Staro 12.05.2008., 03:56   #1
Razer
Razer's Avatar
Postovi: 11,642
Abit IX38 QuadGT, Review by Razer
Abit IX38 QuadGT Review by Razer
Datum objave: 12.05.2008
UVOD
Abit je još od davnih dana bio poznat u krugovima entuzijasta, te unatoč nekim krivim potezima prije godinu dvije, i danas je natrag na nogama.
Sa zadnje dvije serije ploča se polako ali sigurno vraća na stare staze. Radi se o pločama temeljenim na P35 čipsetu (IP35 serija), te X38 čipsetu (IX38 serija).
Osim ove koju ću danas spominjati, Abit IX38 QuadGT, na tržištu se nalazi i jača verzija ploče sa DDR3 memorijom, sa sufiksom MAX.
Glavna joj je konkurencija Asusova P5E/Maximus Formula te Gigabyteova X38-DS5/DQ6.
SPECIFIKACIJE
Code:
  • CPU - Supports Intel® Core™ 2 Duo / Quad processors with 1600/1333/1066/800MHz FSB Supports Intel® Core™ 2 Extreme/Quad/Duo & Pentium® Extreme Edition, Pentium® D, Pentium® 4 Processors, Pentium® Dual Core
  • Digital PWM Designation - provide high quality and efficient power
  • Chipset - Intel® X38 Express / ICH9R Chipset
  • Memory - 4 X 240-pin DIMM sockets support max. memory capacity 8GB Supports Dual channel DDR2 1066/800/667 Un-buffered Non-ECC memory
  • LAN - On board PCI Gigabit LAN controller supports 10/100/1000M Ethernet
  • Audio - On board 7.1 CH HD Audio CODEC Supports auto jack sensing and optical S/PDIF In/Out HDMI audio ready header (S/P DIF header)
  • Expansion Slots - 2 x PCI-E X16 (support PCI Express 2.0), 1 x PCI-E X16 (x4 bandwidth), 1 x PCI-E X1, 2 x PCI
  • Internal I/O - 1 x Floppy Port supports up to 2.88 MB 1 x ATA 133/100/66 IDE connector 6 x SATA 3Gb/s connectors 1 x IEEE1394, 4 x USB header (support 8 ports) 1 x FP-Audio
  • Back Panel I/O - 1 x PS/2 Keyboard, 1 x PS/2 Mouse abit Silent OTES™ 1 x S/P DIF In, 1 x S/P DIF Out 2 x eSATA 7.1 CH Audio connector (Front, Line-in, MIC-in, Center/Subwoofer, Surround, Rear Surround) 1 x 1394, 4 x USB 2.0, 1 x RJ-45 LAN connector, Clear CMOS Button
  • Serial ATA - 6 x SATA 3Gb/s offer by Intel® ICH9R support Intel® Matrix Storage Tech(AHCI & RAID0/1/5/10) 2 x eSATA 3Gb/s through JMicron® JMB363 support 0,1JBOD RAID
  • IEEE 1394 - Supports 2 Ports IEEE 1394 at 400Mb/s transfer rate.
  • Form Factor - ATX form factor 305 x 245mm
  • PCB Color: Blue
  • RoHS 100% lead-free process and RoHS compliant
  • abit Engineered: abit µGuru™ Technology abit Silent OTES™ Technology 100% Low ESR and high ripple conductive polymer aluminum solid state capacitors New Generation digital PWM EZ for CCMOS On board LED Lighting Quick Power On/Off & Reset buttons Right angle SATA connectors
PAKIRANJE I BUNDLE
Lijepo dizajnirana kutija, no relativno siromašan bundle. Siromašan po tome jer nema niti jedan PCI bracket s dodatnim USB/Firewire konektorima.
Također, dolazi sa samo 4 SATA kabla, iako ploča dolazi sa 6+2 SATA utora. Netko bi mogao i zamjeriti to što ploča dolazi bez ikakvo popratnog softvera (u vidu AV programa i sl.).
Dakle, da nabrojim kompletnu opremu što dolazi s pločom:
  • Priručnik
  • IDE kabel
  • FDD kabel
  • 4 SATA kabla
  • Limić za I/O panel
  • Vodič za brzu instalaciju
  • CD s driverima i uGuruom
Zadnje izmijenjeno od: Razer. 12.05.2008. u 05:28.
Staro 12.05.2008., 03:58   #2
Razer
Razer's Avatar
Postovi: 11,642
PLOČA
LAYOUT
Već na prvi pogled vidimo da ploča ima odličan layout, no da ne pričamo u prazno, napisat ću ponešto o svakom dijelu ploče po tom pitanju.
PROSTOR SOCKETA
Kako sa slika vidimo, prostor oko socketa je iznimno pristupačan, to čist po pitanju elektroničkih komponenti.
Dakle, bilo htjeli montirati neki veliki zračni hladnjak, ili pak, htjeli uglaviti nekakav POT, neće biti problema.
