset switches
-onboard VID code LED display
Overclocking Options:
-HTT frequency upto 500 MHz
-All relevant memory timings and adjustments including support for new Rev E CPUs
-HT link ratios X1, X2, X3, X4,X5
-Independent PCI-E overclocking for the graphics bus
Thermal Monitoring:
-thermal monitoring of CPU power delivery circuitry, CPU, NB and ambient
That's all I can remember for now.
Here are some pictures of the motherboard and the custom Danger Den waterblocks that will be made available for sale specifically for this application.
Sljikice tu:
http://www.xtremesystems.org/forums/...ad.php?t=55734
Izgleda jako dobro...
Staro 12.03.2005., 13:57   #2
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,479
E, ovo bi mogla biti jedna dobra generacija ploči. ako su bios uštimali, i ploča nije bugovita. bit će ovo jedna ebena ploča...
Kad ovaj moj rig odsluži svoje, čini mi se da ide full ati kombinacija
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 12.03.2005., 14:32   #3
Bl@de
Bl@de's Avatar
Lokacija: Ispred kompa
Postovi: 2,004
u joj ovo jako dobro zvuci.
btw kad bi to konacno trebalo biti dostupno?
Intel i5 4670k
ASrock Z87 Extreme 3
2x8 Gb Kingston blu
MSI Rx 580x 4 GB
OCZ SSD Vertex 4 - 128 GB
Samsung T166 500 GB 7200 okr/min 16 MB HD501LJ
Samsung F1 1 TB 7200 okr/min 32 MB HD103UJ
Dell S2522HG
Chieftec DX-01BD-V, Corsair 520W CMPSU-520HXEU
Bl@de je offline   Reply With Quote
Staro 12.03.2005., 15:02   #4
Jelc
Super Moderators
Postovi: 17,485
Kasnilo se toliko zato kaj je ATI čekao baš ovu reviziju chipseta i nije htio započeti sa bugovitom AMD pločom.
Sad je valjda sve ok.
Navodno će biti jeftinije od Nvidie, trebale bi biti dostupne u roku od 15-tak dana.
Ste vidjeli slike sa vodenim blokovima???...baš dobro izgleda
Staro 12.03.2005., 15:30   #5
pinsla
Caught Somewhere In Time
pinsla's Avatar
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
jedva čekam da ovo isprobam
pinsla je offline   Reply With Quote
Staro 12.03.2005., 16:10   #6
Jelc
Super Moderators
Postovi: 17,485
Javi kad dobiješ
Staro 12.03.2005., 20:22   #7
pinsla
pinsla's Avatar
Postovi: 1,860
Originally posted by Jelc
Javi kad dobiješ
naravno ima da je dobro izmučimo
jedino sam malo skeptičan prema saphirru ali valjda bu ih ati dobro stegnuo da ovo čudo ispadne dobro
Staro 12.03.2005., 20:27   #8
LuXor
Datum registracije: Jul 2004
Lokacija: Bjelovar
Postovi: 752
@Jelc: Dobro kažeš da cilja na Overclockere, to dokazuje ovaj sajam/prezentacija overclockinga u Texasu (ATi ga sponzorira).
LuXor je offline   Reply With Quote
Staro 12.03.2005., 21:49   #9
Jelc
Super Moderators
Postovi: 17,485
Ma ne, to je bilo nabrijavanje X850XT-PE.
Pogledaj malo specifikacije ploče i do koliko su stavili da možeš dizati proc i memu.
Jedino još DFI ima do 4v, nitko više.
I samo spominjanje vodenog hlađenja mosfeta i slične perverzije je bilo dosta da mulci po overclock siteovima počnu balit
Staro 12.03.2005., 22:14   #10
Tr4f1ka
Tr4f1ka's Avatar
Datum registracije: Apr 2004
Postovi: 301
a i sama dobro izgleda, pogotovo blokovi za cpu/nb/mosfete
HARDCORE 4 LIFE
athlon xp 2500+ @ 3200+ (11x200)
gigabyte ga7n400l ( n force2 )
gigabyte radeon9600pro (@ 510/700 )
2x256 Samsung ddr400
ŽENE SU KAO RAM, ŠTO VIŠE IMAŠ TO BOLJE
Tr4f1ka je offline   Reply With Quote
Staro 13.03.2005., 00:23   #11
killah_tm
killah_tm's Avatar
Postovi: 900
ludnica od ploce hebote.
konacno za ati freekove...
jelc - za 15 dana kod nas u prodaji ili?
killah_tm je offline   Reply With Quote
Staro 13.03.2005., 00:37   #12
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,191
Možete me smatrat retardiranim, al to je ploča za sck, koj?
Ne postoji glupo pitanje.
Ne vidim proc od kulera da bi mogo procijenit.
Staro 13.03.2005., 02:00   #13
Jelc
Super Moderators
Postovi: 17,485
Za 939, a bit će ih koliko čujem i za 754.
Staro 13.03.2005., 02:01   #14
Jelc
Super Moderators
Postovi: 17,485
Tak su rekli-za dva tjedna.
Staro 13.03.2005., 02:38   #15
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,437
Još samo fale dobre recenzije. Sljedeći tjedan bi to već sigurno moglo biti na Anandu.
Vidim da je Jelc jako zagrijan, kladim se da ju bu on uzeo ak već nije uzeo DFI
stef je online   Reply With Quote
Staro 13.03.2005., 03:02   #16
Jelc
Super Moderators
Postovi: 17,485
Pa recenzije modela koje su davali na testove su bile još prije dva mjeseca i bile su dobre...i da, nisam više mogao čekati i uzeo sam opet DFI
Staro 13.03.2005., 03:26   #17
stef
stef's Avatar
Lokacija: Zabok
Postovi: 3,437
Ono je bila demo ploča/inžinjerski primjerak sa lemljenim žicama sa stražnje strane. Bila je OK osim mislim problema sa USB-om. Pretpostavljam sa ova Sapphireova ima noviju reviziju SB-a, a mogli su staviti i onaj novi ULI SB.
