Staro 22.02.2009., 00:19   #2071
Baja 001
Baja 001's Avatar
Postovi: 7,504
SP2 is an update to Windows Vista and Windows Server 2008 that addresses feedback from our customers and ongoing engineering process.
In addition to previously released updates, SP2 will contain changes focused on addressing specific reliability, performance, and compatibility issues, supporting new types of hardware, and adding support for several emerging standards. SP2 will also continue to make it easier for IT administrators to deploy and manage Windows Vista and Windows Server 2008.
Ima li itko potvrdu o ovom RC izdanju?
Staro 06.03.2009., 16:20   #2072
thopok
Lokacija: Splity
Postovi: 3,003
Download SP2 Release Candidate
Staro 19.03.2009., 01:54   #2073
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,695
ovako, imam particiju od 30gb samo za vistu, apdejte i drajvere. Nakon instalacije viste pogledam ja u my comp i vidim fino ima skoro 15gb slobodno nek tak i ostane (eventualno + 1gb radi itunesa). Ljepo ja instaliram win update i drivere, restartam komp, uđem u my com i kad ono slobodno 6gb?!?!? Kud pobogu je nestalo skoro 10gb slobodnog prostora????
Staro 19.03.2009., 03:02   #2074
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Autor Problem Pregled postova
Restore i to...
Staro 19.03.2009., 03:04   #2075
thopok
Lokacija: Splity
Postovi: 3,003
Staro 19.03.2009., 10:51   #2076
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,695
Autor IcyTexx Pregled postova
Restore i to...
tak sam si mislil, al mi je glupo da odmah u startu poždere 10giga. Kaj nebu to s vremenom jos vise?
Staro 19.03.2009., 11:25   #2077
žile
žile's Avatar
Postovi: 3,074
A brisat će ti starije pointove kako bi oslobodila mjesta za nove.
žile je offline   Reply With Quote
Staro 19.03.2009., 11:32   #2078
imaticx
Default
imaticx's Avatar
Lokacija: Požega
Postovi: 1,519
pa iskljuci taj restore. nabavi norton ghost ili acronis i snimi sam image backup
Staro 19.03.2009., 11:41   #2079
Hrvoje xyz
lepi
Postovi: 923
koristim vistu oko 2 mjeseca , za svakodnevni rad kao sto je surfanje , winamp i vlc media player duso dalo . sad ono kaj nisam nikak naso ej kak stavit da kad udjem u folder vidim koliko je "tezak" ? u xpu je bilo cim udjes u folder pise koliko su veliki fajlovi u tom folderu dole na onoj tracici s ljeve strane. ne ocekujem da mi sad izbaci i velicinu foldera unutar tog kojeg otvorim , al ono ..
isto tak kad udjem u recycle ne kaze kolko je tog u njemu ?
Hrvoje xyz je offline   Reply With Quote
Staro 19.03.2009., 11:50   #2080
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,695
Autor imatic Pregled postova
vec jesam
Staro 19.03.2009., 15:04   #2081
tocka
Postovi: 175
ovako slozio sam si backup cjelog kompa tj c particije na kojoj je vista.
Instalirao sam sve drivere i osnovinih 10tak programa kaj koristim cesto.
Backup mi je veliki ravno 20gb zanima me dali taj vistin backup and restore radi?
znaci za 6mjeseci kad mi se nesto gadno sjebe dali ce me 100% vratiti na jucerasnji dan?
glupo mi je stavljati northon ghost kad vec imam u windowsima program za backup.
tocka je offline   Reply With Quote
Staro 24.03.2009., 20:19   #2082
Metamphetamine
Flaccitra
Metamphetamine's Avatar
Lokacija: Vinkovci
Postovi: 276
Autor tocka Pregled postova
Ja radije napravim image sa norton ghostom, high compression i velik je nekih 6gb.
Vista SP2 RTM je dostupan.
Zadnje izmijenjeno od: LAcy. 24.03.2009. u 20:22. Razlog: Preglednost
Metamphetamine je offline   Reply With Quote
Staro 04.04.2009., 21:30   #2083
Buger
Postovi: 4,398
bio sam gotovo godinu dana na Visti i danas sam se vratio na XP, te moram konstatirati da, ma koliko god vi pljuvali po Visti ona je brža od XPa. Kroz period korištenja Viste nisam naišao na neke veće probleme, apsolutno je stabilna, zbog superfetcha je dosta brza, većina na forumu se zakačila na pretjerano korištenje RAMa, ali Vista je stvarno brža u "običnom" radu (surfanje, word i sl.), naravno ako se ima dovoljno RAMa, a 4GB danas nije luksuz...
Neki programi nisu dovoljno dobro radili po Vistom x64 (npr. Winfast Scheadule service se znao rušiti nakon stand bya), ali većina programa radi dobro, pogotovo ako vam ne trebaju neki stariji programi (a i to se može riješiti preko virtualizacije), onda je po meni Vista bolji OS...
