Staro 26.10.2007., 15:16   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Radeon Omega Drivers 3.8.421 (Cat 7.10)
What's New in Omega Drivers?
v3.8.421
[*] Based on the Catalyst 7.10 Official drivers.
[+] Added support for ALL the cards that where missing from last release. (Thanks to all the people that sent their unsupported IDs)
[F] Reworked the settings for lots of cards, now the drivers should be more compatible with Mobility chipsets and others.
[+] Added a temporary fix to the AGP problems (some cards not working) until ATI releases an official fix.
What's new for ATI Tray Tools?
v1.3.6.1064 Beta
[F] Fixed localization for CrossFire dialog window[*] Updated ini files handling procedures to be more compatible with Windows Vista[*] Improved compatibility with IE7 under Vista with UAC enabled???
[+] Added new localizations
[+] Added option to change "Black and White level"
[F] Fixed OSD rendering problem with Overlord game. (Thanks to Unwinder)
[+] Updated Overlay color handling procedure to support new ATI Overlay color modes
[+] Implemented Save/Restore icon positions under WinXP 64 and Vista 64.
[+] Updated support for Adaptive AntiAliasing. Added support Multi-Samplinmg and Super-Sampling modes
[+] Monitoring Graphs window now can be sent to system tray.
[+] Added option to auto load Monitoring Graphs window at start up
Trenutno samo za XP/2000 .
http://www.omegadrivers.net/ati/win2k_xp.php
Zadnje izmijenjeno od: Jelc. 26.10.2007. u 15:32.
Staro 29.10.2007., 17:35   #2
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Baš me zanima ovo za AGP kartice..mora da je to ovaj moj crash sa 7.10 i X1950pro kako si i ti rekao na drugom threadu..ovo piše kao temp fix..znači ATi je shebao stvar po n-ti put s driverima...joj joj.....šta kad mi je 7950GT AGP bila preskupa..išao bi na nju,da sam se mogao rastegnuti..
Staro 29.10.2007., 17:40   #3
Jelc
Super Moderators
Postovi: 17,485
Pa, probaj drivere pa vidi
Staro 29.10.2007., 20:14   #4
thedream
thedream's Avatar
Postovi: 5,458
ne znam šta je ovaj rus napravio..al zadržat ću ove najnovije omege,sve radi 5-10fpsa čak bolje na mojoj X1950pro za razliku od službenjaka 7.10..weird skroz...igrao 2h WoW,nijedan crash..a clockan proc, clockan ram..psu drži zasad radeonku..vidjet ćemo do kada..
omege i att su stvarno zakon,probao sam ih sa 9800pro prvi put..recommended,nema šta...
samo me živo zanima šta je zeznuo ATi sa AGP karticama..u zadnjim driverima..di je puklo..kao,da će izaći neki hotfix uskoro..ali omege nude temporary rješenje..koje očito radi..1h igrao i fifu2008 i nfs carbon..bez crashanja..a fpsi..leti sve..
Staro 29.10.2007., 20:22   #5
Baja 001
Baja 001's Avatar
Postovi: 7,504
OMEGE su najbolje, vrlo su bolje od originalnih Catalysta.Bolje performanse i sve gluposti koje ATI ne zakrpi!
Staro 29.10.2007., 21:05   #6
zippo
herr Flick
zippo's Avatar
Postovi: 2,085
Ohoho
Rus je nesto ubrzao rad
@edit
hmmmmmmmmmm
nikad nisam imao toliko problema sa Omegom. 3 puta sam instalirao, cistio itd i na kraju rucno iz Device managera morao dovrsiti posao
Nisam bas optimistican kako ce to ici, vidjet cu veceras u CoD2
Uglavnom uvijek do sada Omege su mi se instalirale ko po spagi ali ove .....
Ko zna kakvu je sfusanu Votku namijesao u njih
.:S:T:A:L:K:E:R:.. :2 u ocekivanju
nema vise zippacha ......
Zadnje izmijenjeno od: zippo. 29.10.2007. u 23:03.
