Staro 05.10.2010., 21:10   #1
goggy
Datum registracije: Oct 2010
Postovi: 3
Bnet thomson + airlive wl-5470ap (pptp)
/dev/ttyp0
0day 00:03:17 (none) kern.notice pptp[2597]: anon log[mainptp.c:292]: The synchronous pptp option is NOT activated
0day 00:03:18 (none) kern.notice pptp[2604]: anon log[ctrlp_repptp_ctrl.c:251]: Sent control packet type is 1 'Start-Control-Connection-Request'
0day 00:03:18 (none) kern.notice pptp[2604]: anon log[ctrlp_dispptp_ctrl.c:738]: Received Start Control Connection Reply
0day 00:03:18 (none) kern.notice pptp[2604]: anon log[ctrlp_dispptp_ctrl.c:772]: Client connection established.
0day 00:03:18 (none) kern.warn pppd[2590]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access
0day 00:03:19 (none) kern.notice pptp[2604]: anon log[ctrlp_repptp_ctrl.c:251]: Sent control packet type is 7 'Outgoing-Call-Request'
0day 00:03:28 (none) kern.warn pppd[2590]: LCP: timeout sending Config-Requests
0day 00:03:35 (none) kern.notice pptp[2604]: anon log[callmgr_mainptp_callmgr.c:231]: Closing connection (unhandled)
0day 00:03:35 (none) kern.notice pptp[2604]: anon log[ctrlp_repptp_ctrl.c:251]: Sent control packet type is 12 'Call-Clear-Request'
0day 00:03:35 (none) kern.notice pptp[2604]: anon log[call_callbackptp_callmgr.c:78]: Closing connection (call state)
0day 00:03:40 (none) kern.warn klogd: eth1hy is 8305
0day 00:03:43 (none) kern.info udhcpc: udhcp client (v0.9.9-pre) started
0day 00:03:47 (none) kern.debug udhcpc: Sending select for 10.63.220.106...
eto ja stvarno više ne znam što bi pokušao, što nije čudno s obzirom na moje mrežno (ne)znanje , pa eto stvarno ako bi mi netko mogao pomoć bio bih mu vječno zahvalan
Pozdrav svima...
Dakle uzeo sam bnetov xcarnet paket i "dobio" bnetov thomson tcm420 kabelski modem.
Kako već otprije imam airliveov wl-5470ap mrežni uređaj htio sam to dvoje spojit kako bih mogao ići bežično na internet.
Dakle za spajanje na net potrebno je upostaviti pptp konekciju s bnetovim serverom (sa kompom mi to uspije bez problema).
Airlive ima Gateway način rada (AP + Router) sa pptp wan pristupom, i ja sam ga konfigurirao na sljedeći način (prateći http://portal.bnet.hr/ZG/pocetna.htm):
ovo je konfiguracija za wan port na koji sam spojio modem:
ove zadnje kvačice baš i ne znam što znače... ovako je bilo po defaultu... ja sam inače pokušao svakakve kombinacije...
ne znam je li ovo ima kakve veze sa postavkama wan veze ali eto i slika postavki mrežnog sučelja:
Dakle kad to tako postavim, rebootam i airlive i modem... airlive pokušava ostvarit pptp konekciju ali zbog nečega svaki put padne... koliko ja mogu skontati iz log-a airlive se lijepo spoji s tim nekim serverom preko modema (ono dodijelio mu se ip i sve) ali kad se počne dizat pptp konekcija sve propadne...
ali da ne ostane na mojim nagađanjima evo i loga...
0day 00:03:04 (none) kern.debug udhcpc: Sending select for 10.63.220.106...
