Postovi: 15
Konfa do 6000 - gaming
Pozdrav svima! Evo kao sto u naslovu pise, molim da mi sastavite neku gaming konfu do 6k kuna. Pod konfa mislim na samo kantu, bez monitora. Hvala unaprijed! |
In the ghetto
Postovi: 1,943
mbo - Gigabyte P35-DS3R, s775, intel P35+ICH9R, FSB 1333/1066/800MHz cpu - Procesor Intel Core 2 Duo E6750 , 2.66GHz, socket 775, 4Mb cache ram - DDR2 1024Mb ( 1Gb ) PC5300 Kingmax MARS , 667MHz, CL5 x2 vga - GECUBE HD3870 X-TURBO, PCI-Ex16, 512MB DDR4 256-bit, HDTV-out hdd - HDD SAMSUNG SpinPoint T166 500GB 7200rpm 16MB cache Serial ATA dvd - DVD upisivač Pioneer DVR-112DBK, DVD±RW, 18x DVD±R ,8x DL, black psu - Napajanje FORTRON 400W, Super Silent, 12cm ventilator, ATX2 case - Coolermaster CM 690, crno, prozor, bez napajanja, 9,8 kg cooler - SCYTHE Mine SCMN-1100, socket 478/775/754/940/939/AM2 6.037,76Kn sve iz www.adm.hr
Lokacija: Kaštela
Postovi: 45
Evo da ne otvaram novu temu,meni isto treba neka takva konfa ali iz Ve-Milla,Linksa ili Hg spota,po mogućnosti da sve komponente budu iz jednog dućana.
Asus A8N SLI Premium MBO 4x512MB ddr 400 mhz Kingstone GainWard 9600GT Golden Sample AMD 3500+ 64bit |
In the ghetto
Postovi: 1,943
Uzmi malo jeftinije komponete pa mozes ustedit a nece bit neke primjetne razlike (upozoril me McG da vise gladam performanse/cijena) mbo - MBO ABIT, s. 775, IP35-E, iP35X, BUS 1333 MHz, serial ATA II, 7.1 zvuk, 1Gbps, DDR 2, ATX 2 cpu - Intel® Core(TM) 2 Duo E4500 2.20 GHz, 2MB LGA775, BUS 800MHz, Conroe, BOX ram - RAM, 1 Gb, DDR 2, PC-5300, 667 MHz, KINGMAX x2 hdd - HDD SEAGATE Barracuda 250 GB, serial ATA-II 7200.10, 7.200 o/min., 16 MB cache (ST3250410AS) vga - VGA PCI-E CLUB 3D ATI Radeon HD3870 Overclocked Edition, 512 MB, tv-out, Dual DVI dvd - DVD pisač, DVD±RW & DVD±R & DVD-Ram SAMSUNG SH-S203D, 20x, 8x dual layer 8.5 GB, SATA, bulk, crni psu - Midi Tower, CHIEFTEC BH-01BBB, 400 W, crno (znaci zajedno: psu i case) 4.669,00 kn sve iz Hgspota
Lokacija: Kaštela
Postovi: 45
Elvis puno hvala,moga bi ubrzo uzet nešto slično samo s 4gb rama i malo većim hard diskom.
Postovi: 15
Elvis, hvala na odgovoru ali vidio sam gotovu gaming konfu za tocno 6k kuna, pa mi pls reci sta mislis o njoj: http://www.h2-shop.com/katalog.aspx?...ala&ID=1&ID2=2 Radi se o H2 Optimus 4U konfiguraciji EDIT: u Bugu su nahvalili doticnu konfu =) |
#7 | |
Type R
Postovi: 1,485
David linčujem Davida Finčera |
In the ghetto
Postovi: 1,943
Slazem se sa BladeRunnerom ta konfa nije bas najbolja jer ima jako grafu, a ni maticna sa nvidia chipsetom mi se ne svidja. Jedina prednost joj je 3g garancije (ako ne diras unutrasnjost). Ona konfa koju sam gore slozil je jednostavno bolja - the end.
sam svoj aka
Postovi: 789
ili Vistu ![]() |
