Zaključane teme
Staro 09.11.2007., 12:28   #1
lujito
lujito's Avatar
Lokacija: Near
Postovi: 416
Problem pri instalaciji RED ALERT 2
Skiniuo sam je preko torrenta i u instrukcijama sam nasao ovo:
1. Copy contents of Red Alert Allied Disc to your harddrive (for example: c:\temp\ra2_allied)
2. Extract ra2_allied_crk.zip to that directory (for example: c:\temp\ra2_allied)
3. Run crack_allied.bat in the setup dir (for example: c:\temp\ra2_allied\setup)
4. Delete crack_allied.bat and instructions.txt
5. Burn CD with your favorite software using label: RA1
6. Delete temporary directory (for example: c:\temp\ra2_allied)
7. Install game and copy ra2.exe from your CD to the installed dir (for example: X:\crack\ra2.exe)
8. Enjoy the game
Igra je u rar formatu, al ovog CRK sto pise pod brojem 2 nema nigdje...
Isto tako mi nije jasno sta im znaci ovo pod 1. Izgleda mi kao da ja moram vec imat cd od RED ALERT-a...
Nije mi jasno ovo sa temp. Pitanje: Dali igru treba instalirat u folder kojeg ti sam napravis i napises temp pa pod folder ra2_allied ili je treba instalirati u temp folder u local setingsima.
Naime, koliko sam ja skuzio na ovoj stranici http://fileforums.com/archive/index.php/t-17417.html
treba instalirati u taj temp da bi se dobio bat file kojeg ja nikako nemogu dobit...
lujito je offline
Zaključane teme
