#1921 |
Chipokemon
Postovi: 339
Piracy helps stop global warming.Insted of driving to get CDs, buying pre-packaged software from megacorporations and wasting energy,you can help fight Global Warming by using P2P.Help save resources,fight pollution and save the enviroment. -It`s what Jesus would do. |
#1922 |
1oo1 NooB
Postovi: 1,306
IT IS EASY TO KILL FIVE HUNDRED NOOBS. BUT THERE IS STILL FIVE HUNDRED AND ONE AND YOU ARE OUT OF AMMO! 1oo1 NOOB - POWER IN NUMBERS! Good judgment comes from bad experience and a lot of that comes from bad judgment. |
#1923 |
Chipokemon
Postovi: 339
#1924 | |
Honda Prelude 2.0i driver
Lokacija: Zagreb Dubrava
Postovi: 1,128
#1925 |
Uptime 99.99%
Postovi: 2,792
Mogu se bondati dvije parice i dobijes oko 40mbita na dobroj parici. To su u Engleskoj poceli nuditi.
#1926 |
Sruk
Datum registracije: Sep 2004
Postovi: 1,163
#1927 | |
Uptime 99.99%
Postovi: 2,792
http://www.trustedreviews.com/networ...Mbit-Speeds/p1 Jos jedan interesantan proizvod http://www.trustedreviews.com/networ...Speed-Boost/p1
#1928 | |
Postovi: 1,128
pola ljudi je na pcm i pgs uređajima a ti bi sad dvije čiste parice... sebičnjak jedan ![]()
#1929 |
lar~
Postovi: 1,558
To samo ovisi o lokalnim kapacitetima. Ima puno lokacija gdje se bez problema dobivalo nove parice... |
#1932 |
Lokacija: VG
Postovi: 67
Moj profil
Zivim u zgradi i do prije nekih mjesec dana nisam imao pucanje DSL veze. Amis koristim vec 14 mjeseci. Promjenio sam kabel do uticnice, uticnicu, router, zenu, kucu, stan.. ... ali DSL link mi i dalje puca. Ovi u Amisu su vec ludi kad ih nazovem. Vidi sta kaze statistika. Hvala.Uptime: 0 days, 1:50:06 Modulation: G.992.5 Annex B Bandwidth (Up/Down) [kbps/kbps]: 925 / 4.917 Data Transferred (Sent/Received) [MB/MB]: 21,75 / 65,99 Output Power (Up/Down) [dBm]: 12,5 / 5,5 Line Attenuation (Up/Down) [dB]: 6,0 / 5,5 SN Margin (Up/Down) [dB]: 24,5 / 22,5 Vendor ID (Local/Remote): TMMB / BDCM Loss of Framing (Local/Remote): 0 / 0 Loss of Signal (Local/Remote): 60 / 0 Loss of Power (Local/Remote): 0 / 0 Loss of Link (Remote): 0 Error Seconds (Local/Remote): 275 / 0 FEC Errors (Up/Down): 47.873 / 569 CRC Errors (Up/Down): 8.063 / 0 HEC Errors (Up/Down): 95.095 / 0 Eh da.. i ping su mi digli u nebesa pokušavajući pokrpati pucanja... Zadnje izmijenjeno od: gustetic. 29.09.2008. u 17:37. |
#1933 |
Postovi: 778
#1934 | |
Postovi: 1,128
#1935 |
Uptime 99.99%
Postovi: 2,792
Jedna zanimljivost interface za mjerenje prebacenih podataka ne broji podatke prebacene unutar CIX-a.
#1936 |
Lokacija: VG
Postovi: 67
Amis update
Update. Doso' tehnik iz Amisa, iscupao fakin' uticnicu, odrezao konektor na kablu, zabindao zajedno kabel i instalaciju, izolirkom zamotao, vratio steker i to je to. Kaze 30 god. stara zgrada isto tako i instalacija, trebalo bi mijenjat, dok drzi vako.. voziiii Uptime: 2 days, 22:01:17 Modulation: G.992.1 Annex B Bandwidth (Up/Down) [kbps/kbps]: 899 / 4.880 Data Transferred (Sent/Received) [MB/GB]: 226,19 / 1,70 Output Power (Up/Down) [dBm]: 13,0 / 11,0 Line Attenuation (Up/Down) [dB]: 6,0 / 7,0 SN Margin (Up/Down) [dB]: 24,0 / 22,5 Vendor ID (Local/Remote): TMMB / BDCM Loss of Framing (Local/Remote): 0 / 0 Loss of Signal (Local/Remote): 5 / 0 Loss of Power (Local/Remote): 0 / 0 Loss of Link (Remote): 0 Error Seconds (Local/Remote): 6 / 0 FEC Errors (Up/Down): 0 / 0 CRC Errors (Up/Down): 0 / 0 HEC Errors (Up/Down): 0 / 0 |
#1937 |
Postovi: 1,128
ček ak sam dobro shvatio---on je žicu iz utičnice spojio direktno na telefonski kabel ?