Možda se u međuvremenu vratim na Vistu SP2, ali kada dođe win7, definitivno idem na njega.
Staro 05.04.2009., 00:26   #2084
Chome
TK
Chome's Avatar
Postovi: 1,092
Autor Buger Pregled postova
Možda je u običnom radu i brži osjećaj rada ali u igrama je u prosjeku XP brži tako da kad si u XP-u na granici fps-a za normalnu igrivost u Visti bi bilo prenisko.
Chome je offline   Reply With Quote
Staro 06.04.2009., 14:35   #2085
Moree
Postovi: 328
Daj mi recite jel koristite taj Superfetch? Ja sam ga iskljucio..
Moree je offline   Reply With Quote
Staro 06.04.2009., 19:28   #2086
tutix
tutix's Avatar
Postovi: 4,069
Zašto si se onda vratio na XP ?
Autor Moree
Nije mi jasno zašto ekipa gasi taj Superfetch. To je Vistin feature, a ne zločinac.
Staro 06.04.2009., 19:52   #2087
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Vistu nisam ni prokušao staviti do SP1.
Kada samo pokušao u paketu sa SP1, to je bilo to, nikada više, ali ama baš nikada više nebi ni prismrdio XPu
Ne da je Vista bolja, koliko god se pljuvalo po njoj, nego je 10x bolja od XPa
I ja osobno, uopče nisam primjetio razliku između XPa i Viste u igrama
blaa
Staro 06.04.2009., 20:07   #2088
pipe
Bill Gates
pipe's Avatar
Lokacija: Vukovar
Postovi: 1,983
Autor hammer_of_thor Pregled postova
Pa naravno da neces osjetiti razliku kad imas ovu pilu iz siga OMG
I ja imam na ploci.
Staro 06.04.2009., 20:35   #2089
hammer_of_thor
Postovi: 5,430
Autor pipe Pregled postova
Vistu sam koristio puuuuuuuuuuno prije pile iz siga.
(E2160, 2GB RAM, 8800GT )
blaa
Staro 07.04.2009., 00:43   #2090
dario_cile
Troll
dario_cile's Avatar
Lokacija: Doboj
Postovi: 282
evo ja sam sad isntalirao vistu mada nisam prije imao zivaca(koristim dual boot) ali iskreno jos mi se nekako neda preci na vistu jos se nekako ne snalazim na njoj verovtano trebam duze vremena provesti na njoj da bi se navikao i sve to ali opet moje misljenje da mi xp jos uvijek vise godi nego vista.....
Bolje džaba ležati nego džaba raditi
dario_cile je offline   Reply With Quote
Staro 07.04.2009., 02:37   #2091
Moree
Postovi: 328
Autor tutix Pregled postova
Pa i remote control i messenger je xp feature pa ga dosta njih gasi...kuzis sta ocu reci..Vidim da je jedan od onih "smart" featura, koji kao nadgleda sta ja radim najvise u visti i tako preraspodjeljuje resurse...na papiru super zvuci al ipak je to microsoft..
Staro 08.04.2009., 13:02   #2092
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
Instalirao sam Vistu ultimat x64 ali iam problem sa podešavanjem glede igranja CoD 2 preko xfire-a koji sam uspjeo naštelovati i prepoznaje sve kao i servere na kojima igram ali izbacuje neke poruke da nije nešto s nečim kompaktibilno i nemogu igrati Drajveri su najnoviji probao staviti starije ali isto se dešava, jedino neznam ima li kakva opcija i gdje da stavim kompaktibiliti mod kao da radi pod XP-om ukoliko je možda tu problem i kako i gdje u Visti to podesiti jer sam bio na XP-u pa nemogu nači.Punkbuster uključen i A i B ali nešto nevalja i neradi???
http://www.imagesforme.com/show.php/...lemsaCoDom.jpg
Ukoliko netko zna u čemu je problem molio bi pomoć šta i kako
Staro 08.04.2009., 15:41   #2093
imaticx
Default
imaticx's Avatar
Lokacija: Požega
Postovi: 1,519
da li je i vama kopiranje na USB stick dosta sporije nego na xp-u? Iskljucio sam nod, ali isto. u settings je namjesteno "optimise for quick removal" (tako je i u xp-u), stick je corsair voyager 8 GB
Staro 08.04.2009., 15:45   #2094
Metamphetamine
Flaccitra
Lokacija: Vinkovci
Postovi: 276
Meni je brže na Visti nego na XP-u, i kopiranje sa stika i na stik. (Supertalent 16gb)
Što se tiče priča da je na xp-u fps u igrama veći to nije točno, čak je vista sa sp2 u prednosti što se tiče kritičnog min. fps-a u Crysisu.
