Staro 05.11.2007., 15:50   #1
toni36
toni36's Avatar
Postovi: 154
(riješeno) HDD Seagate 200 GB
na reklamaciju dobija san novi hdd.kad san ubacija u konpjuter neprepoznaje ga ka hdd nego ka cd.kad udjen u propetis ,hardver tu ga prepozaje.stari hdd koji je riknija proradija je iz prve kad san ga montira,ali je riknija nakon godine ipo.
Zadnje izmijenjeno od: toni36. 05.11.2007. u 16:07.
toni36 je offline   Reply With Quote
Staro 05.11.2007., 16:10   #2
Joke
N00B
Joke's Avatar
Postovi: 3,886
Hm je li ti samo ikonica kao CD-rom ili ? Ako je tako pogledaj ovaj post http://forum.pcekspert.com/showthread.php?t=86184
Staro 05.11.2007., 16:24   #3
toni36
toni36's Avatar
Postovi: 154
moja greska ovo je virtualni cd . harda uopce nema u my computer.u biosu je ,u propetis - hardver je.
Intel® Desktop Board D865GBF Product features
View the Intel® Product Comparison Charts.
Boxed Product Code BOXD865GBF BOXD865GBFL BOXD865GBFLK 10-pack Product Code BLKD865GBF or KD865GBFPAK10 BLKD865GBFL or KD865GBFLPAK10 BLKD865GBFLK or KD865GBFLKPAK10 BIOS ID String BF86510A.86A Altered Assembly # AA C25827-xyz AA C25843-xyz AA C28142-xyz Form Factor & Size ATX 12 x 9.6 Inches Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI Audio SoundMAX4* XL featuring Flexible 6 Channel Audio with Jack Sensing USB Ports 4 from Back Panel, 4 from Internal Header - USB 2.0 HDD Two (Master & Slave) ATA 66/100 connectors
Two Serial ATA connectors On-Board LAN None Intel® Pro/100 (100 Mb) Intel® Pro/1000 CT Desktop Connection Warranty 3-year limited warranty
Zadnje izmijenjeno od: toni36. 05.11.2007. u 16:35.
Staro 05.11.2007., 16:32   #4
nino
nino's Avatar
Postovi: 12,613
Moras kreirati particije i formatirati, mozes iz Disc managmenta ili Partition magic ako imas.
Staro 05.11.2007., 17:16   #5
toni36
toni36's Avatar
Postovi: 154
rijeseno sa Partition magic.hvala