DONJI LIJEVI/DESNI DIO, ČIPOVLJE
S desne strane uočavamo sljedeće: uGuru čip, koji je zadužen za dijagnostiku i nadzor čitave ploče. Zatim imamo dijagnostički POST display (ovdje možete vidjeti popis kodova i što koji označava). Odmah pored njega imamo socketani BIOS. Dakle, BIOS čip koji se može mijenjati/vaditi, dobar potez od strane Abita po tom pitanju, jer znamo koliko ploča završi na reklamaciji u slučaju neuspjelog flashanja BIOS-a. Ovako je stvar puno jednostavnija za popraviti. Na samom uglu ploče nalazimo dva iznimno korisna gumbića, koji služe za paljenje i resetiranja računala. Iznimno korisno u slučaju da npr. testirate s pločom van kućišta. Pored njih imamo i jumper za Clear CMOS-a, iako je gumb za to postavljen na I/O panel ploče. S lijeve strane, imamo Realtekov ALC888 zvučni čip, iza njega slijedi Texas Instrumentov IEEE1394a Firewire kontroler, te još jedan Realtekov RTL811SOC gigabitni kontroler. O priključcima dolje u tekstu.
HLAĐENJE
Abit se odlučio na pasivno rješenje iliti Silent OTES. Dakle, masivno hlađenje za topli X38 se sastoji od par dijelova. Ugrubo, prvi dio povezan heatpipeovima – obuhvaća heatsinkove na NB-u i SB-u, koji su povezani sa još jednim blokom koji je smješten pored prvog DIMM utora. Dotični služi kao dodatna disicpacijska površina, dakle, ne nasjeda na samu ploču.
Možda i nije najbolje rješenje što je postavljen odmah pored memorije, no dotični se ne zagrijava toliko da bi pravio neke probleme. Nadalje, drugi ''dio'' se sastoji od bakrenog bloka koji služi za hlađenje digitalne regulacije napona, o kojoj će biti više riječi tokom teksta. Na NB bloku se nalaze mjesta za montažu 40mm ventilatora, također i na bloku digitalne regulacije. Nažalost s pločom ne dolaze niti kopče, niti vijci za monitiranje ventilatora. Plus je taj što sam se, na kolegin prijedlog, javio Abitu preko mail, te u roku od tjedan dana dobio tražene kopče. Preporuka je korištenje tanjih ventova (10mm) i onih koji se spajaju putem 3-pinskog konektora, iz razloga kako bi dobili mogućnost regulacije vrtnje preko uGuru softvera, o tome također malo kasnije.
PRIKLJUČCI/UTORI
Eksterni -> Interni
Eksterni priključci (I/O Panel):
Redom, s lijeva na desno:
  • PS/2 konektori za tipkovnicu i miša
  • Clear CMOS gumb
  • Optički ulazi/izlazi
  • Dva eksterna SATA porta (eSATA) pogonjena JMicronovim JMB363 kontrolerom.
  • Audio konektori
  • 4 USB utora
  • Firewire utor
  • Mrežna kartica
Kako vidimo serijski i ostali već zastarjeli portovi su uklonjeni. Minus je taj što ima samo četiri USB utora.
To je valjda donekle nadoknađeno eSATA portovima. Pozdravljam ubacivnja CCMOS gumbića,
koji zbilja zna dobro poslužiti prilikom igranja s OC postavkama. Nekima će se kao minus činiti i ''samo'' jedna mrežna kartica.
Interni priključci/utori:
Uz 2 eksterna, nalazimo 6 SATA utora, postavljenih na rub ploče pod kutem od 90 stupnjeva. Odmah pored, isto tako postavljenog, IDE konektora. Na donjem rubu ploče se nalaze redom, FDD konektor, pinovi za spajanje LED-ica i gumbova sa front panela kućišta. Nadalje, tu imamo 4 seta pinova za dodatne USB brackete, te po jedan set pinova za dodatne audio i firewire izlaze. Minus u toj priči jest potpuni nedostatak dodatnih USB/FireWire bracketa. Od pin-outa na ploči imamo još i set onih za uGuruov front-panel koji ne dolazi s pločom. Da predočim o čemu pričam, škicnite ovu i ovu sliku. Dvije izvedbe dotičnog komadića HW-a.
Na ploči se nalazi ukupno 6 utora za kartice. Odozgo prema dolje: jedan PCI-E x1 utor, dva PCI-E 2.0 x16 utora (x16 propusnosti, plave boje),
te jedan PCI-E 2.0 x16 utor propusnosti x4 (crne boje). Tu su i PCI utori, kojih ima dva komada. Od naponskih priključaka standardno imamo 24-pinski konektor,
8-pinski 12V EPS konektor, pet 3-pinska, te jedan 4-pinski FAN konektor, čiju je brzinu moguće regulirati preko uGurua, o čemu ćemo kasnije.
NAPONSKA JEDINICA
Ploča je opremljena peterofaznom digitalnom regulacijom napona. Za razliku od obične, ova u teoriji nosi manji pad napona, te finije podešavanje napona određenih komponenti. U praksi se dotična pokazala kao vrlo dobar izvođač. Bilo da se radilo o dual core ili o žešće naclockanom quad core procesoru, pad napona je bio minimalan. Vjerujem da dosta govori o ploči kad kažem da Q6600 na 3.9GHz, pri pomalo pretjeranih 1.9v, pada na samo 1.89v, pod punim opterećenjem. Naravno, vrijednosti su mjerene multimetrom, više puta. U slučaju dual core procesora, ploča overvolta za 0.01v, dok u slučaju pada napona, u odnosu na postavljenu vrijednost, kao i u slučaju quad core procesora pada na samo 0.01v, također sve mjereno multimetrom.
