Staro 12.11.2007., 20:00   #1
mdrla
mdrla's Avatar
Lokacija: ZG Dubrava
Postovi: 471
OC intel P4 Northwood,matsonic MS9147c
imam ovu konfu a memorija je SuperTalentCL2, 2 x 512 mb pa me zanima kolike su okvirno mogucnosti OC-a?
cijela konfa:
CPU Type Intel Pentium 4
CPU Alias Northwood
CPU Stepping B0
Engineering Sample No
CPUID CPU Name Intel(R) Pentium(R) 4 CPU 1.80GHz
CPUID Revision 00000F24h
CPU Speed
CPU Clock 1800.1 MHz (original: 1800 MHz)
CPU Multiplier 18.0x
CPU FSB 100.0 MHz (original: 100 MHz)
Memory Bus 100.0 MHz
DRAM:FSB Ratio 1:1
CPU Cache
L1 Trace Cache 12K Instructions
L1 Data Cache 8 KB
L2 Cache 512 KB (On-Die, ECC, ATC, Full-Speed)
Motherboard Properties
Motherboard ID 62-0905-001131-00101111-040201-VIA_P6$MS9147C_MS9147C RELEASE 09/05/2002
Motherboard Name Matsonic MS9147C (4 PCI, 1 AGP, 1 CNR, 4 DIMM, Audio, LAN)
Chipset Properties
Motherboard Chipset VIA VT8753A Apollo P4X333
Memory Timings 2-3-3-5 (CL-RCD-RP-RAS)
Command Rate (CR) 2T
SPD Memory Modules
DIMM1: Xerox MALABS 512 MB PC3200 DDR SDRAM (2.0-3-3-7 @ 200 MHz)
DIMM2: Xerox MALABS 512 MB PC3200 DDR SDRAM (2.0-3-3-7 @ 200 MHz)
BIOS Properties
System BIOS Date 09/05/02
Video BIOS Date 03/09/04
DMI BIOS Version 07.00T
Graphics Processor Properties
Video Adapter Tul Radeon 9200
GPU Code Name RV280 (AGP 4x 1002 / 5961, Rev 01)
GPU Clock 250 MHz (original: 250 MHz)
Memory Clock 200 MHz (original: 200 MHz)
mbo chipset: VIA P4X266 (VT8753)
southbridge:VIA VT 8235
sta ako na mbo promjenim jumper sa 100 na 133 MHz, sta bi dobio!
mdrla je offline   Reply With Quote
Staro 12.11.2007., 22:12   #2
mdrla
mdrla's Avatar
Postovi: 471
evo promjenio jumpere sa 100 na 133 i sad radi na 2.4 GHZ
memorija je sad 133, DRAM:FSB Ratio 1:1 znaci 33% dobio na brzini cpu-a i ddr-a temperatura je sad bez nekog opterecenja 33 jel to u redu
jel bi se jos sta dalo dic gore?
Staro 12.11.2007., 23:47   #3
Baja 001
Baja 001's Avatar
Postovi: 7,504
Autor mdrla Pregled postova
To sa jumperom je za minjanje FSB-a isto radi ko OC, ali mislim da ta matična što se tiče BIOS-a i svega ostaloga nije za OC. To znači ako je tako stabino i BIOS nema još nekih dodatnih opcija super, temperatura je u redu BTW zvrti Orthos ili SuperPI 32M pa onda vidi temperature!
Staro 13.11.2007., 02:49   #4
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
to ti je to nemos vise nis sa tom maticnom .
imao sam ju pa znam
.i.
Razer Blade 15
Staro 14.11.2007., 18:47   #5
mdrla
mdrla's Avatar
Postovi: 471
vratio sam jumpere jer se stalno restartirao! jer se moze to izbjec pa da radi stabilno na 2.4 GHz mislim sa 1.8 na 2.4 je zadovoljavaju ci cloc s obzirom na mbo! codiac jel imas mozda manual od tog matsonica?
Staro 14.11.2007., 20:49   #6
Postovi: 8,235
matsonic MS9147c=> uštekaj u komad daske i bolje ćeš moći klokat neg na matsonicovoj ploči. Imao sam 2 i vjeruj ni jedna neide. Neznam kako tvoja al moja ms9307c nije ni imala p4 priključak, samo standardni atx. nije htjela ni mhz više.
Staro 14.11.2007., 21:02   #7
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,041
Nije ni taj steping northija neka sreća za oc. Moj je na abitici is7 išao max na 2.8....
