Staro 15.06.2011., 00:44   #1
Liquid Snake
Liquid Snake's Avatar
Postovi: 166
Catalyst 11.6 Official
Na serveru:
AMD Catalyst 11.6 Win 7 | Vista (64-bit)
AMD Catalyst 11.6 Win 7 | Vista (32-bit)
AMD Catalyst 11.6 Win XP (64-bit)
AMD Catalyst 11.6 Win XP (32-bit)
Code:
Driver Packaging Version            8.861-110524a-119606C-ATI
Catalyst™ Version                   11.6
Provider                            ATI Technologies Inc.
2D Driver Version                   8.01.01.1162
Direct3D Version                    7.14.10.0841
OpenGL Version                      6.14.10.10834
Catalyst™ Control Center Version    2011.0524.2352.41027
Release Notes:
http://support.amd.com/us/kbarticles...easeNotes.aspx
Dreaming in digital. Living in realtime. Thinking in binary. Talking in IP.....Welcome to our world.
~DI
Liquid Snake je offline   Reply With Quote
Staro 15.06.2011., 12:08   #2
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Daj korektan link na release notes.
All you have is your fire and the place you need to reach.
Don't you ever tame your demons, always keep them on a leash.
Alph4Dawg je offline   Reply With Quote
Staro 15.06.2011., 12:16   #3
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,224
Ma nema još ništa na official stranicama, vrtim već 2h po amd driver pageu, pa nema niš.... A nema šanse da se još jednom zaj. s driverima dok ne vidim changelog.
Staro 15.06.2011., 12:22   #4
2 die 4
2 die 4's Avatar
Postovi: 2,258
ajde konačno nemam ni ja više onaj lag gore desno!
RedGreenBlue
Staro 15.06.2011., 15:19   #5
doky
doky's Avatar
Datum registracije: Nov 2010
Postovi: 1,942
Meni je lag nestao s 11.5b no nakon nekoliko dana se ponovno vratio.
Nadam se da s ovim driverima neće biti slićno.
doky je offline   Reply With Quote
Staro 17.06.2011., 16:08   #6
Thermaltake
1
Postovi: 3,587
Evo instaliro i da javim nema lag-a više igrice nisam probao, ali ima drugi problem sad kod mene koji sam otkrio,a to je override naime kad override-am grafičku ne želi mi prihvatit mjere niti jedne kaže Passed i vrati na najmanje, nemogu niti jedne drivere napravit da su normalni uvijek nešto skršeno.
Evo i Release Notes pošto gore link ne radi.
Release Notes
Zadnje izmijenjeno od: Thermaltake. 17.06.2011. u 16:50.
Staro 17.06.2011., 16:58   #7
KixzoR
noob?
KixzoR's Avatar
Datum registracije: Jan 2011
Lokacija: Zaprešić
Postovi: 135
je tebi bar radi ccc meni neče ni otvorit xD pojma nemam zašto ali nije zbog tih drivera to več jedno 6 mjeseci neradi.
KixzoR je offline   Reply With Quote
Staro 17.06.2011., 16:59   #8
Thermaltake
1
Postovi: 3,587
Radi, obriši u C:\Windows\assembly od starih CCC sve one koji imaju oznaku 90ba9c70f846762e i na novo instaliraj i radit će ti.
Staro 17.06.2011., 17:07   #9
KixzoR
noob?
KixzoR's Avatar
Lokacija: Zaprešić
Postovi: 135
k thnx probat ču jer sam pokušavo neke fore kaj sam našo na netu i nisu radili.
evo sam da javim da mi napokon radi ccc riješio si me muke thnx!
Zadnje izmijenjeno od: Jelc. 19.06.2011. u 11:51. Razlog: dupli post
Staro 17.06.2011., 17:44   #10
Thermaltake
1
Postovi: 3,587
Nema problema, probaj Override napravit bar malo pa mi javi jel tebi radi il netko ako može, da vidim jel to samo do mene il svima.
Staro 17.06.2011., 18:41   #11
doky
doky's Avatar
Postovi: 1,942
Kod mene Overdrive radi normalno. Probaj napraviti reinstall ali da počistiš s DriverSweeperom ostatke prije ponovnog stavljanja drivera, sigurno bu ti to riješilo problem. Ati-evi driveri su jako nježni pa s njima treba pažljivo.
Staro 17.06.2011., 18:46   #12
Thermaltake
1
Postovi: 3,587
A unistaliro sam sa sa opcijom express mako sve ati foldere i skrivene isto počistio sa CCleanerom mislim ako to nije dovoljno, no probat ću još jednom sad maknut.
Pokušaj broj 2 i dalje isto prvo sam express uninstall pa očistio još sve foldere ATI pa očistio sa CCleanerom pa onda driver sweeperom i instaliro i opet ista stvar sa overridom,grafička hd3850 agp, win 7 32bit.
Zadnje izmijenjeno od: Thermaltake. 17.06.2011. u 19:06.
Staro 18.06.2011., 17:13   #13
Liquid Snake
Postovi: 166
Samo da razjasnimo, stavio si 11.6 AGP Hotfix ??
http://support.amd.com/us/kbarticles...AGPHotfix.aspx
~DI
Staro 18.06.2011., 17:34   #14
Thermaltake
1
Postovi: 3,587
Autor Liquid Snake Pregled postova
Jesam, da nisam nebi mi uopće instaliro drajvere od grafičke. Isprobavo sam raznorazne stvari i dalje ništa, prijavio sam grešku ATI support-u.
Staro 18.06.2011., 18:03   #15
Pegasus8
Pegasus8's Avatar
Postovi: 482
napokon uspješni driveri lag od misa u gornjem desnom kutu nestao s ovom verzijom.