Po pitanju temperature. Dakle, kako sam i prije rekao regulacija se hladi pasivnim bakrenim blokom. U slučaju blaže naclockanog dual core procesora, temperature su sasvim pristojne. Konkretno, E8400 na 3.6GHz: idle - ~35C, load - ~45C, pasivno, na otvorenom. S druge strane, sa quad core procesorom situacija je sljedeća. Q6600 na 3.6GHz: idle: ~55C, load ~90C, pasivno, u zatvorenom kućištu. Dodavanjem 40mm ventilatora na pasivni blok, situacija se drastično mijenja. Dakle, Q6600 na 3.6GHz: idle: ~40C, load ~70C. Vjerujem da brojke govore sve. Inače, konstatacije radi, naponska jedinica nebi imala problema ni sa puno većim temperaturama kao što su 100C+. No, naravno, stabilnost i OC potencijal drastično padaju većim zagrijavanjem.
Zadnje izmijenjeno od: Razer. 12.05.2008. u 23:20.
Staro 12.05.2008., 03:59   #3
Razer
Razer's Avatar
Postovi: 11,642
SOFTWARE
Ploča dolazi sa samo jednim CD-om s driverima te s par korisnih stvari. Dakle na CD-u ćemo naći drivere (s podrškom za kako XP, pa tako i Vistu) za: čipset, zvuk, mrežnu, USB 2.0, JMicron SATA kontroler te za Intelov RAID. Princip instalacije navedenih drivera može ići ručno ili automatizirano putem Q-Installa. Ono što je korisno po pitanju samog CD-a jest to što isti može poslužiti kao boot disk. Na CD-u se također nalazi i priručnik ploče i uGurua u PDF formatu. Od dodatnih programa nije neka sreća...tako da imamo samo Acrobat Reader, AWD Flash utility, dakle alat za flashanje ploče iz DOS-a, te upute za isti. Ono što je tu najvažnije jest Abitov proslavljeni softver uGuru utility, o kojem bih napisao nešto više. Inače, sa službene stranice možemo skinuti sve gore navedene programe, tako da se u slučaju gubitke CD-a, samo uputite ovdje. Ili na ovaj FTP.
uGuru
Aktualna verzija je 3.1.0.9, koju možete skinuti sa službenih stranica. Na ovom FTP-u možete pratiti i beta verzije dotičnog programa.
Na početku nas dočekuje veselo oblikovani prozor s par funkcionalnih sekcija.
S lijeve strane imamo izbornik: Abit EQ, OC Guru te Fan EQ, kojim biramo koje sekcije želimo pratiti. Dakle ovisno o odabranoj sekciji možemo pratiti temperature svih krucijalnih komponenti (CPU, MBO, PWM...), stanje napona istih, te pratiti brzinu vrtnje instaliranih ventilatora.
Odmah pri vrhu, imamo par gumbića za podešavanje samog programa, kao što je vrsta skina, stanje samog prozora (prozirnost i sl). Pored njih imamo padajući izbornik kojim možemo birati koje (već unaprijed podešene) profile želimo koristiti (više o tome kasnije). Ispod dotičnih opcija, imamo gumb ''Setup'' kojim ulazimo u detaljnije podešavanje sustava, tj same ploče.
Dakle, u novootvorenoj sekciji nas čeka par podsekcija s nazivima: Abit EQ, Autodrive, Fan EQ, OC Guru, General.
Abit EQ – u ovoj sekciji možemo odabrati što želimo pratiti u monitoringu – voltaže, temperature, te ventilatore. Za svake od navedenih komponenti se mogu podesiti razna upozorenja u slučaju preniskih/visokih voltaža, visokih tempatura te niskih brzina ventilatora.
Autodrive – jedna od opcija koja pokazuje kolike su mogućnosti uGurua. Kako sam prije naveo da možemo birati unaprijed postavljene profile (Turbo, Normal, Quiet) ili svoje vlastite (User 1/2/3 mode), tako za svaku aplikaciju koju koristimo možemo odabrati željeni profil.
Uzmimo da smo u predefiniranom profilu ''User1'' overclockali svoj procesor sa 2GHz na 3GHz, i želimo da nam se brzina procesora diže samo u igrama. S lijeve strane odaberemo ''User1 Mode'' te zatim ''Add''. Time stvaramo listu aplikacija za koje želimo da koriste veću brzinu procesora (npr. COD4, UT3, 3Dmark i sl). S druge strane, imamo predefiniranu opciju ''Quiet Mode''. Time smo odabrali da nam procesor radi na nižoj brzini/voltaži, u kombinaciji sa stišanim ventilatorima – idealno za surfanje, slušanje glazbe ili gledanje filmova (npr. Foobar, GOM, Opera i sl). Znači uz malo igranja sa dotičnim opcijama, možete podesiti sustav da radi točno onako kako želite.
Fan EQ – kako i samo ime govori, ovdje podešavamo brzinu vrtnje ventilatora. Kao i prije, i ovdje imamo već predefinirane postavke (Cool, Quiet, Normal), te naravno možemo i sami podesiti vrtnju kako mi želimo. Pa recimo da želimo uzeti stvar u svoje ruke...Prvo odaberemo ''FanEQ Enable'', pa zatim s lijeve strane, ''User Define''. Time smo otvorili nove opcije za podešavanje. Imamo dvije stvari na izbor. Dali želimo podešavati brzinu putem temperature određene komponente ili putem voltaže koju sami podesimo. Ukoliko odaberemo prvu, imamo na izbor temperature procesora, regulacije napona i ploče. Uzmimo za primjer da smo spojili 3-pinski ventilator koji smo posstavili na blok regulacije napona. Dakle, u idle, podesimo da se vrti sporije, no u slučaju više temperature (koju mi odredimo), ventilator se kreće vrtjeti brže. Slična stvar sa regulacijom preko voltaže. Osobno sam svoje ventilatore držao na 7v, optimum po pitanju hlađenja i tišine.