#1939 | ||
Killer of your Dreams
Lokacija: Final Digit of the Rainbow
Postovi: 107
mozda bi ti jos jedino pomogao adsl2+ (G.992.5 annB) mjesto adsla (G.992.1 annB), al onda bi imao losiji ping. Citiraj:
2.bitdefender, nemam komentara, idi googlaj malo da vidis sta bitdefender prepoznaje, a nod ne preporuka je kaspersky najbolje, onda tek BD, a nod - nikako xD 3.servisi - ko govori o velicini servisa, lol 4.lijepo sto znas sve to, al trebas onda znat da na navedeno ne mozes utjecat, ja govorim kako bar malo sredit situaciju ako ti je parica bullshit kvaliteta alcatelovih dslamova kod amisa je u praksi bolja nego siemensa i sony ericssona kod t-coma u svakom slucaju, ne mozes promjenit broj spojenih korisnika na dslamu ni njegove karakteristike, mozes samo skratit svoj kabel ![]() 5.ti si user, nista vise, pomiri se s time i topla preporuka - ne prigovaraj strucnjacima ![]() 6.moje posao si totalno fulao, telekomunikacije su i moje zanimanje i moj posao sjeti se toga kad zoves korisnicku npr., hoces li dobit nekog nooba koji ce ti rec da ako mozes surfat, sta se onda zalis, ili nekog poput mene koji ce ti pokusat pomoc ![]() da, dobro si shvatio, trebo bi znat da u je takvim situacijama bolje spojit nazivo zice, nego koristit zahrdjale kontakte xD Zadnje izmijenjeno od: Rebellion. 11.10.2008. u 17:51. |
#1940 |
Postovi: 1,128
hahahaha daj oladi ...bok...
#1941 |
Postovi: 118
e, meni za mjesec dana ističe ugovor s t-scumom. i ni jedan mi operater nije dostupan, znači njegova infrastruktura, ne prek t-coma neke gluposti, a na trešnjevci sam, j....ni centar zagreba. dal ono online pokazivanje dostupnosti fakat šljaka il se to mora naručit baš od njih?? |
#1942 |
Postovi: 127
da,da, ak si ukucao br. tel. i piše čestitamo onda onda si ti moguči potencijalni korisnok amisa. Čestitam. Ja sam isto s trešnjevke i sve to relativno dobro funkcionira osim ako si spojen na neku staru tel. centralu kao ja pa su me spajali 2 mj. jerbo su parice bile sje.... navodno. |
#1943 |
Postovi: 118
stvar je u tome da mi ne piše čestitam, nego nismo u mogućnosti bla bla bla... grrrrrr, znači dok se ne prošire ništa od amisa. ne kužim kako ima tamo negdje u pripizdini a ja nemam tu mogućnost.inače sam kod treš. placa blizu, i di se nalazi tu centrala?? Tako je bilo i sa t-comom kad sam uzimao... susjed ima maxadsl, ja ukucam svoj broj ono pokazuje da nisu u mogućnosti i onda za mjesec-dva su bili dostupni i ja naručim...nažalost. |
#1944 | |
Uptime 99.99%
Postovi: 2,792
#1945 |
Postovi: 6
Pozdrav, Kao prvo puno vam hvala za ovaj topic za za dosta podataka korisnih koje sam pokupio. Imam Amis, Zagreb, Črnomerec, 4 MB/768 KB/s. Uređaj je Thompson Speedtouch wireless 780 mislim. Uptime: 8 days, 22:49:18 Modulation: G.992.1 Annex B Bandwidth (Up/Down) [kbps/kbps]: 899 / 4.880 Data Transferred (Sent/Received) [GB/GB]: 2,16 / 30,47 Output Power (Up/Down) [dBm]: 12,5 / 19,0 Line Attenuation (Up/Down) [dB]: 22,5 / 33,0 SN Margin (Up/Down) [dB]: 17,0 / 17,5 Vendor ID (Local/Remote): TMMB / BDCM Loss of Framing (Local/Remote): 0 / 0 Loss of Signal (Local/Remote): 0 / 0 Loss of Power (Local/Remote): 0 / 0 Loss of Link (Remote): 0 Error Seconds (Local/Remote): 3.171 / 0 FEC Errors (Up/Down): 0 / 0 CRC Errors (Up/Down): 0 / 3.396 HEC Errors (Up/Down): 0 / 1.362 Koliko sam ja uspio razaznati iz svega ovoga ovo što ja imam je čisto ok što se kvalitete linije tiče itd i moglo bi biti puno gore. Inače živim u staroj zgradi iz 65' pa brijem da je ovo super. Inače surfanje, download je sve ok. Dosta igram Q2 i ping je stvarno super (40 na ovom serveru dolje) i netgraph linija