Postovi: 29
philips vs lg
koji da uzmem i zašto? LG 1953T - 1620kn ![]() PanelTN Size19 Resolution1280 x 1024 Pixel Pitch0.294 x 0.294 Brightness300 cd/㎡ Contrast Ratio2000:1(DFC) Viewing Angle170/170 Response Time5ms(GTG) Display Colors16.2M Sync Range Horizontal Frequency30 ~ 83 kHz Vertical Frequency56 ~ 75 Hz Input Signal Video SignalRGB Analog, Digital Sync typeSeparate, Composite, SOG Connectors PC15 Pin D-sub, DVI-D Plug & Play DDCDDC/CI Power SupplyAC 90~264 V (47 ~ 63Hz) Power Consumption On33W Stand-by / Suspend1W DPM Off1W User Control TypeTact ButtonMenu(1), Source(1), f-Engine(1), Auto/Set(1), Power(1) Functionsf-Engine, sRGB, Auto Resolution Mechanical Dimension(W x H x D)402 x 408 x 180 mm Weight3.6kg StandTilt(Detachable) RackVESA 75 x 75 Regulations SafetyUL,UL-cUL,TUV-GS,SEMCO EMCFCC-B,CE Low radiationTCO-03 Power savingEPA Energy Star PHILIPS 190C8FS - 1599kn ![]() SPECIFIKACIJA: LCD tip zaslona 1280 x 1024 pixela, Anti glare polarizer, RGB vertical stripe Veličina zaslona: 19" / 48 cm Efektivna vidljivost: 376.3 x 301.1 mm Veličina pixela: 0.294 x 0.294 mm Osvjetljenje: 300 cd/m2 Odnos kontrasta: 800:1 Odnos kontrasta dinamički: 3000:1 Prikaz boja: 16.7M Kut pregleda (H 160°) - (V 160°) Vrijeme odziva: 5ms (crna do crne) Maksimalna rezolucija: 1280 x 1024 @ 75 Hz Preporučena rezolucija: 1280 x 1024 @ 60 Hz frekvencija: (H 30 - 83 KHz) - (V 56 - 76 Hz) sRGB Signalni ulaz: VGA (analogni), DVI-D (digitalni) Predviđen vijek trajanja: 50,000 sati Dimenzije: 442 x 420 x 201 mm Težina: 5.3kg MOGUĆNOSTI: SmartImage tehnologija koja analizira što je prikazano na ekranu te na osnovu toga dinamički podešava kontrast SmartContrast automatski podešava boje i kontrast HDCP ready High-Bandwidth Digital Content Protection (HDCP) zaštita digitalnog sadržaja PerfecTune tehnologija koja bolje podešava algoritam monitora SmartControl II grafičko sučelje koje pomaže pri podešavanju rezolucije, boja isl. Dupli video ulaz Flame retardant cabinet PAKIRANJE: VGA kabel Kabel za napajanje Upute |
Agent 0
Lokacija: Kutina - ZG
Postovi: 4,312
Philips uzmi. U pravilu je bolji, a sada ako imaš vremena...pogledaj oba i testiraj što te zanima. (specifikacije ne gledaj jer dreq znače) Nemoj zaboraviti provjeriti da nema probijanja pozadinskog osvjetljenja te da nema mrtvih pixela. ![]() |
Lokacija: Republica Crikvenica
Postovi: 1,194
uzmi Philipsa...imao sam ga ,, ima perfektne boje obzirom na matricu, pravi GAME monitor...za siću... |
Postovi: 29
uzeo LG odličan je..1953TR...2ms..DVI...500:1 DFC itd.. jako zadovoljan |
