Staro 08.04.2009., 22:58   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Catalyst 9.4
Tema o beti je slučajno završila u smeću, zato nova
http://game.amd.com/us-en/drivers_catalyst.aspx
ATI Catalyst™ 9.4 - New ATI OverDrive™ auto-tuning
application*
�� ATI Catalyst 9.4 includes a new ATI Overdrive™ auto-tune application to accurately
determine the best over-clocked engine and memory values for ATI Overdrive
supported ATI Radeon™ Graphics accelerators
�� Designed for the ATI Radeon™ HD 4000 Series
* AMD’s product warranty does not cover damages caused by over clocking, even when
enabled via AMD OverDrive software
Resolved Issues for the Windows Vista Operating System
This section provides information on resolved issues in this release of the ATI Catalyst™
Software Suite for Windows Vista. These include:
�� "World of Warcraft" or "World of Warcraft - Wrath of the Lich King": Flickering no
longer occurs when Shadow is set to medium/high using CrossFire
�� Google Sketchup no longer displays blank screen
�� Resolutions above 10 x 7 will now full screen properly for specific HDMI displays
�� Artifacts no longer visible while playing Age of Conan DX10
�� VC-1 progressive disc playback no longer exhibits block corruption
Resolved Issues for the Windows XP Operating System
Software Suite for Windows XP. These include:
�� The Compute Abstraction Layer (CAL) driver now functions properly under
Windows XP
�� Overlay Theatre Mode display no longer corrupt after enabling 3D screen saver
�� OS Display Settings no longer shows extra resolutions for Component Video
Resolved Issues for the Windows 7 Operating System
Software Suite for Windows 7. These include:
�� City of Villains: Display now redraws correctly after changing graphics settings
�� Catalyst Control Center: 1080i@30hz and 1080i@25hz Component Video modes
can now be applied via Component Video - Advanced aspect
�� Custom formats modes can now be applied properly and will be available under "List
All Modes"
�� Display profiles will now be restored when displays are swapped while the system
sleeps
�� WinDVD9 HD playback doesn't cause the desktop to jitter or flicker anymore
�� Device Manager no longer displays error during express driver uninstall
Staro 08.04.2009., 23:31   #2
pipe
Bill Gates
pipe's Avatar
Lokacija: Vukovar
Postovi: 1,983
AAAAAaaaa. Bas sam prekjucer instalirao 9.3.
Ima li kakvih vecih promjena ili ne?
I ja imam na ploci.
Staro 08.04.2009., 23:48   #3
BeroVK
Lokacija: Vinkovci
Postovi: 780
Eo probao na X1950XT i naravno da neradi, kao fol nepodrzava tu seriju
BeroVK je offline   Reply With Quote
Staro 09.04.2009., 00:04   #4
Orgazmatron
Orgazmatron's Avatar
Postovi: 139
meni su bolji,bar zasada...
Na 9.3 mi je trzala slika(friski windowsi),stavio 9.4 i nema vise trzanja.
super,vidjet cemo nakon jos par igra kako se ponasaju!
Orgazmatron je offline   Reply With Quote
Staro 09.04.2009., 00:08   #5
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,927
probat cu i ja pa cu prokomentirat
Staro 09.04.2009., 13:32   #6
Orgazmatron
Postovi: 139
Malo su bolji ali opet trza
u PES-u je bolje
u nba 2k9 kada je replay lopta trza u zraku,ne kuzim...
Staro 09.04.2009., 17:26   #7
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,927
mozda mrvicu bolji.nista osobito
Staro 09.04.2009., 17:43   #8
Minox
Minox's Avatar
Postovi: 565
ako nektko koristi win7 neka ne skida ccc za njih
jer su to i dalje 9.3 ver.
edit:
instalirao sam za vist64 no i dalje mi stoji u ccc-u da imam 9.3 ver _
Minox je offline   Reply With Quote
Staro 09.04.2009., 17:53   #9
Metamphetamine
Flaccitra
Metamphetamine's Avatar
Lokacija: Vinkovci
Postovi: 276
Autor Minox Pregled postova
edit:
koja ti verzija drivera stoji pod display adapter u device manageru?
