Staro 20.02.2008., 22:56   #1
striker0207
striker0207's Avatar
Postovi: 58
kompletna konfa za 4,5k kn max
ako bi netko bio tako dobar i preporucio mi neku konfu, ali kompletnu, dakle case, psu i monitor, bez misa i keyboarda, to cu solo nac...
komp ce se koristit ovak za net i rad u Office-u i tak nekim takoreci osnovnim aplikacijama, eventualno nest u PhotoShopu, ali nije potrebna ne znam kakva brzina u njemu...
hvala unaprijed
Of all the things I lost
I miss my mind the most
striker0207 je offline   Reply With Quote
Staro 20.02.2008., 23:27   #2
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
pozdrav
Procesor Intel Pentium Dual-Core E2160=420KN
Gigabyte P31-DS3L, s775,=479KN
DDR2 1024Mb ( 1Gb ) PC5300 Kingmax MARS=135KN x2
HDD WD 250 GB, WD2500AAKS, SATA II, 16MB=448KN
Napajanje FORTRON 350W, PNF, Super Silent=205KN
Radeon 2600Pro , 256Mb DDR2, 800MHz, HIS=458KN
LG Flatron L1919S, 19" sivi, contrast 2000:1=1532KN
Aplus CS-188A PC Case, w/o PSU, RoHS=267KN
DVD upisivač Pioneer DVR-115DBK=202KN
Evo sve skupa izađe cca 4.300KN i sve sklopljeno u ADM-u u ZG.
Staro 20.02.2008., 23:28   #3
jurbAs
jurbAs's Avatar
Postovi: 2,583
postoji trazilica imas takvih konfi sastavljenih ajme! pogledaj malo po forumu...
Staro 20.02.2008., 23:56   #4
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
mbo - Gigabyte P31-DS3L, s775, intel P31+ICH7, FSB 1333/1066/800MHz, 4
cpu - Procesor Intel Pentium Dual-Core E2160 , 1.8GHz, socket 775, 1Mb
ram - DDR2 1024Mb ( 1Gb ) PC5300 Kingmax MARS , 667MHz, CL5 x2
vga - PEAK X1950GT 256Mb DDR3 256bit, TV-out, DVI
dvd - DVD upisivač Liteon DH-20A4P-06C, 20x , DVD-Dual, black, ATAPI,
hdd - HDD Hitachi GST Deskstar T7K250 160 Gb , Serial ATA II-300 , 72
psu - Napajanje FORTRON 350W, PNF, Super Silent, 12cm ventilator, ATX2
cas - Colors-it L8027-C43, bez napajanja, midi tower
mon - PHILIPS 220WS8FB, 22" LCD, widescreen, 1000:1, 5ms, VGA, DVI-D
4.616,11Kn sve iz www.adm.hr
Slicno tominovu ali s nekim kljucnim promjenama!
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 21.02.2008., 00:03   #5
Postovi: 7,568
Autor elvis again Pregled postova
Sa ~116kn van budžeta i grafičkom karticom koju ni u snovima ne bude iskoristil za ono kaj navel. Naravno pod pretpostavkom da govori istinu kaj se tiče namjene.
Staro 21.02.2008., 00:12   #6
elvis again
In the ghetto
Postovi: 1,943
McG ti picajzlek jedan :-). To je samo predlog, ideja mi je bila da ima 22" monitor jer je to nekak danas standard (i na cem se nebi trebalo stedit) a ovo ostalo je sljedilo iz toga.
A to kaj je 116kn iznad buđeta bumo vidil kaj bu vlasnik rekel.
Staro 21.02.2008., 00:18   #7
Postovi: 7,568
Prijedlog za ono kaj je on navel bi IMHO sadržaval ploču s IGPom, pa onda dalje po spisku. Ali pošto se bude on (kak to obično biva) naknadno javil da je zaboravil spomenuti igranje CoD4 i lagani clock, nema smisla razglabati.
Staro 23.02.2008., 00:58   #8
striker0207
Postovi: 58
nece bit nikakvog dodatnog koristenja ovog kompa, jer mu to jednostavno nece bit namjena, dakle cisto surf i osnovne stvari u office-u, kao sto sam naveo...
hvala na pomoci...
Staro 23.02.2008., 01:05   #9
Postovi: 7,568
Onda ti je dosta matična ploča s integriranom grafičkom karticom i nema smisla da trošiš novce na posebne kartice.
Staro 25.02.2008., 14:24   #10
striker0207
Postovi: 58
ok, hvala na savjetu, razmislit cu i o tome...