je uvijek ravna što se ping-a tiče. Igram na Njemačkim serverima, 10 skokova uglavnom: zagreb5-ge-0-1.amis.net [194.146.109.23] zagreb2-ge-0-0-0-1.amis.net [194.146.109.1] maribor3-ge-2-14.amis.net [212.18.41.165] vienna1-po-1.amis.net [212.18.41.138] [193.203.0.146] ge1-1-637.cr3.FRA3.content-core.net [212.123.123.217] Tenge1-1-57.cr2.NBG1.content-core.net [212.123.123.194] p2-92.rtr2.colo1.NBG1.content-colo.net [212.123.123.243] madherosquad.de [62.146.6.232] Prije Amisa sam imao HT i tamo je sve bilo super i ping i PL. Nažalost imam velikih problema sa Packet Loss-om. Packet lossa imam recimo svakih 3-5 sekundi, neki put 3 u 1 sekundi, rijetko da ga nema barem 10 sec. Radio sam traceroute sa pingploterima i ostalima i koliko vidim dosta toga puca na skoku kod Maribora i tamo ima dosta PL-a, opet sa OUTRACE alatom PLa nema i stvarno nisam pametan gdje da uperim prst. Ne bih se htio pomiriti da je problem u MAriboru i odustati od svoje potjere za vezom bez PLa pa bih htio sve ostalo maksimizirati koliko mogu. 1) Podesio sam svoj MTU na kompu na 1500, išao sam na http://www.speedguide.net:8080/ i napravio test i javio je da je MTU 1452. Mene zanima da li je i vama MTU 1452 ili je netko krivo zaštrikao na routeru nešto pa je umijesto 1492 koji je optimalan za pppoe (HTNET) Amis na 1452 i to je tako. Da li je Amis na 1452? - inače podesio sam sve kako je predloženo, MSS, MTU na 1452, RWIN itd. i dalje je packet loss ogroman. 2) Da li ostatak ekipe koja igra igre ovdje ima PLa dosta ili ga nema uopće/ima jako malo. 3) Da li ima kakvih prijedloga šta ciljano da radim. Mislim nazvati support ali rekoh prvo da ovdje još pokupim municije ako mogu. hvala i pozdrav! edit: Mmmmda , ujutro 7 sati, nema PLa, u 11h ima ga jako malo, u 20h puno... Vidim da pucaju dota amis.at i amis.slo. Imam osjećaj da se mogu slikati.... Zadnje izmijenjeno od: Hisoka. 20.10.2008. u 09:06. |
#1946 |
Lokacija: Zagreb, Dubrava
Postovi: 502
rebellion kad si već stručnjak daj mi reci sto bi mi moglo utjecat na velik ping u igrama. na speedtestu je 35 a kad se spojim na neki server koji je van hrvatske prelazi 100. a na hr serveru je 60-80. sve sam pokuso. makno firewall, forwardiro portove, sve zivo i jos uvijek je isto. ne znam sta da vise radim. ![]() ![]() ![]() |
#1947 | |
Uptime 99.99%
Postovi: 2,792
Da li tko ima problema sa packet lossom prema Americi? Ovo je prema pcekspertu 28 packets transmitted, 8 received, 71% packet loss, time 27008ms rtt min/avg/max/mdev = 155.706/159.903/167.150/5.006 ms Amerika do Amisa: 20 packets transmitted, 6 received, 70% packet loss, time 19126ms rtt min/avg/max/mdev = 150.344/155.339/160.997/4.171 ms, pipe 2 Zanemarite ovo, to je planetov problem sa routingom, nabijem ih nesposobne.
“Those who surrender freedom for security will not have, nor do they deserve, either one.” Zadnje izmijenjeno od: Bono. 23.10.2008. u 03:42. |
#1948 |
Postovi: 502
sta ne bi u hr ping trebao bit manji od 80?? i tko god da ima amis i igra cod2 nema tih problema. baš sam proklet!! a tek kad sam spojio amis bio mi je ping savršen. jedva 60 na serverima van hr a u hr 20!!! ![]() |
#1949 | |
Uptime 99.99%
Postovi: 2,792
Ping u HR ako se radi o CIX clanici je ispod 10ms. A ako govoris o T-com serveru onda je ping 20ms. Koliko vidim parica ti nije bas najbolja kada ne mozes ni cistih 4mbita povuci.
#1950 |
Postovi: 2,724
sta napraviti da ti promijene paricu? Ja isto ne mogu primit više od 4Mbits a da ping ne poludi. Na modulaciji za ADSL1 mogu primit 5Mbits, max, a na ADSL2+ primim i 8Mbits, ali ping 100ms prema Austriji, Njemačka, itd......
MMA |
