Staro 02.02.2009., 18:56   #1
daba22
Lokacija: Velika Gorica
Postovi: 8
Sonic tower na Q6600
imam cpu: q6600, mbo :dg31pr , 2gb Ram, VGA: 2600XT
Donedavno sam imao stock cooler i temperatura cpu-a mi je bila na cirka 40 stupnjeva , a nakon što sam stavio sonic tower su mi temperatura cpu-a i jezgri oko 55-60. jel možda rijeć o greški u postavljanju?
Neki savjet? ili barem link na neku već sličnu temu. Puno hvala
daba22 je offline   Reply With Quote
Staro 02.02.2009., 19:15   #2
Majo
Lokacija: Zagreb,Dubrava
Postovi: 2,281
Kaj se cudis kad je sonic tower pasivan
Majo je offline   Reply With Quote
Staro 02.02.2009., 19:19   #3
rodney
only fool, not a horse
rodney's Avatar
Datum registracije: Apr 2008
Lokacija: near zgb
Postovi: 1,280
mozda nije dobro lego.... jesi probao ga ponovo stavit? pasta?
jel ima kakvo puhalo ili pasiva?
edit: nevidjeh post prije mog....
rodney je offline   Reply With Quote
Staro 02.02.2009., 19:24   #4
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
Obavezno na sonica stavljati ventilator kada su u pitanju 4jezgreni procovi...
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 02.02.2009., 19:34   #5
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
40C sa box coolerom a 60C sa Sonicom?
OK, ocito mislis na idle temperature, sto nije mjerodavno, ali svejedno se da zakljuciti da je vent na tom Sonicu nuzan.
Staro 02.02.2009., 19:45   #6
Lud76
Leteći medvjedić
Lud76's Avatar
Postovi: 1,204
Pasivni Sonic ne može dobro hladiti, vent je obavezan tako da su te temp. 55-60 normalne ako nemaš vent na njemu naravno
Lud76 je offline   Reply With Quote
Staro 02.02.2009., 20:43   #7
daba22
Postovi: 8
Puno hvala momci...sutra u kupovinu znaći
ajd kad sam već tu i prije nego kaj se tema zaključa, jel ima ko isproban prijedlog ventilatora za sonic-a?
Staro 02.02.2009., 20:44   #8
spawn
spawn's Avatar
Postovi: 8,359
ne znam za quad-a ali meni e6320 drzi na 40 stupnjeva bez venta. Kad se malo vise radim ide na 45 a kad igram po 2-3 sata max 55. pasivan. Sta se toliko vise grije quad?
Autor daba22
ako te zanima tisina uzmi scythe slipstream bilo koju seriju osim 1900 . ona od 1200 hladi i previse a tiha je.
Staro 02.02.2009., 20:49   #9
daba22
Postovi: 8
pa i nije mi toliko tišina u prvom planu koliko temp. još budem provjerio jesam sve dobro montirao ali svejedno sutra idem po vent...fala bruno
Staro 02.02.2009., 20:53   #10
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
Kupi i pastu tipa AC Ceramique ili sličnu, očisti bazu i ponovo stavi, teško da je baš toliko visoka temp makar i je 65nm jer Sonic definitivno nije loš cooler
blaa
Staro 02.02.2009., 21:09   #11
spawn
spawn's Avatar
Postovi: 8,359
pasta AC arctic silver . Najbolja pasta .
Staro 02.02.2009., 21:22   #12
Hei$$e
Hei$$e's Avatar
Lokacija: Našice
Postovi: 444
Pa nije najbolja ali je među boljima. No Ceramique je daleko više user-friendly a performanse su tu negdje stoga bi ja osobno nju uzeo.
Hei$$e je offline   Reply With Quote
Staro 02.02.2009., 23:53   #13
spawn
spawn's Avatar
Postovi: 8,359
Autor Hei$$e Pregled postova
Sta to znaci? Sama se stavlja na proc?
Staro 02.02.2009., 23:58   #14
rodney
rodney's Avatar
Lokacija: near zgb
Postovi: 1,280
ne provodi struju
Staro 03.02.2009., 00:07   #15
Lud76
Leteći medvjedić
Lud76's Avatar
Postovi: 1,204
Autor daba22 Pregled postova
Možeš ovaj koji imam ja, spušta temp za 20 stupnjeva u idle na 5V, košta 30-40kn u Vemilu (Chieftec inače), i kak ostali kažu uzmi odmah i neku pastu pa promjeni usput
Staro 03.02.2009., 00:15   #16
daba22
Postovi: 8
pa baš gledam sad malo po netu i mislim da budem u vemil...makar mi je hg šrot puno bliže...možda se tam prije zaletim. ali definitivno uzimam paste i ventilator do 50-tak kuna...niš fancy
samo kaj ću izgleda morat radit nosać za ventilator jer nemam mjesta gdje inaće dolaze. ali to je već za "do it yourself" rubriku hehe
Staro 03.02.2009., 00:20   #17
Hei$$e
Hei$$e's Avatar
Lokacija: Našice
Postovi: 444
Jeftinija je (iako manje pakiranje), nije vodljiva, lakše se razmazuje a performanse su uz bok sa AS5.