Metamphetamine je offline   Reply With Quote
Staro 09.04.2009., 17:54   #10
LuxZg
Postovi: 512
@BeroVK - nije "ko fol" nego ne podržava Imam istu kartušu, i zadnje kaj možeš trenutno stavit na nju su 9.3. Vjerojatno će izletit kakav modani driver baziran na 9.4, al treba se strpit.. 9.7 će opet podržavat X1xxx seriju.. pa opet jedan kvartal ništa, to je nova politika
Operating Systems Supported
The latest version of the Catalyst™ software suite is designed to support the following
Microsoft Windows platforms:
- Windows Vista 32-bit version
- Windows Vista 64-bit version
- Windows XP Professional
- Windows XP Home Edition
- Windows XP Media Center Edition
- Windows XP Professional x64 Edition
- Windows 7
AMD Desktop Product Family Support
ATI Radeon™ HD 4890 Series
ATI Radeon™ HD 4870 X2 Series
ATI Radeon™ HD 4850 X2 Series
ATI Radeon™ HD 4800 Series
ATI Radeon™ HD 4670 Series
ATI Radeon™ HD 4650 Series
ATI Radeon™ HD 4600 Series
ATI Radeon™ HD 4550 Series
ATI Radeon™ HD 4350 Series
ATI Radeon™ HD 3800 Series
ATI Radeon™ HD 3600 Series
ATI Radeon™ HD 3400 Series
ATI Radeon™ HD 2900 Series
ATI Radeon™ HD 2600 Series
ATI Radeon™ HD 2400 Series
I da, win7 su podržani i u 32bit i u 64bit, iako ne piše u release notes
Intel Core 2 Duo E4400 @ 320x10 (3200MHz) w/ Scythe Ninja rev.B + 120mm fan | Gigabyte GA-P35-DS3R (Intel P35 + ICH9R) | 4x 1GB Kingmax MARS DDR2 800 CL5 | Sapphire ATi Radeon HD4890 | Seagate 7200.11 250GB+2x WD Black 640GB+Samsung F3 1TB; svi SATA/7200rpm | LG GH20NS15 SuperMulti, SATA | LG W2361V-PF 23", 1920x1080, DVI+HDMI | Aplus CS-188AF case w/ 250mm side fan | onboard 7.1, with Logitech X-540 5.1 speakers | Chieftec 450W /w 120mm fan | Windows 7 64bit Enterprise
LuxZg je offline   Reply With Quote
Staro 09.04.2009., 17:56   #11
Minox
Minox's Avatar
Postovi: 565
Autor Metamphetamine Pregled postova
8.591.0.0
Staro 09.04.2009., 19:07   #12
ZOKSY
ZOKSY's Avatar
Postovi: 278
instalirao sam ih na Visti x64 i rade bez greške..Igre nisam isprobavao,ali sam pokrenuo 3D Mark SM2 test Firefly Forest i sa 9.3 sam imao 46.266fps a sa 9.4 46.759fps-a
a valjda idu na bolje bumo rekli....
ZOKSY je offline   Reply With Quote
Staro 09.04.2009., 19:27   #13
Metamphetamine
Flaccitra
Lokacija: Vinkovci
Postovi: 276
8.591.0.0
to je cat 9.3, jesi skinuo dobar driver? trebalo bi biti 8.600
Staro 10.04.2009., 10:30   #14
Thommy
Thommy's Avatar
Postovi: 468
ja sam instalirao na Visti 32bit-a i driver je 8.600, sve radi ok s tim da sam setup za catalyst skinuo sa Techpowerup stranice, instalacija sa sluzbene ATI stranice mi je isto pokazivala 8.591 driver i cataliyst 9.3 s tim da sam skinuo 9.4 verziju, barem je tako bilo navedeno u nazivu setupa i na sluzbenoj stranici
Thommy je offline   Reply With Quote
Staro 10.04.2009., 11:42   #15
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Dobio par fps-a u crysisu na dx10, vista 32 bit te nepada ispod 30 fps-a (sve very high osim object quality i shadows), u odnosu na 9.2 drivere.
Nikakvih errora nije bilo kao ni inače, u ccc-u pokazuje da je verzija 8.60, te gpu-z potvrđuje da su 9.4 driveri.
@Orgazmatron - probaj uključit vertycal syncronization iliti vsync.
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 10.04.2009., 12:07   #16
Orgazmatron
Postovi: 139
Ukljucen je...
Ali sada mi catalyst ne radi,kada ga pokrenem nista se ne desava...
Framework sam nanovo stavio i isto... (xp,sada je 3.5 gore)
edit: stavio xtreme-g 9.2 i vojla,pes PES ne steka,CCC radi!
ovo je smijesno...
Zadnje izmijenjeno od: Orgazmatron. 10.04.2009. u 13:31.
Staro 10.04.2009., 12:31   #17
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Autor Orgazmatron Pregled postova
Ukljucen je...
Meni slika počne titrat, dobro nebih baš rekao titrat, nego nevidljive linije idu gore dole dok pomičem sliku npr. u hawx-u imam oko 120fps-a i bilo kuda da skrećem počne titrat, a kada je vsync uključen imam 60fps-a i ništa netitra?
Nikad nisam mislio da ću imat "problema" zbog viška fps-a!
TV: LG 7450
GAMEPAD: XBOX One
Staro 10.04.2009., 12:39   #18
Hunt.ONE
ЬГΛY.Z0ИЗ
Hunt.ONE's Avatar
Lokacija: Sisak
Postovi: 258
Pa kaj ce ti visak fps-a?
vsync locka fps-a po refresh rate-u
This post is copyrighted ©
Hunt.ONE je offline   Reply With Quote
Staro 10.04.2009., 14:05   #19
Minox
Minox's Avatar
Postovi: 565
grrr može bit da je do toga
niš budem čekal da dojde na tech za ostale osove
Staro 10.04.2009., 14:42   #20
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Skini sa pceskpertove rubrike "download" 9.4 drivere.