OC Guru – kao i u svakoj sekciji imamo predefinirane postavke, no u ovom slučaju je najbolje uzeti stvar u svoje ruke. Prođimo prije svega koje opcije nam se nude.
Podešavanje frekvencije sabirnice (FSB), brzine PCI-E sabirnice, te voltaže pojedinih komponenti. Voltaža procesora se može dizati na dva načina – dizanjem CPU VID voltaže i CPU Offset. Potonji omogućava finije podešavanje voltaže, te dizanje voltaže kad CPU VID dosegne 1.6v. U tom slučaju imamo 1.6v + CPU Offset s maksimalnih +0.3v. Dakle, krajnja maksimalna voltaža koju je moguće dobiti za procesor jest 1.9v. Da bi se izbjeglo eventualno pogrešno računanje, sa desne strane imamo mali okvir ''Target Voltage'' koji nam pokazuje koja je krajnja odabrana voltaža.
Nadalje tu imamo ostale voltažom obdarene komponente koje ću spomenuti kasnije pri obradi mogućnosti BIOS-a.
General – općenita sekcija u kojom podešavamo opcija samog programa ništa bitno za napomenuti.
Također, nakon instalacije uGurua, dobivamo još dvije aplikacije, a to su FlashMenu i Black Box.
Flash Menu – radi se o programu koji je namijenjen za flashanje BIOS-a iz Windowsa. Otvaranjem istom se dade vidjeti kako je program jednostavan, i kako se sve može napraviti u više manje par klikova. Od traženja najnovijeg BIOS-a za ploču, preko spremanja istog za backup. Inače ne koristim Win-based rješenja za flashanje ploče, no jednom sam koristio i ovaj, te je sve prošlo brzo i bezbolno. Osobno uvijek preporučam, pa ću i ovdje preporučiti flash BIOS-a isključivo iz BIOS-a, preko priloženog AWD Flash utilitya.
Black Box – kako se i iz imena dade zaključiti...Abitova crna kutija zabilježava sve podatke u slučaju rušenja sistema u tekstualnu datoteku, te ponovnim dizanjem (uz ispunjavanje traženih informacija o vašem sustavu) imate mogućnost poslati takav mail Abitu, koji bi problem trebao obraditi, i vama poslati mail s rješenjem. Naravno ovo je sve u teoriji. Osobno, nisam isprobao ovu mogućnost.
Zadnje izmijenjeno od: Razer. 12.05.2008. u 05:29.
Staro 12.05.2008., 04:01   #4
Razer
Razer's Avatar
Postovi: 11,642
BIOS/uGuru
Ploča koristi Awardov BIOS. Snalaženje je jednostavno i intuitivno. Ovdje ću nabrojati glavne sekcije i te napisati nešto o svakoj.
Standard CMOS Features
Ovdje nemamo nešto puno za podešavati: datum, te ukoliko želimo, možemo isključiti floppy, kako ga ploča ne bi tražila pri bootanju.
Advanced BIOS Features -> CPU Feature
Ovdje imamo štošta za podesiti/udesiti: opcije procesora kao što su, ovisno o procesoru, C1E, EIST, virtualizacijsku tehnologiju, poželjno gasiti u slučaju OC-a.
Također ovdje biramo koje uređaje želimo bootati pri paljenju računala. Osobno ostavim samo hard disk, ostalo na Disabled, isto kao i LOGO koji se prikazuje prilikom POST-anja ploče.
Advanced Chipset Chipset -> PCI-E Root Port Function -> OnChip PCI Device -> Super IO Device -> Onboard PCI Device
U ovoj sekciji imamo mogućnosti podešavati latencije memorije. Ništa pretjerano, no opet sasvim dovoljno detaljno po tom pitanju.
Također, ovdje možemo podesiti opcije koje se tiču PCI-E sabirnice, kao što je forsiranje da ista radi na brzini x1 i sl.
Integrated Peripherals -> OnChip SATA Device
Ukoliko se spremate na žešći OC, onda ćete ovdje zasigurno zaći. Osobno ovdje gasim gotovo sve osim SATA kontrolera. Dakle imamo mogućnost gašenja floppy/IDE/USB kontrolera isto kao i mrežne te zvučne kartice.
Power Management Setup
Ništa posebno ovdje, opcije paljenja računala preko tipkovnice/miša, napajanja PS/2 uređaja, te alarma.
PnP/PCI Configurations
Ovdje imamo mogućnost kontroliranja svih bootabilnih te plug and play uređaja, podešavanje latencija PCI uređaja itd.
uGuru Utility
Najzanimljiviji dio u cijeloj priči je, kao i sa softverske strane, uGuru utility. Dakle, isti se dijeli na više sekcija, tj dolje nabrojene.
OC Guru -> Voltage Control
OC Guru sekcija nam omogućava sljedeće mogućnosti:
Mijenjanje frekvencije sabirnice (FSB-a) procesora u intervalu od 133MHz do 700MHz, u 1MHz inkrementima.
Tu je naravno i opcija mijenjanja djelitelja. Dostupni: 1:1, 1:1.0, 1:1.20, 1:1.25, 1:1.50, 1:1.66 te 1:2. Inače, u zagradi pored odabrane, ćemo vidjeti trenutno podešenu brzinu procesora/memorije.