Zadnje izmijenjeno od: Metamphetamine. 08.04.2009. u 15:50. Razlog: Zaboravnost
Staro 10.04.2009., 11:04   #2095
Buger
Postovi: 4,398
bezveze, nešto mi se vista zblesirala, bio je potreban reinstall i ponesen svim silnim pričama o uber brzom XPu i smeću Visti, vratim se ja na XP i isti dan skontam koliko je Vista ustvari bolja. Većina se ovdje zakačila za veliko zauzeće RAMa kod Viste, ali manje više svi ovdje imaju 4GB RAMa, pa to i ne predstavlja neki problem, a uostalom ako koristite x64 Vistu kao što sam ja koristio, fino iskoristite svih 4GB RAMa, a ne kao što sad ja imam XP i mogućnost korištenja 3GB RAMa, dakle i uz veću "potrošnju" RAMa, Vista x64 je u prednosti nad XPom...
Staro 10.04.2009., 14:25   #2096
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,949
bezveze, nešto mi se vista zblesirala, bio je potreban reinstall i ponesen svim silnim pričama o uber brzom XPu i smeću Visti, vratim se ja na XP i isti dan skontam koliko je Vista ustvari bolja.....
Nije ti palo na pamet da se radi o pukoj ljudskoj "navici"
Kao šta ljudi kad pređu na Vistu nakon 5 godina XPa zaključe da je Xp masu bolji, tako i ti nakon nekoliko mjeseci Viste vraćanjem na XP zaključuješ da je XP lošiji.
A istina je negdje u sredini Ja na Visti nisam baš iz navike prema XP, a i radi toga šta sam je proba relativno (pre)rano pa je podešavanje svega, traženje drivera i sve ostalo bilo mukotrpno... Jer ruku na srce, em sam ja uranio, em sam imao 1 GB rama, em je Vista u startu bila poluproizvod (kao i XP u svoje vrijeme da se razumimo) Vistu preskačem definitivno, čeka se sedmica
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Staro 10.04.2009., 16:51   #2097
žile
žile's Avatar
Postovi: 3,074
A misliš da tada neće biti antagonizma prema Windows Se7en i njegovim korisnicima,kao što ga nema ni danas prema nekom tko ima bolji komp od nekog,tko ima bolji miš i tastaturu,tko ima bolji auto,čiji tata glasuje za 4D7 itd itd?
Tako da i M$ je službeno XP poslao u pemziju,a za godinu dana će nekim čudom vista biti najbolji i najstabilniji sustav koji je ikada izašao.
Staro 10.04.2009., 17:19   #2098
Chome
TK
Chome's Avatar
Postovi: 1,092
Autor žile Pregled postova
Neće jer je Win7 "popravljena" Vista.
Staro 10.04.2009., 18:35   #2099
žile
žile's Avatar
Postovi: 3,074
Autor Chome Pregled postova
Je,je.Neki dan se seruckalo nešto o nekom mentalitetu na jednoj dretvi.
Tako sad kad izleti SP2 za vistu,a za godinu dana ne boj se što se neće druga ploča vrtit kod dežurnih dušebrižnika,gdje je vista najbolji sustav ikad,a samo vandali mogu biti na novom i "ne provjerenom" Windows Se7en.
Obaška to što je vista već ispeglana preko godine dana,a usput nonstop sebe sama nešto krpa i drkenja,ništa to ne važi.Važi samo kako je nakon,vidi čuda,više vremena koliko je proteklo da XP postane dobar sistem (2001.-2004.),on sustav koji koriste Über mensch,a vista je,pazi sad ovo,ipak bolja pri nagloj promjeni na arhaični XP,pogotovo otkad 4GB rama ima svaka šuša.
Sve se to nakon godine dana zaboravlja obzirom da je demencija najpopularnija bolest koja se javlja kod svakog odmah na dan 18. rođendana kada se pokraj prava na polaganje vozačkog,što je svakom normalnom najbitnija stvar u životu sa 18 godina,dobiva i obveza ispunjenja građanske dužnosti kada za to dođe vrijeme.Tako da,u svim aspektima života se u RH odvija jedna te ista epizoda,tako da ja zbilja ne bih znao šta se to promjenilo da se ne može zapazit šablona po kojoj živimo i funkcioniramo.Kada izađe Se7en,svi će sve znat,i svi će ić uzbrdo u petoj,i uz fanfare će se tema u kojoj sad piskarate o betama postat poligon za metloboj.
Dobro,dosta sam zagnojio,doći će zločasti admin i reć kako sam nepodoban
Staro 11.04.2009., 10:19   #2100
Buger
Postovi: 4,398
najveća glupost koju sam primjetio u Visti je ono silovanje C particije (punjenje do kraja) što nadam se nema u win 7...
