Lokacija: Vž
Postovi: 81
Azureus Vuze stvara probleme (BSoD)
Pozdrav svima na forumu! Nedavno sam skinuo Azureus Vuze i počeo dobivat BSoD s STOP 0x0000008, premda nisam odmah u početku pomislio da je Azureus krivac za to. Da li ima netko sa sličnim problemom?
The complexity for minimum component costs has increased at a rate of roughly a factor of two per year ... Certainly over the short term this rate can be expected to continue, if not to increase. Over the longer term, the rate of increase is a bit more uncertain, although there is no reason to believe it will not remain nearly constant for at least 10 years. That means by 1975, the number of components per integrated circuit for minimum cost will be 65,000. I believe that such a large circuit can be built on a single wafer. - Gordon Moore |
Postovi: 298
nemam problema ..trenutno no . jel ti dugo komp ukopčan ..jel se koristiš još nekim torent klijentom + radiš druge stvari na compu .. - meni je to znalo bit problem probaj češće restartat |
