Staro 28.10.2007., 19:24   #1
MitO_ZGB
Postovi: 41
LG H62N problem sa snimanjem CD-a
Kao kaj piše u naslovu, imam problema s pržilicom...pržilica je LG-GSA-H62N
naime, može i normalno čita DVD-e i CD-e, najnormalnije prži DVD-e, ali CD-e neće pržiti....
uvijek baci istu grešku.... probal sam i s različitim verzijama nere, i s još nekim programima za prženje, i različitim medijima, ali uvijek ista stvar...
najveći problem mi je kaj sam proguglal sve moguće stranice....ali 99% ljudi ima problem s tim da može pržiti CD-e ali ne i dvd....a kod mene je obratno....
pa ak bi netko znal neki koristan savjet, rješenje..?
evo kaj piše u logu od nere...nakon greške..
CueSheet
13:10:22 #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
13:10:22 #2 Text 0 File Burncd.cpp, Line 3212
HL-DT-ST DVDRAM GSA-H62N
Buffer underrun protection activated
13:10:22 #3 Text 0 File Burncd.cpp, Line 3530
Turn on Disc-At-Once, using CD-R/RW media
13:11:01 #4 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 284106 ( 63:10.06)
13:11:01 #5 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
13:11:01 #6 Text 0 File DlgWaitCD.cpp, Line 2972
Recorder: HL-DT-ST DVDRAM GSA-H62N;
CDR code: 00 97 27 28; OSJ entry from: Princo Corporation
ATIP Data:
Special Info [hex] 1: F0 00 80, 2: 61 1B 1C (LI 97:27.28), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
13:11:01 #7 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
Insert empty disc to write to.
(Medium in drive: Unknown. Medium required by compilation: CD-R/RW.)
13:11:01 #8 Text 0 File ThreadedTransferInterface.cpp, Line 785
Setup items (after recorder preparation)
0: TRM_DATA_RAW_MODE1 (Cue Sheet Track)
2 indices, index0 (150) provided
original disc pos #0 + 284107 (284107) = #284107/63:8.7
relocatable, disc pos for caching/writing not required/not required
-> TRM_DATA_RAW_MODE1, 2352, config 0, wanted index0 0 blocks, length 284107 blocks [G: HL-DT-ST DVDRAM GSA-H62N]
13:11:01 #9 Text 0 File Burncd.cpp, Line 4135
Can only write at 4.800 KB/s instead of 7.200 KB/s to current disc.
13:11:01 #10 Text 0 File ThreadedTransferInterface.cpp, Line 986
Prepare [G: HL-DT-ST DVDRAM GSA-H62N] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_RAW_MODE1, 2352/0x00, FilePos 0 352800 668572464, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
-150 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
-150 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 284107 | 0 | 0x00
284107 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
13:11:01 #11 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
13:11:01 #12 Text 0 File Burncd.cpp, Line 4316
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
13:11:01 #13 Phase 24 File dlgbrnst.cpp, Line 1764
Caching of files started
13:11:01 #14 Text 0 File Burncd.cpp, Line 4435
Cache writing successful.
13:11:01 #15 Phase 25 File dlgbrnst.cpp, Line 1764
Caching of files completed
13:11:01 #16 Phase 36 File dlgbrnst.cpp, Line 1764
Burn process started at 32x (4.800 KB/s)
13:11:01 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2735
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
13:11:01 #18 Text 0 File MMC.cpp, Line 17745
StartDAO : CD-Text - Off
13:11:01 #19 Text 0 File MMC.cpp, Line 22430
Set BUFE: Buffer underrun protection -> ON
13:11:01 #20 Text 0 File MMC.cpp, Line 17973
CueData, Len=32
41 00 00 14 00 00 00 00
41 01 00 11 00 00 00 00
41 01 01 11 00 00 02 00
41 aa 01 14 00 3f 0a 07
13:11:01 #21 Text 0 File ThreadedTransfer.cpp, Line 268
Pipe memory size 83836800
13:12:21 #22 Text 0 File Cdrdrv.cpp, Line 1367
13:12:21.250 - 㩇䠠ⵌ呄匭⁔噄剄䵁䜠䅓䠭㈶N : Queue again later
13:12:23 #23 SPTI -1039 File SCSIPassThrough.cpp, Line 181
CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1039)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x09
Sense Qual: 0x01
CDB Data: 0x2A 00 FF FF FF 6A 00 00 1B 00 00 00
Sense Area: 0x71 00 04 00 00 00 00 0A 34 14 04 80 09 01
Buffer x04cb1580: Len xf810
0x00 FF FF FF FF FF FF FF FF FF FF 00 00 00 00 01
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
13:12:23 #24 CDR -1039 File Writer.cpp, Line 306
Focus or tracking error
13:12:23 #25 Phase 38 File dlgbrnst.cpp, Line 1764
Burn process failed at 32x (4.800 KB/s)
13:12:23 #26 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
13:12:28 #27 Text 0 File Cdrdrv.cpp, Line 11276
DriveLocker: UnLockVolume completed
13:12:28 #28 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
MitO_ZGB je offline   Reply With Quote
Staro 28.10.2007., 19:37   #2
stopalo9
stopalo9's Avatar
Postovi: 763
probaj ubaciti novi firmwire mozda pomogne
stopalo9 je offline   Reply With Quote
Staro 29.10.2007., 00:42   #3
jollyb
4K FTW
jollyb's Avatar
Lokacija: Minken
Postovi: 1,046
ja sam imao istih problema s H62N, koji sam vratio u ve-mil i dobio u zamjenu H66n koji je opet imao istih problema. više neću uzeti sata snimač nego h42n i dati ga cimeru. jer mi samsung sh-s203n iz linksa radi normalno. savjet, odi do dućana gdje si ga kupio, popričaj sa serviserom i reci da želiš neki drugi snimač
jollyb je offline   Reply With Quote