TV: LG 7450
GAMEPAD: XBOX One
Staro 10.04.2009., 18:15   #21
Minox
Minox's Avatar
Postovi: 565
jesam i niš nije pomoglo
očito je do win7(Build 7000) grrr
p.s do sada nikad nisam imo problema sad win7
čak su radili i 64bit wista driveri
niš budem pogledal jel funkcionira na visti64
Zadnje izmijenjeno od: Minox. 10.04.2009. u 18:28.
Staro 10.04.2009., 18:32   #22
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Meni na sedmici 9.2 nisu htjeli radit, točnije display driver se nije štjeo instalirat.
A šta ti očekuješ od beta OS-a? Skini build 7105 ili kak već..
TV: LG 7450
GAMEPAD: XBOX One
Staro 10.04.2009., 22:39   #23
LuxZg
Postovi: 512
Ovak, za one na Win7, a možda je slično i na Visti 64bit
Ak vam instalacija prođe, a i dalje piše da su stari Catalyst-i u CCC, onda fino ovak:
- raspakirajte drivere u neki folder
- odite na device manager, kliknite na karticu, desni klik, update driver
- pokažite mu na folder sa raspakiranim driverima
- on izinstalira, restart (za svaki slučaj)
- trebalo bi sad pokazivat i radit ispravno..
Ima neki bug, više ljudi na techpowerup i guru3d je spominjalo da im u Win7 "preskoči" instalaciju. Kao prođe, ali prebrzo, i driver ostane stari.
Probajte, javite!
Staro 11.04.2009., 11:39   #24
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Autor LuxZg Pregled postova
Probajte, javite!
Ne nego na kraju instalacije se pokaže onaj žuti ili crveni uskličnik i klikneš na njega i pokaže ti tijek instalacije...
Uglavnom sve piše successful, ali kod display drivera piše error. Probao sam samo display drivere instalirat i nije htjelo.
TV: LG 7450
GAMEPAD: XBOX One
Staro 12.04.2009., 00:25   #25
Ziiky
Ziiky's Avatar
Postovi: 2,880
9.4 u Warhammeru DOW2 malo malo inicira VPU recovery a 9.3 u mjesec dana koliko igram niti jednom
MBO: MSI Mortal
RAM: Crucial DDR4 8gb
GPU: Gigabyte GF GTX 1050 ti
HDD: SSD 128gb + WD blue 1TB
RW: LG
MON: Acer 24"
CASE: Antec Fusion Remote Max
PS: Fortron 550w modular
NAS: Synology 210j WDred4TB
HEADPHONES:Bluedio t3 plus BT
TV: Philips 55pus7805
REC: DENON x1600H
SUB: SVS PB1000
Trenutno ništa ...
Moje njuškalo
Staro 12.04.2009., 15:17   #26
ivan_karlovac
ivan_karlovac's Avatar
Datum registracije: Aug 2008
Lokacija: karlovac
Postovi: 111
Ja bi zamolio netkoga tko ima Catalyst 9.3 drivere za windows 7 za ati 3870 da mi ih stavi na rapid jer ne mogu nikako dobiti Catalyst 9.4 da mi rade uopće ne mogu upaliti ccc niti u samom screen resolution dobiti extendet desktop iako mi pod vistim i xp radi ovdje odaberem extended stavim apply i vrati mi na show on 1. display. Evo link koji potvrđuje probleme sa friško instaliranim Catalyst 9.4 http://forums.amd.com/game/messagevi...&enterthread=y ja uopće ne mogu otvoriti ccc. Hvala unaprijed.
ivan_karlovac je offline   Reply With Quote
Staro 12.04.2009., 15:26   #27
Metamphetamine
Flaccitra
Lokacija: Vinkovci
Postovi: 276
Autor ivan_karlovac Pregled postova
izvolte
http://downloads.guru3d.com/Videocar...%7C64_c31.html
Staro 13.04.2009., 19:10   #28
ivan_karlovac
Lokacija: karlovac
Postovi: 111
Hvala na linku ali na žalost ništa mi nije pomo. Nikako nisam uspio da mi proradi extended desktop u windowsima 7, kako god narikram nema šanse da proradi uvjek vrati na "show on 1." pa sam na kraju odustao, deinstalirao windowse 7 i stavio si nanovo dual boot xp i vista oboje x64 i tu radi sve kao i inače, ne znam u čemu je stvar. Svejedno hvala.
Staro 13.04.2009., 20:39   #29
Jeote
Jeote's Avatar
Lokacija: 50km od Zg
Postovi: 87
Evo instalirao 9.4 na vistu x64 i neće otvorit CCC..
Jeote je offline   Reply With Quote
