Staro 19.11.2007., 15:44   #1
igi13
Lokacija: S
Postovi: 15
Rusi mi se opera...
....skinuo sam i instalirao operu verzija 9.24 international
setup...pokrenem ju...i kad pokusam otvorit bilo koju stranicu ona se
rusi...evo error reporta
Error signature
AppName : opera.exe AppVer:9.24.8816.0 ModName.unknown
ModVer:0.0.0.0 Offset:00000000
Reporting details_
This error report include:information regarding the condition of Opera
Internet Browser when the problem occurred;the operating system version and
computer hardware in use;your Digital Product ID which could be used to
indebtify your license;and the Internet Protocol(IP) address of your
computer.
We do not intentionally collect your files,name ,address,email address or
any other form of personally identifiable information.However,the error
report could contain customer-specific information such as data from open
files.While this information could potentially be used your identity, if
present, it will not used.
The data that we collest will only be used to fix the problem.If more
information is available, we will tell you when you report the problem.This
error will be sent using a secure connection to a database with limited
access and will not be used for marketing purposes.
Posto moj engleski nije najbolji...jel mi moze netko reci u cemu je
problem...te kako isti rjesiti...zahvaljujem na pomoci...pozdrav
igi13 je offline   Reply With Quote
Staro 19.11.2007., 16:02   #2
MeT
MeT's Avatar
Postovi: 97
hahahhahahha, ovak sta jos nisam vidio, pise ti da ti je komp nesiguran i kao da ti oni nece iskoristiti protiv tebe podatke koje dobiju, tipa IP adrese, ISP-a itd itd.... ajme majko
MeT je offline   Reply With Quote
Staro 19.11.2007., 16:13   #3
igi13
Lokacija: S
Postovi: 15
Autor MeT Pregled postova
I sto mogu uciniti da ovaj problem sredim?...inace buraz mi prekjucer reinstalirao windowse...nod32 je instaliran...do prije 2h sam surfao normalno...a onda ovo...pozdrav
Staro 19.11.2007., 16:14   #4
MeT
MeT's Avatar
Postovi: 97
probaj ponovo skinut operu, po mogucnosti nesto stariju verziju...
Staro 19.11.2007., 17:10   #5
igi13
Lokacija: S
Postovi: 15
E poludjet cu...skinuo veziju 9.20...probao instalirat...i pojavi mi se ova poruka:
Data Execution prevention - Microsoft windows
To help protect your computer, Windows has closed this program. Name:Windows Explorer
Publisher:Microsoft Corporation
http://upload.wikimedia.org/wikipedi...ed_program.png
zatim se pojavi ova poruka
Dr.watson Postmorten Debugger has encountered a problem and needs to close.we are sorry for the inconvenience.
i nakon toga se pojavi poruka sto sam je napisao u prvom postu...
...inace buraz mi je instalirao origigi windowse...a ja sam danas instalirao neke programe(nero.total commander) bez licence...jel to mozda razlog ovih problema...hvala...pozdrav
Zadnje izmijenjeno od: igi13. 19.11.2007. u 18:51.
Staro 20.11.2007., 01:03   #6
Joke
N00B
Joke's Avatar
Postovi: 3,886
Igi13 pogledaj ovu temu, da ga i ti provas iskljucit? http://forum.pcekspert.com/showthread.php?p=867077
