Lokacija: Zabok
Postovi: 1,189
(riješeno) MBO kako spojit zvuk = hitno
u kucistu imam kablove: MIC-IN GROUND L-RET R-RET MIC-POWER L-OUT R-OUT a na maticni utore : GND , PRESENCE# , MIC_RET , OUT_RET MIC2_L, MIC2_R , OUT2_R , J_SENCE , OUT2_L sto da kamo spojim kako bi mi zvuk radio.. |
Bill Gates
Lokacija: Vukovar
Postovi: 1,983
GND na GROUND, OUT2_R na R-OUT, OUT2_L na L-OUT. PRESENCE# i J_SENCE ne spajas nigdje. Za ostale nisam siguran. Pogledaj manual od maticne i kucista. |
Adrenaline junkie
Lokacija: Doboj - Banja Luka
Postovi: 3,593
![]() Nađi forumaša koji se odaziva na Japac. On je imao iste prbleme.
Lenovo ThinkPad W530 - Core i7 3840QM, 32 GB RAM, SSD Samsung 512 GB, nVidia Quadro K1000M 2 GB, 15.6" 1920x1080 IPS, baterija 9 ćelija |
#8 | |
Beskorisna bitanga...
Lokacija: Sesvete (Zg)
Postovi: 6,956
L-OUT + OUT2_L R-OUT + OUT2_R MIC-IN + MIC2_L MIC-POWER + MIC2_R RAzlog za problem je taj da ti je CASE connector po AC97 a na ploči ti je HD Audio (Azalia) mislim da se ovako treba spojit...
-- Have a nice day... |
#9 | |
Postovi: 4,707
PRESENCE# -> MIC_RET -> OUT_RET -> MIC2_L -> MIC-POWER MIC2_R -> MIC-IN OUT2_R -> R-OUT J_SENCE -> OUT2_L -> L-OUT EDIT: Demit, dok sam spajao preteko me yedwy. :P EDIT2: Bolje ti slušaj yedwyja... |
Postovi: 18,953
Ne podiži temu bezveze, nije ti ovo podforum tržnica. Strpi se i pričekaj dok ti još netko ne odgovori, a Pipeov odgovor je sasvim dovoljan. ![]() 1. High Definition Audio supports Jack Sensing, but the panel wire on the chassis must support HDA to function correctly. Please follow the instruction in our manual and chassis manual to install your system. 2. If you use AC’97 audio panel, please install it to the front panel audio header as below: A. Connect Mic_IN (MIC) to MIC2_L. B. Connect Audio_R (RIN) to OUT2_R and Audio_L (LIN) to OUT2_L. C. Connect Ground (GND) to Ground (GND). D. MIC_RET and OUT_RET are for HD audio panel only. You don’t need to connect them for AC’97 audio panel. E. Enter BIOS Setup Utility. Enter Advanced Settings, and then select Chipset Configuration. Set the Front Panel Control option from [Auto] to [Enabled]. EDIT: Sad imaš malo više odgovora...
Lokacija: Zabok
Postovi: 1,189
Lokacija: Zabok
Postovi: 1,189
ovako... sad sam provjerio, sve je spojeno kak treba biti.. neznam u cemu moze biti stvar !?!?! i btw, dobivam beepove kad mi dode neki error ili kad se netko ulogira na msn... znaci li to sta ? |
Bill Gates
Lokacija: Vukovar
Postovi: 1,983
Jesli li instalirao drivere i enableao zvucnu u biosu? |
Postovi: 18,953
#16 |
Lokacija: Zabok
Postovi: 1,189
hvala svima na pomoci ali ja jednostavno zvuk nemogu dobiti.. zelim otvoriti realtekov izbornik, ( kao sto je domy dao ) i idem na C:\program files .... realtek.. i onda kad tamo pod instal shieldom kliknem na ikonicu, ne otvara se nista ((tako da nemogu doci u ovaj izbornik kako bi maknuo kvacicu sa ovog.. |
#17 |
Postovi: 6,956
Jesi instalirao prave drivere? Mislim da imaš Vistu rekao bi da imaš problem s driverima, nekoliko ljudi se opeklo na Asrokicama sa Vistom jer im zvuk jednostavno nije htio raditi ali ne sjećam se dda je neko na XPu imao taj problem, ipak ti imaš SP3 neznam kako on pristupa problemu...
#19 |
Postovi: 18,953
Klikneš na onu Realtekovu ikonicu pored sata, prebaciš na Audio I/O i onda na vilasti ključ pored ANALOG.
#21 |
Postovi: 18,953
Probaj onda staviti najnovije drivere... ftp://202.65.194.211/pc/audio/WDM_R191.exe Koje Windowse uopće imaš? Ove XP sa SP3 ili...?
#23 |
Postovi: 6,956
Deinstaliraj si te drivere koji su došlli s pločom i skini te instaliraj ovo... http://dlsvr03.asus.com/pub/ASUS/mis..._V51005294.zip Edit: Pretekao me Domy... ![]()
#24 |
Postovi: 18,953
Imaš li uopće zvuka na stražnjim audio konektorima? Ako nemaš, trebaš će ti hotfix KB835221 budući da si stavio SP3...
#25 |
Lokacija: Zabok
Postovi: 1,189
neznam na sta mislis kad kazes dal imam zvuka na straznjim konektorima, ali kad spajam ovaj kabel s zvucnika u MBO cuju se nekakvi neartikulirajuci zvukovi.. sta da stavim taj hotfix ili ? .. ove drivere cu sada skinut za 3 minute.. |
#26 |
Postovi: 18,953
Samo na prednjim konektorima nema zvuka ili nema i na stražnjim? Kakva je situacija u Device Manageru, ima li žutih uskličnika? Ne instaliraj hotfix dok ne odgovoriš na ovo sve...
#27 | |
Lokacija: Zabok
Postovi: 1,189
a kada ocu pustiti bilo koji zvuk tj. pjesmu dode mi error da nemam instalirani sound device.. |
#28 |
Postovi: 6,956
Onda deinstaliraj sve vezano uz zvuk, rebootaj i nakon toga nemoj dati da ti instalira ništa od drivera, skini hotfix koji je rekao domy (iako bi trebao biti dio SP3 kolko ja znam ali nema veze sad) i neki od drivera koji smo ti linkali... Ako niti onda ne radi nosi ploču na reklmaciju ili kupi drugu zvučno jer je u tom slučaju kaput... ![]()
#30 | |
Postovi: 18,953
Sad pogledaj Device Manager pa ćemo onda odlučiti trebaš li instalirati onaj hotfix ili ne...
