Staro 10.12.2007., 12:27   #1
stopalo9
stopalo9's Avatar
Postovi: 763
Call Of Duty 5 Najava
Activision has announced that Call of Duty 5 is in the making, which they announced in an announcement released yesterday which can be read here.
The confirmation is not really unexpected, as the CoD franchise has always been a success.
Details concerning Call of Duty 5 has not yet been revealed though.
Rumors suggest that this again in the Second World War will play.
Sto reci,opet u iscekivanju
stopalo9 je offline   Reply With Quote
Staro 10.12.2007., 13:21   #2
maX
maX's Avatar
Postovi: 7,326
yep, back on WW2, jedva cekam =)
izgleda da su ipak shvatili kakvu su zapravo glupost napravili sa charlie oscar delta 4 ^^
Staro 10.12.2007., 14:02   #3
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
Autor stopalo9 Pregled postova
Activision has announced that Call of Duty 5 is in the making,...Rumors suggest that this again in the Second World War will play.
Još kad bude mješavina najboljeg iz CoD2 i CoD4 di češ bolje...
Jedino se bojim da ne bude kao trojka samo za konzole....
IT IS EASY TO KILL FIVE HUNDRED NOOBS. BUT THERE IS STILL FIVE HUNDRED AND ONE AND YOU ARE OUT OF AMMO!
1oo1
NOOB - POWER IN NUMBERS!
Good judgment comes from bad experience and a lot of that comes from bad judgment.
MisterM je offline   Reply With Quote
Staro 10.12.2007., 14:07   #4
robert7
robert7's Avatar
Postovi: 1,711
yep,5-ica je za konzole
http://eu.prepsafe.com
robert7 je offline   Reply With Quote
Staro 10.12.2007., 14:09   #5
maX
maX's Avatar
Postovi: 7,326
pas mater, onda se ceka 6-ica
@ robert7 - promijeni si grafu u Moj Komp
Staro 10.12.2007., 14:11   #6
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
Autor robert7 Pregled postova
To sam si i mislil kad sam čuo da se Activison udružio sa Vivendijem koji ima pod sobom Blizzard - naime jako ima se sviđa kak je WoW organiziran.......
1oo1
Staro 10.12.2007., 14:18   #7
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
Pa uopce neznam zasto ste iskljucili opciju PC-a.....
Mislim da je trojka bila tek toliko da u prvih godinu i pol se pojavi bilo kakav naslov CoD-a na konzolama.... mislim da bi taj peti nastavak mogao paralelno na svim platformama izaci bez beda...
Bar se nadam...
Jedino sto me zapravo brine je da NE naprave port sa konzolaske verzije na PC- nego obrnuto, jer ako bude po prvoj soluciji bit ce u startu govnasce igra
Master: E7200, 3MB L2, M0 {TT Big Typhoon VX @3500mhz}/Gigabyte P35-DS3P/2x1GB SuperTalent CL4 Overclock DDR2 800Mhz + 2GB Kingmax/Coolermaster Extreme Power 430W/XFX 8800GTX {Arctic Cooling Accelero Extreme} /Seagate Barracuda 250GB/Pioneer DVD-RW/
Periferija: LG W2242T 22"/Logitech X-230/Razer - Death Adder/LCD TV Toshiba WL66Z Regza 32"/Thrust Keyboard+Mouse Wifi/Logitech ChillStream/Sharkoon Rebel12
Gjurovski je offline   Reply With Quote
Staro 10.12.2007., 14:26   #8
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
Autor Gjurovski Pregled postova
Bar se nadam...
Mislim da se spomenulo da će Treyarch radit a oni briju konzole.....
1oo1
Staro 10.12.2007., 14:31   #9
robert7
robert7's Avatar
Postovi: 1,711
yep.
a port nijedan ne valja dosad (osim PES-a ),a brijem da je lakse napravit port sa ps-a na pc nego obrnuto
ima jos daleko do 6-ice,zivi bili pa vidjeli
Staro 10.12.2007., 14:32   #10
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
Da ali nevjerujem da ce raditi upotpunosti novi ENGINE za peticu sto znaci da ce koristiti vec koristeni kojeg je moguce portirati sa platforme na platformu, mislim da nije to toliko velika stvar koliko se moze zaraditi na toj igri jer realno ce biti prodano oko 35milijuna konzola a jednostavnim portom mogu igru prebaciti za jos minimalno 300milijuna PC-a tako da moras biti retardiran da samo tako odustanes od te love.....
Znaci ako budu koristili stari engine od 4 recimo nevjerujem da ce igra izbjeci PC samo tako...
Ako budu radili novi engine onda vec sada mogu reci da ce igra biti govno
Edit: cisti primjer LOSEG porta je Lost Planet igra na najvisim detaljima pri 1600x1200 se vrti cak losije na nekim dijelovima od Crysis-a pri istoj rezi a mislim da je vizualna razlika prevelika (sigurno im je i reklama poglec te kak je nas Xbox najbolsi za igranje ) nezelim uopce takve igre na svom hardu jer od takvih igara dobivam bad sectore....
Zadnje izmijenjeno od: Gjurovski. 10.12.2007. u 15:01.
Staro 10.12.2007., 14:34   #11
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
FTW!
Dok ništa ne rade IW bi mogao napravit jedan dobar patch za CoD2
Makar znam da sad patchaju četvorku.........
EDIT: engine od četvorke na WWII tematiku--> FTW!
1oo1
Staro 10.12.2007., 15:10   #12
nino
nino's Avatar
Postovi: 12,613
I nek vrate bash (zbog njuka), a ne ovaj nozic
Staro 10.12.2007., 17:21   #13
robert7
robert7's Avatar
Postovi: 1,711
da,drazi mi je nego kad zarezem ninu
imam osjecaj ko da ga bombonima gadam,a i prividno mi se pimpek smanji.
bash mi je bio drazi,onaj drveni zvuk udarca po celu od nine....
ah vremena
@nino,sto se avatu desilo
Staro 10.12.2007., 23:35   #14
Gjurovski
P.E.B.K.A.C.
Gjurovski's Avatar
Postovi: 2,304
@MisterM evo Treyarch je radio i Spidermana 3 za konzole pa je zavrsio na PC-u...
Staro 11.12.2007., 11:42   #15
Ementaler
Ementaler's Avatar
Postovi: 133
Da, ali je PC verzija Spideramana 3 bila loš port sa konzola sa mnogobrojnim problemima u framerateu.
Call of Duty franšiza prebitna je da bi ju napravili kao port sa konzole. Ako će peti nastavak imati PC verziju, onda će ju raditi drugi studio, nikako Treyarch.
Ementaler je offline   Reply With Quote