Ovdje imamo i mogućnost mijenjanja PCI-E sabirnice, u 1MHz inkrementu, od 100 do 200MHz. Pretjerivanje s dizanjem dotične frekvencije zna imati štetne/pogubne posljedice po uređaje na sabirnice iste. Dakle, grafička kartica, te diskovi spojeni na SATA kontroler. Tako da, nemoj te pretjerivati, te se držite umjerenih 110MHz, 120MHz max preporučljivo. Dizanjem dotične sabirnice, kako sam već i prije pisao možemo (no ne nužno) dobiti par MHz za FSB, te eventulno veći OC grafičke kartice.
I zadnja stavka u ovo sekciji jest Power Cycle Statistics u kojem, kako nam i naslov govori, možemo pregledati koliko je računalo dugo radilo, koliko smo ga puta resetirali/upalili i slično.
Prijeđimo na Voltage Control dio. Ovdje možemo detaljno podešavati voltažu svake pojedine komponente.
Voltažu procesora možemo dizati na dva načina: VID/Offset. Prvi način nam omogućava dizanje voltaže u 0.025v inkrementima od 0.8v do 1.6v. Preko Offset voltaže možemo dizati voltažu za 0.01v. Dakle uz maksimalnih 1.6 preko VID-a, sa Offset voltažom dobivamo maksimalnih 1.9v. Za nešto ekstremnije možda mrvicu premalo, no nebih to uzimao za neki minus, još uz to, postoji i vCore mod (dolje u tekstu naveden) za nešto više. Ispod gore navedenih opcija, imamo i prostor u kojem piše točna odabrana voltaža za procesor.
DDR2 napon je moguće dizati od 1.8v do 3.0v sa 0.025v inkrementom. Također bi bilo poželjno kad bi postojala mogućnost za nekih 3.1-3.2v, no i ovo je i više nego dovoljno za većinu clockera. Pisao sam i u OC guideu, no ponovit ću, nije preporučljivo dizanje voltaže memorije preko 2.5v. Ukoliko se upoštate u OC, poželjan vent za na memoriju.
CPU VTT napon je moguće dizati od 1.2v do 1.6v sa 0.01V inkrementom. Quad core procesori vole malo viši napon dotične komponente. Za quada kojeg sam ja koristio, davao sam i 1.5-1.55v, sve preko toga nema smisla. Kod 45nm procesora maksimalna vrijednost spušta se na 1.5v. Uz to, kod potonjih, dizanje ove voltaže nije toliko potrebno. Meni je i 1.35v bilo dosta za 4.5GHz.
MCH napon je moguće dizati od 1.25v do 1.9v sa 0.01v inkrementom. Opcija za dizanje voltaže Northbridgea. Osobno nisam išao preko 1.75v. S obzirom da povećanje istog drastično povećava zagrijavanje čipseta, poželjno je staviti nekakav ventilator na NB blok.
ICH napon je moguće dizati od 1.05v do 1.5v sa 0.01v inkrementom. Opcija dizanja napona samom Southbridgeu. Nije baš krucijalna za postizanje velikih taktova. Preko 1.35v, jednostavno nema potrebe ići.
ICHIO napon je moguće dizati od 1.5v do 2.0v sa 0.01v inkrementom. Dizanje voltaže I/O Soutbridgea. Opcija koja dosta utječe na maksimalnu frekvenciju sabirnice (FSB-a). Nekakav prosjek koji sam koristio, tj koji mi je bio dovoljan za frekvencije koje sam ganjao, bio je oko 1.75v-1.8v, sve preko toga nije preporučljivo kako za ploču, pa ni za procesor.
DDR2 Reference napon moguće dizati/spuštati od -150mV do +150mV. Služi za veću stabilnost pri visokim brzinama, osobno nisam osjetio neke veće razlike, osim kad sam ga digao na nekih +50mV ganjajući brzine na 1300MHz+.
CPU GTL Reference napon (0&2 i 1&3) moguće dizati od 45% do 80% u 1% inkrementu. Opcija koja dosta zna utjecati ne samo na maksimalnu krajnju frekvenciju procesora nego i stabilnost istog. Quad core procesori dosta profitiraju od ove opcije, tako da treba lagano s time. Osobno sam imao podosta igranja kako bih našao optimalne vrijednosti. Poznato je kako se svaki pojedini procesor drukčije ponaša s podešenim GTL postavkama. Najbolji primjer je moj E8400 koji je bolje radio na 64%, dok je 67% defaultna postavka. Da nisam koristio uGuru iz Windowsa, dobrano bih se namučio da nađem optimalne vrijednosti.
Zanimljiva stvarčica, koju nisam vidio kod ostalih ploča, jest mogućnost pod nazivom OC On The Fly, koju aktiviramo tipkom F8. Ta opcija nam omogućava to, da ploča odmah po zahtjevu, prihvaća unesene OC vrijednosti u uGuruu. Dakle, ukoliko imamo FSB na 200MHz i voltažu na 1.2v, unošenjem nove vrijednosti, npr. 300MHz/1.3v i pritiskom F8 nakon toga, ploča odmah diže frekvenciju procesora bez potrebe za restartom. Opcija u praksi radi vrlo dobro, osim kad pretjeramo s vrijednostima (tipa dizanje FSB-a sa 200 na 500MHz), ploča se zblesira, tj smrzne, pa moramo ručno resetirati računalo.
Od zanimljivih opcija tu je mogućnost spremanja postavki u profile. Ovdje imamo mogućnost čuvanja do 5 odabranih profila. Dijalog za spremanje pozivamo tipkom F6, dok load obavljamo tipkom F7.