Pegasus8 je offline   Reply With Quote
Staro 18.06.2011., 18:44   #16
hylem
Postovi: 279
nabijem ja taj ati na čunu ... svima lag nestane a meni se s ovim driverima pojavi, i to bilo gdje na monitoru ... a 11.5 sasvim normalno radili bez ikakvog laga
... nemogu oni da izbace poštene drivere da ih vrag prca u bulju
hylem je offline   Reply With Quote
Staro 18.06.2011., 19:41   #17
izi
izi's Avatar
Lokacija: Vinkovci - Slavonski Brod
Postovi: 139
Meni takodjer nestao lag, a koliko sam primjetio i BSOD prilikom gledanja filmova.
izi je offline   Reply With Quote
Staro 18.06.2011., 20:39   #18
Enter Sandman
dark paradise
Enter Sandman's Avatar
Postovi: 551
Ja sam pregazio 11.5a i sve 5, nikakvih problema.
Enter Sandman je offline   Reply With Quote
Staro 18.06.2011., 20:45   #19
HCS
Premijum
HCS's Avatar
Postovi: 1,360
Poboljsanja na 58XX seriji?
Staro 18.06.2011., 20:55   #20
Liquid Snake
Postovi: 166
Da li si rucno unio mjere ili si isao na Auto-Tune ? Ako nisi daj probaj preko Auto-Tune, pa javi da li ti spremi postavke.
~DI
Staro 18.06.2011., 21:43   #21
Thermaltake
1
Postovi: 3,587
Probao sam i auto-tune i ništa i dalje na defaultnim radi. Kad ručno metnem on kad testita stavi na mjere koje sam unio vidim dole da se promjieni tokom testitanja i onda vrati na najmanje i kaže passed, a dole pod frekvencijama piše da radi na najmanjima, a trebalo bi bar memoriju dić jer gpu tek pri nekom većem opterećenju diže, pa sam i to probo reko možda su sad neke nove šeme napravili da i memorija skoči pod većim opterećenjem no nije i dalje isto.
Staro 18.06.2011., 22:04   #22
Liquid Snake
Postovi: 166
Pa imas gornja polja za unos frekvencije tj. overclock, a ona polja dolje su 2D/Idle frekvencije, znaci kad racunalo miruje ili nije pokrenuta neka zahtjevnija aplikacija. Znaci tek kad pokrenes neku zahtjevniju 3D aplikaciju onda se promjene frekvencije u tim donjim poljima na one koje si unio prilikom overclocka.
~DI
Staro 18.06.2011., 22:40   #23
Thermaltake
1
Postovi: 3,587
Inače mi to samo za GPU vrijedi da skoči kad je pri većem opterećenju i onda ostane poslije tog opterećenja na najvišem taktu ovog kojeg stavim u override-u, a memorija je odma skočila kad sam stavio nisam trebao nikakvo opterećenje radit, a sad neće ni gpu ni memorija ni u mirovanju ni pri opterećenju.
evo i slike:
slika 1
slika 2
Zadnje izmijenjeno od: Thermaltake. 18.06.2011. u 22:47.
Staro 18.06.2011., 23:20   #24
Liquid Snake
Postovi: 166
evo i slike:
slika 1
slika 2
Kao sto sam ti rekao u prethodnom postu a i sad kad gledam tvoje slike, sve je OK. Ti si stavio frekvenciju 720/950 i pokrenuo si Test Custom Clocks, koji provjerava da li je taj overclock stabilan. U poljima dolje dok traje test koristi se tvoja custom frekvencija 720/950, a nako sto test zavrsi frekvencije se vracaju u 2D/Idle stanje koje je za tvoju grafu 300/829. To se zove PowerPlay i sluzi ne bi li se smanjila potrosnja energije od strane GPU-a.
Znaci to nije nikakav bug i kod tebe je sve OK.
~DI
Staro 19.06.2011., 10:33   #25
Thermaltake
1
Postovi: 3,587
Aha, da sad sam skužio i ja kad sam pokrenuo Unigine test pa sam vidio u catalystu da skoči, znači malo je drukčije od starog catalysta,hvala riješio sam to onda.
Staro 27.06.2011., 23:43   #26
viper
super user
viper's Avatar
Lokacija: Houston, TX
Postovi: 1,805
Ova verzija je odlicna ! Vise nemam problema sa bjelim ekranom u bc2 ,nema vise crash-anja drivera !
viper je offline   Reply With Quote
Staro 30.06.2011., 00:34   #27
Zyklon
Zyklon's Avatar
Postovi: 171
o kakvom lagu je riječ uopće?
Zyklon je offline   Reply With Quote
Staro 27.07.2011., 11:58   #28
toni36
toni36's Avatar
Postovi: 154
pomoć ccc
kako da dobijen sliku preko cijelog lcd tv ekrana preko najnovijeg ccc.
lcd tv nije primarni monitor.
toni36 je offline   Reply With Quote
Staro 27.07.2011., 15:05   #29
slavonac90
slavonac90's Avatar
Postovi: 1,521
staviš samo extended opciju i staviš rezoluciju za TV istu kao i za monitor...tako je meni barem.
slavonac90 je offline   Reply With Quote
Staro 27.07.2011., 15:35   #30
BlackDwarf
BIND SOFT d.o.o.
BlackDwarf's Avatar
Lokacija: Novska
Postovi: 2,420
Ne, ima opcija za prikaz preko cijelog ekrana.
Scaling options ili tako nekako.
BlackDwarf je online   Reply With Quote
