Staro 25.01.2008., 10:05   #1
_aco_
Postovi: 134
Koju 5.1 Zvučnu
Koji mi preporučujete 5.1 zvučnu do 400-500 kn
_aco_ je offline   Reply With Quote
Staro 25.01.2008., 13:45   #2
karlito
sam svoj aka
karlito's Avatar
Postovi: 789
moja preporuka : CREATIVE LABS X-Fi mX Xtreme Audio, košta ti 399kn u hgspotu, u linksu je 316kn ili uzmeš neku Creative Audigy
karlito je offline   Reply With Quote
Staro 25.01.2008., 15:04   #3
Z-man
Z-man's Avatar
Lokacija: Bjelovar - Zagreb
Postovi: 1,079
Ni slučajno nemoj uzet CREATIVE LABS X-Fi Xtreme Audio, to ništ nevalja za tu cijenu koliko košta.....
Moja preporuka X-fi Xtreme Music u linksu 550 kn ili ako ne možeš dat toliko novaca onda Audigy 4 koja ti je oko 420 kn
Z-man je offline   Reply With Quote
Staro 25.01.2008., 22:08   #4
_aco_
Postovi: 134
Jbg uzeo sam danas,CREATIVE LABS X-Fi mX Xtreme Audio još je nisam testirao kako treba,ali malo me zeza bas...
ako mi neko može objasniti kako da je uštimam da radi kako treba,bio bih zahvalan
Staro 26.01.2008., 16:58   #5
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Auzentech 7.1 hda xplosion
AMD Phenom 9850be 2,5ghz@2,9ghz@OCZ Vendetta 2 700rpm
DFI Lan Party JR 790GX-M2RS
OCZ Blade 2x2Gb ddrII@1066mhz@1.8v
Gigabyte HD4850 1GB Multi Core @passive
Auzentech Meridian@Opamp LM4562NA
2xWestern Digital 6400aaks@RAID 1 + Seagate S-ATA 160gb@XXX
Tagan 480W Supersilent
Thermaltake V1000+ black with side window
Logitech MX500
DELL 2007FP
AMD Athlon 3000+(venice e3) stock
Abit AV8
Kingmax Superram 2x256ddr433 FHAS stock
Gainward 7600GT GS 256mb
Seagate Barracuda 80gb P-ata
Denon AVR-3805 black finish @DIY 3.5mm > 2RCA(Neutrik RCA plugs)
Focal Jmlab Chorus S 726s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S CC700s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S SW700 classic finish@Bandridge Profigold Subwoofer Cable
Review Chorus S serije
Review Denon AVR-3805
micek_kc je offline   Reply With Quote
Staro 26.01.2008., 17:26   #6
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
slab je taj X-fi Audio..ali koliko se sa Gamera sjećam..imaš CD sa auto-install software-om..i ne bi ti posebno naštimavanje trebalo biti problem..ikonica se pojavi u taskbaru..jasno,onboard zvuk u BIOS-u prethodno disablaš..i pobrišeš sve drivere sa DC Pro...Realtek drivere,pretpostavljam..
Što se tiče tog creative control panela,sjećam se da sam crystalizer držao na 30tak posto,podesiš na 5.1 bass redirection ili kako se već zvalo..jer ima i nekakav stereo surround opcija..ti odaberi bass redirection..i tako,to je sve manje više igranje..
Ako pravilno pobrišeš stare,i staviš Creative drivere..ne bi smio ništa zeznuti..pa je sve stvar osobnog naštimavanja..
makar..za 500kn..uh..da se naći puno bolja kartica od obične Xtreme Audio verzije..Gamer je možda 50-100kn skuplji..a kartica je aviončina..ja prodao jer mi je lova trebala hitno..inače nikad ne bi..
Staro 26.01.2008., 17:53   #7
_aco_
Postovi: 134
A ***iga uvijek imaj za 100-150 kn skuplju karticu..
Nego taj bass redirection mi se nekada isključi sam od sebe..da ga pojačam do kraja i dodam boost 15 dB
Staro 26.01.2008., 18:41   #8
thedream
thedream's Avatar
Postovi: 5,458
ma znam šta hoćeš reći točno..100,po 100 kuna..na kraju 1000...ali baš je bilo govora o tome..bezbroj tema o X-fi..ja sam ih osobno bar 5 otvorio...tako da smo nekako složili zaključak da je X-fi Audio najslabiji..a Gamer mrvićak iznad Musica..Platinum i Fatal1ty su gluparije..jer je X-ram teški marketing-shrott...tako da si možda za 550kn trebao gamera uzeti..
što se tiče bass redirectiona..hm,ja osobno baš ne vjerujem tim soft-mod rješenjima..ne znam koje zvučnike imaš..ja bi isključio taj bass boost i radije pojačao na wooferu..na jedno 60%...da postigneš nekakav optimum..i uključiš bass redirection mode..i to bi trebalo biti to..
crystalizer na 33%...eax effects off..ili ako baš mora biti..on,pa na none..shemu..i ne znam šta još ima tamo..zaboravio sam...to je subjektivna kategorija..ja sam recimo imao woofer na 60%,bass u panelu na 33%,treble na 55% i zvuk je bio savršen...više sam volio visoke tonove..nego drmanje..bassa...
pogledaj sam..ništa te ne košta..neće ništa grunuti
Staro 26.01.2008., 18:53   #9
_aco_
Postovi: 134
Imam Genius SW 5.1 5000 (nekako su mi žešće radili na integiranom šrotu realtek 7.1 ) ovdje osjetim možda malo kvalitetniji zvuk,ali dosta je tiše..
Staro 26.01.2008., 19:21   #10
thedream
thedream's Avatar
Postovi: 5,458
ma nije Realtek tako loš..evo,ja imam Logitech X530,i Realtek ALC883,to je HD chip..192khz/24bit..nije to X-fi,daleko od toga..ali dobio sam ga na Asusu mbo..zašto ga ne iskoristiti..a grmi na sve strane..
ne znam zašto se tiše čuje..dosta ljudi ima taj problem..stvarno nemam pojma..ja nisam imao takvih sranja.
jesi line in stavio na mute..i mikrofon..i ostale gluparije..i pojačao do kraja wave i to..
Staro 26.01.2008., 19:53   #11
_aco_
Postovi: 134
Malo sam radio premještaj woofera u sobi,nešto malo čačkao po onom njihovom panelu i donekle uštimao sve..inače sve ono ostalo mi je na mute uglavnom sve oke...uzeo sam onu zvučnu i sad kak je -tak je..nemogu tu nista hehe
Staro 26.01.2008., 20:24   #12
thedream
thedream's Avatar
Postovi: 5,458
..nemoj se uopće opterećivati..