Abit EQ -> Temperature Monitoring -> Voltage Monitoring -> Fan Speed Monitoring -> FanEQ Control -> 1st FanEQ Group -> 2nd FanEQ Group
Pošto sam već pisao o dijagnostici, nadzoru temperatura, voltaža te vrtnje ventilatora gore u tekstu, u sekciji Software/uGuru, vjerujem da nema potrebe pisati opet, jer se sve svodi na isti princip.
I za kraj ovog dijela, par riječi o BIOS-u. Kako je Abit poznat po tome, početni BIOS-i su bili dosta mušičavi, no svakom novom revizijom su sve bolji. Upravo iz tog razloga ćete vidjeti dosta zamjerki na BIOS u recenzijama na internetu. Dakle ovdje možete skinuti najnoviji službenu verziju BIOS-a (v12). Aktualnu verziju možete skinuti ovdje. Dakle prva revizija v13, koja se još ne nalazi na službenim stranicama. Hvala Vin EuroDizelu za update.
Zadnje izmijenjeno od: Razer. 12.05.2008. u 05:30.
Staro 12.05.2008., 04:04   #5
Razer
Razer's Avatar
Postovi: 11,642
OVERCLOCKING
Ovdje neću pisati nekakve bajke, tipa reze sa LN2, modanom pločom i sl, već točno ono što sam osobno uspio napraviti sa svojom pločom.
Sve testove koje sam provodio bili su sa predzadnjim BIOS-om. Na ploči sam clockao dosta procesora, a i memorija. Pa ću ovdje navesti neke od tih rezultata.
Maksimalni FSB koji sam uspio postići s ovom pločom bio je 545MHz. Radila je i na 555MHz, no pošto za to nemam dokaz tj SS i validaciju, to ćemo staviti na stranu.
S obzirom da se radi o X38 čipsetu, koji inače nije namijenjen za ganjanje visokog FSB-a, ovo nikako nije loš rezultat.
Dakle, 545MHz, sa E8400 procesorom:
Maksimalnu frekvenciju na dual core procesoru (E8400) koju sam uspio postići bila je 4500MHz:
Maksimalna 3D ''stabilna'' frekvencija bila je 4320MHz:
Maksimalnu frekvenciju sa quad core procesorom (Q6600) koju sam uspio postići bila je 4475MHz:
Maksimalna 3D ''stabilna'' frekvencija bila je 4150MHz:
Vjerujem da brojke govore za sebe, tj. vidimo kako je ploča dobar clocker. Pogotovo me ugodno iznenadilo kako je dobro radila sa quadom.
VOLT MODDING
Prije svega da navedem mjerne točke za najvažnije komponente na ploči:
VCore -> vDimm -> VTT
Za izvlačenje maksimuma, putem ekstremnijeg hlađenja, se ipak treba malo poigrati s pločom.
Dosada sam vidio da je samo slovenski OC-er zbogi uspio navući 600MHz, pa eto čisto nek se zna da ploča može...
Johnny Bravo sa Xtremsystems Foruma je zaslužan za modove napravljene nad ovom pločom.
Modove za razliku od nekih ploča, na ovoj, su potrebni samo u najekstremnijim situacijama.
Što hoću reći time jest to da ploča može pružiti dosta napona pojedinim komponentama i bez modova.
Dakle, imamo vDrop, vCore, vPLL te VTT modove, pored svakog su napisane vrijednosti varijabilnih otpornika koji su potrebni za mod:
vDrop (1kOhm):
vCore (500ohm):
vPLL (50kOhm):
VTT (50kOhm):
Za više informacija o tome, ovdje imate otvoren topic na XS-u.
KORISNI LINKOVI
Zadnje izmijenjeno od: Razer. 06.09.2008. u 19:44.
Staro 12.05.2008., 04:06   #6
Razer
Razer's Avatar
Postovi: 11,642
ZAKLJUČAK
Eto stigli smo i na kraj ovog reviewa, nadam se da nije bilo dosadno. Jest da sam to mogao napisati i kraće, no htio sam detaljno obraditi svaki pojedini dio. Nadam se da sam u tome uspio. No dobro, idemo zaključiti što se ima reći o ovoj ploči. Abit s ovom pločom očito nije ciljao na korisnike koji žele ploču punu điđa koje neće koristiti ili neže znati iskoristiti što redovito prakticira Asus (sa skupljim pločama). Zato je ova ploča i jedna od najjeftinijih ploča temeljenih na X38 čipsetu, a daleko od toga da je lošija od konkurencije po pitanju mogućnosti. Dakle, po pitanju bundle ide jedan veliki minus. Znam da mnogi ne gledaju na to, no stvari kao što je nedostatatak ijednog USB bracketa, kopči za instalaciju ventilatora (iako je u priručniku navedeno da se dobiju), samo 4 SATA kabela, unatoč 6+2 postojeća na ploči, malo bude u oči. Nadalje, layout je za svaku pohvalu. Isto tako mogu reći i za dobro riješeno hlađenje, koje se, na prvi pogled, možda i ne čini kao najbolje rješenje. Pogotovo u slučaju instalacije dodatnih ventilatora na pojedine blokove. Nešto o cijeni same ploče. S obzirom da se radi o ploči sa X38 čipsetom, i o tome da je ovo gotovo vrh ponude Abitovih ploča, mogu reći da je cijena sasvim u redu. Po pitanju BIOS-a sam već napisao par riječi, dakle, početni su bili dosta mušičavi i radili probleme, no svakom verzijom na sreću se riješava dosta problemčića u vezi kako po pitanju overclocka, bilo po pitanju stabilnosti same ploče. Overclocking mogućnosti su odlične, pogotovo s quad core procesorima. Ono što će se većini svidjeti jest i to što BIOS nije prekompliciran kao u slučaju npr. DFI-jke na koju prelazim. Možda će se netko zapitati zašto sam ju prodao. Razlog je jednostavan, nabavio sam 45nm DC procesor, a X38 čipseti nisu namijenjeni za izvlačenje maksimuma iz njih. Tako da, s moje strane, ova ploča, dobiva preporuku za kupovinu.