0day 00:03:04 (none) kern.info udhcpc: Lease of 10.63.220.106 obtained, lease time 43200
0day 00:03:17 (none) kern.notice pppd[2590]: pppd 2.4.2b1 started by root, uid 0
0day 00:03:17 (none) kern.info pppd[2590]: Using interface ppp0
0day 00:03:17 (none) kern.notice pppd[2590]: Connect: ppp0 <--> /dev/ttyp0
goggy je offline   Reply With Quote
Staro 05.10.2010., 22:21   #2
Matta
El Mattador
Matta's Avatar
Lokacija: <->
Postovi: 1,938
Khm, sto se tice tvog problema stvarno ti ne bih znao pomoci ali dok se netko ne nadje da ti pomogne zasto jednostavno ne stavis da modem sam dize konekciju, das mu LAN adresu 192.168.100.1, dignes Airlive u cistom AP modu, ostavis adresu koja je i stavis IP adresu od modema kao gateway ?
Stvar ce raditi sigurno.
Matta je offline   Reply With Quote
Staro 05.10.2010., 22:28   #3
goggy
Postovi: 3
Autor Matta Pregled postova
mislim da ovaj modem ne može sam dignut konekciju... ili se možda varam?
Staro 05.10.2010., 22:33   #4
Postovi: 23,623
Bemu miša, šta nisi pogledao malo po forumu ?
Carnet PPTP igrokaz jedva slućajno / namjerno radi samo sa WRT54GC (pazi: baš ta verzija sa origigi fw).
Još je netko bio prijavio da je složio sa još jednim router - om, ne sjećam se kojim, evo našao TP-Link TL-WR340G ali vidim da ima više revizija pa opet nije siguro.
Rješenja:
- trampi / nabavi gore spomenuti router
- nađeš neku kramu od kompa, staviš dvije mrežne i digneš neki linux u router funkciji
- odustani od Carnet PPTP igrokaza
Staro 05.10.2010., 22:43   #5
goggy
Postovi: 3
Autor Nikky Pregled postova
Rješenja:
ma gledao sam ja i po forumu i svuda po netu, i nisam našao da je netko pokušavao sa ovim novim firmwareom od airlive-a (onaj stari nije imao kombinaciju pptp-a i automatskog obtaina ip adrese)
pa zato pitam ovdje... možda se s ovim može a ja ne znam kako...
Staro 05.10.2010., 22:48   #6
Postovi: 23,623
Probaj, mada sumljam
Staro 06.10.2010., 09:30   #7
Matta
El Mattador
Matta's Avatar
Lokacija: <->
Postovi: 1,938
Autor goggy Pregled postova
Nemam nikakvog iskustva sa kabelskim modemima ali zar to nije i svrha modema na kraju krajeva ? Da digne konekciju ?
Staro 06.10.2010., 09:54   #8
Postovi: 23,623
@Matta
Ovdje nije problem u uređajima nego u implementaciji PPTP u Carnet režiji, ista stvar / problem se pojavljuje i kod drugih ISP - ova u kombinaciji sa Carnet account - om.
Mnogi uređaji imaju PPTP funkcionalnost ali samo par njih uredno radi u kombinaciji sa Carnet - om, nije moguće da svi proizvođači neznaju tu funkciju (način spajanja) napravit kako treba.
Carnet je i htio otežati spajanje više kompjutera / kućne mreže preko osobnog account - a pravdajući se formulom "osobni account = jedno računalo" a dokaz tome je šta konekcija na kompu (Dial-Up) u Win i Linux os - u radi bez problema.
Staro 24.11.2010., 13:53   #9
BrusJr
BrusJr's Avatar
Postovi: 78
znači, kako trenutno stvari stoje, airlive nije moguće koristiti za pptp sa Carnetom, ili se možda varam?
BrusJr je offline   Reply With Quote
Staro 24.11.2010., 15:11   #10
Postovi: 23,623
Posudiš, probaš i javiš rezultat. Nije nitko prijavio jel radi - ne radi.
Staro 30.11.2010., 01:07   #11
BrusJr
BrusJr's Avatar
Postovi: 78
evo da onda ja prijavim da bi trebalo raditi. Koristim Metro-Carnet koji isto treba pptp konekciju. u kombinaciji sa 5470AP-om stvar radi super.
