Staro 02.12.2007., 14:36   #1
SniperWolf
SniperWolf's Avatar
Postovi: 4,193
problem s mrezom - ne otvara drugi komp
Ovo mi se od nikuda jučer počelo događati
dakle otvorim susjeda (dabogtx) bez problema
on otvori mene bez problema
otvaram HTPC - kaze ovo. Firewall je ugasen na svim kompovima.
http://support.microsoft.com/?kbid=318030
^ napravio sam i kako tu pise ali ista stvar.
a HTPC mene otvori normalno..
čak mogu i preko remote Desktopa u htpc uci - probao sam i resetirati ruter -- .. sve je do sad radilo odlicno IPove se dodijeljuju preko DHCPa
podesio sam permission normalno, ne kuzim u cemu je stvar.
Pošteni Trgovci: 1,2
Staro 02.12.2007., 18:49   #2
Buger
Postovi: 4,398
"Control Panel
Administrative Tools
Local Security Policy
+ Local Policies
+ Security Options
Network Access: Do not allow anonymous enumeration of SAM account, and shares. (Enabled) - It Should Be Disabled."
Staro 02.12.2007., 19:17   #3
SniperWolf
SniperWolf's Avatar
Postovi: 4,193
Bilo mi je to na disabled..
za svaki slucaj sam probo i sa enabled i ista stvar
Staro 02.12.2007., 22:07   #4
mahoona
mahoona's Avatar
Postovi: 284
Ovako ja obično slažem ljudima:
Prvo enablati Guest account:
Control Panel -> Performance and Maintenance ->
Administrative Tools -> Computer Management
Odaberi "Local Users" -> "Users"
Desni klik na "Guest" account i odabereš "Properties"
Makni kvačicu "Account is disabled"
Izlistavanje shareova:
"Control Panel" -> "Performance and Maintenance" ->
"Administrative Tools" -> "Local Security Policy"
Odaberi "Local Policies" -> "Security options"
Postavka "Network access: Do not allow anonymous
enumeration of SAM accounts and shares " mora biti disabled.
Micanje passworda za pristup shareu:
Postavka "Accounts: Limit local account use of blank passwords
to console login only" mora biti disabled.
Davanje pristupa preko mreže za Everyone:
Odaberi "Local Policies" -> "User Rights Assignment"
Postavka "Access this computer from the network" mora sadržavati "Guests" and "Everyone"
Postavka "Deny access to this computer from the network"
ne smije sadržavati "Guests" i "Everyone"
Ako imaš isključen Simple file shareing i daješ raznolike permissione ljudima, onda :
Postavku "Network access: Sharing and security model for local
accounts" postavi na "Classic: local users authenticate as themselves"
Simple file sharing isključuješ u Control panelu-> Folder options-> View i tu na dnu, zadnja opcija.
Kad sve to postaviš, napravi jedan restart i probaj.
Naravno, postavi dobro permissione na ono što shareaš (Shared i NTFS permissione).
Pozdrav!
mahoona je offline   Reply With Quote
Staro 02.12.2007., 22:19   #5
SniperWolf
SniperWolf's Avatar
Postovi: 4,193
Hvala na ovom detaljnom postu mahoona!
Vijerujem da će ljudima pomoći, ako se znaju koristit tražilicom.
Igrao sam se sa admin tools ali nisam sredio pa sam jednostavno reinstalirao win xp, jos mi je nesto s codecima ostalo kao problem pa sam se odlučio ovako sve nanovo ..
tnx
Staro 26.12.2010., 03:33   #6
Joza001
Joza001's Avatar
Datum registracije: Dec 2010
Postovi: 9
Autor mahoona Pregled postova
Pozdrav!
napravljeno sve što tu piše, i dalje ne funkcionira, a moj problem je sljedeći, imam 3 kompa u mreži 1. w7x64 2.w7x32 3. xp sp2
sa prvog vidim svakog i uđem na sve i kopiram sve radi, ali sa 2. i 3. vidim 1. mogu uci ima samo public folder u koji ne mogu ući iako su šerani svi hardovi, nema trika da uđem ili vidim bilo koji hard... plz help
Joza001 je offline   Reply With Quote
Staro 27.12.2010., 05:05   #7
Joke
N00B
Joke's Avatar
Postovi: 3,886
Na tome prvome postavi, permissione za te ostale..
Ne znam sto bi trebao bit problem, ako si sve sredio (sto se tice permissiona)!
Ja imam u mrezi W7 X64 - Windows server 2k8 - Windows server 2k3 - Debian - XP itd. i sljaka sve okej.
IE6
Linux is Not Windows
Staro 16.06.2011., 15:59   #8
EvilWorker
EvilWorker's Avatar
Datum registracije: Aug 2009
Postovi: 58
Pozdrav!
Sve sam ovo napravio, ali opet sa jednog kompa ne mogu pristupiti dtugome dok sa tog drugoga mogu pristupi na prvi, pristup sheranim folderima radi samo u jednom smjeru
Oba kompa imaju Windows /, ukljućeni sherovi za pojedine foldere, u share postavkama dozvoljeno sheranje bez sifre, ugašen Firewall.
Kompovi su spojeni preko Rutera SX763, imamo fixne IP adrese, isti Gateway i dns
EvilWorker je offline   Reply With Quote
Staro 21.06.2011., 00:26   #9
Nitzer Ebb
Nitzer Ebb's Avatar
Postovi: 87
ZA XPSP2:
1-podesi isto ime Workgrupe na svim kompovima
2-run->control userpasswords2
->advanced->manage passwords->add
Server:W7x64
Username: XPSP2\TvojUser
To ponovi za W7x32
/Last Abit/
Nitzer Ebb je offline   Reply With Quote