Prednosti
  • Layout;
  • Digitalna regulacija;
  • uGuru/BIOS/Odlične OC mogućnosti;
  • Onboard tipke za paljenje i gašenje, te I/O tipka za CCMOS;
  • eSATA na I/O panelu;
  • Cijena
Osrednje
  • Hlađenje;
  • Jedna mrežna kartica
Nedostaci
  • Bundle;
  • Samo 4 USB utora
Ocjenu neću staviti, jer vjerujem da uz gore navedene informacije, ista i nije potrebna, no ako budete inzistirali, stavit ću ju.
Nadam se da vam se svidio moj prvi review koji ću s vremenom još updateati. Komenatari, kritike, prijedlozi, poželjni
Zadnje izmijenjeno od: Razer. 12.05.2008. u 11:52.
Staro 12.05.2008., 04:18   #7
jurbAs
jurbAs's Avatar
Postovi: 2,583
eto toliko od mene bolji review nisam vidio na stranici istina da sam preletio ali koliko sam vidim sve je opisano nadam se da ces tako odradit i DFI stvarno max truda znam da si ovo radio nekih 5 dana i stvarno se vidi koliko je truda ulozeno. Moram priznat da je ama bas sve pokriveno. Tko god kupi ili zeli kupit plocu ovo bi trebao procitat!
cast mi je da prvi ovo mogu komentirat!
Staro 12.05.2008., 04:26   #8
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Samo da se javim, da ne mislis da spavam dok ti pises
Dobar text.
Milentije je online   Reply With Quote
Staro 12.05.2008., 04:37   #9
Fleks
JDM
Fleks's Avatar
Datum registracije: Sep 2004
Postovi: 6,137
Dobar dobar review !
Jedino mi nije jasno kak si izveo fotke biosa, mozda zato sto je kasno. Nisi valjda crtao to? Svaka cast na trudu .
Staro 12.05.2008., 08:40   #10
Juggernaut
Lokacija: Varaždin, Bronx
Postovi: 1,097
Fala Bogu da si objavio to više
Dobar osvrt na ploču
Juggernaut je offline   Reply With Quote
Staro 12.05.2008., 08:42   #11
timmy
timmy's Avatar
Lokacija: N/A
Postovi: 1,242
svaka cast
timmy je offline   Reply With Quote
Staro 12.05.2008., 09:10   #12
^SuperUnknown^
Prečupavi mod
^SuperUnknown^'s Avatar
Postovi: 9,128
Autor Fleks Pregled postova
Mozda SS-ovi iz manuala? Inace, pohvale Razeru, otkud vam samo vrijeme za toliko pisanja...
Primary macine:
Apple Mac Pro 5,1
64 GB ECC DDR3 800 MHz
Geforce GTX 980 4 GB
Kingston 120GB SSD
30 TB HDDs
Sharkoon QuickPort@USB
Optiarc DVD RW AD-7170A
Mac OS X 10.12.3
Secondary machine:
Apple Mac Pro 2,1
22 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 970 4 GB
Seagate 500GB 7200.10
Hitachi 1000GB 7K1000.B
Seagate 1000GB 7200.11
Hitachi 7K3000 3000GB
Mac OS X 10.10.3
Work rig:
Apple Mac Pro 1,1@2,1
13 GB DDR2 FB-DIMM 667 MHz
Geforce GTX 660 2GB
Seagate 500GB 7200.12
2xWD Black 1000GB
2xSharkoon QuickPort@eSATA
Mac OS X 10.10.3
Sony KDL-26U2000 26"@HDMI
Apple Alu Keyboard
Logitech MX518
LAP:
Apple Macbook Pro 3,1
Intel Core 2 Duo 2.53 GHz
4 GB DDR2
Kingson 180 GB SSD
Seagate 320 GB HDD
* Looking in:
* Listening to:
Technics SA-EX320
iPhone 6S 64GB black
iPad 16GB WiFi 4.3.2
* Connected via:
90/90 Mbps Iskon Trio
* "Powered" by:
UPS APC Smart-UPS1500VA
* Playing:
Tama Arstar II
Yamaha DTXPRESS IV Special
Staro 12.05.2008., 09:45   #13
razor i2c
razor i2c's Avatar
Lokacija: Hercegovina
Postovi: 363
svaka čast na reviewu
Sig 50 kb max :-)
razor i2c je offline   Reply With Quote
Staro 12.05.2008., 09:58   #14
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,312
Odlično!
Nešto mi govori da si ovaj review uradio s dodatnim motivom da nekima pokažeš kako se review radi
Staro 12.05.2008., 10:28   #15
Micko
Peachwize=mudra breskva
Micko's Avatar
Lokacija: Ri
Postovi: 210
Autor Gilbert5 Pregled postova
Odlično!
-ukrao si mi riječ iz usta.
Inače Razer,svaka ti čast,dobro si se oznojio pisajući ovaj review.