Staro 03.02.2009., 01:27   #18
Rino
[ZA DOM]Rino
Rino's Avatar
Lokacija: Kutina
Postovi: 762
Nemas mjesta između tornjeva? Sto god pisalo na uputama tamo stavi vent...ako ga ne mozes montirati pomocu nosaca mozes ga ucvrstiti obicnim plasticnim vezicama i sl.
Rino je offline   Reply With Quote
Staro 03.02.2009., 02:29   #19
spawn
spawn's Avatar
Postovi: 8,359
Autor rodney Pregled postova
ne provodi struju
ne kuzim kako vi stavljate paste. Pa neces valjda na plocu stavit,stavis na HS od procesora,kakva struja?
Staro 03.02.2009., 02:37   #20
domis
Lokacija: Hrvatistan
Postovi: 4,164
@bruno...to se ovi koji si nemogu silver5 priustit tjese sa svojom user frendli pastom
uglavnom...
obje paste su odlicne...nijedna NE provodi struju...ako me sad mislite loviti za rijec zbog dvostruke negacije...onda da preformuliram...obje ne provode struju, zapravo, elektricnu energiju
a vi koji tvrdite dasilver5 provodi struju...molim multimetar u ruke, 12v (max u kompu) i javite dal provodi
takoder probajte s malo jacom amperazom, makar sumnjam da to ima ikakve veze
Staro 03.02.2009., 10:49   #21
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Blah pasta sim pasta tam...
Ovo je moj komp (ovi ventovi su na CASEu a ne na sonicu) a pasta je ona bjela gadarija koja dolazi u tubicama sa zalman coolerima...
Ipak za quad nisam siguran da bi išlo bez venta iako s druge strane noviji quadovi imaju manje mikrona, manji napon i time bi trebali i manje trošit od mojeg po jezgri tako da bi zapravo trebalo biti tu negdje...
Have a nice day...
Staro 03.02.2009., 11:01   #22
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
meni je sonic drzao proc na 60tak stupnjeva u full loadu, def pastu bolju uzmi, i ako ti se da ispoliraj malo bazu hladnjaka, trebalo bi mrvicu pomoci. Sto se tice montiranja venta između tornjeva i sa strane osobno nisam primjetio nikakvu razliku, na kraju je radilo tako da je jedan vent puhao kroz cijeli hladnjak a s druge strane je bio vent na zadnjoj strani kucista koji je sve to izvlacio. S gornje strane ti malo i napajanje pomogne
Staro 03.02.2009., 12:09   #23
Hei$$e
Hei$$e's Avatar
Lokacija: Našice
Postovi: 444
Autor d'beast Pregled postova
uglavnom...
Ne provodi ona struju kao bakar. Nije to problem. Nego srebro u njoj može izazvati kratki spoj. Bilo kako bilo, koju god uzme neće pogriješiti, iako AS5 baš i nije za početnike (neznam kakvog on iskustva ima)
Staro 03.02.2009., 16:12   #24
domis
Postovi: 4,164
ma, prva pasta koju sam stavljal je bila silver5 na frendovog bartona
malo sam se zajebo i prevec stavil pa obrisal...uglavnom, taj barton radi jos i danas
Staro 03.02.2009., 17:29   #25
Lud76
Leteći medvjedić
Lud76's Avatar
Postovi: 1,204
Ak češ u HG onda uzmi Zalman F3, imam i njega doma isto jako dobar vent
Staro 03.02.2009., 19:41   #26
domis
Postovi: 4,164
radije chief u vemilu...
zalmana sam imal i lezajevi se cuju nakon mjesec ili 2...
chief imam vec 5 mjeseci i ni glasa lezajevima
Staro 07.04.2009., 10:07   #27
vladosch
vladosch's Avatar
Lokacija: Garešnica
Postovi: 100
Vidim da raspravljate o Sonic Toweru Rev.2. Imao sam taj hladnjak + Thermaltake Silent Wheel A2330 130mm Case Fan koji mu original paše i postavio sam ga da puše direktno van iz kučišta. Bezčujan je i na Intel E8400 na 3.6 GHz držao je idle 29-30 C, a load 47-48 C na sobnoj temperaturi oko 20 C, dok mi je quad Q6600 na 3.6 držao na oko 56-57 C pod load usred ljeta. Puno sam tražio po reviwima i mislim da je to jedan od najboljih hladnjaka ne računajući vodeno hlađenje.
vladosch je offline   Reply With Quote
Staro 07.04.2009., 10:35   #28
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
indeed it is, my young padawan
