Staro 24.10.2007., 10:27   #1
Hrubi
Hrubi's Avatar
Datum registracije: Sep 2004
Postovi: 817
Samsung ili Seagate 160GB???
Odlucio sam kupiti novi SATA II hard,pa se premisljam koji od ova dva uzeti?
Za Samsunga znam da je tih,Seagate brz ali problemi sa firmwareom...
Sta da radim ,sta??
Ovaj
http://www.adm.hr/product_info.php?c...oducts_id=4659
ili ovaj
http://www.optimum-online.hr/shop/vi...roduct=A506041
Hrubi je offline   Reply With Quote
Staro 24.10.2007., 13:51   #2
Hrubi
Hrubi's Avatar
Postovi: 817
hvala ,hvala,ne morate se toliko truditi.
Kupio sam Samsunga.
Staro 24.10.2007., 14:05   #3
NJUNJO_HR
NJUNJO_HR's Avatar
Lokacija: Zagreb (Trešnjevka, kod placa)
Postovi: 674
jako dobro pivo(disk)
PCE 100+kg demolition squad
LCD 19'' Philips 190P6 | Coolermaster Stacker ATX/BTX (STC-T01) Black | Corsair HX520
ASRock P55 Extreme | Intel i5 760 | G.Skill F3-12800CL7D-4GBECO 2x2GB | XFX 7950 GT 512MB DDR3
Benq DW1670 & Plextor PX-755A | WD Black 1TB (WD1002FAEX), WD Green 2TB (WD20EARS)
Creative SB Audigy Player SB0090 | TP-Link TL-WN651G
Microsoft Wireless Optical Desktop for Bluetooth (Miš i Tipkovnica) | Razer Copperhead (Green) | Genious KB-16e Black
___ <<< Enchantress >>> ___
Parts of watercooling:
Laing DDC-1 water pump
3x Magicool Extreme radiators
EK-Supreme-Acetal for CPU
EK-NF4 rev1.1 for chipset
EK-FC79 for GPU
EK-Multioption reservoir 400 + EK-Multioption RES Bottom Rev.2
& green tubes.
Loop:
rezervoar / pumpa / GPU / rad1 / NB / rad2 / CPU / rad3 / rezervoar
Par slikica iz galerije
H2O galerija
___ <<< ex Morgoth >>> ___
Parts of ex aircooling:
Celeron 420 | ASRock 4CoreDual-SATA2 | XFX 7900 GS 600M
Thermalright Ultra-120 Extreme for CPU lapped
Thermalright HR-05 IFX for chipset lapped
Thermalright HR-03 PLUS for GPU
Lapping galerija
NJUNJO_HR je offline   Reply With Quote
Staro 24.10.2007., 14:06   #4
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
samsung.
ako vec oces tih 3% brzine uzmi wdaaks.
.i.
Razer Blade 15
Staro 24.10.2007., 14:26   #5
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,113
AAKS se radi tek od 250 GB na više koliko sam ja upućen. Kupio sam i ja te Samsunge i ne primjećujem da je nešto tiši od starog Maxtora kojeg sam imao. Prije stavljanja AAM-a na minimum čak je možda i bio glasniji kod pisanja/čitanja po disku.
Staro 24.10.2007., 17:51   #6
Hrubi
Hrubi's Avatar
Postovi: 817
Staro 24.10.2007., 18:11   #7
Hrubi
Hrubi's Avatar
Postovi: 817
Autor 1v@n Pregled postova
"Prije stavljanja AAM-a na minimum"?
Sto je to AAM?Kaj ima nesto za podesavanje?Gdje?Kako?
Staro 24.10.2007., 18:53   #8
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,113
Pogledaj stickye u vezi hardova. Imaš jedan programčić "Hitachi Tool", skineš ga i spržiš na cd i bootaš s njega. Nađeš tu AAM ( Acoustic Management ) opciju i staviš na minimum ( mislim da ti je skroz lijevo "quiet" a skroz desno "fast" ). To ti dosta utiša hard, ali se još uvijek čuje.
Staro 24.10.2007., 19:39   #9
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
Znam da je kasno vec ali mozda za nekog tko ce citati u buducnosti...
Ja sam starome uzeo WD 160GB AAJS, da sam pri lovi bih odma sutra otisao po bar jedan WD za sebe. Manje od 35C bez venta, necujan cak i u seeku (u masini su 2 venta - u fortronu 350W i 80mm AC na procu, term. reguliran).
Koji si to samsung uzeo? 1604C, 160JJ ili S166?
EDIT: S166
Zadnje izmijenjeno od: Matesonik. 26.10.2007. u 14:39.
Staro 24.10.2007., 19:43   #10
Hrubi
Hrubi's Avatar
Postovi: 817
Autor Matesonik Pregled postova
Koji si to samsung uzeo? 1604C ili S166?
ovaj
http://www.samsung.com/global/busine...down&ppmi=1157
Staro 28.10.2007., 13:01   #11
Uber Gosu
FORD Fix Or Repair Daily
Uber Gosu's Avatar
Postovi: 872
da ne otvaram novi post pitat cu ovdje:
Kako znat da je Samsung HDD T166 srija???
Uber Gosu je offline   Reply With Quote
Staro 28.10.2007., 13:19   #12
Hrubi
Hrubi's Avatar
Postovi: 817
Staro 28.10.2007., 13:22   #13
1v@n
The mighty pirate
1v@n's Avatar
Lokacija: London
Postovi: 9,113
Moji su 160HJ
Staro 28.10.2007., 13:30   #14
Uber Gosu
Uber Gosu's Avatar
Postovi: 872
Autor Hrubi Pregled postova
Ali kad kupujem, znam i ja vidit u HDTu lol, ali me zanima kad ga kupujem u ducanu.
Staro 28.10.2007., 13:32   #15
Hrubi
Hrubi's Avatar
Postovi: 817
Autor Uber Gosu Pregled postova
nazovi i pitaj.Tako sam i ja,i covjek mi je rekao koji je tocno model.
Staro 28.10.2007., 14:37   #16
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,041
Err, pitaš u dućnu da ti ga pokažu prije nego platiš, pa pogledaš na naljepnici?
To sam ja sa svojim napravio.
Sad ćeš me sigurno pitat "a što ako mi neće pokazat???". E, u tom slučaju ih pošalješ na određeno mjesto, i NIKAD više ne uđeš u taj dućan.
Staro 03.11.2007., 10:21   #17
Nik
Nik's Avatar
Postovi: 454
+1
Kupio ga jucer i potpisujem gore navedeno, disk je tih i hladan...za ilustraciju, prije par dana sklopio sam konfiguraciju i u nju stavio Samsunga 160GB i cuje se iz aviona, krevet mi je 5m od kompa i cuje se kako rostva dok spavam...sva sreca da sam ga imao u ruci prije kupovine hdd-a za sebe jer bi odmah isao u (pre)prodaju