Micko je offline   Reply With Quote
Staro 12.05.2008., 10:40   #16
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
sjajno
DeadMan+ je offline   Reply With Quote
Staro 12.05.2008., 10:50   #17
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Evo da i ja napisem koju svoju subjektivo/objektivnu opservaciju o doticnoj ploci. Kako mi padne sto napamet to cu editirati u ovaj post da ne ispadne nepegledna spamara
Prvo kad sam vidio layout ploce me je iznenadilo sto PWM HS nije spojen pipom sa ostatkom HS-ova na ploci, naime pipa vodi sa SB-NB na mali radijator izmedju socketa T i memorijskih slotova. Ali to se pokazalo kao odlicno rjesenje jer se X38 grije kao sam vrag, cak i u idle-u, bez nekog pretjeranog gazenja. A spajanjem pipom sa PWM HS-om bi se ti MOSFETI jos vise zagrijali od NB-a, ovako je taj MOSFET Heatsink standalone i s malim moddingom dodavanjem ventilatora 40x40x10mm postaje prava mala hladna zvjercica sa temperaturama FET-ova u punom opterecenju manjim nego Core temperature mjerene u jezgri mog E6850 na trenutno 3.5GHz@1.375V. To sam i malo detaljnije razradio i objasnio tu svoju egzibiciju u posebnom postu na intel podforumu, pa Erejzer moze skupiti sve postove u jedan thread da bude preglednija, ako hoce.
http://forum.pcekspert.com/showthread.php?t=105587
Druga stvar koju abit ima i sto nitko od ekipe nema je nevjerovatna kontrola vrtnje svih ventilatora i parametara ploce u uGuru dijelu biosa. Svaki vent se moze iskontrolirati i podesiti po vise parametara kako da se ponasa. To doduse imaju sve abit highend ploce iz proslih vremena, sto moze i yedwy i SU potvrditi, ali se poprilicno unaprijedila kontrola, jer recimo na IC7-MAX3 nije postojala mogucnost da se iskontroliraju svi ventovi. Sada je to djecja igra
Erejzer, cestitam na novoj bebi iz DFI-ja i pohvale na reviewu.
Staro 12.05.2008., 12:00   #18
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Zvjerski obradeno , nema sta. Citajuci tvoj, uvidio sam par propusta u mom reviewu
Sad je red da napravis review DFI sa P35 cipsetom a na meni sa x38 cipsetom
za trud
Staro 12.05.2008., 12:42   #19
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
Odličan review Razer,pogotovo što si obradio uGuru i sve detaljno objasnio
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 12.05.2008., 13:08   #20
Razer
Razer's Avatar
Postovi: 11,642
Hvala svima
@Fleks - kako je i SU pretpostavio, napravio sam SS-ove iz manuala ploče,
nekako mislim da tako ljepše izgleda, nego da sam ručno slikao BIOS.
@Vin EuroDizel - budem ubacio
Staro 12.05.2008., 14:22   #21
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
@Razer
Opak reviev...
@Vin EuroDizel
Potvrđujem rečeno ali samo da znaš - moja ploča nema uGuru na sebi...
Ali svejedno radi regulacija ventilatora za razliku od nekih drugih...
Have a nice day...
Staro 12.05.2008., 14:45   #22
Sa_Stilom
Sa_Stilom's Avatar
Postovi: 2,717
Naklon i poštovanje
MC
Staro 12.05.2008., 14:49   #23
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Jako lijepo, dobar review
Zadnje izmijenjeno od: Jelc. 12.05.2008. u 17:03.
Staro 12.05.2008., 14:51   #24
maX
maX's Avatar
Postovi: 7,326
svaka cast na reviewu, stvarno treba jako puno vremena uloziti da se napise nesto takvo
Staro 12.05.2008., 15:28   #25
aski
Je suis Schumi
aski's Avatar
Postovi: 1,524
Na forumima nisam odavno čitao bolji review
Svaka ti dala, pa klokala
Di sam stao?
Staro 12.05.2008., 15:49   #26
vservera
vservera's Avatar
Datum registracije: Apr 2008
Postovi: 201
Odlicko, svaka cast imas dara za pisat review ce bit sta kad dodje DFI-ca?
RIOC Team
vservera je offline   Reply With Quote
Staro 12.05.2008., 19:47   #27
the-rider
ha?
the-rider's Avatar
Lokacija: Poreč
Postovi: 543
svaka cast Razer, odlicno napravljeno
nego kad smo vec na temi, ne znam da li me ploca zeza, ili sam ja lud, ali ne mogu spustiti ventove preko uguru-a na manje od 700 okretaja(xilence 12cm)
je to normalno ili?
the-rider je offline   Reply With Quote
Staro 12.05.2008., 20:24   #28
Baja 001
Baja 001's Avatar
Postovi: 7,504
Super odrađeno
Svaka ti dala
Evo malo sam preletio i samo mi je ovo upalo u oko!
o čemu žemo kasnije.
Staro 12.05.2008., 21:13   #29
Funkenstein
Funkenstein's Avatar
Lokacija: Kaštela
Postovi: 179
Razer svaka čast
I uGuru i Easy Tune ( Pro ) su odlični, ali uGuru mi se čini nešto moćniji, vezano uz funkcije. ( oba ogavno izgledaju, previše šminkerski ).
Funkenstein je offline   Reply With Quote
Staro 12.05.2008., 22:00   #30
rega
rega's Avatar
Lokacija: BiH/RS Doboj
Postovi: 63
Jako dobro Razer,svaka cast
Od tebe je tako nesto i za ocekivat.
rega je offline   Reply With Quote