zippo je offline   Reply With Quote
Staro 29.10.2007., 23:04   #7
Jelc
Super Moderators
Postovi: 17,485
Tko još jedamput napiše da je Angel RUS osvaja
Zove se Angel a živi u Puerto Ricu
Dobro da ga niste u eskima prekrstili
Staro 29.10.2007., 23:08   #8
zippo
herr Flick
zippo's Avatar
Postovi: 2,085
Autor Jelc Pregled postova
Zvao se ovako ili onako, nesto je lose lokao dok je radio ove Omege
@edit
mozda mu je barba Fidel podvalio kakav pokvareni rum i marlboro umjesto Havane
Staro 29.10.2007., 23:17   #9
Armand
192.168.0.1
Armand's Avatar
Lokacija: BiH
Postovi: 463
De malo pojasni sta se pod ovim podrazumjeva(lo)...zivo me interesuje
P4 3.0 Prescott (Zalman 7000b-cu) @ Gigabyte 8ik1100
2x512 Apacer ddr400
AiW x800xt + vf900
Hitachi 80gb Sata2
Corsair HX520W
Linksys WRT54GL@Tomato 1.25.8515 RAF (Victek Mod)
Armand je offline   Reply With Quote
Staro 29.10.2007., 23:31   #10
Jelc
Super Moderators
Postovi: 17,485
Autor zippo Pregled postova
@edit
Meni su radili ok.
Osim STALKER-a koji je zezao i sa zadnjom revizijom Omege...
Kad imaš krš od grafe...
Staro 29.10.2007., 23:33   #11
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
Samo jedno objašnjenje koje je potrebno s vremena na vrijeme...tip NE piše nikakve drivere, samo mixa postojeće i mijenja inf fajlove
Ja sam probao njegov driver pack negdje 2000-te u vrijeme UT-a, istina je da je bio brži, ali slika je bila ko da imam Nvidiu pa sam se vratio službenim driverima...možda mu opet dam šansu za koju godinu
Staro 29.10.2007., 23:37   #12
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,183
Evo ja isprobao neve omege, i konacno mi proradio Crysis kako spada, prije mi je sve bilo crno..koncno mogu malo igrat..
Staro 30.10.2007., 00:33   #13
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Za one koji ne znaju Jelca prijevod: Oćuuu tuuu grafuuuu! :P
žmnpp
Staro 30.10.2007., 01:16   #14
zippo
herr Flick
zippo's Avatar
Postovi: 2,085
Autor buljo Pregled postova
kad prevedes njegov kineski ispadne tako nekako
Staro 30.10.2007., 01:33   #15
Jelc
Super Moderators
Postovi: 17,485
Kaj će mi ta krampina kad imam ovakvu ljepoticu, tek je navršila godina dana
Staro 30.10.2007., 03:51   #16
Pygm4li0n
Lokacija: Požega
Postovi: 54
e jel netko ikad donir'o nesh tom' tipu preko onih paypal opcija itd. ?
koristim omege vec dvije god. muy zadovoljan i bas mu planiram uplatit kojih 15-20 $ oko Xmasa
Pygm4li0n je offline   Reply With Quote
Staro 30.10.2007., 09:24   #17
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
I moja je imala rođendan ali se valjda toliko urokala da je odapela 2 tjedna nakon... Ahhh jadna, šta je samo uzela (Cod4? )
žmnpp
Staro 30.10.2007., 17:20   #18
thedream
thedream's Avatar
Postovi: 5,458
ma rus je..otkud mi to..pitaj Boga..neka,rade ko urica..puerto rico..fino..znači nemaju samo dobre ženske,nego i programeri rade ko ludi..makar je ovo više hakiranje..
Staro 30.10.2007., 19:49   #19
Armand
192.168.0.1
Armand's Avatar
Lokacija: BiH
Postovi: 463
@ thedream - post broj 9. Nemoj preskakat kad citas, pitanje jos uvjek vazi
2x512 Apacer ddr400
AiW x800xt + vf900
Hitachi 80gb Sata2
Corsair HX520W
Staro 30.10.2007., 20:33   #20
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
E, ja instalirao te omega drivere, a imo prije stare iz 12 mj. 2005 godine...i nikakve razlike nema...?Wierd
Staro 30.10.2007., 21:43   #21
thedream
thedream's Avatar
Postovi: 5,458
Autor Armand Pregled postova
šef ti je napisao u prvom postu cijeli release note..evo ti citat :
ja imao x800xt pe..i radilo,sa 7.10..kupio MSI x1950pro,i neće...srušilo me 10 puta..šta iz igara,šta restart kompa sam od sebe..reko,e nećeš..
Omege su mi wow sa nekih 57-65 digle na 60-70fpsa na 1280x1024,sve full detalji..2xAA..2xAF..
Carbon isto,leti..Fifa 2008..super..meni je pomoglo..
Mislim da je ATi nešto zeznuo,piše ti some cards not working..hebi ga..očito some cards od nekih proizvođača..meni frend ima X1950pro od Sapphirea i njemu radi,zasad..dok evo,pitao drugog,on ima Powercolorku AGP i njemu isti problemi ko meni....ovisi očito od primjerka..kao i uvijek..unutar serije zna se dogodit sranje..
