Staro 11.12.2007., 22:49   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
PCI Express 2.0
Nema dugo da smo pričali o tome na forumu-koja je razlika u brzini i slično.
Ispada da je razlika generalno 10% i to u višim rezama.
The RV670 offers sterling support for PCI Express 2.0. The second version of PCI Express doubles the standard bandwidth, from 2.5 Gbit/s to 5 Gbit/s. As a result, the standard graphics slot (x16) can transfer data at up to 8 GB/s in each direction (marketing specialists love to sum up these numbers and specify 16 GB/s) versus 4 GB/s for Version 1.x. Besides, PCI Express 2.0 is compatible with PCI Express 1.1. Old graphics cards will work in new motherboards, and new graphics cards supporting the second version will still work in motherboards without this support. External power supply being sufficient, of course. And they won't have the increased interface bandwidth.
It's not easy to evaluate the real effect of higher PCI Express bandwidth on performance - tests should be run in equal conditions, which is problematic. But higher bandwidth won't hurt, especially for SLI/CrossFire systems that exchange data via PCI Express as well. Besides, lots of modern games require large volumes of fast memory. When there is not enough video memory, a game will use system memory, so PCI Express 2.0 will certainly be welcome.
AMD publishes the following data for RADEON HD 3850 with 256 MB of memory: performance difference between systems with PCI Express 1.x and 2.0 in Company of Heroes, Call of Juarez, Lost Planet, and World In Conflict varies from 5% to 25%, about 10% on the average. In high resolutions of course, when a frame buffer and contiguous buffers occupy the biggest part of local video memory, and some resources are stored in system memory.
To provide backward compatibility with existing PCI Express 1.0 and 1.1 solutions, Specifications 2.0 support both 2.5 Gbit/s and 5 Gbit/s transfer rates. Backward compatibility of PCI Express 2.0 allows to install older 2.5 Gbit/s solutions in 5.0 Gbit/s slots, which will operate at a lower speed. And devices designed in compliance with Specs 2.0 will support both 2.5 Gbit/s and 5 Gbit/s. As usual, it's all good on paper, but engineers may encounter some compatibility problems with some combinations of motherboards and expansion cards.
http://www.digit-life.com/articles3/...rt1-page3.html
Staro 11.12.2007., 23:00   #2
Kapica
Lokacija: Varazdin
Postovi: 108
da se nadovezem nekim logickim pitanjem?
jel podrzava koja maticna ili ti chipset pci express 2.0?
Kapica je offline   Reply With Quote
Staro 11.12.2007., 23:08   #3
Jelc
Super Moderators
Postovi: 17,485
Autor Kapica Pregled postova
AMD 770/790 chipset podržava ziher, Intel ne pratim
Staro 11.12.2007., 23:12   #4
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
Autor Jelc Pregled postova
pih Nvidiu prati a intel ne
Inače intel isto podržava ja mislim od x38 čipseta,evo jedne ploče koja 100% podržava PCI-E 2.0 http://www.abit.com.tw/page/en/mothe...775&DEFTITLE=Y
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 12.12.2007., 01:59   #5
Jelc
Super Moderators
Postovi: 17,485
Autor Lihto Pregled postova
intel ne
Pa, nemam namjeru prelazit na Intel pa mi nije zanimljivo
Staro 12.12.2007., 02:00   #6
Lihto
Lihto's Avatar
Postovi: 3,945
a na Nvidiu bi kao prešao
iPhone XR 128gb
Staro 12.12.2007., 02:41   #7
Razer
Razer's Avatar
Postovi: 11,642
Yup, svi Intelovi čipseti od X38, pa nadalje podržavaju PCI-E 2.0.
